--- ray/src/util/genBSDF.pl 2010/09/09 06:02:16 2.3
+++ ray/src/util/genBSDF.pl 2012/10/13 20:15:43 2.40
@@ -1,28 +1,57 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.3 2010/09/09 06:02:16 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.40 2012/10/13 20:15:43 greg Exp $
# Compute BSDF based on geometry and material description
# G. Ward
use strict;
+use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}mgf][{+|-}geom] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
exit 1;
-my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
+my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
chomp $td;
-my $nsamp = 1000;
+my @savedARGV = @ARGV;
+my $tensortree = 0;
+my $ttlog2 = 4;
+my $nsamp = 2000;
+my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
my $mgfin = 0;
my $geout = 1;
my $nproc = 1;
+my $doforw = 0;
+my $doback = 1;
+my $pctcull = 90;
+my $gunit = "Meter";
my @dim;
# Get options
while ($#ARGV >= 0) {
if ("$ARGV[0]" =~ /^[-+]m/) {
$mgfin = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-r") {
+ $rtargs = "$rtargs $ARGV[1]";
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
$geout = ("$ARGV[0]" =~ /^\+/);
+ $gunit = $ARGV[1];
+ if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
+ die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
+ shift @ARGV;
+ } elsif ("$ARGV[0]" =~ /^[-+]f/) {
+ $doforw = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" =~ /^[-+]b/) {
+ $doback = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-t") {
+ # Use value < 0 for rttree_reduce bypass
+ $pctcull = $ARGV[1];
+ shift @ARGV;
+ } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
+ $tensortree = substr($ARGV[0], 2, 1);
+ $ttlog2 = $ARGV[1];
+ shift @ARGV;
} elsif ("$ARGV[0]" eq "-c") {
$nsamp = $ARGV[1];
shift @ARGV;
@@ -31,7 +60,7 @@ while ($#ARGV >= 0) {
shift @ARGV;
} elsif ("$ARGV[0]" =~ /^-d/) {
userror() if ($#ARGV < 6);
- @dim = "@ARGV[1..6]";
+ @dim = @ARGV[1..6];
shift @ARGV for (1..6);
} elsif ("$ARGV[0]" =~ /^[-+]./) {
userror();
@@ -40,6 +69,8 @@ while ($#ARGV >= 0) {
shift @ARGV;
+# Check that we're actually being asked to do something
+die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
# Get scene description and dimensions
my $radscn = "$td/device.rad";
my $mgfscn = "$td/device.mgf";
@@ -49,33 +80,267 @@ if ( $mgfin ) {
die "Could not load MGF input\n" if ( $? );
system "mgf2rad $mgfscn > $radscn";
} else {
- system "cat @ARGV | xform -e > $radscn";
+ system "xform -e @ARGV > $radscn";
die "Could not load Radiance input\n" if ( $? );
system "rad2mgf $radscn > $mgfscn" if ( $geout );
if ($#dim != 5) {
- @dim = split /\s+/, `getbbox -h $radscn`;
- shift @dim;
+ @dim = split ' ', `getbbox -h $radscn`;
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
-# Add receiver surface (rectangle)
-my $modnm="_receiver_black_";
+# Add receiver surfaces (rectangular)
+my $fmodnm="receiver_face";
+my $bmodnm="receiver_behind";
open(RADSCN, ">> $radscn");
-print RADSCN "void glow $modnm\n0\n0\n4 0 0 0 0\n\n";
-print RADSCN "$modnm polygon _receiver_\n0\n0\n12\n";
-print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
+print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
+print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
close RADSCN;
# Generate octree
system "oconv -w $radscn > $octree";
die "Could not compile scene\n" if ( $? );
-# Set up sampling
+# Output XML prologue
+print
+print "\n";
+print
+'System
+BSDF
+ Name
+ Manufacturer
+printf "\t\t%.3f\n", $dim[5] - $dim[4];
+printf "\t\t%.3f\n", $dim[1] - $dim[0];
+printf "\t\t%.3f\n", $dim[3] - $dim[2];
+print "\t\tOther\n";
+print " \n";
+# Output MGF description if requested
+if ( $geout ) {
+ print "\t\n";
+ print "\t\t\n";
+ printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
+ open(MGFSCN, "< $mgfscn");
+ while () { print $_; }
+ close MGFSCN;
+ print "xf\n";
+ print "\t\t\n";
+ print "\t\n";
+# Set up surface sampling
+my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
+my $ny = int($nsamp/$nx + .5);
+$nsamp = $nx * $ny;
+my $ns = 2**$ttlog2;
+my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
+# Create data segments (all the work happens here)
+if ( $tensortree ) {
+ do_tree_bsdf();
+} else {
+ do_matrix_bsdf();
+# Output XML epilogue
+print
+# Clean up temporary files and exit
+exec("rm -rf $td");
+#-------------- End of main program segment --------------#
+#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
+sub do_tree_bsdf {
+# Shirley-Chiu mapping from unit square to disk
+$sq2disk = '
+in_square_a = 2*in_square_x - 1;
+in_square_b = 2*in_square_y - 1;
+in_square_rgn = if(in_square_a + in_square_b,
+ if(in_square_a - in_square_b, 1, 2),
+ if(in_square_b - in_square_a, 3, 4));
+out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
+ -in_square_a, -in_square_b);
+out_disk_phi = PI/4 * select(in_square_rgn,
+ in_square_b/in_square_a,
+ 2 - in_square_a/in_square_b,
+ 4 + in_square_b/in_square_a,
+ if(in_square_b*in_square_b,
+ 6 - in_square_a/in_square_b, 0));
+Dx = out_disk_r*cos(out_disk_phi);
+Dy = out_disk_r*sin(out_disk_phi);
+Dz = sqrt(1 - out_disk_r*out_disk_r);
+# Shirley-Chiu mapping from unit disk to square
+$disk2sq = '
+norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
+in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
+in_disk_phi = norm_radians(atan2(Dy, Dx));
+in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
+out_square_a = select(in_disk_rgn,
+ in_disk_r,
+ (PI/2 - in_disk_phi)*in_disk_r/(PI/4),
+ -in_disk_r,
+ (in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
+out_square_b = select(in_disk_rgn,
+ in_disk_phi*in_disk_r/(PI/4),
+ in_disk_r,
+ (PI - in_disk_phi)*in_disk_r/(PI/4),
+ -in_disk_r);
+out_square_x = (out_square_a + 1)/2;
+out_square_y = (out_square_b + 1)/2;
+# Announce ourselves in XML output
+print "\t\n";
+print "\t\tTensorTree$tensortree\n";
+print "\t\n";
+# Start rcontrib processes for compute each side
+do_tree_rtcontrib(0) if ( $doback );
+do_tree_rtcontrib(1) if ( $doforw );
+} # end of sub do_tree_bsdf()
+# Run rcontrib process to generate tensor tree samples
+sub do_tree_rtcontrib {
+ my $forw = shift;
+ my $matargs = "-m $bmodnm";
+ if ( !$forw || !$doback || $tensortree==3 ) { $matargs .= " -m $fmodnm"; }
+ my $cmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
+ "-e '$disk2sq' -bn '$ns*$ns' " .
+ "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
+ "-o $td/%s.flt $matargs $octree";
+ if ( $tensortree == 3 ) {
+ # Isotropic BSDF
+ my $ns2 = $ns / 2;
+ $cmd = "cnt $ns2 $ny $nx " .
+ "| rcalc -e 'r1=rand(.8681*recno-.673892)' " .
+ "-e 'r2=rand(-5.37138*recno+67.1737811)' " .
+ "-e 'r3=rand(+3.17603772*recno+83.766771)' " .
+ "-e 'Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
+ "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
+ "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
+ "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
+ "| $cmd";
+ } else {
+ # Anisotropic BSDF
+ # Sample area vertically to improve load balance, since
+ # shading systems usually have bilateral symmetry (L-R)
+ $cmd = "cnt $ns $ns $ny $nx " .
+ "-e 'r3=rand(3.17603772*recno+83.766771)' " .
+ "-e 'r4=rand(-2.3857833*recno-964.72738)' " .
+ "-e 'in_square_x=(\$1+r1)/$ns' " .
+ "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
+ "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "| $cmd";
+# print STDERR "Starting: $cmd\n";
+ system "$cmd" || die "Failure running rcontrib";
+ ttree_out($forw);
+} # end of do_tree_rtcontrib()
+# Simplify and output tensor tree results
+sub ttree_out {
+ my $forw = shift;
+ my $side = ("Back","Front")[$forw];
+ my $cmd;
+# Only output one transmitted anisotropic distribution, preferring backwards
+if ( !$forw || !$doback || $tensortree==3 ) {
+print
+ System
+ Visible
+ CIE Illuminant D65 1nm.ssp
+ ASTM E308 1931 Y.dsp
+print "\t\t\tTransmission $side\n";
+print
+' LBNL/Shirley-Chiu
+ BTDF
+$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
+ q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' };
+if ($pctcull >= 0) {
+ $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " .
+ "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
+ system "$cmd" || die "Failure running rttree_reduce";
+} else {
+ $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt";
+ print "{\n";
+ system "$cmd" || die "Failure running rcalc";
+ for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
+ print "0\n";
+ print "}\n";
+print
+# Output reflection
+print
+ System
+ Visible
+print "\t\t\tReflection $side\n";
+print
+ BTDF
+ $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " .
+} else {
+ $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt";
+ print "{\n";
+ print "0\n";
+ print "}\n";
+print
+} # end of ttree_out()
+#------------- End of do_tree_bsdf() & subroutines -------------#
+#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
+sub do_matrix_bsdf {
+# Set up sampling of portal
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
-my $tcal = '
+$tcal = '
DEGREE : PI/180;
-Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
+sq(x) : x*x;
+Kpola(r) : select(r+1, 0, 5, 15, 25, 35, 45, 55, 65, 75, 90);
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
Kmax : Kaccum(Knaz(0));
@@ -85,19 +350,20 @@ Kcol = Kbin - Kaccum(Krow-1);
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
sin_kpol = sin(Kpol);
-Dx = -cos(Kazi)*sin_kpol;
+Dx = cos(Kazi)*sin_kpol;
Dy = sin(Kazi)*sin_kpol;
Dz = sqrt(1 - sin_kpol*sin_kpol);
-Komega = 2*PI*if(Kbin-.5,
- (cos(Kpola(Krow-1)*DEGREE) - cos(Kpola(Krow)*DEGREE))/Knaz(Krow),
- 1 - cos(Kpola(1)*DEGREE));
+KprojOmega = PI * if(Kbin-.5,
+ (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
+ 1 - sq(cos(Kpola(1)*DEGREE)));
-# Compute Klems bin from exiting ray direction
-my $kcal = '
+# Compute Klems bin from exiting ray direction (forward or backward)
+$kcal = '
DEGREE : PI/180;
-Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
+abs(x) : if(x, x, -x);
+Acos(x) : if(x-1, 0, if(-1-x, PI, acos(x))) / DEGREE;
posangle(a) : if(-a, a + 2*PI, a);
-Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
+Atan2(y,x) : posangle(atan2(y,x)) / DEGREE;
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
@@ -115,128 +381,137 @@ kbin2(pol,azi) = select(kfindrow(1, pol),
kaccum(7) + kazn(azi,360/knaz(8)),
kaccum(8) + kazn(azi,360/knaz(9))
-kbin = kbin2(Acos(Dz), Atan2(Dy, -Dx));
+kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
my $ndiv = 145;
-my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
-my $ny = int($nsamp/$nx + .5);
-$nsamp = $nx * $ny;
-# Compute scattering data using rtcontrib
-my $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
+# Compute scattering data using rcontrib
+my @tfarr;
+my @rfarr;
+my @tbarr;
+my @rbarr;
+my $cmd;
+my $rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
+ "-e '$kcal' -b kbin -bn $ndiv " .
+ "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
+my $rccmd = "rcalc -e '$tcal' " .
+ "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
+ q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' };
+if ( $doforw ) {
+$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
+ "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp:$dim[4]' " .
+ q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
+ "| $rtcmd";
+system "$cmd" || die "Failure running: $cmd\n";
+@tfarr = `$rccmd $td/$fmodnm.flt`;
+die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
+chomp(@tfarr);
+@rfarr = `$rccmd $td/$bmodnm.flt`;
+die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
+chomp(@rfarr);
+if ( $doback ) {
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[4]-1e-5' " .
+ "-e 'zp:$dim[5]' " .
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
- q{-e '$1=xp;$2=yp;$3=zp;$4=Dx;$5=Dy;$6=Dz' } .
- "| rtcontrib -h -ff -n $nproc -c $nsamp -e '$kcal' -b kbin -bn $ndiv " .
- "-m $modnm -w -ab 5 -ad 700 -lw 3e-6 $octree " .
- "| rcalc -e 'x1:.5;x2:.5;$tcal' -e 'Kbin=floor((recno-1)/$ndiv)' " .
- q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/(Komega*Dz)'};
-my @darr = `$cmd`;
-die "Failure running: $cmd\n" if ( $? );
-# Output XML prologue
-print
- System
- Name
- Manufacturer
-printf "\t\t\t%.3f\n", $dim[5] - $dim[4];
-printf "\t\t\t%.3f\n", $dim[1] - $dim[0];
-printf "\t\t\t%.3f\n", $dim[3] - $dim[2];
-print "\t\t\tIntegral\n";
-# Output MGF description if requested
-if ( $geout ) {
- print "\t\t\t\n";
- printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
- system "cat $mgfscn";
- print "xf\n";
- print "\t\t\t\n";
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
+ "| $rtcmd";
+@tbarr = `$rccmd $td/$bmodnm.flt`;
+chomp(@tbarr);
+@rbarr = `$rccmd $td/$fmodnm.flt`;
+chomp(@rbarr);
-print '
- Columns
+# Output angle basis
+print
+ Columns
LBNL/Klems Full
- 0
- 1
+ 0
+ 1
0
5
- 10
- 8
- 5
- 15
- 20
- 16
- 15
- 25
- 30
- 20
- 25
- 35
- 40
- 24
- 35
- 45
- 50
- 24
- 45
- 55
- 60
- 24
- 55
- 65
- 70
- 16
- 65
- 75
- 82.5
- 12
- 75
- 90
+ 10
+ 8
+ 5
+ 15
+ 20
+ 16
+ 15
+ 25
+ 30
+ 20
+ 25
+ 35
+ 40
+ 24
+ 35
+ 45
+ 50
+ 24
+ 45
+ 55
+ 60
+ 24
+ 55
+ 65
+ 70
+ 16
+ 65
+ 75
+ 82.5
+ 12
+ 75
+ 90
+if ( $doforw ) {
+print
System
Visible
@@ -248,21 +523,91 @@ print '
BTDF
-# Output computed data (transposed order)
+# Output front transmission (transposed order)
for (my $od = 0; $od < $ndiv; $od++) {
for (my $id = 0; $id < $ndiv; $id++) {
- print $darr[$ndiv*$id + $od];
+ print $tfarr[$ndiv*$id + $od], ",\n";
print "\n";
-# Output XML epilogue
print
+ System
+ Visible
+ Reflection Front
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BTDF
-# Clean up temporary files
-system "rm -rf $td";
+# Output front reflection (transposed order)
+for (my $od = 0; $od < $ndiv; $od++) {
+ for (my $id = 0; $id < $ndiv; $id++) {
+ print $rfarr[$ndiv*$id + $od], ",\n";
+ print "\n";
+print
+if ( $doback ) {
+print
+ System
+ Visible
+ Transmission Back
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BTDF
+# Output back transmission (transposed order)
+ print $tbarr[$ndiv*$id + $od], ",\n";
+ print "\n";
+print
+ System
+ Visible
+ Reflection Back
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BTDF
+# Output back reflection (transposed order)
+ print $rbarr[$ndiv*$id + $od], ",\n";
+ print "\n";
+print
+#------------- End of do_matrix_bsdf() --------------#
