--- ray/src/util/genBSDF.pl 2012/06/14 22:42:21 2.37
+++ ray/src/util/genBSDF.pl 2016/07/13 00:51:17 2.64
@@ -1,37 +1,92 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.37 2012/06/14 22:42:21 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.64 2016/07/13 00:51:17 greg Exp $
# Compute BSDF based on geometry and material description
# G. Ward
use strict;
+my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
exit 1;
-my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
-chomp $td;
+my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
+my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz);
+if ($windoz) {
+ my $tmploc = `echo \%TMP\%`;
+ chomp($tmploc);
+ $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
+ $radscn = "$td\\device.rad";
+ $mgfscn = "$td\\device.mgf";
+ $octree = "$td\\device.oct";
+ $fsender = "$td\\fsender.rad";
+ $bsender = "$td\\bsender.rad";
+ $receivers = "$td\\receivers.rad";
+ $facedat = "$td\\face.dat";
+ $behinddat = "$td\\behind.dat";
+ $tf = "$td\\tf.dat";
+ $rf = "$td\\rf.dat";
+ $tb = "$td\\tb.dat";
+ $rb = "$td\\rb.dat";
+ $tfx = "$td\\tfx.dat";
+ $rfx = "$td\\rfx.dat";
+ $tbx = "$td\\tbx.dat";
+ $rbx = "$td\\rbx.dat";
+ $tfz = "$td\\tfz.dat";
+ $rfz = "$td\\rfz.dat";
+ $tbz = "$td\\tbz.dat";
+ $rbz = "$td\\rbz.dat";
+ chomp $td;
+ $rmtmp = "rd /S /Q $td";
+} else {
+ $td = mkdtemp("/tmp/genBSDF.XXXXXX");
+ chomp $td;
+ $radscn = "$td/device.rad";
+ $mgfscn = "$td/device.mgf";
+ $octree = "$td/device.oct";
+ $fsender = "$td/fsender.rad";
+ $bsender = "$td/bsender.rad";
+ $receivers = "$td/receivers.rad";
+ $facedat = "$td/face.dat";
+ $behinddat = "$td/behind.dat";
+ $tf = "$td/tf.dat";
+ $rf = "$td/rf.dat";
+ $tb = "$td/tb.dat";
+ $rb = "$td/rb.dat";
+ $tfx = "$td/tfx.dat";
+ $rfx = "$td/rfx.dat";
+ $tbx = "$td/tbx.dat";
+ $rbx = "$td/rbx.dat";
+ $tfz = "$td/tfz.dat";
+ $rfz = "$td/rfz.dat";
+ $tbz = "$td/tbz.dat";
+ $rbz = "$td/rbz.dat";
+ $rmtmp = "rm -rf $td";
my @savedARGV = @ARGV;
+my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6";
+my $wrapper = "wrapBSDF";
my $tensortree = 0;
my $ttlog2 = 4;
my $nsamp = 2000;
-my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
my $mgfin = 0;
my $geout = 1;
my $nproc = 1;
+my $docolor = 0;
my $doforw = 0;
my $doback = 1;
my $pctcull = 90;
-my $gunit = "Meter";
+my $gunit = "meter";
+my $curspec = "Visible";
my @dim;
# Get options
while ($#ARGV >= 0) {
if ("$ARGV[0]" =~ /^[-+]m/) {
$mgfin = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" eq "-r") {
- $rtargs = "$rtargs $ARGV[1]";
+ $rfluxmtx .= " $ARGV[1]";
shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
$geout = ("$ARGV[0]" =~ /^\+/);
@@ -40,6 +95,8 @@ while ($#ARGV >= 0) {
die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
shift @ARGV;
+ } elsif ("$ARGV[0]" =~ /^[-+]C/) {
+ $docolor = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
$doforw = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
@@ -47,11 +104,19 @@ while ($#ARGV >= 0) {
} elsif ("$ARGV[0]" eq "-t") {
# Use value < 0 for rttree_reduce bypass
$pctcull = $ARGV[1];
+ if ($pctcull >= 100) {
+ die "Illegal -t culling percentage, must be < 100\n";
shift @ARGV;
} elsif ("$ARGV[0]" =~ /^-t[34]$/) {
$tensortree = substr($ARGV[0], 2, 1);
$ttlog2 = $ARGV[1];
shift @ARGV;
+ } elsif ("$ARGV[0]" eq "-s") {
+ $wrapper .= " -f \"$ARGV[1]\"";
+ shift @ARGV;
+ } elsif ("$ARGV[0]" eq "-W") {
+ $wrapper .= " -W";
} elsif ("$ARGV[0]" eq "-c") {
$nsamp = $ARGV[1];
shift @ARGV;
@@ -71,536 +136,342 @@ while ($#ARGV >= 0) {
# Check that we're actually being asked to do something
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
+# Issue warning for unhandled reciprocity case
+print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
+ ($tensortree==3 && !($doforw && $doback));
+$wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
+$wrapper .= " -u $gunit";
# Get scene description and dimensions
-my $radscn = "$td/device.rad";
-my $mgfscn = "$td/device.mgf";
-my $octree = "$td/device.oct";
if ( $mgfin ) {
- system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
+ system "mgf2rad @ARGV > $radscn";
die "Could not load MGF input\n" if ( $? );
- system "mgf2rad $mgfscn > $radscn";
} else {
system "xform -e @ARGV > $radscn";
die "Could not load Radiance input\n" if ( $? );
- system "rad2mgf $radscn > $mgfscn" if ( $geout );
if ($#dim != 5) {
@dim = split ' ', `getbbox -h $radscn`;
-print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
-# Add receiver surfaces (rectangular)
-my $fmodnm="receiver_face";
-my $bmodnm="receiver_behind";
-open(RADSCN, ">> $radscn");
-print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
-print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
-print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
-print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
-close RADSCN;
+die "Device entirely inside room!\n" if ($dim[4] >= 0);
+if ($dim[5] > 1e-5) {
+ print STDERR "Warning: Device extends into room\n";
+} elsif ($dim[5]*$dim[5] < .01*($dim[1]-$dim[0])*($dim[3]-$dim[2])) {
+ print STDERR "Warning: Device far behind Z==0 plane\n";
+# Assume Zmax==0 to derive thickness so pkgBSDF will work
+$wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
+ ';h=' . ($dim[3] - $dim[2]) . '"';
# Generate octree
system "oconv -w $radscn > $octree";
die "Could not compile scene\n" if ( $? );
-# Output XML prologue
-print
-print "\n";
-print
-'System
- Name
- Manufacturer
-printf "\t\t%.3f\n", $dim[5] - $dim[4];
-printf "\t\t%.3f\n", $dim[1] - $dim[0];
-printf "\t\t%.3f\n", $dim[3] - $dim[2];
-print "\t\tIntegral\n";
-# Output MGF description if requested
+# Add MGF description if requested
if ( $geout ) {
- print "\t\t\n";
- printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
- open(MGFSCN, "< $mgfscn");
- while () { print $_; }
+ open(MGFSCN, "> $mgfscn");
+ printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
close MGFSCN;
- print "xf\n";
- print "\t\t\n";
+ if ( $mgfin ) {
+ system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
+ } else {
+ system "rad2mgf $radscn >> $mgfscn";
+ open(MGFSCN, ">> $mgfscn");
+ print MGFSCN "xf\n";
+ close MGFSCN;
+ $wrapper .= " -g $mgfscn";
-print " \n";
-# Set up surface sampling
-my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
-my $ny = int($nsamp/$nx + .5);
+# Create receiver & sender surfaces (rectangular)
+my $FEPS = 1e-5;
+my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
+my $ny = int($nsamp/$nx + 1);
$nsamp = $nx * $ny;
my $ns = 2**$ttlog2;
-my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
+open(RADSCN, "> $receivers");
+print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
+print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
+print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
+print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
+print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
+print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
+close RADSCN;
+# Finish rfluxmtx command and prepare sender surfaces
+$rfluxmtx .= " -n $nproc -c $nsamp";
+if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
+ open (RADSCN, "> $fsender");
+ print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
+ print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
+ close RADSCN;
+ open (RADSCN, "> $bsender");
+ print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
+ print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
+ printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
+ close RADSCN;
+# Calculate CIE (u',v') from Radiance RGB:
+my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
+ 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
+ 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
+ 'den=Xi+15*Yi+3*Zi;' .
+ 'uprime=4*Xi/den;vprime=9*Yi/den;' ;
# Create data segments (all the work happens here)
if ( $tensortree ) {
do_tree_bsdf();
} else {
do_matrix_bsdf();
-# Output XML epilogue
-print
+# Output XML
+# print STDERR "Running: $wrapper\n";
+system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
+die "Could not wrap BSDF data\n" if ( $? );
# Clean up temporary files and exit
-exec("rm -rf $td");
+exec $rmtmp;
#-------------- End of main program segment --------------#
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
sub do_tree_bsdf {
-# Shirley-Chiu mapping from unit square to disk
-$sq2disk = '
-in_square_a = 2*in_square_x - 1;
-in_square_b = 2*in_square_y - 1;
-in_square_rgn = if(in_square_a + in_square_b,
- if(in_square_a - in_square_b, 1, 2),
- if(in_square_b - in_square_a, 3, 4));
-out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
- -in_square_a, -in_square_b);
-out_disk_phi = PI/4 * select(in_square_rgn,
- in_square_b/in_square_a,
- 2 - in_square_a/in_square_b,
- 4 + in_square_b/in_square_a,
- if(in_square_b*in_square_b,
- 6 - in_square_a/in_square_b, 0));
-Dx = out_disk_r*cos(out_disk_phi);
-Dy = out_disk_r*sin(out_disk_phi);
-Dz = sqrt(1 - out_disk_r*out_disk_r);
-# Shirley-Chiu mapping from unit disk to square
-$disk2sq = '
-norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
-in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
-in_disk_phi = norm_radians(atan2(Dy, Dx));
-in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
-out_square_a = select(in_disk_rgn,
- in_disk_r,
- (PI/2 - in_disk_phi)*in_disk_r/(PI/4),
- -in_disk_r,
- (in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
-out_square_b = select(in_disk_rgn,
- in_disk_phi*in_disk_r/(PI/4),
- in_disk_r,
- (PI - in_disk_phi)*in_disk_r/(PI/4),
- -in_disk_r);
-out_square_x = (out_square_a + 1)/2;
-out_square_y = (out_square_b + 1)/2;
-# Announce ourselves in XML output
-print "\t\n";
-print "\t\tTensorTree$tensortree\n";
-print "\t\n";
-# Start rcontrib processes for compute each side
-do_tree_rtcontrib(0) if ( $doback );
-do_tree_rtcontrib(1) if ( $doforw );
+ # Run rfluxmtx processes to compute each side
+ do_ttree_dir(0) if ( $doback );
+ do_ttree_dir(1) if ( $doforw );
} # end of sub do_tree_bsdf()
-# Run rcontrib process in background to generate tensor tree samples
-sub do_tree_rtcontrib {
+# Call rfluxmtx and process tensor tree BSDF for the given direction
+sub do_ttree_dir {
my $forw = shift;
- my $matargs = "-m $bmodnm";
- if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
- my $cmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
- "-e '$disk2sq' -bn '$ns*$ns' " .
- "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
- "-o $td/%s.flt $matargs $octree";
+ my $cmd;
if ( $tensortree == 3 ) {
# Isotropic BSDF
my $ns2 = $ns / 2;
- $cmd = "cnt $ns2 $ny $nx " .
- "| rcalc -e 'r1=rand(.8681*recno-.673892)' " .
- "-e 'r2=rand(-5.37138*recno+67.1737811)' " .
- "-e 'r3=rand(+3.17603772*recno+83.766771)' " .
- "-e 'Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
- "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
- "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
- "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
- "| $cmd";
+ if ($windoz) {
+ $cmd = "cnt $ns2 $ny $nx " .
+ qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
+ qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
+ qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
+ qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
+ qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
+ qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
+ qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
+ qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
+ qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
+ "| $rfluxmtx -fa -y $ns2 - $receivers -i $octree";
+ } else {
+ qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
+ qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
+ "| $rfluxmtx -h -ff -y $ns2 - $receivers -i $octree";
} else {
# Anisotropic BSDF
- # Sample area vertically to improve load balance, since
- # shading systems usually have bilateral symmetry (L-R)
- $cmd = "cnt $ns $ns $ny $nx " .
- "-e 'r3=rand(3.17603772*recno+83.766771)' " .
- "-e 'r4=rand(-2.3857833*recno-964.72738)' " .
- "-e 'in_square_x=(\$1+r1)/$ns' " .
- "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
- "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "| $cmd";
+ my $sender = ($bsender,$fsender)[$forw];
+ if ($windoz) {
+ $cmd = "$rfluxmtx -fa $sender $receivers -i $octree";
+ } else {
+ $cmd = "$rfluxmtx -h -ff $sender $receivers -i $octree";
-# print STDERR "Starting: $cmd\n";
- system "$cmd" || die "Failure running rcontrib";
+ # print STDERR "Starting: $cmd\n";
+ system $cmd;
+ die "Failure running rfluxmtx" if ( $? );
ttree_out($forw);
-} # end of do_tree_rtcontrib()
+} # end of do_ttree_dir()
-# Simplify and output tensor tree results
+# Simplify and store tensor tree results
sub ttree_out {
my $forw = shift;
- my $side = ("Back","Front")[$forw];
- my $cmd;
-# Only output one transmitted distribution, preferring backwards
-if ( !$forw || !$doback ) {
-print
- System
- Visible
- CIE Illuminant D65 1nm.ssp
- ASTM E308 1931 Y.dsp
- Transmission
- LBNL/Shirley-Chiu
- BTDF
-$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
- q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' };
-if ($pctcull >= 0) {
- $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " .
- "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
- system "$cmd" || die "Failure running rttree_reduce";
-} else {
- $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt";
- print "{\n";
- system "$cmd" || die "Failure running rcalc";
- for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
- print "0\n";
+ my ($refldat,$transdat);
+ if ( $forw ) {
+ $transdat = $facedat;
+ $refldat = $behinddat;
+ } else {
+ $transdat = $behinddat;
+ $refldat = $facedat;
- print "}\n";
-print
-# Output reflection
-print
- System
- Visible
-print "\t\t\tReflection $side\n";
-print
-' LBNL/Shirley-Chiu
- BRDF
- $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " .
-} else {
- $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt";
- print "{\n";
- print "0\n";
+ # Only output one transmitted anisotropic distribution, preferring backwards
+ if ( !$forw || !$doback || $tensortree==3 ) {
+ my $ttyp = ("tb","tf")[$forw];
+ ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
+ if ( $docolor ) {
+ ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
+ ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
- print "}\n";
-print
+ # Output reflection
+ my $rtyp = ("rb","rf")[$forw];
+ ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
+ if ( $docolor ) {
+ ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
+ ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
} # end of ttree_out()
+# Call rttree_reduce on the given component
+sub ttree_comp {
+ my $typ = shift;
+ my $spec = shift;
+ my $src = shift;
+ my $dest = shift;
+ my $cmd;
+ if ($windoz) {
+ if ("$spec" eq "Visible") {
+ $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
+ q{-e "Ri=$1;Gi=$2;Bi=$3" } .
+ qq{-e "$CIEuv" } .
+ q{-e "$1=Yi/Omega"};
+ } elsif ("$spec" eq "CIE-u") {
+ $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
+ q{-e "$1=uprime"};
+ } elsif ("$spec" eq "CIE-v") {
+ q{-e "$1=vprime"};
+ } else {
+ $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
+ q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
+ "-e '$CIEuv' " .
+ q{-e '$1=Yi/Omega'};
+ $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
+ "-e '$CIEuv' " .
+ q{-e '$1=uprime'};
+ "-e '$CIEuv' " .
+ q{-e '$1=vprime'};
+ if ($pctcull >= 0) {
+ my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
+ my $pcull = ("$spec" eq "Visible") ? $pctcull :
+ (100 - (100-$pctcull)*.25) ;
+ if ($windoz) {
+ $cmd = "rcollate -ho -oc 1 $src | " .
+ $cmd .
+ " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
+ } else {
+ $cmd .= " -of $src " .
+ "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
+ # print STDERR "Running: $cmd\n";
+ system "$cmd > $dest";
+ die "Failure running rttree_reduce" if ( $? );
+ } else {
+ if ($windoz) {
+ $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
+ } else {
+ $cmd .= " $src";
+ open(DATOUT, "> $dest");
+ print DATOUT "{\n";
+ close DATOUT;
+ system "$cmd >> $dest";
+ die "Failure running rcalc" if ( $? );
+ open(DATOUT, ">> $dest");
+ for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
+ print DATOUT "0\n";
+ print DATOUT "}\n";
+ close DATOUT;
+ if ( "$spec" ne "$curspec" ) {
+ $wrapper .= " -s $spec";
+ $curspec = $spec;
+ $wrapper .= " -$typ $dest";
+} # end of ttree_comp()
#------------- End of do_tree_bsdf() & subroutines -------------#
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
sub do_matrix_bsdf {
-# Set up sampling of portal
-# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
-$tcal = '
-DEGREE : PI/180;
-sq(x) : x*x;
-Kpola(r) : select(r+1, 0, 5, 15, 25, 35, 45, 55, 65, 75, 90);
-Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
-Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
-Kmax : Kaccum(Knaz(0));
-Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
-Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
-Kcol = Kbin - Kaccum(Krow-1);
-Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
-Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
-sin_kpol = sin(Kpol);
-Dx = cos(Kazi)*sin_kpol;
-Dy = sin(Kazi)*sin_kpol;
-Dz = sqrt(1 - sin_kpol*sin_kpol);
-KprojOmega = PI * if(Kbin-.5,
- (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
- 1 - sq(cos(Kpola(1)*DEGREE)));
-# Compute Klems bin from exiting ray direction (forward or backward)
-$kcal = '
-DEGREE : PI/180;
-abs(x) : if(x, x, -x);
-Acos(x) : if(x-1, 0, if(-1-x, PI, acos(x))) / DEGREE;
-posangle(a) : if(-a, a + 2*PI, a);
-Atan2(y,x) : posangle(atan2(y,x)) / DEGREE;
-kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
-knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
-kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
-kfindrow(r, pol) : if(r-kpola(0)+.5, r,
- if(pol-kpola(r), kfindrow(r+1, pol), r) );
-kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
-kbin2(pol,azi) = select(kfindrow(1, pol),
- kazn(azi,360/knaz(1)),
- kaccum(1) + kazn(azi,360/knaz(2)),
- kaccum(2) + kazn(azi,360/knaz(3)),
- kaccum(3) + kazn(azi,360/knaz(4)),
- kaccum(4) + kazn(azi,360/knaz(5)),
- kaccum(5) + kazn(azi,360/knaz(6)),
- kaccum(6) + kazn(azi,360/knaz(7)),
- kaccum(7) + kazn(azi,360/knaz(8)),
- kaccum(8) + kazn(azi,360/knaz(9))
-kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
-my $ndiv = 145;
-# Compute scattering data using rcontrib
-my @tfarr;
-my @rfarr;
-my @tbarr;
-my @rbarr;
-my $cmd;
-my $rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
- "-e '$kcal' -b kbin -bn $ndiv " .
- "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
-my $rccmd = "rcalc -e '$tcal' " .
- "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
- q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' };
-if ( $doforw ) {
-$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
- "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[4]' " .
- q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
- q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
- "| $rtcmd";
-system "$cmd" || die "Failure running: $cmd\n";
-@tfarr = `$rccmd $td/$fmodnm.flt`;
-die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
-@rfarr = `$rccmd $td/$bmodnm.flt`;
-die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
-if ( $doback ) {
- "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[5]' " .
- q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
- q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
- "| $rtcmd";
-@tbarr = `$rccmd $td/$bmodnm.flt`;
-chomp(@tbarr);
-@rbarr = `$rccmd $td/$fmodnm.flt`;
-chomp(@rbarr);
-# Output angle basis
-print
- Columns
- LBNL/Klems Full
- 0
- 1
- 0
- 5
- 10
- 8
- 5
- 15
- 20
- 16
- 15
- 25
- 30
- 20
- 25
- 35
- 40
- 24
- 35
- 45
- 50
- 24
- 45
- 55
- 60
- 24
- 55
- 65
- 70
- 16
- 65
- 75
- 82.5
- 12
- 75
- 90
-if ( $doforw ) {
-print
- System
- Visible
- Transmission Front
- LBNL/Klems Full
- LBNL/Klems Full
- BTDF
-# Output front transmission (transposed order)
-for (my $od = 0; $od < $ndiv; $od++) {
- for (my $id = 0; $id < $ndiv; $id++) {
- print $tfarr[$ndiv*$id + $od], ",\n";
+ do_matrix_dir(0) if ( $doback );
+ do_matrix_dir(1) if ( $doforw );
+} # end of sub do_matrix_bsdf()
+sub do_matrix_dir {
+ my $forw = shift;
+ my $cmd;
+ $cmd = "$rfluxmtx -fd $sender $receivers -i $octree";
+ system $cmd;
+ matrix_out($forw);
+} # end of do_matrix_dir()
+sub matrix_out {
+ my $forw = shift;
+ if ( $forw ) {
+ } else {
- print "\n";
-print
- System
- Visible
- Reflection Front
- LBNL/Klems Full
- LBNL/Klems Full
- BRDF
-# Output front reflection (transposed order)
- print $rfarr[$ndiv*$id + $od], ",\n";
+ # Output transmission
+ matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
+ if ( $docolor ) {
+ matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
+ matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
- print "\n";
-print
-if ( $doback ) {
-print
- System
- Visible
- Transmission Back
- LBNL/Klems Full
- LBNL/Klems Full
- BTDF
-# Output back transmission (transposed order)
- print $tbarr[$ndiv*$id + $od], ",\n";
+ matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
+ if ( $docolor ) {
+ matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
+ matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
- print "\n";
-print
- System
- Visible
- Reflection Back
- LBNL/Klems Full
- LBNL/Klems Full
- BRDF
-# Output back reflection (transposed order)
- print $rbarr[$ndiv*$id + $od], ",\n";
+} # end of matrix_out()
+# Transpose matrix component data and save to file
+sub matrix_comp {
+ my $typ = shift;
+ my $spec = shift;
+ my $src = shift;
+ my $dest = shift;
+ my $cmd = "rmtxop -fa -t";
+ $cmd .= " -c 0.2651 0.6701 0.0648";
+ } elsif ("$spec" eq "CIE-X") {
+ $cmd .= " -c 0.5141 0.3239 0.1620";
+ } elsif ("$spec" eq "CIE-Z") {
+ $cmd .= " -c 0.0241 0.1229 0.8530";
- print "\n";
-print
-#------------- End of do_matrix_bsdf() --------------#
+ $cmd .= " $src | rcollate -ho -oc 145";
+ die "Failure running rmtxop" if ( $? );
+ $curspec = $spec;
+} # end of matrix_comp()
+#------------- End of do_matrix_bsdf() & subroutines --------------#
