--- ray/src/util/genBSDF.pl 2011/02/24 20:14:26 2.11
+++ ray/src/util/genBSDF.pl 2014/07/09 15:03:11 2.48
@@ -1,24 +1,47 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.11 2011/02/24 20:14:26 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.48 2014/07/09 15:03:11 greg Exp $
# Compute BSDF based on geometry and material description
# G. Ward
use strict;
+my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
+use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
exit 1;
-my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
-chomp $td;
-my $nsamp = 1000;
+my ($td,$radscn,$mgfscn,$octree,$cnttmp,$rmtmp);
+if ($windoz) {
+ my $tmploc = `echo \%TMP\%`;
+ chomp($tmploc);
+ $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
+ $radscn = "$td\\device.rad";
+ $mgfscn = "$td\\device.mgf";
+ $octree = "$td\\device.oct";
+ chomp $td;
+ $rmtmp = "rmdir /S /Q $td";
+} else{
+ $td = mkdtemp("/tmp/genBSDF.XXXXXX");
+ chomp $td;
+ $radscn = "$td/device.rad";
+ $mgfscn = "$td/device.mgf";
+ $octree = "$td/device.oct";
+ $rmtmp = "rm -rf $td";
+my @savedARGV = @ARGV;
+my $tensortree = 0;
+my $ttlog2 = 4;
+my $nsamp = 2000;
my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
my $mgfin = 0;
my $geout = 1;
my $nproc = 1;
my $doforw = 0;
my $doback = 1;
+my $pctcull = 90;
+my $gunit = "meter";
my @dim;
# Get options
while ($#ARGV >= 0) {
@@ -29,10 +52,23 @@ while ($#ARGV >= 0) {
shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
$geout = ("$ARGV[0]" =~ /^\+/);
+ $gunit = $ARGV[1];
+ if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
+ die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
$doforw = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
$doback = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-t") {
+ # Use value < 0 for rttree_reduce bypass
+ $pctcull = $ARGV[1];
+ shift @ARGV;
+ } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
+ $tensortree = substr($ARGV[0], 2, 1);
+ $ttlog2 = $ARGV[1];
+ shift @ARGV;
} elsif ("$ARGV[0]" eq "-c") {
$nsamp = $ARGV[1];
shift @ARGV;
@@ -51,17 +87,18 @@ while ($#ARGV >= 0) {
shift @ARGV;
# Check that we're actually being asked to do something
-die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
+die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
+# Issue warning for unhandled reciprocity case
+print STDERR "Warning: recommend both +forward and +backward with -t3" if
+ ($tensortree==3 && !($doforw && $doback));
# Get scene description and dimensions
-my $radscn = "$td/device.rad";
-my $mgfscn = "$td/device.mgf";
-my $octree = "$td/device.oct";
if ( $mgfin ) {
- system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
+ system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV > $mgfscn};
die "Could not load MGF input\n" if ( $? );
system "mgf2rad $mgfscn > $radscn";
} else {
- system "cat @ARGV | xform -e > $radscn";
+ system "xform -e @ARGV > $radscn";
die "Could not load Radiance input\n" if ( $? );
system "rad2mgf $radscn > $mgfscn" if ( $geout );
@@ -81,203 +118,527 @@ close RADSCN;
# Generate octree
system "oconv -w $radscn > $octree";
die "Could not compile scene\n" if ( $? );
-# Set up sampling of interior portal
-# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
-my $tcal = '
-DEGREE : PI/180;
-sq(x) : x*x;
-Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
-Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
-Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
-Kmax : Kaccum(Knaz(0));
-Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
-Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
-Kcol = Kbin - Kaccum(Krow-1);
-Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
-Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
-sin_kpol = sin(Kpol);
-Dx = cos(Kazi)*sin_kpol;
-Dy = sin(Kazi)*sin_kpol;
-Dz = sqrt(1 - sin_kpol*sin_kpol);
-KprojOmega = PI * if(Kbin-.5,
- (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
- 1 - sq(cos(Kpola(1)*DEGREE)));
+# Output XML prologue
+print
-# Compute Klems bin from exiting ray direction (forward or backward)
-my $kcal = '
-DEGREE : PI/180;
-abs(x) : if(x, x, -x);
-Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
-posangle(a) : if(-a, a + 2*PI, a);
-Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
-kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
-knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
-kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
-kfindrow(r, pol) : if(r-kpola(0)+.5, r,
- if(pol-kpola(r), kfindrow(r+1, pol), r) );
-kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
-kbin2(pol,azi) = select(kfindrow(1, pol),
- kazn(azi,360/knaz(1)),
- kaccum(1) + kazn(azi,360/knaz(2)),
- kaccum(2) + kazn(azi,360/knaz(3)),
- kaccum(3) + kazn(azi,360/knaz(4)),
- kaccum(4) + kazn(azi,360/knaz(5)),
- kaccum(5) + kazn(azi,360/knaz(6)),
- kaccum(6) + kazn(azi,360/knaz(7)),
- kaccum(7) + kazn(azi,360/knaz(8)),
- kaccum(8) + kazn(azi,360/knaz(9))
-kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
+print "\n";
+print
+'System
+BSDF
+ Name
+ Manufacturer
-my $ndiv = 145;
-my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
-my $ny = int($nsamp/$nx + .5);
+printf qq{\t\t%.6f\n}, $dim[5] - $dim[4];
+printf qq{\t\t%.6f\n}, $dim[1] - $dim[0];
+printf qq{\t\t%.6f\n}, $dim[3] - $dim[2];
+print "\t\tOther\n";
+print "\t\n";
+# Output MGF description if requested
+if ( $geout ) {
+ print qq{\t\t\n};
+ print qq{\t\t\n};
+ printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
+ open(MGFSCN, "< $mgfscn");
+ while () { print $_; }
+ close MGFSCN;
+ print "xf\n";
+ print "\n";
+ print "\t\n";
+# Set up surface sampling
+my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
+my $ny = int($nsamp/$nx + 1);
$nsamp = $nx * $ny;
-# Compute scattering data using rtcontrib
+my $ns = 2**$ttlog2;
+my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
+# Create data segments (all the work happens here)
+if ( $tensortree ) {
+ do_tree_bsdf();
+} else {
+ do_matrix_bsdf();
+# Output XML epilogue
+print
+# Clean up temporary files and exit
+system $rmtmp;
+#-------------- End of main program segment --------------#
+#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
+sub do_tree_bsdf {
+# Shirley-Chiu mapping from unit square to disk
+$sq2disk = 'in_square_a = 2*in_square_x - 1; ' .
+ 'in_square_b = 2*in_square_y - 1; ' .
+ 'in_square_rgn = if(in_square_a + in_square_b, ' .
+ 'if(in_square_a - in_square_b, 1, 2), ' .
+ 'if(in_square_b - in_square_a, 3, 4)); ' .
+ 'out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b, ' .
+ '-in_square_a, -in_square_b); ' .
+ 'out_disk_phi = PI/4 * select(in_square_rgn, ' .
+ 'in_square_b/in_square_a, ' .
+ '2 - in_square_a/in_square_b, ' .
+ '4 + in_square_b/in_square_a, ' .
+ 'if(in_square_b*in_square_b, ' .
+ '6 - in_square_a/in_square_b, 0)); ' .
+ 'Dx = out_disk_r*cos(out_disk_phi); ' .
+ 'Dy = out_disk_r*sin(out_disk_phi); ' .
+ 'Dz = sqrt(1 - out_disk_r*out_disk_r);' ;
+# Shirley-Chiu mapping from unit disk to square
+$disk2sq = 'norm_radians(p) : if(-p - PI/4, p + 2*PI, p); ' .
+ 'in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy); ' .
+ 'in_disk_phi = norm_radians(atan2(Dy, Dx)); ' .
+ 'in_disk_rgn = floor((.999995*in_disk_phi + PI/4)/(PI/2)) + 1; ' .
+ 'out_square_a = select(in_disk_rgn, ' .
+ 'in_disk_r, ' .
+ '(PI/2 - in_disk_phi)*in_disk_r/(PI/4), ' .
+ '-in_disk_r, ' .
+ '(in_disk_phi - 3*PI/2)*in_disk_r/(PI/4)); ' .
+ 'out_square_b = select(in_disk_rgn, ' .
+ 'in_disk_phi*in_disk_r/(PI/4), ' .
+ 'in_disk_r, ' .
+ '(PI - in_disk_phi)*in_disk_r/(PI/4), ' .
+ '-in_disk_r); ' .
+ 'out_square_x = (out_square_a + 1)/2; ' .
+ 'out_square_y = (out_square_b + 1)/2;';
+# Announce ourselves in XML output
+print "\t\n";
+print "\t\tTensorTree$tensortree\n";
+print "\t\n";
+# Start rcontrib processes for compute each side
+do_tree_rtcontrib(0) if ( $doback );
+do_tree_rtcontrib(1) if ( $doforw );
+} # end of sub do_tree_bsdf()
+# Run rcontrib process to generate tensor tree samples
+sub do_tree_rtcontrib {
+ my $forw = shift;
+ my $cmd;
+ my $matargs = "-m $bmodnm";
+ if ( !$forw || !$doback || $tensortree==3 ) { $matargs .= " -m $fmodnm"; }
+ if ($windoz) {
+ $cmd = "rcontrib $rtargs -h -faa -fo -n $nproc -c $nsamp " .
+ qq{-e "$disk2sq" -bn "$ns*$ns" } .
+ qq{-b "$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)" } .
+ "-o $td/%s.flt $matargs $octree";
+ } else {
+ $cmd = "rcontrib $rtargs -h -fff -fo -n $nproc -c $nsamp " .
+ if ( $tensortree == 3 ) {
+ # Isotropic BSDF
+ my $ns2 = $ns / 2;
+ if ($windoz) {
+ $cmd = "cnt $ns2 $ny $nx " .
+ qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
+ qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
+ qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
+ qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
+ qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
+ qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
+ qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
+ qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
+ qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
+ "| $cmd";
+ } else {
+ qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
+ qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
+ "| $cmd";
+ } else {
+ # Anisotropic BSDF
+ # Sample area vertically to improve load balance, since
+ # shading systems usually have bilateral symmetry (L-R)
+ if ($windoz) {
+ $cmd = "cnt $ns $ns $ny $nx " .
+ qq{-e "r3=rand(3.17603772*recno+83.766771)" } .
+ qq{-e "r4=rand(-2.3857833*recno-964.72738)" } .
+ qq{-e "in_square_x=(\$1+r1)/$ns" } .
+ qq{-e "in_square_y=(\$2+r2)/$ns" -e "$sq2disk" } .
+ qq{-e "xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
+ qq{-e "yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
+ "| $cmd";
+ } else {
+ "| $cmd";
+# print STDERR "Starting: $cmd\n";
+ system "$cmd" || die "Failure running rcontrib";
+ ttree_out($forw);
+} # end of do_tree_rtcontrib()
+# Simplify and output tensor tree results
+sub ttree_out {
+ my $forw = shift;
+ my $side = ("Back","Front")[$forw];
+ my $cmd;
+# Only output one transmitted anisotropic distribution, preferring backwards
+if ( !$forw || !$doback || $tensortree==3 ) {
+print
+ System
+ Visible
+ CIE Illuminant D65 1nm.ssp
+ ASTM E308 1931 Y.dsp
+print "\t\t\tTransmission $side\n";
+print
+' LBNL/Shirley-Chiu
+ BTDF
+if ($windoz) {
+ $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
+ q{-e "$1=(0.265*$1+0.670*$2+0.065*$3)/Omega" };
+} else {
+ $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
+ q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' };
+if ($pctcull >= 0) {
+ if ($windoz) {
+ $cmd = "rcollate -h -oc 1 $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt | " .
+ $cmd .
+ "| rttree_reduce -h -fa -t $pctcull -r $tensortree -g $ttlog2";
+ } else {
+ $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " .
+ " | rttree_reduce -h -ff -t $pctcull -r $tensortree -g $ttlog2";
+ system "$cmd" || die "Failure running rttree_reduce";
+} else {
+ if ($windoz) {
+ $cmd ;
+ } else {
+ $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt";
+ print "{\n";
+ system "$cmd" || die "Failure running rcalc";
+ for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
+ print "0\n";
+ print "}\n";
+print
+# Output reflection
+print
+ System
+ Visible
+print "\t\t\tReflection $side\n";
+print
+ BTDF
+if ($windoz) {
+}else {
+ if ($windoz) {
+ $cmd = "rcollate -h -oc 1 $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt |" .
+ $cmd .
+ " | rttree_reduce -a -h -fa -t $pctcull -r $tensortree -g $ttlog2";
+ } else {
+ $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " .
+ "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
+} else {
+ if ($windoz) {
+ $cmd ;
+ } else {
+ $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt";
+ print "{\n";
+ print "0\n";
+ print "}\n";
+print
+} # end of ttree_out()
+#------------- End of do_tree_bsdf() & subroutines -------------#
+#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
+sub do_matrix_bsdf {
+# Set up sampling of portal
+# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
+$tcal = 'DEGREE : PI/180; ' .
+ 'sq(x) : x*x; ' .
+ 'Kpola(r) : select(r+1, 0, 5, 15, 25, 35, 45, 55, 65, 75, 90); ' .
+ 'Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); ' .
+ 'Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); ' .
+ 'Kmax : Kaccum(Knaz(0)); ' .
+ 'Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r); ' .
+ 'Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin)); ' .
+ 'Kcol = Kbin - Kaccum(Krow-1); ' .
+ 'Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow); ' .
+ 'Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); ' .
+ 'sin_kpol = sin(Kpol); ' .
+ 'Dx = cos(Kazi)*sin_kpol; ' .
+ 'Dy = sin(Kazi)*sin_kpol; ' .
+ 'Dz = sqrt(1 - sin_kpol*sin_kpol); ' .
+ 'KprojOmega = PI * if(Kbin-.5, ' .
+ '(sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow), ' .
+ '1 - sq(cos(Kpola(1)*DEGREE))); ';
+# Compute Klems bin from exiting ray direction (forward or backward)
+$kcal = 'DEGREE : PI/180; ' .
+ 'abs(x) : if(x, x, -x); ' .
+ 'Acos(x) : if(x-1, 0, if(-1-x, PI, acos(x)))/DEGREE; ' .
+ 'posangle(a) : if(-a, a + 2*PI, a); ' .
+ 'Atan2(y,x) : posangle(atan2(y,x))/DEGREE; ' .
+ 'kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90); ' .
+ 'knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); ' .
+ 'kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0); ' .
+ 'kfindrow(r, pol) : if(r-kpola(0)+.5, r, ' .
+ 'if(pol-kpola(r), kfindrow(r+1, pol), r) ); ' .
+ 'kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0); ' .
+ 'kbin2(pol,azi) = select(kfindrow(1, pol), ' .
+ 'kazn(azi,360/knaz(1)), ' .
+ 'kaccum(1) + kazn(azi,360/knaz(2)), ' .
+ 'kaccum(2) + kazn(azi,360/knaz(3)), ' .
+ 'kaccum(3) + kazn(azi,360/knaz(4)), ' .
+ 'kaccum(4) + kazn(azi,360/knaz(5)), ' .
+ 'kaccum(5) + kazn(azi,360/knaz(6)), ' .
+ 'kaccum(6) + kazn(azi,360/knaz(7)), ' .
+ 'kaccum(7) + kazn(azi,360/knaz(8)), ' .
+ 'kaccum(8) + kazn(azi,360/knaz(9)) ' .
+ 'kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));';
+my $ndiv = 145;
+# Compute scattering data using rcontrib
my @tfarr;
my @rfarr;
my @tbarr;
my @rbarr;
+my (@data,@line); # for windows
my $cmd;
-my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
- "-e '$kcal' -b kbin -bn $ndiv " .
- "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
-my $rccmd = "rcalc -e '$tcal' " .
- "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
- q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
+my $rtcmd;
+my $rccmd;
+if ($windoz) {
+ $rtcmd = "rcontrib $rtargs -h -fo -n $nproc -c $nsamp " .
+ qq{-e "$kcal" -b kbin -bn $ndiv } .
+ qq{-o "$td\\%s.flt" -m $fmodnm -m $bmodnm $octree };
+ $rccmd = qq{rcalc -e "$tcal" } .
+ qq{-e "mod(n,d):n-floor(n/d)*d" -e "Kbin=mod(recno-.999,$ndiv)" } .
+ q{ -e "$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega" };
+} else {
+ $rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
+ "-e '$kcal' -b kbin -bn $ndiv " .
+ "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
+ $rccmd = "rcalc -e '$tcal' " .
+ "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
+ q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' };
if ( $doforw ) {
-$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
- "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[4]' " .
- q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
- q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
- "| $rtcmd";
+ if ($windoz) {
+ $cmd = qq{cnt $ndiv $ny $nx | rcalc -e "$tcal" } .
+ qq{-e "xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
+ qq{-e "yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
+ qq{-e "zp:$dim[4]" } .
+ q{-e "Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)" } .
+ q{-e "$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz" } .
+ "| $rtcmd ";
+ } else {
+ $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
+ "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp:$dim[4]' " .
+ q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
+ "| $rtcmd";
system "$cmd" || die "Failure running: $cmd\n";
-@tfarr = `$rccmd $td/$fmodnm.flt`;
+if ($windoz) {
+ @tfarr = `rcollate -h -oc 1 $td\\$fmodnm.flt | $rccmd`;
+} else {
+ @tfarr = `$rccmd $td/$fmodnm.flt`;
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
-@rfarr = `$rccmd $td/$bmodnm.flt`;
+if ($windoz) {
+ @rfarr = `rcollate -h -oc 1 $td\\$bmodnm.flt | $rccmd`;
+} else {
+ @rfarr = `$rccmd $td/$bmodnm.flt`;
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
if ( $doback ) {
- "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
- "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
- "-e 'zp:$dim[5]' " .
- q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
- q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
- "| $rtcmd";
+ if ($windoz) {
+ qq{-e "xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
+ qq{-e "yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
+ qq{-e "zp:$dim[5]" } .
+ q{-e "Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)" } .
+ q{-e "$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz" } .
+ "| $rtcmd";
+ } else {
+ "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
+ "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
+ "-e 'zp:$dim[5]' " .
+ q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
+ q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
+ "| $rtcmd";
-@tbarr = `$rccmd $td/$bmodnm.flt`;
+if ($windoz) {
+ @tbarr = `rcollate -h -oc 1 $td\\$bmodnm.flt | $rccmd`;
+} else {
+ @tbarr = `$rccmd $td/$bmodnm.flt`;
-@rbarr = `$rccmd $td/$fmodnm.flt`;
+chomp(@tbarr);
+if ($windoz) {
+ @rbarr = `rcollate -h -oc 1 $td\\$fmodnm.flt | $rccmd`;
+} else {
+ @rbarr = `$rccmd $td/$fmodnm.flt`;
+chomp(@rbarr);
-# Output XML prologue
+# Output angle basis
print
- System
- Name
- Manufacturer
-printf "\t\t\t%.3f\n", $dim[5] - $dim[4];
-printf "\t\t\t%.3f\n", $dim[1] - $dim[0];
-printf "\t\t\t%.3f\n", $dim[3] - $dim[2];
-print "\t\t\tIntegral\n";
-# Output MGF description if requested
-if ( $geout ) {
- print "\t\t\t\n";
- printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
- system "cat $mgfscn";
- print "xf\n";
- print "\t\t\t\n";
-print '
- Columns
+ Columns
LBNL/Klems Full
- 0
- 1
+ 0
+ 1
0
5
- 10
- 8
- 5
- 15
- 20
- 16
- 15
- 25
- 30
- 20
- 25
- 35
- 40
- 24
- 35
- 45
- 50
- 24
- 45
- 55
- 60
- 24
- 55
- 65
- 70
- 16
- 65
- 75
- 82.5
- 12
- 75
- 90
+ 10
+ 8
+ 5
+ 15
+ 20
+ 16
+ 15
+ 25
+ 30
+ 20
+ 25
+ 35
+ 40
+ 24
+ 35
+ 45
+ 50
+ 24
+ 45
+ 55
+ 60
+ 24
+ 55
+ 65
+ 70
+ 16
+ 65
+ 75
+ 82.5
+ 12
+ 75
+ 90
if ( $doforw ) {
-print '
+print
System
Visible
@@ -292,13 +653,14 @@ print '
# Output front transmission (transposed order)
for (my $od = 0; $od < $ndiv; $od++) {
for (my $id = 0; $id < $ndiv; $id++) {
- print $tfarr[$ndiv*$id + $od];
+ chomp $tfarr[$ndiv*$id + $od];
+ print $tfarr[$ndiv*$id + $od], ",\t";
print "\n";
print
System
@@ -309,24 +671,26 @@ print
Reflection Front
LBNL/Klems Full
LBNL/Klems Full
- BRDF
+ BTDF
# Output front reflection (transposed order)
- print $rfarr[$ndiv*$id + $od];
+ chomp $rfarr[$ndiv*$id + $od];
+ print $rfarr[$ndiv*$id + $od], ",\t";
print "\n";
print
if ( $doback ) {
-print '
+print
System
Visible
@@ -341,13 +705,14 @@ print '
# Output back transmission (transposed order)
- print $tbarr[$ndiv*$id + $od];
+ chomp $tbarr[$ndiv*$id + $od];
+ print $tbarr[$ndiv*$id + $od], ",\t";
print "\n";
print
System
@@ -358,26 +723,22 @@ print
Reflection Back
LBNL/Klems Full
LBNL/Klems Full
- BRDF
+ BTDF
# Output back reflection (transposed order)
- print $rbarr[$ndiv*$id + $od];
+ chomp $rbarr[$ndiv*$id + $od];
+ print $rbarr[$ndiv*$id + $od], ",\t";
print "\n";
print
-# Output XML epilogue
-print '
-# Clean up temporary files
-system "rm -rf $td";
+#------------- End of do_matrix_bsdf() --------------#
