--- ray/src/util/genBSDF.pl 2011/02/21 22:48:51 2.9
+++ ray/src/util/genBSDF.pl 2011/06/24 00:41:51 2.22
@@ -1,34 +1,52 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.9 2011/02/21 22:48:51 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.22 2011/06/24 00:41:51 greg Exp $
# Compute BSDF based on geometry and material description
# G. Ward
use strict;
+use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
exit 1;
-my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
+my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
chomp $td;
+my @savedARGV = @ARGV;
+my $tensortree = 0;
+my $ttlog2 = 4;
my $nsamp = 1000;
+my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
my $mgfin = 0;
my $geout = 1;
my $nproc = 1;
my $doforw = 0;
my $doback = 1;
+my $gunit = "Meter";
my @dim;
# Get options
while ($#ARGV >= 0) {
if ("$ARGV[0]" =~ /^[-+]m/) {
$mgfin = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-r") {
+ $rtargs = "$rtargs $ARGV[1]";
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
$geout = ("$ARGV[0]" =~ /^\+/);
+ $gunit = $ARGV[1];
+ if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
+ die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
$doforw = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
$doback = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
+ $tensortree = substr($ARGV[0], 2, 1);
+ $ttlog2 = $ARGV[1];
+ shift @ARGV;
} elsif ("$ARGV[0]" eq "-c") {
$nsamp = $ARGV[1];
shift @ARGV;
@@ -47,7 +65,13 @@ while ($#ARGV >= 0) {
shift @ARGV;
# Check that we're actually being asked to do something
-die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
+die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
+# Name our own persist file?
+my $persistfile;
+if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) {
+ $persistfile = "$td/pfile.txt";
+ $rtargs = "-PP $persistfile $rtargs";
# Get scene description and dimensions
my $radscn = "$td/device.rad";
my $mgfscn = "$td/device.mgf";
@@ -57,7 +81,7 @@ if ( $mgfin ) {
die "Could not load MGF input\n" if ( $? );
system "mgf2rad $mgfscn > $radscn";
} else {
- system "cat @ARGV | xform -e > $radscn";
+ system "xform -e @ARGV > $radscn";
die "Could not load Radiance input\n" if ( $? );
system "rad2mgf $radscn > $mgfscn" if ( $geout );
@@ -66,28 +90,267 @@ if ($#dim != 5) {
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
# Add receiver surfaces (rectangular)
-my $bmodnm="receiver_behind";
my $fmodnm="receiver_face";
+my $bmodnm="receiver_behind";
open(RADSCN, ">> $radscn");
-print RADSCN "void glow $fmodnm\n0\n0\n4 0 0 0 0\n\n";
-print RADSCN "$fmodnm polygon f_receiver\n0\n0\n12\n";
-print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[5]+2e-5,"\n";
-print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[5]+2e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[5]+2e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[5]+2e-5,"\n";
-print RADSCN "void glow $bmodnm\n0\n0\n4 0 0 0 0\n\n";
-print RADSCN "$bmodnm polygon b_receiver\n0\n0\n12\n";
-print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[4]-2e-5,"\n";
-print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[4]-2e-5,"\n";
-print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[4]-2e-5,"\n";
-print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[4]-2e-5,"\n";
+print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
+print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
+print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
close RADSCN;
# Generate octree
system "oconv -w $radscn > $octree";
die "Could not compile scene\n" if ( $? );
-# Set up sampling of interior portal
+# Output XML prologue
+print
+print "\n";
+print
+'System
+ Name
+ Manufacturer
+printf "\t\t%.3f\n", $dim[5] - $dim[4];
+printf "\t\t%.3f\n", $dim[1] - $dim[0];
+printf "\t\t%.3f\n", $dim[3] - $dim[2];
+print "\t\tIntegral\n";
+# Output MGF description if requested
+if ( $geout ) {
+ print "\t\t\n";
+ printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
+ open(MGFSCN, "< $mgfscn");
+ while () { print $_; }
+ close MGFSCN;
+ print "xf\n";
+ print "\t\t\n";
+print " \n";
+# Set up surface sampling
+my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
+my $ny = int($nsamp/$nx + .5);
+$nsamp = $nx * $ny;
+my $ns = 2**$ttlog2;
+my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
+# Create data segments (all the work happens here)
+if ( $tensortree ) {
+ do_tree_bsdf();
+} else {
+ do_matrix_bsdf();
+# Output XML epilogue
+print
+# Clean up temporary files and exit
+if ( $persistfile && open(PFI, "< $persistfile") ) {
+ while () {
+ s/^[^ ]* //;
+ kill('ALRM', $_);
+ last;
+ close PFI;
+exec("rm -rf $td");
+#-------------- End of main program segment --------------#
+#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
+sub do_tree_bsdf {
+# Get sampling rate and subdivide task
+my $ns2 = $ns;
+$ns2 /= 2 if ( $tensortree == 3 );
+@pdiv = (0, int($ns2/$nproc));
+my $nrem = $ns2 % $nproc;
+for (my $i = 1; $i < $nproc; $i++) {
+ my $nv = $pdiv[$i] + $pdiv[1];
+ ++$nv if ( $nrem-- > 0 );
+ push @pdiv, $nv;
+die "Script error 1" if ($pdiv[-1] != $ns2);
+# Shirley-Chiu mapping from unit square to disk
+$sq2disk = '
+in_square_a = 2*in_square_x - 1;
+in_square_b = 2*in_square_y - 1;
+in_square_rgn = if(in_square_a + in_square_b,
+ if(in_square_a - in_square_b, 1, 2),
+ if(in_square_b - in_square_a, 3, 4));
+out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
+ -in_square_a, -in_square_b);
+out_disk_phi = PI/4 * select(in_square_rgn,
+ in_square_b/in_square_a,
+ 2 - in_square_a/in_square_b,
+ 4 + in_square_b/in_square_a,
+ if(in_square_b*in_square_b,
+ 6 - in_square_a/in_square_b, 0));
+Dx = out_disk_r*cos(out_disk_phi);
+Dy = out_disk_r*sin(out_disk_phi);
+Dz = sqrt(1 - out_disk_r*out_disk_r);
+# Shirley-Chiu mapping from unit disk to square
+$disk2sq = '
+norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
+in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
+in_disk_phi = norm_radians(atan2(Dy, Dx));
+in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
+out_square_a = select(in_disk_rgn,
+ in_disk_r,
+ (PI/2 - in_disk_phi)*in_disk_r/(PI/4),
+ -in_disk_r,
+ (in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
+out_square_b = select(in_disk_rgn,
+ in_disk_phi*in_disk_r/(PI/4),
+ in_disk_r,
+ (PI - in_disk_phi)*in_disk_r/(PI/4),
+ -in_disk_r);
+out_square_x = (out_square_a + 1)/2;
+out_square_y = (out_square_b + 1)/2;
+# Announce ourselves in XML output
+print "\t\n";
+print "\t\tTensorTree$tensortree\n";
+print "\t\n";
+# Fork parallel rtcontrib processes to compute each side
+if ( $doback ) {
+ for (my $proc = 0; $proc < $nproc; $proc++) {
+ bg_tree_rtcontrib(0, $proc);
+ while (wait() >= 0) {
+ die "rtcontrib process reported error" if ( $? );
+ ttree_out(0);
+if ( $doforw ) {
+ bg_tree_rtcontrib(1, $proc);
+ ttree_out(1);
+} # end of sub do_tree_bsdf()
+# Run i'th rtcontrib process for generating tensor tree samples
+sub bg_tree_rtcontrib {
+ my $pid = fork();
+ die "Cannot fork new process" unless defined $pid;
+ if ($pid > 0) { return $pid; }
+ my $forw = shift;
+ my $pn = shift;
+ my $pbeg = $pdiv[$pn];
+ my $plen = $pdiv[$pn+1] - $pbeg;
+ my $matargs = "-m $bmodnm";
+ if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
+ my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " .
+ "-e '$disk2sq' -bn '$ns*$ns' " .
+ "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
+ "-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree";
+ if ( $tensortree == 3 ) {
+ # Isotropic BSDF
+ $cmd = "cnt $plen $ny $nx " .
+ "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
+ "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
+ "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
+ "-e 'Dx=1-2*($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
+ "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
+ "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
+ "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
+ "| $cmd";
+ } else {
+ # Anisotropic BSDF
+ # Sample area vertically to improve load balance, since
+ # shading systems usually have bilateral symmetry (L-R)
+ $cmd = "cnt $plen $ns $ny $nx " .
+ "-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " .
+ "-e 'in_square_x=($pbeg+\$1+r1)/$ns' " .
+ "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
+ "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "| $cmd";
+# print STDERR "Starting: $cmd\n";
+ exec($cmd); # no return; status report to parent via wait
+ die "Cannot exec: $cmd\n";
+} # end of bg_tree_rtcontrib()
+# Simplify and output tensor tree results
+sub ttree_out {
+ my $forw = shift;
+ my $side = ("Back","Front")[$forw];
+# Only output one transmitted distribution, preferring backwards
+if ( !$forw || !$doback ) {
+print
+ System
+ Visible
+ CIE Illuminant D65 1nm.ssp
+ ASTM E308 1931 Y.dsp
+ Transmission
+ LBNL/Shirley-Chiu
+ BTDF
+system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
+ q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
+ "$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " .
+ "| rttree_reduce -h -ff -r $tensortree -g $ttlog2";
+die "Failure running rttree_reduce" if ( $? );
+print
+# Output reflection
+print
+ System
+ Visible
+print "\t\t\tReflection $side\n";
+print
+' LBNL/Shirley-Chiu
+ BRDF
+ "$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " .
+print
+} # end of ttree_out()
+#------------- End of do_tree_bsdf() & subroutines -------------#
+#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
+sub do_matrix_bsdf {
+# Set up sampling of portal
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
-my $tcal = '
+$tcal = '
DEGREE : PI/180;
sq(x) : x*x;
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
@@ -108,8 +371,9 @@ KprojOmega = PI * if(Kbin-.5,
1 - sq(cos(Kpola(1)*DEGREE)));
# Compute Klems bin from exiting ray direction (forward or backward)
-my $kcal = '
+$kcal = '
DEGREE : PI/180;
+abs(x) : if(x, x, -x);
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
posangle(a) : if(-a, a + 2*PI, a);
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
@@ -130,32 +394,29 @@ kbin2(pol,azi) = select(kfindrow(1, pol),
kaccum(7) + kazn(azi,360/knaz(8)),
kaccum(8) + kazn(azi,360/knaz(9))
-kbin = if(Dz, kbin2(Acos(Dz),Atan2(Dy,Dx)), kbin2(Acos(-Dz),Atan2(-Dy,-Dx)));
+kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
my $ndiv = 145;
-my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
-my $ny = int($nsamp/$nx + .5);
-$nsamp = $nx * $ny;
# Compute scattering data using rtcontrib
my @tfarr;
my @rfarr;
my @tbarr;
my @rbarr;
my $cmd;
-my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
-my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
+my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
"-e '$kcal' -b kbin -bn $ndiv " .
- "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
+ "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
my $rccmd = "rcalc -e '$tcal' " .
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
- q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
+ q{-if3 -e 'oval=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' } .
+ q[-o '${ oval },'];
if ( $doforw ) {
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
- "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[4]-1e-5' " .
- q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
- q{-e '$1=xp;$2=yp;$3=zp;$4=Dx;$5=Dy;$6=Dz' } .
+ "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp:$dim[4]' " .
+ q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
"| $rtcmd";
system "$cmd" || die "Failure running: $cmd\n";
@tfarr = `$rccmd $td/$fmodnm.flt`;
@@ -167,9 +428,9 @@ if ( $doback ) {
- "-e 'zp:$dim[5]+1e-5' " .
+ "-e 'zp:$dim[5]' " .
- q{-e '$1=xp;$2=yp;$3=zp;$4=-Dx;$5=-Dy;$6=-Dz' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
"| $rtcmd";
@tbarr = `$rccmd $td/$bmodnm.flt`;
@@ -177,40 +438,18 @@ die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $
@rbarr = `$rccmd $td/$fmodnm.flt`;
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
-# Output XML prologue
+# Output angle basis
print
- System
- Name
- Manufacturer
-printf "\t\t\t%.3f\n", $dim[5] - $dim[4];
-printf "\t\t\t%.3f\n", $dim[1] - $dim[0];
-printf "\t\t\t%.3f\n", $dim[3] - $dim[2];
-print "\t\t\tIntegral\n";
-# Output MGF description if requested
-if ( $geout ) {
- print "\t\t\t\n";
- printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
- system "cat $mgfscn";
- print "xf\n";
- print "\t\t\t\n";
-print '
- Columns
+ Columns
LBNL/Klems Full
0
1
- 0
- 5
+ 0
+ 5
@@ -281,7 +520,8 @@ print '
if ( $doforw ) {
-print '
+print
System
Visible
@@ -301,8 +541,8 @@ for (my $od = 0; $od < $ndiv; $od++) {
print "\n";
print
System
@@ -324,13 +564,14 @@ for (my $od = 0; $od < $ndiv; $od++) {
print "\n";
print
if ( $doback ) {
-print '
+print
System
Visible
@@ -350,8 +591,8 @@ for (my $od = 0; $od < $ndiv; $od++) {
print "\n";
print
System
@@ -373,15 +614,10 @@ for (my $od = 0; $od < $ndiv; $od++) {
print "\n";
print
-# Output XML epilogue
-print '
-# Clean up temporary files
-system "rm -rf $td";
+#------------- End of do_matrix_bsdf() --------------#
