Fixed second typo in same line(!)
Fixed typo.
Fixed quoting errors for -t3 on Unix
More consistent use of warnings
Fixed issue with warning on recovery file under Windows
Minor readability improvements
Fixes to recovery option -- was not building wrapBSDF command correctly
Fix for unlikely case where first rfluxmtx has not happened before recovery
Removed stray unused variable
Fixes to last feature addition
Fixed warning about device being far beind Z==0 plane
Rob G's fix for Git Bash error
Fixed single-quote in wrapBSDF command, which fails under Windows
Minor correction to error message
Corrected error in last change
Added missing character type to XML header
Minor fix to usage message
Fixes for Klems & tensor tree coordinate orientations
Fixed bug in CIE (u',v') BSDF output
Changed output of tensor tree to use CIE (u',v') coordinates
Fixed issue with missing rcollate -oc specification
Added missing semicolons
Fixes for Windows
Added warning for -t3 w/o +forward and +backward
Andy finished making genBSDF Windows-compatible
Added protection against very small dimension(s)
Re-allowed rttree_reduce -a option for isotropic transmission
Bug fix for round-off error at phi=315 degrees
Correction to last change
Hopeful fixes to tensor tree reciprocity and orientation
Simplified and called new rcontrib program
Minor changes that should not affect results
Fix for -t3 N -t -1
Changed default -t to 90 and set up -t -1 to skip rttree_reduce call
Fixed problem with extra newlines
Took out reciprocity averaging for matrix data, which wasn't being done properly
Minor fix for corner case
Added reciprocity averaging
Eliminated Unix dependencies
Bug fix for 32-bit OS
Fixed usage message
