--- ray/src/util/genBSDF.pl 2012/05/09 17:40:17 2.35 +++ ray/src/util/genBSDF.pl 2012/06/14 22:42:21 2.37 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.35 2012/05/09 17:40:17 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.37 2012/06/14 22:42:21 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -71,12 +71,6 @@ while ($#ARGV >= 0) { } # Check that we're actually being asked to do something die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback); -# Name our own persist file? -my $persistfile; -if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) { - $persistfile = "$td/pfile.txt"; - $rtargs = "-PP $persistfile $rtargs"; -} # Get scene description and dimensions my $radscn = "$td/device.rad"; my $mgfscn = "$td/device.mgf"; @@ -158,35 +152,8 @@ exec("rm -rf $td"); #-------------- End of main program segment --------------# -#++++++++++++++ Kill persistent rtrace +++++++++++++++++++# -sub persist_end { - if ( $persistfile && open(PFI, "< $persistfile") ) { - while () { - s/^[^ ]* //; - kill('ALRM', $_); - last; - } - close PFI; - } -} - #++++++++++++++ Tensor tree BSDF generation ++++++++++++++# sub do_tree_bsdf { -# Get sampling rate and subdivide task -my $ns2 = $ns; -$ns2 /= 2 if ( $tensortree == 3 ); -my $nsplice = $nproc; -$nsplice *= 10 if ($nproc > 1); -$nsplice = $ns2 if ($nsplice > $ns2); -$nsplice = 999 if ($nsplice > 999); -@pdiv = (0, int($ns2/$nsplice)); -my $nrem = $ns2 % $nsplice; -for (my $i = 1; $i < $nsplice; $i++) { - my $nv = $pdiv[$i] + $pdiv[1]; - ++$nv if ( $nrem-- > 0 ); - push @pdiv, $nv; -} -die "Script error 1" if ($pdiv[-1] != $ns2); # Shirley-Chiu mapping from unit square to disk $sq2disk = ' in_square_a = 2*in_square_x - 1; @@ -229,66 +196,30 @@ out_square_y = (out_square_b + 1)/2; print "\t\n"; print "\t\tTensorTree$tensortree\n"; print "\t\n"; -# Fork parallel rtcontrib processes to compute each side -my $npleft = $nproc; -if ( $doback ) { - for (my $splice = 0; $splice < $nsplice; $splice++) { - if (! $npleft ) { - wait(); - die "rtcontrib process reported error" if ( $? ); - $npleft++; - } - bg_tree_rtcontrib(0, $splice); - $npleft--; - } - while (wait() >= 0) { - die "rtcontrib process reported error" if ( $? ); - $npleft++; - } - persist_end(); - ttree_out(0); -} -if ( $doforw ) { - for (my $splice = 0; $splice < $nsplice; $splice++) { - if (! $npleft ) { - wait(); - die "rtcontrib process reported error" if ( $? ); - $npleft++; - } - bg_tree_rtcontrib(1, $splice); - $npleft--; - } - while (wait() >= 0) { - die "rtcontrib process reported error" if ( $? ); - $npleft++; - } - persist_end(); - ttree_out(1); -} + +# Start rcontrib processes for compute each side +do_tree_rtcontrib(0) if ( $doback ); +do_tree_rtcontrib(1) if ( $doforw ); + } # end of sub do_tree_bsdf() -# Run rtcontrib process in background to generate tensor tree samples -sub bg_tree_rtcontrib { - my $pid = fork(); - die "Cannot fork new process" unless defined $pid; - if ($pid > 0) { return $pid; } +# Run rcontrib process in background to generate tensor tree samples +sub do_tree_rtcontrib { my $forw = shift; - my $pn = shift; - my $pbeg = $pdiv[$pn]; - my $plen = $pdiv[$pn+1] - $pbeg; my $matargs = "-m $bmodnm"; if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; } - my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " . + my $cmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " . "-e '$disk2sq' -bn '$ns*$ns' " . "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " . - "-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree"; + "-o $td/%s.flt $matargs $octree"; if ( $tensortree == 3 ) { # Isotropic BSDF - $cmd = "cnt $plen $ny $nx " . - "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " . - "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " . - "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " . - "-e 'Dx=1-2*($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " . + my $ns2 = $ns / 2; + $cmd = "cnt $ns2 $ny $nx " . + "| rcalc -e 'r1=rand(.8681*recno-.673892)' " . + "-e 'r2=rand(-5.37138*recno+67.1737811)' " . + "-e 'r3=rand(+3.17603772*recno+83.766771)' " . + "-e 'Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " . "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " . @@ -299,12 +230,12 @@ sub bg_tree_rtcontrib { # Anisotropic BSDF # Sample area vertically to improve load balance, since # shading systems usually have bilateral symmetry (L-R) - $cmd = "cnt $plen $ns $ny $nx " . - "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " . - "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " . - "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " . - "-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " . - "-e 'in_square_x=($pbeg+\$1+r1)/$ns' " . + $cmd = "cnt $ns $ns $ny $nx " . + "| rcalc -e 'r1=rand(.8681*recno-.673892)' " . + "-e 'r2=rand(-5.37138*recno+67.1737811)' " . + "-e 'r3=rand(3.17603772*recno+83.766771)' " . + "-e 'r4=rand(-2.3857833*recno-964.72738)' " . + "-e 'in_square_x=(\$1+r1)/$ns' " . "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " . "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . @@ -314,9 +245,9 @@ sub bg_tree_rtcontrib { "| $cmd"; } # print STDERR "Starting: $cmd\n"; - exec($cmd); # no return; status report to parent via wait - die "Cannot exec: $cmd\n"; -} # end of bg_tree_rtcontrib() + system "$cmd" || die "Failure running rcontrib"; + ttree_out($forw); +} # end of do_tree_rtcontrib() # Simplify and output tensor tree results sub ttree_out { @@ -340,11 +271,11 @@ print $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' }; if ($pctcull >= 0) { - $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " . + $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " . "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2"; system "$cmd" || die "Failure running rttree_reduce"; } else { - $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt"; + $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt"; print "{\n"; system "$cmd" || die "Failure running rcalc"; for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { @@ -376,11 +307,11 @@ print $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' }; if ($pctcull >= 0) { - $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " . + $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " . "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2"; system "$cmd" || die "Failure running rttree_reduce"; } else { - $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt"; + $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt"; print "{\n"; system "$cmd" || die "Failure running rcalc"; for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { @@ -448,13 +379,13 @@ kbin2(pol,azi) = select(kfindrow(1, pol), kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx)); '; my $ndiv = 145; -# Compute scattering data using rtcontrib +# Compute scattering data using rcontrib my @tfarr; my @rfarr; my @tbarr; my @rbarr; my $cmd; -my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " . +my $rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " . "-e '$kcal' -b kbin -bn $ndiv " . "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree"; my $rccmd = "rcalc -e '$tcal' " .
