--- ray/src/util/genBSDF.pl 2019/06/09 20:52:13 2.82 +++ ray/src/util/genBSDF.pl 2025/04/04 18:06:48 2.95 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.82 2019/06/09 20:52:13 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.95 2025/04/04 18:06:48 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -13,7 +13,7 @@ sub userror { exit 1; } my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp); -my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph); +my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz); my ($curphase, $recovery); if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) { $td = $ARGV[1]; @@ -57,7 +57,6 @@ if ($windoz) { $rfz = "$td\\rfz.dat"; $tbz = "$td\\tbz.dat"; $rbz = "$td\\rbz.dat"; - $cph = "$td\\phase.txt"; $rmtmp = "rd /S /Q $td"; } else { $radscn = "$td/device.rad"; @@ -80,7 +79,6 @@ if ($windoz) { $rfz = "$td/rfz.dat"; $tbz = "$td/tbz.dat"; $rbz = "$td/rbz.dat"; - $cph = "$td/phase.txt"; $rmtmp = "rm -rf $td"; } my @savedARGV = @ARGV; @@ -165,7 +163,7 @@ if ( !defined $recovery ) { ($tensortree==3 && !($doforw && $doback)); # Get scene description if ( $mgfin ) { - system "mgf2rad @ARGV > $radscn"; + system "mgf2rad -s @ARGV > $radscn"; die "Could not load MGF input\n" if ( $? ); } else { system "xform -e @ARGV > $radscn"; @@ -186,10 +184,7 @@ $wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] ';h=' . ($dim[3] - $dim[2]) . '"'; $wrapper .= " -g $mgfscn" if ( $geout ); # Calculate CIE (u',v') from Radiance RGB: -my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' . - 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' . - 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' . - 'den=Xi+15*Yi+3*Zi;' . +my $CIEuv = 'den=Xi+15*Yi+3*Zi;' . 'uprime=if(Yi,4*Xi/den,4/19);' . 'vprime=if(Yi,9*Yi/den,9/19);' ; my $FEPS = 1e-5; @@ -213,6 +208,7 @@ if ( !defined $recovery ) { printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; close MGFSCN; if ( $mgfin ) { + die "+mgf requires input file with +geom\n" if ($#ARGV < 0); system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn}; } else { system "rad2mgf $radscn >> $mgfscn"; @@ -324,8 +320,9 @@ sub do_ttree_dir { qq{-e "r2=rand(-5.37138*recno+67.1737811)" } . qq{-e "r3=rand(+3.17603772*recno+83.766771)" } . qq{-e "r4=rand(-1.5839226*recno-59.82712)" } . - qq{-e "Dx=1-2*(\$1+r1)/$ns" } . - qq{-e "Dy=if(\$1-.5,1/$ns,sqrt(1-Dx*Dx))*(2*r2-1)" } . + qq{-e "odds(n):if(.5*n-floor(.5*n)-.25,-1,1)"} . + qq{-e "Dx=1-(\$1+r1)/$ns2" } . + qq{-e "Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2" } . qq{-e "Dz=sqrt(1-Dx*Dx-Dy*Dy)" } . qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . @@ -339,15 +336,16 @@ sub do_ttree_dir { qq{-e 'r2=rand(-5.37138*recno+67.1737811)' } . qq{-e 'r3=rand(+3.17603772*recno+83.766771)' } . qq{-e 'r4=rand(-1.5839226*recno-59.82712)' } . - qq{-e 'Dx=1-2*(\$1+r1)/$ns' } . - qq{-e 'Dy=if(\$1-.5,1/$ns,sqrt(1-Dx*Dx))*(2*r2-1)' } . + qq{-e 'odds(n):if(.5*n-floor(.5*n)-.25,-1,1)' } . + qq{-e 'Dx=1-(\$1+r1)/$ns2' } . + qq{-e 'Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2' } . qq{-e 'Dz=sqrt(1-Dx*Dx-Dy*Dy)' } . qq{-e 'xp=(\$3+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' } . qq{-e 'yp=(\$2+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' } . qq{-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' } . qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } . qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } . - "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree"; + "| $rfluxmtx$r -ff -y $ns2 - $receivers -i $octree"; } } else { # Anisotropic BSDF @@ -355,7 +353,7 @@ sub do_ttree_dir { if ($windoz) { $cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree"; } else { - $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree"; + $cmd = "$rfluxmtx$r -ff $sender $receivers -i $octree"; } } if ( $dop ) { @@ -403,55 +401,43 @@ sub ttree_comp { my $dest = shift; my $cmd; if ($windoz) { + $cmd = "rcomb -fa -c xyz $src | rcollate -ho -oc 1" . + q{ | rcalc -e "Xi=$1;Yi=$2;Zi=$3" }; if ("$spec" eq "Visible") { - $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } . - q{-e "Ri=$1;Gi=$2;Bi=$3" } . - qq{-e "$CIEuv" } . + $cmd .= qq{-e "Omega:PI/($ns*$ns)" } . q{-e "$1=Yi/Omega"}; } elsif ("$spec" eq "CIE-u") { - $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } . - qq{-e "$CIEuv" } . + $cmd .= qq{-e "$CIEuv" } . q{-e "$1=uprime"}; } elsif ("$spec" eq "CIE-v") { - $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } . - qq{-e "$CIEuv" } . + $cmd .= qq{-e "$CIEuv" } . q{-e "$1=vprime"}; } } else { + $cmd = "rcomb -ff -c xyz $src | getinfo -" . + q{ | rcalc -if3 -of -e 'Xi=$1;Yi=$2;Zi=$3' }; if ("$spec" eq "Visible") { - $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . - q{-e 'Ri=$1;Gi=$2;Bi=$3' } . - "-e '$CIEuv' " . + $cmd .= "-e 'Omega:PI/($ns*$ns)' " . q{-e '$1=Yi/Omega'}; } elsif ("$spec" eq "CIE-u") { - $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } . - "-e '$CIEuv' " . + $cmd .= "-e '$CIEuv' " . q{-e '$1=uprime'}; } elsif ("$spec" eq "CIE-v") { - $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } . - "-e '$CIEuv' " . + $cmd .= "-e '$CIEuv' " . q{-e '$1=vprime'}; } } if ($pctcull >= 0) { - my $avg = ( $dorecip && "$typ" =~ /^r[fb]/ ) ? " -a" : ""; + my $avg = ( $dorecip && ( $tensortree == 3 || "$typ" =~ /^r[fb]/ ) ) ? " -a" : ""; my $pcull = ("$spec" eq "Visible") ? $pctcull : (100 - (100-$pctcull)*.25) ; if ($windoz) { - $cmd = "rcollate -ho -oc 1 $src | " . - $cmd . - " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2"; + $cmd .= " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2"; } else { - $cmd .= " -of $src " . - "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2"; + $cmd .= " | rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2"; } run_check "$cmd > $dest"; } else { - if ($windoz) { - $cmd = "rcollate -ho -oc 1 $src | " . $cmd ; - } else { - $cmd .= " $src"; - } if ( active_phase() ) { open(DATOUT, "> $dest"); print DATOUT "{\n"; @@ -491,7 +477,7 @@ sub do_matrix_dir { my $dop = do_phase(); my $r = ($dop < 0) ? " -r" : ""; my $sender = ($bsender,$fsender)[$forw]; - my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree"; + my $cmd = "$rfluxmtx$r -ff $sender $receivers -i $octree"; if ( $dop ) { # print STDERR "Running: $cmd\n"; system $cmd; @@ -534,11 +520,11 @@ sub matrix_comp { my $dest = shift; my $cmd = "rmtxop -fa -t"; if ("$spec" eq "Visible") { - $cmd .= " -c 0.2651 0.6701 0.0648"; + $cmd .= " -c y"; } elsif ("$spec" eq "CIE-X") { - $cmd .= " -c 0.5141 0.3239 0.1620"; + $cmd .= " -c x"; } elsif ("$spec" eq "CIE-Z") { - $cmd .= " -c 0.0241 0.1229 0.8530"; + $cmd .= " -c z"; } $cmd .= " $src | getinfo -"; run_check "$cmd > $dest";
