root/radiance/ray/src/util/genBSDF.pl
Revision: 2.66
Committed: Fri Sep 16 17:54:56 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.65: +131 -81 lines
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.65 2016/08/18 15:09:29 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 use File::Temp qw/ :mktemp /;
11 sub userror {
12 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
13 exit 1;
14 }
15 my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
16 my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph,$sav);
17 my ($curphase, $recovery);
18 if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) {
19 $td = $ARGV[1];
20 open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n";
21 @ARGV = <MYAVH>;
22 close MYAVH;
23 chomp @ARGV;
24 if (open(MYPH, "< $td/phase.txt")) {
25 while (<MYPH>) {
26 chomp($recovery = $_);
27 }
28 close MYPH;
29 }
30 } elsif ($windoz) {
31 my $tmploc = `echo \%TMP\%`;
32 chomp $tmploc;
33 $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
34 } else {
35 $td = mkdtemp("/tmp/genBSDF.XXXXXX");
36 chomp $td;
37 }
38 if ($windoz) {
39 $radscn = "$td\\device.rad";
40 $mgfscn = "$td\\device.mgf";
41 $octree = "$td\\device.oct";
42 $fsender = "$td\\fsender.rad";
43 $bsender = "$td\\bsender.rad";
44 $receivers = "$td\\receivers.rad";
45 $facedat = "$td\\face.dat";
46 $behinddat = "$td\\behind.dat";
47 $tf = "$td\\tf.dat";
48 $rf = "$td\\rf.dat";
49 $tb = "$td\\tb.dat";
50 $rb = "$td\\rb.dat";
51 $tfx = "$td\\tfx.dat";
52 $rfx = "$td\\rfx.dat";
53 $tbx = "$td\\tbx.dat";
54 $rbx = "$td\\rbx.dat";
55 $tfz = "$td\\tfz.dat";
56 $rfz = "$td\\rfz.dat";
57 $tbz = "$td\\tbz.dat";
58 $rbz = "$td\\rbz.dat";
59 $cph = "$td\\phase.txt";
60 $rmtmp = "rd /S /Q $td";
61 } else {
62 $radscn = "$td/device.rad";
63 $mgfscn = "$td/device.mgf";
64 $octree = "$td/device.oct";
65 $fsender = "$td/fsender.rad";
66 $bsender = "$td/bsender.rad";
67 $receivers = "$td/receivers.rad";
68 $facedat = "$td/face.dat";
69 $behinddat = "$td/behind.dat";
70 $tf = "$td/tf.dat";
71 $rf = "$td/rf.dat";
72 $tb = "$td/tb.dat";
73 $rb = "$td/rb.dat";
74 $tfx = "$td/tfx.dat";
75 $rfx = "$td/rfx.dat";
76 $tbx = "$td/tbx.dat";
77 $rbx = "$td/rbx.dat";
78 $tfz = "$td/tfz.dat";
79 $rfz = "$td/rfz.dat";
80 $tbz = "$td/tbz.dat";
81 $rbz = "$td/rbz.dat";
82 $cph = "$td/phase.txt";
83 $rmtmp = "rm -rf $td";
84 }
85 my @savedARGV = @ARGV;
86 my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6";
87 my $wrapper = "wrapBSDF";
88 my $tensortree = 0;
89 my $ttlog2 = 4;
90 my $nsamp = 2000;
91 my $mgfin = 0;
92 my $geout = 1;
93 my $nproc = 1;
94 my $docolor = 0;
95 my $doforw = 0;
96 my $doback = 1;
97 my $pctcull = 90;
98 my $gunit = "meter";
99 my $curspec = "Visible";
100 my @dim;
101 # Get options
102 while ($#ARGV >= 0) {
103 if ("$ARGV[0]" =~ /^[-+]m/) {
104 $mgfin = ("$ARGV[0]" =~ /^\+/);
105 } elsif ("$ARGV[0]" eq "-r") {
106 $rfluxmtx .= " $ARGV[1]";
107 shift @ARGV;
108 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
109 $geout = ("$ARGV[0]" =~ /^\+/);
110 $gunit = $ARGV[1];
111 if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
112 die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
113 }
114 shift @ARGV;
115 } elsif ("$ARGV[0]" =~ /^[-+]C/) {
116 $docolor = ("$ARGV[0]" =~ /^\+/);
117 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
118 $doforw = ("$ARGV[0]" =~ /^\+/);
119 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
120 $doback = ("$ARGV[0]" =~ /^\+/);
121 } elsif ("$ARGV[0]" eq "-t") {
122 # Use value < 0 for rttree_reduce bypass
123 $pctcull = $ARGV[1];
124 if ($pctcull >= 100) {
125 die "Illegal -t culling percentage, must be < 100\n";
126 }
127 shift @ARGV;
128 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
129 $tensortree = substr($ARGV[0], 2, 1);
130 $ttlog2 = $ARGV[1];
131 shift @ARGV;
132 } elsif ("$ARGV[0]" eq "-s") {
133 $wrapper .= " -f \"$ARGV[1]\"";
134 shift @ARGV;
135 } elsif ("$ARGV[0]" eq "-W") {
136 $wrapper .= " -W";
137 } elsif ("$ARGV[0]" eq "-c") {
138 $nsamp = $ARGV[1];
139 shift @ARGV;
140 } elsif ("$ARGV[0]" eq "-n") {
141 $nproc = $ARGV[1];
142 shift @ARGV;
143 } elsif ("$ARGV[0]" =~ /^-d/) {
144 userror() if ($#ARGV < 6);
145 @dim = @ARGV[1..6];
146 shift @ARGV for (1..6);
147 } elsif ("$ARGV[0]" =~ /^[-+]./) {
148 userror();
149 } else {
150 last;
151 }
152 shift @ARGV;
153 }
154 # Check that we're actually being asked to do something
155 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
156 $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
157 $wrapper .= " -u $gunit";
158 if (!defined $recovery) {
159 # Issue warning for unhandled reciprocity case
160 print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
161 ($tensortree==3 && !($doforw && $doback));
162 # Get scene description and dimensions
163 if ( $mgfin ) {
164 system "mgf2rad @ARGV > $radscn";
165 die "Could not load MGF input\n" if ( $? );
166 } else {
167 system "xform -e @ARGV > $radscn";
168 die "Could not load Radiance input\n" if ( $? );
169 }
170 }
171 if ($#dim != 5) {
172 @dim = split ' ', `getbbox -h $radscn`;
173 }
174 die "Device entirely inside room!\n" if ($dim[4] >= 0);
175 if ($dim[5] > 1e-5) {
176 print STDERR "Warning: Device extends into room\n";
177 } elsif ($dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2])) {
178 print STDERR "Warning: Device far behind Z==0 plane\n";
179 }
180 # Assume Zmax==0 to derive thickness so pkgBSDF will work
181 $wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
182 ';h=' . ($dim[3] - $dim[2]) . '"';
183 # Calculate CIE (u',v') from Radiance RGB:
184 my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
185 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
186 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
187 'den=Xi+15*Yi+3*Zi;' .
188 'uprime=4*Xi/den;vprime=9*Yi/den;' ;
189 my $FEPS = 1e-5;
190 my $ns = 2**$ttlog2;
191 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
192 my $ny = int($nsamp/$nx + 1);
193 $nsamp = $nx * $ny;
194 $rfluxmtx .= " -n $nproc -c $nsamp";
195 if (!defined $recovery) {
196 open(MYAVH, "> $td/savedARGV.txt");
197 foreach (@savedARGV) {
198 print MYAVH "$_\n";
199 }
200 close MYAVH;
201 # Generate octree
202 system "oconv -w $radscn > $octree";
203 die "Could not compile scene\n" if ( $? );
204 # Add MGF description if requested
205 if ( $geout ) {
206 open(MGFSCN, "> $mgfscn");
207 printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
208 close MGFSCN;
209 if ( $mgfin ) {
210 system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
211 } else {
212 system "rad2mgf $radscn >> $mgfscn";
213 }
214 open(MGFSCN, ">> $mgfscn");
215 print MGFSCN "xf\n";
216 close MGFSCN;
217 $wrapper .= " -g $mgfscn";
218 }
219 # Create receiver & sender surfaces (rectangular)
220 open(RADSCN, "> $receivers");
221 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
222 print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
223 print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
224 print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
225 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
226 print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
227 print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
228 print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
229 close RADSCN;
230 # Prepare sender surfaces
231 if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
232 open (RADSCN, "> $fsender");
233 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
234 print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
235 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
236 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
237 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
238 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
239 close RADSCN;
240 open (RADSCN, "> $bsender");
241 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
242 print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
243 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
244 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
245 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
246 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
247 close RADSCN;
248 }
249 print STDERR "Recover using: $0 -recover $td\n";
250 }
251 open(MYPH, ">> $td/phase.txt");
252 { # unbuffer output to MYPH
253 my $ofh = select MYPH;
254 $| = 1;
255 select $ofh;
256 }
257 $curphase = 0;
258 # Function to determine if next phase should be skipped or recovered
259 sub do_phase {
260 $curphase++;
261 if (defined $recovery) {
262 if ($recovery == $curphase) { return -1; }
263 if ($recovery > $curphase) { return 0; }
264 }
265 print MYPH "$curphase\n";
266 return 1;
267 }
268 # Create data segments (all the work happens here)
269 if ( $tensortree ) {
270 do_tree_bsdf();
271 } else {
272 do_matrix_bsdf();
273 }
274 # Output XML
275 print STDERR "Running: $wrapper\n";
276 system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
277 die "Could not wrap BSDF data\n" if ( $? );
278 # Clean up temporary files and exit
279 exec $rmtmp;
280
281 #-------------- End of main program segment --------------#
282
283 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
284 sub do_tree_bsdf {
285
286 # Run rfluxmtx processes to compute each side
287 do_ttree_dir(0) if ( $doback );
288 do_ttree_dir(1) if ( $doforw );
289
290 } # end of sub do_tree_bsdf()
291
292 # Call rfluxmtx and process tensor tree BSDF for the given direction
293 sub do_ttree_dir {
294 my $forw = shift;
295 my $r = do_phase();
296 if (!$r) { return; }
297 $r = ($r < 0) ? " -r" : "";
298 my $cmd;
299 if ( $tensortree == 3 ) {
300 # Isotropic BSDF
301 my $ns2 = $ns / 2;
302 if ($windoz) {
303 $cmd = "cnt $ns2 $ny $nx " .
304 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
305 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
306 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
307 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
308 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
309 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
310 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
311 qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
312 qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
313 "| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree";
314 } else {
315 $cmd = "cnt $ns2 $ny $nx " .
316 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
317 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
318 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
319 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
320 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
321 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
322 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
323 qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
324 qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
325 "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree";
326 }
327 } else {
328 # Anisotropic BSDF
329 my $sender = ($bsender,$fsender)[$forw];
330 if ($windoz) {
331 $cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree";
332 } else {
333 $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree";
334 }
335 }
336 print STDERR "Starting: $cmd\n";
337 system $cmd;
338 die "Failure running rfluxmtx" if ( $? );
339 ttree_out($forw);
340 } # end of do_ttree_dir()
341
342 # Simplify and store tensor tree results
343 sub ttree_out {
344 my $forw = shift;
345 my ($refldat,$transdat);
346 if ( $forw ) {
347 $transdat = $facedat;
348 $refldat = $behinddat;
349 } else {
350 $transdat = $behinddat;
351 $refldat = $facedat;
352 }
353 # Only output one transmitted anisotropic distribution, preferring backwards
354 if ( !$forw || !$doback || $tensortree==3 ) {
355 my $ttyp = ("tb","tf")[$forw];
356 ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
357 if ( $docolor ) {
358 ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
359 ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
360 }
361 }
362 # Output reflection
363 my $rtyp = ("rb","rf")[$forw];
364 ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
365 if ( $docolor ) {
366 ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
367 ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
368 }
369 } # end of ttree_out()
370
371 # Call rttree_reduce on the given component
372 sub ttree_comp {
373 my $typ = shift;
374 my $spec = shift;
375 my $src = shift;
376 my $dest = shift;
377 my $cmd;
378 if ($windoz) {
379 if ("$spec" eq "Visible") {
380 $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
381 q{-e "Ri=$1;Gi=$2;Bi=$3" } .
382 qq{-e "$CIEuv" } .
383 q{-e "$1=Yi/Omega"};
384 } elsif ("$spec" eq "CIE-u") {
385 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
386 qq{-e "$CIEuv" } .
387 q{-e "$1=uprime"};
388 } elsif ("$spec" eq "CIE-v") {
389 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
390 qq{-e "$CIEuv" } .
391 q{-e "$1=vprime"};
392 }
393 } else {
394 if ("$spec" eq "Visible") {
395 $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
396 q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
397 "-e '$CIEuv' " .
398 q{-e '$1=Yi/Omega'};
399 } elsif ("$spec" eq "CIE-u") {
400 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
401 "-e '$CIEuv' " .
402 q{-e '$1=uprime'};
403 } elsif ("$spec" eq "CIE-v") {
404 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
405 "-e '$CIEuv' " .
406 q{-e '$1=vprime'};
407 }
408 }
409 if ($pctcull >= 0) {
410 my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
411 my $pcull = ("$spec" eq "Visible") ? $pctcull :
412 (100 - (100-$pctcull)*.25) ;
413 if ($windoz) {
414 $cmd = "rcollate -ho -oc 1 $src | " .
415 $cmd .
416 " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
417 } else {
418 $cmd .= " -of $src " .
419 "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
420 }
421 print STDERR "Running: $cmd\n";
422 system "$cmd > $dest";
423 die "Failure running rttree_reduce" if ( $? );
424 } else {
425 if ($windoz) {
426 $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
427 } else {
428 $cmd .= " $src";
429 }
430 open(DATOUT, "> $dest");
431 print DATOUT "{\n";
432 close DATOUT;
433 print STDERR "Running: $cmd\n";
434 system "$cmd >> $dest";
435 die "Failure running rcalc" if ( $? );
436 open(DATOUT, ">> $dest");
437 for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
438 print DATOUT "0\n";
439 }
440 print DATOUT "}\n";
441 close DATOUT;
442 }
443 if ( "$spec" ne "$curspec" ) {
444 $wrapper .= " -s $spec";
445 $curspec = $spec;
446 }
447 $wrapper .= " -$typ $dest";
448 } # end of ttree_comp()
449
450 #------------- End of do_tree_bsdf() & subroutines -------------#
451
452 #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
453 sub do_matrix_bsdf {
454
455 # Run rfluxmtx processes to compute each side
456 do_matrix_dir(0) if ( $doback );
457 do_matrix_dir(1) if ( $doforw );
458
459 } # end of sub do_matrix_bsdf()
460
461 # Call rfluxmtx and process tensor tree BSDF for the given direction
462 sub do_matrix_dir {
463 my $forw = shift;
464 my $r = do_phase();
465 if (!$r) { return; }
466 $r = ($r < 0) ? " -r" : "";
467 my $cmd;
468 my $sender = ($bsender,$fsender)[$forw];
469 $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree";
470 print STDERR "Starting: $cmd\n";
471 system $cmd;
472 die "Failure running rfluxmtx" if ( $? );
473 matrix_out($forw);
474 } # end of do_matrix_dir()
475
476 sub matrix_out {
477 my $forw = shift;
478 my ($refldat,$transdat);
479 if ( $forw ) {
480 $transdat = $facedat;
481 $refldat = $behinddat;
482 } else {
483 $transdat = $behinddat;
484 $refldat = $facedat;
485 }
486 # Output transmission
487 my $ttyp = ("tb","tf")[$forw];
488 matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
489 if ( $docolor ) {
490 matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
491 matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
492 }
493 # Output reflection
494 my $rtyp = ("rb","rf")[$forw];
495 matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
496 if ( $docolor ) {
497 matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
498 matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
499 }
500 } # end of matrix_out()
501
502 # Transpose matrix component data and save to file
503 sub matrix_comp {
504 my $typ = shift;
505 my $spec = shift;
506 my $src = shift;
507 my $dest = shift;
508 my $cmd = "rmtxop -fa -t";
509 if ("$spec" eq "Visible") {
510 $cmd .= " -c 0.2651 0.6701 0.0648";
511 } elsif ("$spec" eq "CIE-X") {
512 $cmd .= " -c 0.5141 0.3239 0.1620";
513 } elsif ("$spec" eq "CIE-Z") {
514 $cmd .= " -c 0.0241 0.1229 0.8530";
515 }
516 $cmd .= " $src | rcollate -ho -oc 145";
517 print STDERR "Running: $cmd\n";
518 system "$cmd > $dest";
519 die "Failure running rmtxop" if ( $? );
520 if ( "$spec" ne "$curspec" ) {
521 $wrapper .= " -s $spec";
522 $curspec = $spec;
523 }
524 $wrapper .= " -$typ $dest";
525 } # end of matrix_comp()
526
527 #------------- End of do_matrix_bsdf() & subroutines --------------#
