root/radiance/ray/src/util/genBSDF.pl
Revision: 2.90
Committed: Fri Sep 22 18:01:32 2023 UTC (20 months ago) by greg
Changes since 2.89: +2 -4 lines
style: removed unused variable
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.90 # RCSid $Id: genBSDF.pl,v 2.89 2022/03/02 21:15:18 greg Exp $
3 greg 2.1 #
4     # Compute BSDF based on geometry and material description
5     #
6     # G. Ward
7     #
8     use strict;
9 greg 2.47 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 greg 2.13 use File::Temp qw/ :mktemp /;
11 greg 2.1 sub userror {
12 greg 2.76 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}a][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
13 greg 2.1 exit 1;
14     }
15 greg 2.49 my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
16 greg 2.90 my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz);
17 greg 2.66 my ($curphase, $recovery);
18     if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) {
19     $td = $ARGV[1];
20     open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n";
21     @ARGV = <MYAVH>;
22     close MYAVH;
23     chomp @ARGV;
24 greg 2.69 $recovery = 0;
25 greg 2.66 if (open(MYPH, "< $td/phase.txt")) {
26     while (<MYPH>) {
27     chomp($recovery = $_);
28     }
29     close MYPH;
30     }
31     } elsif ($windoz) {
32 greg 2.47 my $tmploc = `echo \%TMP\%`;
33 greg 2.66 chomp $tmploc;
34 greg 2.47 $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
35 greg 2.66 } else {
36     $td = mkdtemp("/tmp/genBSDF.XXXXXX");
37     chomp $td;
38     }
39     if ($windoz) {
40 greg 2.47 $radscn = "$td\\device.rad";
41     $mgfscn = "$td\\device.mgf";
42     $octree = "$td\\device.oct";
43 greg 2.49 $fsender = "$td\\fsender.rad";
44     $bsender = "$td\\bsender.rad";
45     $receivers = "$td\\receivers.rad";
46     $facedat = "$td\\face.dat";
47     $behinddat = "$td\\behind.dat";
48     $tf = "$td\\tf.dat";
49     $rf = "$td\\rf.dat";
50     $tb = "$td\\tb.dat";
51     $rb = "$td\\rb.dat";
52     $tfx = "$td\\tfx.dat";
53     $rfx = "$td\\rfx.dat";
54     $tbx = "$td\\tbx.dat";
55     $rbx = "$td\\rbx.dat";
56     $tfz = "$td\\tfz.dat";
57     $rfz = "$td\\rfz.dat";
58     $tbz = "$td\\tbz.dat";
59     $rbz = "$td\\rbz.dat";
60 greg 2.63 $rmtmp = "rd /S /Q $td";
61 greg 2.49 } else {
62 greg 2.47 $radscn = "$td/device.rad";
63     $mgfscn = "$td/device.mgf";
64     $octree = "$td/device.oct";
65 greg 2.49 $fsender = "$td/fsender.rad";
66     $bsender = "$td/bsender.rad";
67     $receivers = "$td/receivers.rad";
68     $facedat = "$td/face.dat";
69     $behinddat = "$td/behind.dat";
70     $tf = "$td/tf.dat";
71     $rf = "$td/rf.dat";
72     $tb = "$td/tb.dat";
73     $rb = "$td/rb.dat";
74     $tfx = "$td/tfx.dat";
75     $rfx = "$td/rfx.dat";
76     $tbx = "$td/tbx.dat";
77     $rbx = "$td/rbx.dat";
78     $tfz = "$td/tfz.dat";
79     $rfz = "$td/rfz.dat";
80     $tbz = "$td/tbz.dat";
81     $rbz = "$td/rbz.dat";
82 greg 2.47 $rmtmp = "rm -rf $td";
83     }
84 greg 2.20 my @savedARGV = @ARGV;
85 greg 2.74 my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6 -w-";
86 greg 2.49 my $wrapper = "wrapBSDF";
87 greg 2.15 my $tensortree = 0;
88     my $ttlog2 = 4;
89 greg 2.76 my $dorecip = 1;
90 greg 2.25 my $nsamp = 2000;
91 greg 2.1 my $mgfin = 0;
92     my $geout = 1;
93     my $nproc = 1;
94 greg 2.49 my $docolor = 0;
95 greg 2.9 my $doforw = 0;
96     my $doback = 1;
97 greg 2.33 my $pctcull = 90;
98 greg 2.41 my $gunit = "meter";
99 greg 2.49 my $curspec = "Visible";
100 greg 2.1 my @dim;
101     # Get options
102     while ($#ARGV >= 0) {
103     if ("$ARGV[0]" =~ /^[-+]m/) {
104     $mgfin = ("$ARGV[0]" =~ /^\+/);
105 greg 2.10 } elsif ("$ARGV[0]" eq "-r") {
106 greg 2.49 $rfluxmtx .= " $ARGV[1]";
107 greg 2.10 shift @ARGV;
108 greg 2.1 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
109     $geout = ("$ARGV[0]" =~ /^\+/);
110 greg 2.22 $gunit = $ARGV[1];
111     if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
112     die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
113     }
114     shift @ARGV;
115 greg 2.49 } elsif ("$ARGV[0]" =~ /^[-+]C/) {
116     $docolor = ("$ARGV[0]" =~ /^\+/);
117 greg 2.78 } elsif ("$ARGV[0]" =~ /^[-+]a/) {
118 greg 2.76 $dorecip = ("$ARGV[0]" =~ /^\+/);
119 greg 2.9 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
120     $doforw = ("$ARGV[0]" =~ /^\+/);
121     } elsif ("$ARGV[0]" =~ /^[-+]b/) {
122     $doback = ("$ARGV[0]" =~ /^\+/);
123 greg 2.27 } elsif ("$ARGV[0]" eq "-t") {
124 greg 2.33 # Use value < 0 for rttree_reduce bypass
125 greg 2.27 $pctcull = $ARGV[1];
126 greg 2.55 if ($pctcull >= 100) {
127     die "Illegal -t culling percentage, must be < 100\n";
128     }
129 greg 2.27 shift @ARGV;
130 greg 2.15 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
131     $tensortree = substr($ARGV[0], 2, 1);
132     $ttlog2 = $ARGV[1];
133     shift @ARGV;
134 greg 2.55 } elsif ("$ARGV[0]" eq "-s") {
135 greg 2.49 $wrapper .= " -f \"$ARGV[1]\"";
136     shift @ARGV;
137     } elsif ("$ARGV[0]" eq "-W") {
138     $wrapper .= " -W";
139 greg 2.1 } elsif ("$ARGV[0]" eq "-c") {
140     $nsamp = $ARGV[1];
141     shift @ARGV;
142     } elsif ("$ARGV[0]" eq "-n") {
143     $nproc = $ARGV[1];
144     shift @ARGV;
145     } elsif ("$ARGV[0]" =~ /^-d/) {
146     userror() if ($#ARGV < 6);
147 greg 2.8 @dim = @ARGV[1..6];
148 greg 2.1 shift @ARGV for (1..6);
149     } elsif ("$ARGV[0]" =~ /^[-+]./) {
150     userror();
151     } else {
152     last;
153     }
154     shift @ARGV;
155     }
156 greg 2.9 # Check that we're actually being asked to do something
157 greg 2.15 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
158 greg 2.49 $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
159     $wrapper .= " -u $gunit";
160 greg 2.67 if ( !defined $recovery ) {
161 greg 2.66 # Issue warning for unhandled reciprocity case
162     print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
163     ($tensortree==3 && !($doforw && $doback));
164 greg 2.67 # Get scene description
165 greg 2.66 if ( $mgfin ) {
166     system "mgf2rad @ARGV > $radscn";
167     die "Could not load MGF input\n" if ( $? );
168     } else {
169     system "xform -e @ARGV > $radscn";
170     die "Could not load Radiance input\n" if ( $? );
171     }
172 greg 2.1 }
173 greg 2.67 if ( $#dim != 5 ) {
174 greg 2.74 @dim = split ' ', `getbbox -h -w $radscn`;
175 greg 2.1 }
176 greg 2.67 die "Device entirely inside room!\n" if ( $dim[4] >= 0 );
177     if ( $dim[5] > 1e-5 ) {
178 greg 2.64 print STDERR "Warning: Device extends into room\n";
179 greg 2.67 } elsif ( $dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2]) ) {
180 greg 2.64 print STDERR "Warning: Device far behind Z==0 plane\n";
181     }
182     # Assume Zmax==0 to derive thickness so pkgBSDF will work
183     $wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
184 greg 2.49 ';h=' . ($dim[3] - $dim[2]) . '"';
185 greg 2.67 $wrapper .= " -g $mgfscn" if ( $geout );
186 greg 2.66 # Calculate CIE (u',v') from Radiance RGB:
187     my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
188     'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
189     'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
190 greg 2.80 'den=Xi+15*Yi+3*Zi;' .
191     'uprime=if(Yi,4*Xi/den,4/19);' .
192     'vprime=if(Yi,9*Yi/den,9/19);' ;
193 greg 2.56 my $FEPS = 1e-5;
194 greg 2.66 my $ns = 2**$ttlog2;
195 greg 2.46 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
196     my $ny = int($nsamp/$nx + 1);
197 greg 2.15 $nsamp = $nx * $ny;
198 greg 2.49 $rfluxmtx .= " -n $nproc -c $nsamp";
199 greg 2.67 if ( !defined $recovery ) {
200 greg 2.66 open(MYAVH, "> $td/savedARGV.txt");
201     foreach (@savedARGV) {
202     print MYAVH "$_\n";
203     }
204     close MYAVH;
205     # Generate octree
206 greg 2.81 system "oconv -w $radscn > $octree";
207 greg 2.66 die "Could not compile scene\n" if ( $? );
208     # Add MGF description if requested
209     if ( $geout ) {
210     open(MGFSCN, "> $mgfscn");
211     printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
212     close MGFSCN;
213     if ( $mgfin ) {
214 greg 2.89 die "+mgf requires input file with +geom\n" if ($#ARGV < 0);
215 greg 2.66 system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
216     } else {
217     system "rad2mgf $radscn >> $mgfscn";
218     }
219     open(MGFSCN, ">> $mgfscn");
220     print MGFSCN "xf\n";
221     close MGFSCN;
222     }
223     # Create receiver & sender surfaces (rectangular)
224     open(RADSCN, "> $receivers");
225     print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
226     print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
227     print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
228     print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
229     print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
230     print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
231     print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
232     print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
233 greg 2.49 close RADSCN;
234 greg 2.66 # Prepare sender surfaces
235     if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
236     open (RADSCN, "> $fsender");
237     print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
238     print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
239     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
240     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
241     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
242     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
243     close RADSCN;
244     open (RADSCN, "> $bsender");
245     print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
246     print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
247     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
248     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
249     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
250     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
251     close RADSCN;
252     }
253     print STDERR "Recover using: $0 -recover $td\n";
254     }
255     $curphase = 0;
256 greg 2.15 # Create data segments (all the work happens here)
257     if ( $tensortree ) {
258     do_tree_bsdf();
259     } else {
260     do_matrix_bsdf();
261     }
262 greg 2.49 # Output XML
263 greg 2.67 # print STDERR "Running: $wrapper\n";
264 greg 2.62 system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
265 greg 2.49 die "Could not wrap BSDF data\n" if ( $? );
266 greg 2.15 # Clean up temporary files and exit
267 greg 2.53 exec $rmtmp;
268 greg 2.16
269 greg 2.67 #============== End of main program segment ==============#
270
271     # Function to determine if next phase should be skipped or recovered
272     sub do_phase {
273     $curphase++;
274 greg 2.70 if ( defined $recovery ) {
275     if ( $recovery > $curphase ) { return 0; }
276     if ( $recovery == $curphase ) { return -1; }
277 greg 2.67 }
278 greg 2.73 open(MYPH, ">> $td/phase.txt");
279 greg 2.67 print MYPH "$curphase\n";
280 greg 2.73 close MYPH;
281 greg 2.67 return 1;
282     }
283 greg 2.15
284 greg 2.70 # Check if we are in active phase (not skipping parts)
285     sub active_phase {
286     if ( defined $recovery ) {
287     if ( $recovery > $curphase ) { return 0; }
288     if ( $recovery == $curphase ) { return -1; }
289     }
290     return 1;
291     }
292
293     # Function to run program and check output if in active phase
294     sub run_check {
295     if ( !active_phase() ) { return; }
296     my $cmd = shift;
297     # print STDERR "Running: $cmd\n";
298     system $cmd;
299     die "Failure running: $cmd\n" if ( $? );
300     }
301
302 greg 2.15 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
303     sub do_tree_bsdf {
304 greg 2.49
305     # Run rfluxmtx processes to compute each side
306     do_ttree_dir(0) if ( $doback );
307     do_ttree_dir(1) if ( $doforw );
308 greg 2.36
309 greg 2.15 } # end of sub do_tree_bsdf()
310
311 greg 2.49 # Call rfluxmtx and process tensor tree BSDF for the given direction
312     sub do_ttree_dir {
313 greg 2.15 my $forw = shift;
314 greg 2.70 my $dop = do_phase();
315     my $r = ($dop < 0) ? " -r" : "";
316 greg 2.47 my $cmd;
317 greg 2.15 if ( $tensortree == 3 ) {
318     # Isotropic BSDF
319 greg 2.36 my $ns2 = $ns / 2;
320 greg 2.47 if ($windoz) {
321     $cmd = "cnt $ns2 $ny $nx " .
322     qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
323     qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
324     qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
325 greg 2.82 qq{-e "r4=rand(-1.5839226*recno-59.82712)" } .
326 greg 2.84 qq{-e "odds(n):if(.5*n-floor(.5*n)-.25,-1,1)"} .
327     qq{-e "Dx=1-(\$1+r1)/$ns2" } .
328 greg 2.86 qq{-e "Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2" } .
329 greg 2.82 qq{-e "Dz=sqrt(1-Dx*Dx-Dy*Dy)" } .
330 greg 2.47 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
331     qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
332     qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
333     qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
334     qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
335 greg 2.66 "| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree";
336 greg 2.47 } else {
337     $cmd = "cnt $ns2 $ny $nx " .
338 greg 2.75 qq{| rcalc -e 'r1=rand(.8681*recno-.673892)' } .
339     qq{-e 'r2=rand(-5.37138*recno+67.1737811)' } .
340     qq{-e 'r3=rand(+3.17603772*recno+83.766771)' } .
341 greg 2.82 qq{-e 'r4=rand(-1.5839226*recno-59.82712)' } .
342 greg 2.84 qq{-e 'odds(n):if(.5*n-floor(.5*n)-.25,-1,1)' } .
343     qq{-e 'Dx=1-(\$1+r1)/$ns2' } .
344 greg 2.86 qq{-e 'Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2' } .
345 greg 2.82 qq{-e 'Dz=sqrt(1-Dx*Dx-Dy*Dy)' } .
346     qq{-e 'xp=(\$3+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' } .
347     qq{-e 'yp=(\$2+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' } .
348 greg 2.75 qq{-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' } .
349 greg 2.47 qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
350     qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
351 greg 2.66 "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree";
352 greg 2.47 }
353 greg 2.15 } else {
354     # Anisotropic BSDF
355 greg 2.49 my $sender = ($bsender,$fsender)[$forw];
356 greg 2.47 if ($windoz) {
357 greg 2.66 $cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree";
358 greg 2.47 } else {
359 greg 2.66 $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree";
360 greg 2.47 }
361 greg 2.15 }
362 greg 2.71 if ( $dop ) {
363     # print STDERR "Running: $cmd\n";
364     system $cmd;
365     die "Failure running rfluxmtx" if ( $? );
366     }
367 greg 2.36 ttree_out($forw);
368 greg 2.49 } # end of do_ttree_dir()
369 greg 2.15
370 greg 2.49 # Simplify and store tensor tree results
371 greg 2.15 sub ttree_out {
372     my $forw = shift;
373 greg 2.49 my ($refldat,$transdat);
374     if ( $forw ) {
375     $transdat = $facedat;
376     $refldat = $behinddat;
377 greg 2.47 } else {
378 greg 2.49 $transdat = $behinddat;
379     $refldat = $facedat;
380 greg 2.47 }
381 greg 2.49 # Only output one transmitted anisotropic distribution, preferring backwards
382     if ( !$forw || !$doback || $tensortree==3 ) {
383     my $ttyp = ("tb","tf")[$forw];
384     ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
385     if ( $docolor ) {
386 greg 2.53 ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
387     ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
388 greg 2.49 }
389 greg 2.47 }
390 greg 2.49 # Output reflection
391     my $rtyp = ("rb","rf")[$forw];
392     ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
393     if ( $docolor ) {
394 greg 2.53 ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
395     ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
396 greg 2.34 }
397 greg 2.49 } # end of ttree_out()
398
399     # Call rttree_reduce on the given component
400     sub ttree_comp {
401     my $typ = shift;
402     my $spec = shift;
403     my $src = shift;
404     my $dest = shift;
405     my $cmd;
406 greg 2.47 if ($windoz) {
407 greg 2.49 if ("$spec" eq "Visible") {
408     $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
409 greg 2.53 q{-e "Ri=$1;Gi=$2;Bi=$3" } .
410     qq{-e "$CIEuv" } .
411     q{-e "$1=Yi/Omega"};
412     } elsif ("$spec" eq "CIE-u") {
413 greg 2.54 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
414 greg 2.53 qq{-e "$CIEuv" } .
415 greg 2.54 q{-e "$1=uprime"};
416 greg 2.53 } elsif ("$spec" eq "CIE-v") {
417 greg 2.54 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
418 greg 2.53 qq{-e "$CIEuv" } .
419 greg 2.54 q{-e "$1=vprime"};
420 greg 2.49 }
421 greg 2.47 } else {
422 greg 2.49 if ("$spec" eq "Visible") {
423     $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
424 greg 2.53 q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
425     "-e '$CIEuv' " .
426     q{-e '$1=Yi/Omega'};
427     } elsif ("$spec" eq "CIE-u") {
428 greg 2.54 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
429 greg 2.53 "-e '$CIEuv' " .
430 greg 2.54 q{-e '$1=uprime'};
431 greg 2.53 } elsif ("$spec" eq "CIE-v") {
432 greg 2.54 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
433 greg 2.53 "-e '$CIEuv' " .
434 greg 2.54 q{-e '$1=vprime'};
435 greg 2.49 }
436 greg 2.47 }
437 greg 2.49 if ($pctcull >= 0) {
438 greg 2.88 my $avg = ( $dorecip && ( $tensortree == 3 || "$typ" =~ /^r[fb]/ ) ) ? " -a" : "";
439 greg 2.53 my $pcull = ("$spec" eq "Visible") ? $pctcull :
440 greg 2.55 (100 - (100-$pctcull)*.25) ;
441 greg 2.49 if ($windoz) {
442     $cmd = "rcollate -ho -oc 1 $src | " .
443     $cmd .
444 greg 2.53 " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
445 greg 2.49 } else {
446     $cmd .= " -of $src " .
447 greg 2.53 "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
448 greg 2.49 }
449 greg 2.70 run_check "$cmd > $dest";
450 greg 2.47 } else {
451 greg 2.49 if ($windoz) {
452     $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
453     } else {
454     $cmd .= " $src";
455     }
456 greg 2.70 if ( active_phase() ) {
457     open(DATOUT, "> $dest");
458     print DATOUT "{\n";
459     close DATOUT;
460     # print STDERR "Running: $cmd\n";
461     system "$cmd >> $dest";
462     die "Failure running rcalc" if ( $? );
463     open(DATOUT, ">> $dest");
464     for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
465     print DATOUT "0\n";
466     }
467     print DATOUT "}\n";
468     close DATOUT;
469 greg 2.49 }
470 greg 2.47 }
471 greg 2.49 if ( "$spec" ne "$curspec" ) {
472 greg 2.51 $wrapper .= " -s $spec";
473 greg 2.49 $curspec = $spec;
474 greg 2.34 }
475 greg 2.49 $wrapper .= " -$typ $dest";
476     } # end of ttree_comp()
477 greg 2.15
478     #------------- End of do_tree_bsdf() & subroutines -------------#
479
480     #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
481     sub do_matrix_bsdf {
482 greg 2.49
483     # Run rfluxmtx processes to compute each side
484     do_matrix_dir(0) if ( $doback );
485     do_matrix_dir(1) if ( $doforw );
486
487     } # end of sub do_matrix_bsdf()
488
489     # Call rfluxmtx and process tensor tree BSDF for the given direction
490     sub do_matrix_dir {
491     my $forw = shift;
492 greg 2.70 my $dop = do_phase();
493     my $r = ($dop < 0) ? " -r" : "";
494 greg 2.49 my $sender = ($bsender,$fsender)[$forw];
495 greg 2.71 my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree";
496     if ( $dop ) {
497     # print STDERR "Running: $cmd\n";
498     system $cmd;
499     die "Failure running rfluxmtx" if ( $? );
500     }
501 greg 2.49 matrix_out($forw);
502     } # end of do_matrix_dir()
503
504     sub matrix_out {
505     my $forw = shift;
506     my ($refldat,$transdat);
507     if ( $forw ) {
508     $transdat = $facedat;
509     $refldat = $behinddat;
510 greg 2.47 } else {
511 greg 2.49 $transdat = $behinddat;
512     $refldat = $facedat;
513 greg 2.47 }
514 greg 2.49 # Output transmission
515     my $ttyp = ("tb","tf")[$forw];
516     matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
517     if ( $docolor ) {
518     matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
519     matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
520     }
521     # Output reflection
522     my $rtyp = ("rb","rf")[$forw];
523     matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
524     if ( $docolor ) {
525     matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
526     matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
527     }
528     } # end of matrix_out()
529
530     # Transpose matrix component data and save to file
531     sub matrix_comp {
532     my $typ = shift;
533     my $spec = shift;
534     my $src = shift;
535     my $dest = shift;
536     my $cmd = "rmtxop -fa -t";
537     if ("$spec" eq "Visible") {
538 greg 2.55 $cmd .= " -c 0.2651 0.6701 0.0648";
539 greg 2.49 } elsif ("$spec" eq "CIE-X") {
540 greg 2.55 $cmd .= " -c 0.5141 0.3239 0.1620";
541 greg 2.49 } elsif ("$spec" eq "CIE-Z") {
542 greg 2.55 $cmd .= " -c 0.0241 0.1229 0.8530";
543 greg 2.49 }
544 greg 2.72 $cmd .= " $src | getinfo -";
545 greg 2.70 run_check "$cmd > $dest";
546 greg 2.49 if ( "$spec" ne "$curspec" ) {
547 greg 2.51 $wrapper .= " -s $spec";
548 greg 2.49 $curspec = $spec;
549 greg 2.47 }
550 greg 2.49 $wrapper .= " -$typ $dest";
551     } # end of matrix_comp()
552 greg 2.47
553 greg 2.49 #------------- End of do_matrix_bsdf() & subroutines --------------#
