--- ray/src/util/genBSDF.pl 2015/03/16 00:40:51 2.52 +++ ray/src/util/genBSDF.pl 2016/07/13 00:51:17 2.64 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.52 2015/03/16 00:40:51 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.64 2016/07/13 00:51:17 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -9,7 +9,7 @@ use strict; my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64"); use File::Temp qw/ :mktemp /; sub userror { - print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-f \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n"; + print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n"; exit 1; } my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp); @@ -39,7 +39,7 @@ if ($windoz) { $tbz = "$td\\tbz.dat"; $rbz = "$td\\rbz.dat"; chomp $td; - $rmtmp = "rmdir /S /Q $td"; + $rmtmp = "rd /S /Q $td"; } else { $td = mkdtemp("/tmp/genBSDF.XXXXXX"); chomp $td; @@ -66,7 +66,7 @@ if ($windoz) { $rmtmp = "rm -rf $td"; } my @savedARGV = @ARGV; -my $rfluxmtx = "rfluxmtx -v -ab 5 -ad 700 -lw 3e-6"; +my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6"; my $wrapper = "wrapBSDF"; my $tensortree = 0; my $ttlog2 = 4; @@ -104,12 +104,15 @@ while ($#ARGV >= 0) { } elsif ("$ARGV[0]" eq "-t") { # Use value < 0 for rttree_reduce bypass $pctcull = $ARGV[1]; + if ($pctcull >= 100) { + die "Illegal -t culling percentage, must be < 100\n"; + } shift @ARGV; } elsif ("$ARGV[0]" =~ /^-t[34]$/) { $tensortree = substr($ARGV[0], 2, 1); $ttlog2 = $ARGV[1]; shift @ARGV; - } elsif ("$ARGV[0]" eq "-f") { + } elsif ("$ARGV[0]" eq "-s") { $wrapper .= " -f \"$ARGV[1]\""; shift @ARGV; } elsif ("$ARGV[0]" eq "-W") { @@ -149,8 +152,14 @@ if ( $mgfin ) { if ($#dim != 5) { @dim = split ' ', `getbbox -h $radscn`; } -print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); -$wrapper .= ' -f "t=' . ($dim[5] - $dim[4]) . ';w=' . ($dim[1] - $dim[0]) . +die "Device entirely inside room!\n" if ($dim[4] >= 0); +if ($dim[5] > 1e-5) { + print STDERR "Warning: Device extends into room\n"; +} elsif ($dim[5]*$dim[5] < .01*($dim[1]-$dim[0])*($dim[3]-$dim[2])) { + print STDERR "Warning: Device far behind Z==0 plane\n"; +} +# Assume Zmax==0 to derive thickness so pkgBSDF will work +$wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) . ';h=' . ($dim[3] - $dim[2]) . '"'; # Generate octree system "oconv -w $radscn > $octree"; @@ -171,16 +180,18 @@ if ( $geout ) { $wrapper .= " -g $mgfscn"; } # Create receiver & sender surfaces (rectangular) +my $FEPS = 1e-5; my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1); my $ny = int($nsamp/$nx + 1); $nsamp = $nx * $ny; my $ns = 2**$ttlog2; open(RADSCN, "> $receivers"); -print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=sc$ns\n" : "h=kf\n"); -print RADSCN '#@rfluxmtx ' . "u=Y o=$facedat\n\n"; +print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n"); +print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n"; print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n"; print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n"; -print RADSCN '#@rfluxmtx ' . "u=Y o=$behinddat\n\n"; +print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n"); +print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n"; print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n"; print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n"; close RADSCN; @@ -188,22 +199,28 @@ close RADSCN; $rfluxmtx .= " -n $nproc -c $nsamp"; if ( $tensortree != 3 ) { # Isotropic tensor tree is exception open (RADSCN, "> $fsender"); - print RADSCN '#@rfluxmtx u=Y ' . ($tensortree ? "h=sc$ns\n\n" : "h=kf\n\n"); + print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n"); print RADSCN "void polygon fwd_sender\n0\n0\n12\n"; - printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[2], $dim[4]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[3], $dim[4]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[3], $dim[4]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[2], $dim[4]; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS; close RADSCN; open (RADSCN, "> $bsender"); - print RADSCN '#@rfluxmtx u=Y ' . ($tensortree ? "h=sc$ns\n\n" : "h=kf\n\n"); - print RADSCN "void polygon fwd_sender\n0\n0\n12\n"; - printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[2], $dim[5]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[2], $dim[5]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[3], $dim[5]; - printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[3], $dim[5]; + print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n"); + print RADSCN "void polygon bwd_sender\n0\n0\n12\n"; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS; close RADSCN; } +# Calculate CIE (u',v') from Radiance RGB: +my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' . + 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' . + 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' . + 'den=Xi+15*Yi+3*Zi;' . + 'uprime=4*Xi/den;vprime=9*Yi/den;' ; # Create data segments (all the work happens here) if ( $tensortree ) { do_tree_bsdf(); @@ -211,15 +228,11 @@ if ( $tensortree ) { do_matrix_bsdf(); } # Output XML -my $old_fh = select(STDOUT); -$| = 1; -select($old_fh); -print "\n"; # print STDERR "Running: $wrapper\n"; -system $wrapper; +system "$wrapper -C \"Created by: genBSDF @savedARGV\""; die "Could not wrap BSDF data\n" if ( $? ); # Clean up temporary files and exit -system $rmtmp; +exec $rmtmp; #-------------- End of main program segment --------------# @@ -295,16 +308,16 @@ sub ttree_out { my $ttyp = ("tb","tf")[$forw]; ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]); if ( $docolor ) { - ttree_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]); - ttree_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]); + ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]); + ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]); } } # Output reflection my $rtyp = ("rb","rf")[$forw]; ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]); if ( $docolor ) { - ttree_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]); - ttree_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]); + ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]); + ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]); } } # end of ttree_out() @@ -318,35 +331,45 @@ sub ttree_comp { if ($windoz) { if ("$spec" eq "Visible") { $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } . - q{-e "$1=(0.265*$1+0.670*$2+0.065*$3)/Omega"}; - } elsif ("$spec" eq "CIE-X") { - $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } . - q{-e "$1=(0.514*$1+0.324*$2+0.162*$3)/Omega"}; - } elsif ("$spec" eq "CIE-Z") { - $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } . - q{-e "$1=(0.024*$1+0.123*$2+0.853*$3)/Omega"}; + q{-e "Ri=$1;Gi=$2;Bi=$3" } . + qq{-e "$CIEuv" } . + q{-e "$1=Yi/Omega"}; + } elsif ("$spec" eq "CIE-u") { + $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } . + qq{-e "$CIEuv" } . + q{-e "$1=uprime"}; + } elsif ("$spec" eq "CIE-v") { + $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } . + qq{-e "$CIEuv" } . + q{-e "$1=vprime"}; } } else { if ("$spec" eq "Visible") { $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . - q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega'}; - } elsif ("$spec" eq "CIE-X") { - $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . - q{-e '$1=(0.514*$1+0.324*$2+0.162*$3)/Omega'}; - } elsif ("$spec" eq "CIE-Z") { - $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . - q{-e '$1=(0.024*$1+0.123*$2+0.853*$3)/Omega'}; + q{-e 'Ri=$1;Gi=$2;Bi=$3' } . + "-e '$CIEuv' " . + q{-e '$1=Yi/Omega'}; + } elsif ("$spec" eq "CIE-u") { + $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } . + "-e '$CIEuv' " . + q{-e '$1=uprime'}; + } elsif ("$spec" eq "CIE-v") { + $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } . + "-e '$CIEuv' " . + q{-e '$1=vprime'}; } } if ($pctcull >= 0) { my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : ""; + my $pcull = ("$spec" eq "Visible") ? $pctcull : + (100 - (100-$pctcull)*.25) ; if ($windoz) { $cmd = "rcollate -ho -oc 1 $src | " . $cmd . - " | rttree_reduce$avg -h -fa -t $pctcull -r $tensortree -g $ttlog2"; + " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2"; } else { $cmd .= " -of $src " . - "| rttree_reduce$avg -h -ff -t $pctcull -r $tensortree -g $ttlog2"; + "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2"; } # print STDERR "Running: $cmd\n"; system "$cmd > $dest"; @@ -434,16 +457,16 @@ sub matrix_comp { my $dest = shift; my $cmd = "rmtxop -fa -t"; if ("$spec" eq "Visible") { - $cmd .= " -c 0.265 0.670 0.065"; + $cmd .= " -c 0.2651 0.6701 0.0648"; } elsif ("$spec" eq "CIE-X") { - $cmd .= " -c 0.514 0.324 0.162"; + $cmd .= " -c 0.5141 0.3239 0.1620"; } elsif ("$spec" eq "CIE-Z") { - $cmd .= " -c 0.024 0.123 0.853"; + $cmd .= " -c 0.0241 0.1229 0.8530"; } $cmd .= " $src | rcollate -ho -oc 145"; # print STDERR "Running: $cmd\n"; system "$cmd > $dest"; - die "Failure running rttree_reduce" if ( $? ); + die "Failure running rmtxop" if ( $? ); if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; $curspec = $spec;
