--- ray/src/util/genBSDF.pl 2016/09/16 17:54:56 2.66 +++ ray/src/util/genBSDF.pl 2017/01/31 23:13:17 2.73 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.66 2016/09/16 17:54:56 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.73 2017/01/31 23:13:17 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -13,7 +13,7 @@ sub userror { exit 1; } my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp); -my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph,$sav); +my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph); my ($curphase, $recovery); if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) { $td = $ARGV[1]; @@ -21,6 +21,7 @@ if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) { @ARGV = ; close MYAVH; chomp @ARGV; + $recovery = 0; if (open(MYPH, "< $td/phase.txt")) { while () { chomp($recovery = $_); @@ -155,11 +156,11 @@ while ($#ARGV >= 0) { die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback); $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c"; $wrapper .= " -u $gunit"; -if (!defined $recovery) { +if ( !defined $recovery ) { # Issue warning for unhandled reciprocity case print STDERR "Warning: recommend both +forward and +backward with -t3\n" if ($tensortree==3 && !($doforw && $doback)); - # Get scene description and dimensions + # Get scene description if ( $mgfin ) { system "mgf2rad @ARGV > $radscn"; die "Could not load MGF input\n" if ( $? ); @@ -168,18 +169,19 @@ if (!defined $recovery) { die "Could not load Radiance input\n" if ( $? ); } } -if ($#dim != 5) { +if ( $#dim != 5 ) { @dim = split ' ', `getbbox -h $radscn`; } -die "Device entirely inside room!\n" if ($dim[4] >= 0); -if ($dim[5] > 1e-5) { +die "Device entirely inside room!\n" if ( $dim[4] >= 0 ); +if ( $dim[5] > 1e-5 ) { print STDERR "Warning: Device extends into room\n"; -} elsif ($dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2])) { +} elsif ( $dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2]) ) { print STDERR "Warning: Device far behind Z==0 plane\n"; } # Assume Zmax==0 to derive thickness so pkgBSDF will work $wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) . ';h=' . ($dim[3] - $dim[2]) . '"'; +$wrapper .= " -g $mgfscn" if ( $geout ); # Calculate CIE (u',v') from Radiance RGB: my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' . 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' . @@ -192,7 +194,7 @@ my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$d my $ny = int($nsamp/$nx + 1); $nsamp = $nx * $ny; $rfluxmtx .= " -n $nproc -c $nsamp"; -if (!defined $recovery) { +if ( !defined $recovery ) { open(MYAVH, "> $td/savedARGV.txt"); foreach (@savedARGV) { print MYAVH "$_\n"; @@ -214,7 +216,6 @@ if (!defined $recovery) { open(MGFSCN, ">> $mgfscn"); print MGFSCN "xf\n"; close MGFSCN; - $wrapper .= " -g $mgfscn"; } # Create receiver & sender surfaces (rectangular) open(RADSCN, "> $receivers"); @@ -248,23 +249,7 @@ if (!defined $recovery) { } print STDERR "Recover using: $0 -recover $td\n"; } -open(MYPH, ">> $td/phase.txt"); -{ # unbuffer output to MYPH - my $ofh = select MYPH; - $| = 1; - select $ofh; -} $curphase = 0; -# Function to determine if next phase should be skipped or recovered -sub do_phase { - $curphase++; - if (defined $recovery) { - if ($recovery == $curphase) { return -1; } - if ($recovery > $curphase) { return 0; } - } - print MYPH "$curphase\n"; - return 1; -} # Create data segments (all the work happens here) if ( $tensortree ) { do_tree_bsdf(); @@ -272,14 +257,45 @@ if ( $tensortree ) { do_matrix_bsdf(); } # Output XML -print STDERR "Running: $wrapper\n"; +# print STDERR "Running: $wrapper\n"; system "$wrapper -C \"Created by: genBSDF @savedARGV\""; die "Could not wrap BSDF data\n" if ( $? ); # Clean up temporary files and exit exec $rmtmp; -#-------------- End of main program segment --------------# +#============== End of main program segment ==============# +# Function to determine if next phase should be skipped or recovered +sub do_phase { + $curphase++; + if ( defined $recovery ) { + if ( $recovery > $curphase ) { return 0; } + if ( $recovery == $curphase ) { return -1; } + } + open(MYPH, ">> $td/phase.txt"); + print MYPH "$curphase\n"; + close MYPH; + return 1; +} + +# Check if we are in active phase (not skipping parts) +sub active_phase { + if ( defined $recovery ) { + if ( $recovery > $curphase ) { return 0; } + if ( $recovery == $curphase ) { return -1; } + } + return 1; +} + +# Function to run program and check output if in active phase +sub run_check { + if ( !active_phase() ) { return; } + my $cmd = shift; + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running: $cmd\n" if ( $? ); +} + #++++++++++++++ Tensor tree BSDF generation ++++++++++++++# sub do_tree_bsdf { @@ -292,9 +308,8 @@ sub do_tree_bsdf { # Call rfluxmtx and process tensor tree BSDF for the given direction sub do_ttree_dir { my $forw = shift; - my $r = do_phase(); - if (!$r) { return; } - $r = ($r < 0) ? " -r" : ""; + my $dop = do_phase(); + my $r = ($dop < 0) ? " -r" : ""; my $cmd; if ( $tensortree == 3 ) { # Isotropic BSDF @@ -333,9 +348,11 @@ sub do_ttree_dir { $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree"; } } - print STDERR "Starting: $cmd\n"; - system $cmd; - die "Failure running rfluxmtx" if ( $? ); + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } ttree_out($forw); } # end of do_ttree_dir() @@ -418,27 +435,27 @@ sub ttree_comp { $cmd .= " -of $src " . "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2"; } - print STDERR "Running: $cmd\n"; - system "$cmd > $dest"; - die "Failure running rttree_reduce" if ( $? ); + run_check "$cmd > $dest"; } else { if ($windoz) { $cmd = "rcollate -ho -oc 1 $src | " . $cmd ; } else { $cmd .= " $src"; } - open(DATOUT, "> $dest"); - print DATOUT "{\n"; - close DATOUT; - print STDERR "Running: $cmd\n"; - system "$cmd >> $dest"; - die "Failure running rcalc" if ( $? ); - open(DATOUT, ">> $dest"); - for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { - print DATOUT "0\n"; + if ( active_phase() ) { + open(DATOUT, "> $dest"); + print DATOUT "{\n"; + close DATOUT; + # print STDERR "Running: $cmd\n"; + system "$cmd >> $dest"; + die "Failure running rcalc" if ( $? ); + open(DATOUT, ">> $dest"); + for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { + print DATOUT "0\n"; + } + print DATOUT "}\n"; + close DATOUT; } - print DATOUT "}\n"; - close DATOUT; } if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; @@ -461,15 +478,15 @@ sub do_matrix_bsdf { # Call rfluxmtx and process tensor tree BSDF for the given direction sub do_matrix_dir { my $forw = shift; - my $r = do_phase(); - if (!$r) { return; } - $r = ($r < 0) ? " -r" : ""; - my $cmd; + my $dop = do_phase(); + my $r = ($dop < 0) ? " -r" : ""; my $sender = ($bsender,$fsender)[$forw]; - $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree"; - print STDERR "Starting: $cmd\n"; - system $cmd; - die "Failure running rfluxmtx" if ( $? ); + my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree"; + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } matrix_out($forw); } # end of do_matrix_dir() @@ -513,10 +530,8 @@ sub matrix_comp { } elsif ("$spec" eq "CIE-Z") { $cmd .= " -c 0.0241 0.1229 0.8530"; } - $cmd .= " $src | rcollate -ho -oc 145"; - print STDERR "Running: $cmd\n"; - system "$cmd > $dest"; - die "Failure running rmtxop" if ( $? ); + $cmd .= " $src | getinfo -"; + run_check "$cmd > $dest"; if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; $curspec = $spec;
