1 |
#!/usr/bin/perl -w |
2 |
# RCSid $Id: genBSDF.pl,v 2.14 2011/04/16 01:13:22 greg Exp $ |
3 |
4 |
# Compute BSDF based on geometry and material description |
5 |
6 |
# G. Ward |
7 |
8 |
use strict; |
9 |
use File::Temp qw/ :mktemp /; |
10 |
sub userror { |
11 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n"; |
12 |
exit 1; |
13 |
14 |
my $td = mkdtemp("/tmp/genBSDF.XXXXXX"); |
15 |
chomp $td; |
16 |
my $tensortree = 0; |
17 |
my $ttlog2 = 4; |
18 |
my $nsamp = 1000; |
19 |
my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6"; |
20 |
my $mgfin = 0; |
21 |
my $geout = 1; |
22 |
my $nproc = 1; |
23 |
my $doforw = 0; |
24 |
my $doback = 1; |
25 |
my @dim; |
26 |
# Get options |
27 |
while ($#ARGV >= 0) { |
28 |
if ("$ARGV[0]" =~ /^[-+]m/) { |
29 |
$mgfin = ("$ARGV[0]" =~ /^\+/); |
30 |
} elsif ("$ARGV[0]" eq "-r") { |
31 |
$rtargs = "$rtargs $ARGV[1]"; |
32 |
shift @ARGV; |
33 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) { |
34 |
$geout = ("$ARGV[0]" =~ /^\+/); |
35 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) { |
36 |
$doforw = ("$ARGV[0]" =~ /^\+/); |
37 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) { |
38 |
$doback = ("$ARGV[0]" =~ /^\+/); |
39 |
} elsif ("$ARGV[0]" =~ /^-t[34]$/) { |
40 |
$tensortree = substr($ARGV[0], 2, 1); |
41 |
$ttlog2 = $ARGV[1]; |
42 |
shift @ARGV; |
43 |
} elsif ("$ARGV[0]" eq "-c") { |
44 |
$nsamp = $ARGV[1]; |
45 |
shift @ARGV; |
46 |
} elsif ("$ARGV[0]" eq "-n") { |
47 |
$nproc = $ARGV[1]; |
48 |
shift @ARGV; |
49 |
} elsif ("$ARGV[0]" =~ /^-d/) { |
50 |
userror() if ($#ARGV < 6); |
51 |
@dim = @ARGV[1..6]; |
52 |
shift @ARGV for (1..6); |
53 |
} elsif ("$ARGV[0]" =~ /^[-+]./) { |
54 |
userror(); |
55 |
} else { |
56 |
last; |
57 |
58 |
shift @ARGV; |
59 |
60 |
# Check that we're actually being asked to do something |
61 |
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback); |
62 |
# Name our own persist file? |
63 |
my $persistfile; |
64 |
if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) { |
65 |
$persistfile = "$td/pfile.txt"; |
66 |
$rtargs = "-PP $persistfile $rtargs"; |
67 |
68 |
# Get scene description and dimensions |
69 |
my $radscn = "$td/device.rad"; |
70 |
my $mgfscn = "$td/device.mgf"; |
71 |
my $octree = "$td/device.oct"; |
72 |
if ( $mgfin ) { |
73 |
system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn"; |
74 |
die "Could not load MGF input\n" if ( $? ); |
75 |
system "mgf2rad $mgfscn > $radscn"; |
76 |
} else { |
77 |
system "xform -e @ARGV > $radscn"; |
78 |
die "Could not load Radiance input\n" if ( $? ); |
79 |
system "rad2mgf $radscn > $mgfscn" if ( $geout ); |
80 |
81 |
if ($#dim != 5) { |
82 |
@dim = split ' ', `getbbox -h $radscn`; |
83 |
84 |
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); |
85 |
# Add receiver surfaces (rectangular) |
86 |
my $fmodnm="receiver_face"; |
87 |
my $bmodnm="receiver_behind"; |
88 |
open(RADSCN, ">> $radscn"); |
89 |
print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n"; |
90 |
print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n"; |
91 |
print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n"; |
92 |
print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n"; |
93 |
close RADSCN; |
94 |
# Generate octree |
95 |
system "oconv -w $radscn > $octree"; |
96 |
die "Could not compile scene\n" if ( $? ); |
97 |
# Output XML prologue |
98 |
print |
99 |
'<?xml version="1.0" encoding="UTF-8"?> |
100 |
<WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd"> |
101 |
<WindowElementType>System</WindowElementType> |
102 |
<Optical> |
103 |
<Layer> |
104 |
<Material> |
105 |
<Name>Name</Name> |
106 |
<Manufacturer>Manufacturer</Manufacturer> |
107 |
108 |
printf "\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4]; |
109 |
printf "\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0]; |
110 |
printf "\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2]; |
111 |
print "\t\t<DeviceType>Integral</DeviceType>\n"; |
112 |
# Output MGF description if requested |
113 |
if ( $geout ) { |
114 |
print "\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n"; |
115 |
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; |
116 |
open(MGFSCN, "< $mgfscn"); |
117 |
while (<MGFSCN>) { print $_; } |
118 |
close MGFSCN; |
119 |
print "xf\n"; |
120 |
print "\t\t</Geometry>\n"; |
121 |
122 |
print " </Material>\n"; |
123 |
# Set up surface sampling |
124 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5); |
125 |
my $ny = int($nsamp/$nx + .5); |
126 |
$nsamp = $nx * $ny; |
127 |
my $ns = 2**$ttlog2; |
128 |
my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal); |
129 |
# Create data segments (all the work happens here) |
130 |
if ( $tensortree ) { |
131 |
do_tree_bsdf(); |
132 |
} else { |
133 |
do_matrix_bsdf(); |
134 |
135 |
# Output XML epilogue |
136 |
print |
137 |
'</Layer> |
138 |
</Optical> |
139 |
</WindowElement> |
140 |
141 |
# Clean up temporary files and exit |
142 |
if ( $persistfile ) { |
143 |
open(PFI, "< $persistfile"); |
144 |
while (<PFI>) { |
145 |
s/^[^ ]* //; |
146 |
kill('ALRM', $_); |
147 |
last; |
148 |
149 |
close PFI; |
150 |
151 |
system "rm -rf $td"; |
152 |
exit 0; |
153 |
#-------------- End of main program segment --------------# |
154 |
155 |
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++# |
156 |
sub do_tree_bsdf { |
157 |
# Get sampling rate and subdivide task |
158 |
my $ns2 = $ns; |
159 |
$ns2 /= 2 if ( $tensortree == 3 ); |
160 |
@pdiv = (0, int($ns2/$nproc)); |
161 |
my $nrem = $ns2 % $nproc; |
162 |
for (my $i = 1; $i < $nproc; $i++) { |
163 |
my $nv = $pdiv[$i] + $pdiv[1]; |
164 |
++$nv if ( $nrem-- > 0 ); |
165 |
push @pdiv, $nv; |
166 |
167 |
die "Script error 1" if ($pdiv[-1] != $ns2); |
168 |
# Shirley-Chiu mapping from unit square to disk |
169 |
$sq2disk = ' |
170 |
in_square_a = 2*in_square_x - 1; |
171 |
in_square_b = 2*in_square_y - 1; |
172 |
in_square_rgn = if(in_square_a + in_square_b, |
173 |
if(in_square_a - in_square_b, 1, 2), |
174 |
if(in_square_b - in_square_a, 3, 4)); |
175 |
out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b, |
176 |
-in_square_a, -in_square_b); |
177 |
out_disk_phi = PI/4 * select(in_square_rgn, |
178 |
in_square_b/in_square_a, |
179 |
2 - in_square_a/in_square_b, |
180 |
4 + in_square_b/in_square_a, |
181 |
if(in_square_b*in_square_b, |
182 |
6 - in_square_a/in_square_b, 0)); |
183 |
Dx = out_disk_r*cos(out_disk_phi); |
184 |
Dy = out_disk_r*sin(out_disk_phi); |
185 |
Dz = sqrt(1 - out_disk_r*out_disk_r); |
186 |
187 |
# Shirley-Chiu mapping from unit disk to square |
188 |
$disk2sq = ' |
189 |
norm_radians(p) : if(-p - PI/4, p + 2*PI, p); |
190 |
in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy); |
191 |
in_disk_phi = norm_radians(atan2(Dy, Dx)); |
192 |
in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1; |
193 |
out_square_a = select(in_disk_rgn, |
194 |
in_disk_r, |
195 |
(PI/2 - in_disk_phi)*in_disk_r/(PI/4), |
196 |
-in_disk_r, |
197 |
(in_disk_phi - 3*PI/2)*in_disk_r/(PI/4)); |
198 |
out_square_b = select(in_disk_rgn, |
199 |
in_disk_phi*in_disk_r/(PI/4), |
200 |
in_disk_r, |
201 |
(PI - in_disk_phi)*in_disk_r/(PI/4), |
202 |
-in_disk_r); |
203 |
out_square_x = (out_square_a + 1)/2; |
204 |
out_square_y = (out_square_b + 1)/2; |
205 |
206 |
# Announce ourselves in XML output |
207 |
print " <DataDefinition>\n"; |
208 |
print " <IncidentDataStructure>TensorTree$tensortree</IncidentDataStructure>\n"; |
209 |
print " </DataDefinition>\n"; |
210 |
# Fork parallel rtcontrib processes to compute each side |
211 |
if ( $doback ) { |
212 |
for (my $proc = 0; $proc < $nproc; $proc++) { |
213 |
bg_tree_rtcontrib(0, $proc); |
214 |
215 |
while (wait() >= 0) { |
216 |
die "rtcontrib process reported error" if ( $? ); |
217 |
218 |
ttree_out(0); |
219 |
220 |
if ( $doforw ) { |
221 |
222 |
bg_tree_rtcontrib(1, $proc); |
223 |
224 |
225 |
226 |
227 |
ttree_out(1); |
228 |
229 |
} # end of sub do_tree_bsdf() |
230 |
231 |
# Run i'th rtcontrib process for generating tensor tree samples |
232 |
sub bg_tree_rtcontrib { |
233 |
my $pid = fork(); |
234 |
die "Cannot fork new process" unless defined $pid; |
235 |
if ($pid > 0) { return $pid; } |
236 |
my $forw = shift; |
237 |
my $pn = shift; |
238 |
my $pbeg = $pdiv[$pn]; |
239 |
my $plen = $pdiv[$pn+1] - $pbeg; |
240 |
my $matargs = "-m $bmodnm"; |
241 |
if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; } |
242 |
my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " . |
243 |
"-e '$disk2sq' -bn '$ns*$ns' " . |
244 |
"-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " . |
245 |
"-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree"; |
246 |
if ( $tensortree == 3 ) { |
247 |
# Isotropic BSDF |
248 |
$cmd = "cnt $plen $ny $nx " . |
249 |
"| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " . |
250 |
"-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " . |
251 |
"-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " . |
252 |
"-e 'Dx=1-($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " . |
253 |
"-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
254 |
"-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
255 |
"-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " . |
256 |
"-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " . |
257 |
"-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " . |
258 |
"| $cmd"; |
259 |
} else { |
260 |
# Anisotropic BSDF |
261 |
# Sample area vertically to improve load balance, since |
262 |
# shading systems usually have bilateral symmetry (L-R) |
263 |
$cmd = "cnt $plen $ns $ny $nx " . |
264 |
265 |
266 |
267 |
"-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " . |
268 |
"-e 'in_square_x=($pbeg+\$1+r1)/$ns' " . |
269 |
"-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " . |
270 |
"-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
271 |
"-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
272 |
273 |
274 |
275 |
"| $cmd"; |
276 |
277 |
# print STDERR "Starting: $cmd\n"; |
278 |
exec($cmd); # no return; status report to parent via wait |
279 |
die "Cannot exec: $cmd\n"; |
280 |
} # end of bg_tree_rtcontrib() |
281 |
282 |
# Simplify and output tensor tree results |
283 |
sub ttree_out { |
284 |
my $forw = shift; |
285 |
my $side = ("Back","Front")[$forw]; |
286 |
# Only output one transmitted distribution, preferring backwards |
287 |
if ( !$forw || !$doback ) { |
288 |
print |
289 |
' <WavelengthData> |
290 |
<LayerNumber>System</LayerNumber> |
291 |
<Wavelength unit="Integral">Visible</Wavelength> |
292 |
<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum> |
293 |
<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum> |
294 |
<WavelengthDataBlock> |
295 |
<WavelengthDataDirection>Transmission</WavelengthDataDirection> |
296 |
<AngleBasis>LBNL/Shirley-Chiu</AngleBasis> |
297 |
<ScatteringDataType>BTDF</ScatteringDataType> |
298 |
<ScatteringData> |
299 |
300 |
system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . |
301 |
q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } . |
302 |
"$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " . |
303 |
"| rttree_reduce -h -ff -r $tensortree -g $ttlog2"; |
304 |
die "Failure running rttree_reduce" if ( $? ); |
305 |
print |
306 |
' </ScatteringData> |
307 |
</WavelengthDataBlock> |
308 |
</WavelengthData> |
309 |
310 |
311 |
# Output reflection |
312 |
print |
313 |
314 |
315 |
316 |
317 |
318 |
319 |
<WavelengthDataDirection>Reflection $side</WavelengthDataDirection> |
320 |
321 |
<ScatteringDataType>BRDF</ScatteringDataType> |
322 |
<ScatteringData> |
323 |
324 |
325 |
326 |
"$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " . |
327 |
328 |
329 |
print |
330 |
331 |
332 |
</WavelengthData> |
333 |
334 |
} # end of ttree_out() |
335 |
336 |
#------------- End of do_tree_bsdf() & subroutines -------------# |
337 |
338 |
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++# |
339 |
sub do_matrix_bsdf { |
340 |
# Set up sampling of portal |
341 |
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms |
342 |
$tcal = ' |
343 |
DEGREE : PI/180; |
344 |
sq(x) : x*x; |
345 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
346 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
347 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); |
348 |
Kmax : Kaccum(Knaz(0)); |
349 |
Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r); |
350 |
Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin)); |
351 |
Kcol = Kbin - Kaccum(Krow-1); |
352 |
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow); |
353 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); |
354 |
sin_kpol = sin(Kpol); |
355 |
Dx = cos(Kazi)*sin_kpol; |
356 |
Dy = sin(Kazi)*sin_kpol; |
357 |
Dz = sqrt(1 - sin_kpol*sin_kpol); |
358 |
KprojOmega = PI * if(Kbin-.5, |
359 |
(sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow), |
360 |
1 - sq(cos(Kpola(1)*DEGREE))); |
361 |
362 |
# Compute Klems bin from exiting ray direction (forward or backward) |
363 |
$kcal = ' |
364 |
DEGREE : PI/180; |
365 |
abs(x) : if(x, x, -x); |
366 |
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x))); |
367 |
posangle(a) : if(-a, a + 2*PI, a); |
368 |
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x)); |
369 |
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
370 |
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
371 |
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0); |
372 |
kfindrow(r, pol) : if(r-kpola(0)+.5, r, |
373 |
if(pol-kpola(r), kfindrow(r+1, pol), r) ); |
374 |
kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0); |
375 |
kbin2(pol,azi) = select(kfindrow(1, pol), |
376 |
kazn(azi,360/knaz(1)), |
377 |
kaccum(1) + kazn(azi,360/knaz(2)), |
378 |
kaccum(2) + kazn(azi,360/knaz(3)), |
379 |
kaccum(3) + kazn(azi,360/knaz(4)), |
380 |
kaccum(4) + kazn(azi,360/knaz(5)), |
381 |
kaccum(5) + kazn(azi,360/knaz(6)), |
382 |
kaccum(6) + kazn(azi,360/knaz(7)), |
383 |
kaccum(7) + kazn(azi,360/knaz(8)), |
384 |
kaccum(8) + kazn(azi,360/knaz(9)) |
385 |
386 |
kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx)); |
387 |
388 |
my $ndiv = 145; |
389 |
# Compute scattering data using rtcontrib |
390 |
my @tfarr; |
391 |
my @rfarr; |
392 |
my @tbarr; |
393 |
my @rbarr; |
394 |
my $cmd; |
395 |
my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " . |
396 |
"-e '$kcal' -b kbin -bn $ndiv " . |
397 |
"-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree"; |
398 |
my $rccmd = "rcalc -e '$tcal' " . |
399 |
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " . |
400 |
q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'}; |
401 |
if ( $doforw ) { |
402 |
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " . |
403 |
"-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
404 |
"-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
405 |
"-e 'zp:$dim[4]' " . |
406 |
q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } . |
407 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } . |
408 |
"| $rtcmd"; |
409 |
system "$cmd" || die "Failure running: $cmd\n"; |
410 |
@tfarr = `$rccmd $td/$fmodnm.flt`; |
411 |
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? ); |
412 |
@rfarr = `$rccmd $td/$bmodnm.flt`; |
413 |
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? ); |
414 |
415 |
if ( $doback ) { |
416 |
417 |
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
418 |
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
419 |
"-e 'zp:$dim[5]' " . |
420 |
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } . |
421 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } . |
422 |
"| $rtcmd"; |
423 |
424 |
@tbarr = `$rccmd $td/$bmodnm.flt`; |
425 |
426 |
@rbarr = `$rccmd $td/$fmodnm.flt`; |
427 |
428 |
429 |
# Output angle basis |
430 |
print |
431 |
' <DataDefinition> |
432 |
<IncidentDataStructure>Columns</IncidentDataStructure> |
433 |
<AngleBasis> |
434 |
<AngleBasisName>LBNL/Klems Full</AngleBasisName> |
435 |
<AngleBasisBlock> |
436 |
<Theta>0</Theta> |
437 |
<nPhis>1</nPhis> |
438 |
<ThetaBounds> |
439 |
<LowerTheta>0</LowerTheta> |
440 |
<UpperTheta>5</UpperTheta> |
441 |
</ThetaBounds> |
442 |
</AngleBasisBlock> |
443 |
<AngleBasisBlock> |
444 |
<Theta>10</Theta> |
445 |
<nPhis>8</nPhis> |
446 |
<ThetaBounds> |
447 |
<LowerTheta>5</LowerTheta> |
448 |
<UpperTheta>15</UpperTheta> |
449 |
</ThetaBounds> |
450 |
451 |
<AngleBasisBlock> |
452 |
<Theta>20</Theta> |
453 |
<nPhis>16</nPhis> |
454 |
<ThetaBounds> |
455 |
<LowerTheta>15</LowerTheta> |
456 |
<UpperTheta>25</UpperTheta> |
457 |
</ThetaBounds> |
458 |
459 |
<AngleBasisBlock> |
460 |
<Theta>30</Theta> |
461 |
<nPhis>20</nPhis> |
462 |
<ThetaBounds> |
463 |
<LowerTheta>25</LowerTheta> |
464 |
<UpperTheta>35</UpperTheta> |
465 |
</ThetaBounds> |
466 |
467 |
<AngleBasisBlock> |
468 |
<Theta>40</Theta> |
469 |
<nPhis>24</nPhis> |
470 |
<ThetaBounds> |
471 |
<LowerTheta>35</LowerTheta> |
472 |
<UpperTheta>45</UpperTheta> |
473 |
</ThetaBounds> |
474 |
475 |
<AngleBasisBlock> |
476 |
<Theta>50</Theta> |
477 |
<nPhis>24</nPhis> |
478 |
<ThetaBounds> |
479 |
<LowerTheta>45</LowerTheta> |
480 |
<UpperTheta>55</UpperTheta> |
481 |
</ThetaBounds> |
482 |
483 |
<AngleBasisBlock> |
484 |
<Theta>60</Theta> |
485 |
<nPhis>24</nPhis> |
486 |
<ThetaBounds> |
487 |
<LowerTheta>55</LowerTheta> |
488 |
<UpperTheta>65</UpperTheta> |
489 |
</ThetaBounds> |
490 |
491 |
<AngleBasisBlock> |
492 |
<Theta>70</Theta> |
493 |
<nPhis>16</nPhis> |
494 |
<ThetaBounds> |
495 |
<LowerTheta>65</LowerTheta> |
496 |
<UpperTheta>75</UpperTheta> |
497 |
</ThetaBounds> |
498 |
499 |
<AngleBasisBlock> |
500 |
<Theta>82.5</Theta> |
501 |
<nPhis>12</nPhis> |
502 |
<ThetaBounds> |
503 |
<LowerTheta>75</LowerTheta> |
504 |
<UpperTheta>90</UpperTheta> |
505 |
</ThetaBounds> |
506 |
507 |
</AngleBasis> |
508 |
</DataDefinition> |
509 |
510 |
if ( $doforw ) { |
511 |
print |
512 |
513 |
514 |
515 |
516 |
517 |
518 |
<WavelengthDataDirection>Transmission Front</WavelengthDataDirection> |
519 |
<ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis> |
520 |
<RowAngleBasis>LBNL/Klems Full</RowAngleBasis> |
521 |
522 |
<ScatteringData> |
523 |
524 |
# Output front transmission (transposed order) |
525 |
for (my $od = 0; $od < $ndiv; $od++) { |
526 |
for (my $id = 0; $id < $ndiv; $id++) { |
527 |
print $tfarr[$ndiv*$id + $od]; |
528 |
529 |
print "\n"; |
530 |
531 |
print |
532 |
533 |
534 |
</WavelengthData> |
535 |
<WavelengthData> |
536 |
537 |
538 |
539 |
540 |
541 |
<WavelengthDataDirection>Reflection Front</WavelengthDataDirection> |
542 |
543 |
544 |
545 |
<ScatteringData> |
546 |
547 |
# Output front reflection (transposed order) |
548 |
549 |
550 |
print $rfarr[$ndiv*$id + $od]; |
551 |
552 |
print "\n"; |
553 |
554 |
print |
555 |
556 |
557 |
</WavelengthData> |
558 |
559 |
560 |
if ( $doback ) { |
561 |
print |
562 |
563 |
564 |
565 |
566 |
567 |
568 |
<WavelengthDataDirection>Transmission Back</WavelengthDataDirection> |
569 |
570 |
571 |
572 |
<ScatteringData> |
573 |
574 |
# Output back transmission (transposed order) |
575 |
576 |
577 |
print $tbarr[$ndiv*$id + $od]; |
578 |
579 |
print "\n"; |
580 |
581 |
print |
582 |
583 |
584 |
</WavelengthData> |
585 |
<WavelengthData> |
586 |
587 |
588 |
589 |
590 |
591 |
<WavelengthDataDirection>Reflection Back</WavelengthDataDirection> |
592 |
593 |
594 |
595 |
<ScatteringData> |
596 |
597 |
# Output back reflection (transposed order) |
598 |
599 |
600 |
print $rbarr[$ndiv*$id + $od]; |
601 |
602 |
print "\n"; |
603 |
604 |
print |
605 |
606 |
607 |
</WavelengthData> |
608 |
609 |
610 |
611 |
#------------- End of do_matrix_bsdf() --------------# |
