--- ray/src/util/genBSDF.pl 2010/12/09 06:14:04 2.4
+++ ray/src/util/genBSDF.pl 2011/04/16 01:13:22 2.14
@@ -1,28 +1,39 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.4 2010/12/09 06:14:04 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.14 2011/04/16 01:13:22 greg Exp $
# Compute BSDF based on geometry and material description
# G. Ward
use strict;
+use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}mgf][{+|-}geom] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
exit 1;
-my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
+my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
chomp $td;
my $nsamp = 1000;
+my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
my $mgfin = 0;
my $geout = 1;
my $nproc = 1;
+my $doforw = 0;
+my $doback = 1;
my @dim;
# Get options
while ($#ARGV >= 0) {
if ("$ARGV[0]" =~ /^[-+]m/) {
$mgfin = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-r") {
+ $rtargs = "$rtargs $ARGV[1]";
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
$geout = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" =~ /^[-+]f/) {
+ $doforw = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" =~ /^[-+]b/) {
+ $doback = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" eq "-c") {
$nsamp = $ARGV[1];
shift @ARGV;
@@ -31,7 +42,7 @@ while ($#ARGV >= 0) {
shift @ARGV;
} elsif ("$ARGV[0]" =~ /^-d/) {
userror() if ($#ARGV < 6);
- @dim = "@ARGV[1..6]";
+ @dim = @ARGV[1..6];
shift @ARGV for (1..6);
} elsif ("$ARGV[0]" =~ /^[-+]./) {
userror();
@@ -40,6 +51,8 @@ while ($#ARGV >= 0) {
shift @ARGV;
+# Check that we're actually being asked to do something
+die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
# Get scene description and dimensions
my $radscn = "$td/device.rad";
my $mgfscn = "$td/device.mgf";
@@ -49,32 +62,31 @@ if ( $mgfin ) {
die "Could not load MGF input\n" if ( $? );
system "mgf2rad $mgfscn > $radscn";
} else {
- system "cat @ARGV | xform -e > $radscn";
+ system "xform -e @ARGV > $radscn";
die "Could not load Radiance input\n" if ( $? );
system "rad2mgf $radscn > $mgfscn" if ( $geout );
if ($#dim != 5) {
- @dim = split /\s+/, `getbbox -h $radscn`;
- shift @dim;
+ @dim = split ' ', `getbbox -h $radscn`;
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
-# Add receiver surface (rectangle)
-my $modnm="_receiver_black_";
+# Add receiver surfaces (rectangular)
+my $fmodnm="receiver_face";
+my $bmodnm="receiver_behind";
open(RADSCN, ">> $radscn");
-print RADSCN "void glow $modnm\n0\n0\n4 0 0 0 0\n\n";
-print RADSCN "$modnm polygon _receiver_\n0\n0\n12\n";
-print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
+print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
+print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
close RADSCN;
# Generate octree
system "oconv -w $radscn > $octree";
die "Could not compile scene\n" if ( $? );
-# Set up sampling
+# Set up sampling of interior portal
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
my $tcal = '
DEGREE : PI/180;
+sq(x) : x*x;
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
@@ -85,16 +97,17 @@ Kcol = Kbin - Kaccum(Krow-1);
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
sin_kpol = sin(Kpol);
-Dx = -cos(Kazi)*sin_kpol;
+Dx = cos(Kazi)*sin_kpol;
Dy = sin(Kazi)*sin_kpol;
Dz = sqrt(1 - sin_kpol*sin_kpol);
-Komega = 2*PI*if(Kbin-.5,
- (cos(Kpola(Krow-1)*DEGREE) - cos(Kpola(Krow)*DEGREE))/Knaz(Krow),
- 1 - cos(Kpola(1)*DEGREE));
+KprojOmega = PI * if(Kbin-.5,
+ (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
+ 1 - sq(cos(Kpola(1)*DEGREE)));
-# Compute Klems bin from exiting ray direction
+# Compute Klems bin from exiting ray direction (forward or backward)
my $kcal = '
DEGREE : PI/180;
+abs(x) : if(x, x, -x);
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
posangle(a) : if(-a, a + 2*PI, a);
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
@@ -115,26 +128,52 @@ kbin2(pol,azi) = select(kfindrow(1, pol),
kaccum(7) + kazn(azi,360/knaz(8)),
kaccum(8) + kazn(azi,360/knaz(9))
-kbin = kbin2(Acos(Dz), Atan2(Dy, -Dx));
+kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
my $ndiv = 145;
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
my $ny = int($nsamp/$nx + .5);
$nsamp = $nx * $ny;
# Compute scattering data using rtcontrib
-my $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
+my @tfarr;
+my @rfarr;
+my @tbarr;
+my @rbarr;
+my $cmd;
+my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
+ "-e '$kcal' -b kbin -bn $ndiv " .
+ "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
+my $rccmd = "rcalc -e '$tcal' " .
+ "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
+ q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
+if ( $doforw ) {
+$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
+ "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp:$dim[4]' " .
+ q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
+ "| $rtcmd";
+system "$cmd" || die "Failure running: $cmd\n";
+@tfarr = `$rccmd $td/$fmodnm.flt`;
+die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
+@rfarr = `$rccmd $td/$bmodnm.flt`;
+die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
+if ( $doback ) {
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[4]-1e-5' " .
+ "-e 'zp:$dim[5]' " .
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
- q{-e '$1=xp;$2=yp;$3=zp;$4=Dx;$5=Dy;$6=Dz' } .
- "| rtcontrib -h -ff -n $nproc -c $nsamp -e '$kcal' -b kbin -bn $ndiv " .
- "-m $modnm -w -ab 5 -ad 700 -lw 3e-6 $octree " .
- "| rcalc -e 'x1:.5;x2:.5;$tcal' " .
- "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-1,$ndiv)' " .
- q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/(Komega*Dz)'};
-my @darr = `$cmd`;
-die "Failure running: $cmd\n" if ( $? );
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
+ "| $rtcmd";
+@tbarr = `$rccmd $td/$bmodnm.flt`;
+@rbarr = `$rccmd $td/$fmodnm.flt`;
# Output XML prologue
print
@@ -154,7 +193,9 @@ print "\t\t\tIntegral\n";
if ( $geout ) {
print "\t\t\t\n";
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
- system "cat $mgfscn";
+ open(MGFSCN, "< $mgfscn");
+ while () { print $_; }
+ close MGFSCN;
print "xf\n";
print "\t\t\t\n";
@@ -237,7 +278,9 @@ print '
+if ( $doforw ) {
+print '
System
Visible
CIE Illuminant D65 1nm.ssp
@@ -249,19 +292,93 @@ print '
BTDF
-# Output computed data (transposed order)
+# Output front transmission (transposed order)
for (my $od = 0; $od < $ndiv; $od++) {
for (my $id = 0; $id < $ndiv; $id++) {
- print $darr[$ndiv*$id + $od];
+ print $tfarr[$ndiv*$id + $od];
print "\n";
-# Output XML epilogue
print
+ System
+ Visible
+ CIE Illuminant D65 1nm.ssp
+ ASTM E308 1931 Y.dsp
+ Reflection Front
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BRDF
+# Output front reflection (transposed order)
+for (my $od = 0; $od < $ndiv; $od++) {
+ for (my $id = 0; $id < $ndiv; $id++) {
+ print $rfarr[$ndiv*$id + $od];
+ print "\n";
+print
+if ( $doback ) {
+print '
+ System
+ Visible
+ Transmission Back
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BTDF
+# Output back transmission (transposed order)
+ print $tbarr[$ndiv*$id + $od];
+ print "\n";
+print
+ System
+ Visible
+ Reflection Back
+ LBNL/Klems Full
+ LBNL/Klems Full
+ BRDF
+# Output back reflection (transposed order)
+ print $rbarr[$ndiv*$id + $od];
+ print "\n";
+print
+# Output XML epilogue
+print '
