root/radiance/ray/src/util/genBSDF.pl
Revision: 2.11
Committed: Thu Feb 24 20:14:26 2011 UTC (13 years, 3 months ago) by greg
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.10 2011/02/22 22:51:23 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 sub userror {
10 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
11 exit 1;
12 }
13 my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
14 chomp $td;
15 my $nsamp = 1000;
16 my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
17 my $mgfin = 0;
18 my $geout = 1;
19 my $nproc = 1;
20 my $doforw = 0;
21 my $doback = 1;
22 my @dim;
23 # Get options
24 while ($#ARGV >= 0) {
25 if ("$ARGV[0]" =~ /^[-+]m/) {
26 $mgfin = ("$ARGV[0]" =~ /^\+/);
27 } elsif ("$ARGV[0]" eq "-r") {
28 $rtargs = "$rtargs $ARGV[1]";
29 shift @ARGV;
30 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
31 $geout = ("$ARGV[0]" =~ /^\+/);
32 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
33 $doforw = ("$ARGV[0]" =~ /^\+/);
34 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
35 $doback = ("$ARGV[0]" =~ /^\+/);
36 } elsif ("$ARGV[0]" eq "-c") {
37 $nsamp = $ARGV[1];
38 shift @ARGV;
39 } elsif ("$ARGV[0]" eq "-n") {
40 $nproc = $ARGV[1];
41 shift @ARGV;
42 } elsif ("$ARGV[0]" =~ /^-d/) {
43 userror() if ($#ARGV < 6);
44 @dim = @ARGV[1..6];
45 shift @ARGV for (1..6);
46 } elsif ("$ARGV[0]" =~ /^[-+]./) {
47 userror();
48 } else {
49 last;
50 }
51 shift @ARGV;
52 }
53 # Check that we're actually being asked to do something
54 die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
55 # Get scene description and dimensions
56 my $radscn = "$td/device.rad";
57 my $mgfscn = "$td/device.mgf";
58 my $octree = "$td/device.oct";
59 if ( $mgfin ) {
60 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
61 die "Could not load MGF input\n" if ( $? );
62 system "mgf2rad $mgfscn > $radscn";
63 } else {
64 system "cat @ARGV | xform -e > $radscn";
65 die "Could not load Radiance input\n" if ( $? );
66 system "rad2mgf $radscn > $mgfscn" if ( $geout );
67 }
68 if ($#dim != 5) {
69 @dim = split ' ', `getbbox -h $radscn`;
70 }
71 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
72 # Add receiver surfaces (rectangular)
73 my $fmodnm="receiver_face";
74 my $bmodnm="receiver_behind";
75 open(RADSCN, ">> $radscn");
76 print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
77 print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
78 print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
79 print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
80 close RADSCN;
81 # Generate octree
82 system "oconv -w $radscn > $octree";
83 die "Could not compile scene\n" if ( $? );
84 # Set up sampling of interior portal
85 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
86 my $tcal = '
87 DEGREE : PI/180;
88 sq(x) : x*x;
89 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
90 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
91 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
92 Kmax : Kaccum(Knaz(0));
93 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
94 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
95 Kcol = Kbin - Kaccum(Krow-1);
96 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
97 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
98 sin_kpol = sin(Kpol);
99 Dx = cos(Kazi)*sin_kpol;
100 Dy = sin(Kazi)*sin_kpol;
101 Dz = sqrt(1 - sin_kpol*sin_kpol);
102 KprojOmega = PI * if(Kbin-.5,
103 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
104 1 - sq(cos(Kpola(1)*DEGREE)));
105 ';
106 # Compute Klems bin from exiting ray direction (forward or backward)
107 my $kcal = '
108 DEGREE : PI/180;
109 abs(x) : if(x, x, -x);
110 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
111 posangle(a) : if(-a, a + 2*PI, a);
112 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
113 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
114 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
115 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
116 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
117 if(pol-kpola(r), kfindrow(r+1, pol), r) );
118 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
119 kbin2(pol,azi) = select(kfindrow(1, pol),
120 kazn(azi,360/knaz(1)),
121 kaccum(1) + kazn(azi,360/knaz(2)),
122 kaccum(2) + kazn(azi,360/knaz(3)),
123 kaccum(3) + kazn(azi,360/knaz(4)),
124 kaccum(4) + kazn(azi,360/knaz(5)),
125 kaccum(5) + kazn(azi,360/knaz(6)),
126 kaccum(6) + kazn(azi,360/knaz(7)),
127 kaccum(7) + kazn(azi,360/knaz(8)),
128 kaccum(8) + kazn(azi,360/knaz(9))
129 );
130 kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
131 ';
132 my $ndiv = 145;
133 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
134 my $ny = int($nsamp/$nx + .5);
135 $nsamp = $nx * $ny;
136 # Compute scattering data using rtcontrib
137 my @tfarr;
138 my @rfarr;
139 my @tbarr;
140 my @rbarr;
141 my $cmd;
142 my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
143 "-e '$kcal' -b kbin -bn $ndiv " .
144 "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
145 my $rccmd = "rcalc -e '$tcal' " .
146 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
147 q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
148 if ( $doforw ) {
149 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
150 "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
151 "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
152 "-e 'zp:$dim[4]' " .
153 q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
154 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
155 "| $rtcmd";
156 system "$cmd" || die "Failure running: $cmd\n";
157 @tfarr = `$rccmd $td/$fmodnm.flt`;
158 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
159 @rfarr = `$rccmd $td/$bmodnm.flt`;
160 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
161 }
162 if ( $doback ) {
163 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
164 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
165 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
166 "-e 'zp:$dim[5]' " .
167 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
168 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
169 "| $rtcmd";
170 system "$cmd" || die "Failure running: $cmd\n";
171 @tbarr = `$rccmd $td/$bmodnm.flt`;
172 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
173 @rbarr = `$rccmd $td/$fmodnm.flt`;
174 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
175 }
176 # Output XML prologue
177 print
178 '<?xml version="1.0" encoding="UTF-8"?>
179 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
180 <WindowElementType>System</WindowElementType>
181 <Optical>
182 <Layer>
183 <Material>
184 <Name>Name</Name>
185 <Manufacturer>Manufacturer</Manufacturer>
186 ';
187 printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4];
188 printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0];
189 printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2];
190 print "\t\t\t<DeviceType>Integral</DeviceType>\n";
191 # Output MGF description if requested
192 if ( $geout ) {
193 print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n";
194 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
195 system "cat $mgfscn";
196 print "xf\n";
197 print "\t\t\t</Geometry>\n";
198 }
199 print ' </Material>
200 <DataDefinition>
201 <IncidentDataStructure>Columns</IncidentDataStructure>
202 <AngleBasis>
203 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
204 <AngleBasisBlock>
205 <Theta>0</Theta>
206 <nPhis>1</nPhis>
207 <ThetaBounds>
208 <LowerTheta>0</LowerTheta>
209 <UpperTheta>5</UpperTheta>
210 </ThetaBounds>
211 </AngleBasisBlock>
212 <AngleBasisBlock>
213 <Theta>10</Theta>
214 <nPhis>8</nPhis>
215 <ThetaBounds>
216 <LowerTheta>5</LowerTheta>
217 <UpperTheta>15</UpperTheta>
218 </ThetaBounds>
219 </AngleBasisBlock>
220 <AngleBasisBlock>
221 <Theta>20</Theta>
222 <nPhis>16</nPhis>
223 <ThetaBounds>
224 <LowerTheta>15</LowerTheta>
225 <UpperTheta>25</UpperTheta>
226 </ThetaBounds>
227 </AngleBasisBlock>
228 <AngleBasisBlock>
229 <Theta>30</Theta>
230 <nPhis>20</nPhis>
231 <ThetaBounds>
232 <LowerTheta>25</LowerTheta>
233 <UpperTheta>35</UpperTheta>
234 </ThetaBounds>
235 </AngleBasisBlock>
236 <AngleBasisBlock>
237 <Theta>40</Theta>
238 <nPhis>24</nPhis>
239 <ThetaBounds>
240 <LowerTheta>35</LowerTheta>
241 <UpperTheta>45</UpperTheta>
242 </ThetaBounds>
243 </AngleBasisBlock>
244 <AngleBasisBlock>
245 <Theta>50</Theta>
246 <nPhis>24</nPhis>
247 <ThetaBounds>
248 <LowerTheta>45</LowerTheta>
249 <UpperTheta>55</UpperTheta>
250 </ThetaBounds>
251 </AngleBasisBlock>
252 <AngleBasisBlock>
253 <Theta>60</Theta>
254 <nPhis>24</nPhis>
255 <ThetaBounds>
256 <LowerTheta>55</LowerTheta>
257 <UpperTheta>65</UpperTheta>
258 </ThetaBounds>
259 </AngleBasisBlock>
260 <AngleBasisBlock>
261 <Theta>70</Theta>
262 <nPhis>16</nPhis>
263 <ThetaBounds>
264 <LowerTheta>65</LowerTheta>
265 <UpperTheta>75</UpperTheta>
266 </ThetaBounds>
267 </AngleBasisBlock>
268 <AngleBasisBlock>
269 <Theta>82.5</Theta>
270 <nPhis>12</nPhis>
271 <ThetaBounds>
272 <LowerTheta>75</LowerTheta>
273 <UpperTheta>90</UpperTheta>
274 </ThetaBounds>
275 </AngleBasisBlock>
276 </AngleBasis>
277 </DataDefinition>
278 ';
279 if ( $doforw ) {
280 print ' <WavelengthData>
281 <LayerNumber>System</LayerNumber>
282 <Wavelength unit="Integral">Visible</Wavelength>
283 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
284 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
285 <WavelengthDataBlock>
286 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
287 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
288 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
289 <ScatteringDataType>BTDF</ScatteringDataType>
290 <ScatteringData>
291 ';
292 # Output front transmission (transposed order)
293 for (my $od = 0; $od < $ndiv; $od++) {
294 for (my $id = 0; $id < $ndiv; $id++) {
295 print $tfarr[$ndiv*$id + $od];
296 }
297 print "\n";
298 }
299 print
300 ' </ScatteringData>
301 </WavelengthDataBlock>
302 </WavelengthData>
303 <WavelengthData>
304 <LayerNumber>System</LayerNumber>
305 <Wavelength unit="Integral">Visible</Wavelength>
306 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
307 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
308 <WavelengthDataBlock>
309 <WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
310 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
311 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
312 <ScatteringDataType>BRDF</ScatteringDataType>
313 <ScatteringData>
314 ';
315 # Output front reflection (transposed order)
316 for (my $od = 0; $od < $ndiv; $od++) {
317 for (my $id = 0; $id < $ndiv; $id++) {
318 print $rfarr[$ndiv*$id + $od];
319 }
320 print "\n";
321 }
322 print
323 ' </ScatteringData>
324 </WavelengthDataBlock>
325 </WavelengthData>
326 ';
327 }
328 if ( $doback ) {
329 print ' <WavelengthData>
330 <LayerNumber>System</LayerNumber>
331 <Wavelength unit="Integral">Visible</Wavelength>
332 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
333 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
334 <WavelengthDataBlock>
335 <WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
336 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
337 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
338 <ScatteringDataType>BTDF</ScatteringDataType>
339 <ScatteringData>
340 ';
341 # Output back transmission (transposed order)
342 for (my $od = 0; $od < $ndiv; $od++) {
343 for (my $id = 0; $id < $ndiv; $id++) {
344 print $tbarr[$ndiv*$id + $od];
345 }
346 print "\n";
347 }
348 print
349 ' </ScatteringData>
350 </WavelengthDataBlock>
351 </WavelengthData>
352 <WavelengthData>
353 <LayerNumber>System</LayerNumber>
354 <Wavelength unit="Integral">Visible</Wavelength>
355 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
356 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
357 <WavelengthDataBlock>
358 <WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
359 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
360 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
361 <ScatteringDataType>BRDF</ScatteringDataType>
362 <ScatteringData>
363 ';
364 # Output back reflection (transposed order)
365 for (my $od = 0; $od < $ndiv; $od++) {
366 for (my $id = 0; $id < $ndiv; $id++) {
367 print $rbarr[$ndiv*$id + $od];
368 }
369 print "\n";
370 }
371 print
372 ' </ScatteringData>
373 </WavelengthDataBlock>
374 </WavelengthData>
375 ';
376 }
377 # Output XML epilogue
378 print '</Layer>
379 </Optical>
380 </WindowElement>
381 ';
382 # Clean up temporary files
383 system "rm -rf $td";
