--- ray/src/util/genBSDF.pl 2011/10/25 20:51:10 2.26
+++ ray/src/util/genBSDF.pl 2013/09/07 17:56:02 2.44
@@ -1,5 +1,5 @@
#!/usr/bin/perl -w
-# RCSid $Id: genBSDF.pl,v 2.26 2011/10/25 20:51:10 greg Exp $
+# RCSid $Id: genBSDF.pl,v 2.44 2013/09/07 17:56:02 greg Exp $
# Compute BSDF based on geometry and material description
@@ -8,7 +8,7 @@
use strict;
use File::Temp qw/ :mktemp /;
sub userror {
- print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
+ print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
exit 1;
my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
@@ -23,7 +23,8 @@ my $geout = 1;
my $nproc = 1;
my $doforw = 0;
my $doback = 1;
-my $gunit = "Meter";
+my $pctcull = 90;
+my $gunit = "meter";
my @dim;
# Get options
while ($#ARGV >= 0) {
@@ -43,6 +44,10 @@ while ($#ARGV >= 0) {
$doforw = ("$ARGV[0]" =~ /^\+/);
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
$doback = ("$ARGV[0]" =~ /^\+/);
+ } elsif ("$ARGV[0]" eq "-t") {
+ # Use value < 0 for rttree_reduce bypass
+ $pctcull = $ARGV[1];
+ shift @ARGV;
} elsif ("$ARGV[0]" =~ /^-t[34]$/) {
$tensortree = substr($ARGV[0], 2, 1);
$ttlog2 = $ARGV[1];
@@ -66,12 +71,6 @@ while ($#ARGV >= 0) {
# Check that we're actually being asked to do something
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
-# Name our own persist file?
-my $persistfile;
-if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) {
- $persistfile = "$td/pfile.txt";
- $rtargs = "-PP $persistfile $rtargs";
# Get scene description and dimensions
my $radscn = "$td/device.rad";
my $mgfscn = "$td/device.mgf";
@@ -109,6 +108,7 @@ print
print "\n";
print
'System
+BSDF
@@ -118,18 +118,20 @@ print
printf "\t\t%.3f\n", $dim[5] - $dim[4];
printf "\t\t%.3f\n", $dim[1] - $dim[0];
printf "\t\t%.3f\n", $dim[3] - $dim[2];
-print "\t\tIntegral\n";
+print "\t\tOther\n";
+print " \n";
# Output MGF description if requested
if ( $geout ) {
- print "\t\t\n";
+ print "\t\n";
+ print "\t\t\n";
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
open(MGFSCN, "< $mgfscn");
while () { print $_; }
close MGFSCN;
print "xf\n";
- print "\t\t\n";
+ print "\n";
+ print "\t\n";
-print " \n";
# Set up surface sampling
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
my $ny = int($nsamp/$nx + .5);
@@ -153,35 +155,8 @@ exec("rm -rf $td");
#-------------- End of main program segment --------------#
-#++++++++++++++ Kill persistent rtrace +++++++++++++++++++#
-sub persist_end {
- if ( $persistfile && open(PFI, "< $persistfile") ) {
- while () {
- s/^[^ ]* //;
- kill('ALRM', $_);
- last;
- close PFI;
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
sub do_tree_bsdf {
-# Get sampling rate and subdivide task
-my $ns2 = $ns;
-$ns2 /= 2 if ( $tensortree == 3 );
-my $nsplice = $nproc;
-$nsplice *= 10 if ($nproc > 1);
-$nsplice = $ns2 if ($nsplice > $ns2);
-$nsplice = 999 if ($nsplice > 999);
-@pdiv = (0, int($ns2/$nsplice));
-my $nrem = $ns2 % $nsplice;
-for (my $i = 1; $i < $nsplice; $i++) {
- my $nv = $pdiv[$i] + $pdiv[1];
- ++$nv if ( $nrem-- > 0 );
- push @pdiv, $nv;
-die "Script error 1" if ($pdiv[-1] != $ns2);
# Shirley-Chiu mapping from unit square to disk
$sq2disk = '
in_square_a = 2*in_square_x - 1;
@@ -206,7 +181,7 @@ $disk2sq = '
norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
in_disk_phi = norm_radians(atan2(Dy, Dx));
-in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
+in_disk_rgn = floor((.999995*in_disk_phi + PI/4)/(PI/2)) + 1;
out_square_a = select(in_disk_rgn,
in_disk_r,
(PI/2 - in_disk_phi)*in_disk_r/(PI/4),
@@ -224,66 +199,30 @@ out_square_y = (out_square_b + 1)/2;
print "\t\n";
print "\t\tTensorTree$tensortree\n";
print "\t\n";
-# Fork parallel rtcontrib processes to compute each side
-my $npleft = $nproc;
-if ( $doback ) {
- for (my $splice = 0; $splice < $nsplice; $splice++) {
- if (! $npleft ) {
- wait();
- die "rtcontrib process reported error" if ( $? );
- $npleft++;
- bg_tree_rtcontrib(0, $splice);
- $npleft--;
- while (wait() >= 0) {
- $npleft++;
- persist_end();
- ttree_out(0);
-if ( $doforw ) {
- if (! $npleft ) {
- wait();
- $npleft++;
- bg_tree_rtcontrib(1, $splice);
- $npleft--;
- $npleft++;
- persist_end();
- ttree_out(1);
+# Start rcontrib processes for compute each side
+do_tree_rtcontrib(0) if ( $doback );
+do_tree_rtcontrib(1) if ( $doforw );
} # end of sub do_tree_bsdf()
-# Run rtcontrib process in background to generate tensor tree samples
-sub bg_tree_rtcontrib {
- my $pid = fork();
- die "Cannot fork new process" unless defined $pid;
- if ($pid > 0) { return $pid; }
+# Run rcontrib process to generate tensor tree samples
+sub do_tree_rtcontrib {
my $forw = shift;
- my $pn = shift;
- my $pbeg = $pdiv[$pn];
- my $plen = $pdiv[$pn+1] - $pbeg;
my $matargs = "-m $bmodnm";
- if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
- my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " .
+ if ( !$forw || !$doback || $tensortree==3 ) { $matargs .= " -m $fmodnm"; }
+ my $cmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
"-e '$disk2sq' -bn '$ns*$ns' " .
"-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
- "-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree";
+ "-o $td/%s.flt $matargs $octree";
if ( $tensortree == 3 ) {
# Isotropic BSDF
- $cmd = "cnt $plen $ny $nx " .
- "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
- "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
- "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
- "-e 'Dx=1-2*($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
+ my $ns2 = $ns / 2;
+ $cmd = "cnt $ns2 $ny $nx " .
+ "| rcalc -e 'r1=rand(.8681*recno-.673892)' " .
+ "-e 'r2=rand(-5.37138*recno+67.1737811)' " .
+ "-e 'r3=rand(+3.17603772*recno+83.766771)' " .
+ "-e 'Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
"-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
"-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
"-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
@@ -294,12 +233,12 @@ sub bg_tree_rtcontrib {
# Anisotropic BSDF
# Sample area vertically to improve load balance, since
# shading systems usually have bilateral symmetry (L-R)
- $cmd = "cnt $plen $ns $ny $nx " .
- "-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " .
- "-e 'in_square_x=($pbeg+\$1+r1)/$ns' " .
+ $cmd = "cnt $ns $ns $ny $nx " .
+ "-e 'r3=rand(3.17603772*recno+83.766771)' " .
+ "-e 'r4=rand(-2.3857833*recno-964.72738)' " .
+ "-e 'in_square_x=(\$1+r1)/$ns' " .
"-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
"-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
"-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
@@ -309,16 +248,17 @@ sub bg_tree_rtcontrib {
"| $cmd";
# print STDERR "Starting: $cmd\n";
- exec($cmd); # no return; status report to parent via wait
- die "Cannot exec: $cmd\n";
-} # end of bg_tree_rtcontrib()
+ system "$cmd" || die "Failure running rcontrib";
+ ttree_out($forw);
+} # end of do_tree_rtcontrib()
# Simplify and output tensor tree results
sub ttree_out {
my $forw = shift;
my $side = ("Back","Front")[$forw];
-# Only output one transmitted distribution, preferring backwards
-if ( !$forw || !$doback ) {
+ my $cmd;
+# Only output one transmitted anisotropic distribution, preferring backwards
+if ( !$forw || !$doback || $tensortree==3 ) {
print
System
@@ -326,16 +266,28 @@ print
CIE Illuminant D65 1nm.ssp
ASTM E308 1931 Y.dsp
- Transmission
- LBNL/Shirley-Chiu
+print "\t\t\tTransmission $side\n";
+print
+' LBNL/Shirley-Chiu
BTDF
-system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
- q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
- "$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " .
- "| rttree_reduce -h -ff -r $tensortree -g $ttlog2";
-die "Failure running rttree_reduce" if ( $? );
+$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
+ q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' };
+if ($pctcull >= 0) {
+ $cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " .
+ "| rttree_reduce -h -ff -t $pctcull -r $tensortree -g $ttlog2";
+ system "$cmd" || die "Failure running rttree_reduce";
+} else {
+ $cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt";
+ print "{\n";
+ system "$cmd" || die "Failure running rcalc";
+ for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
+ print "0\n";
+ print "}\n";
print
@@ -354,14 +306,24 @@ print
print "\t\t\tReflection $side\n";
print
' LBNL/Shirley-Chiu
- BRDF
+ BTDF
- "$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " .
+ $cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " .
+ "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
+} else {
+ $cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt";
+ print "{\n";
+ print "0\n";
+ print "}\n";
print
@@ -378,7 +340,7 @@ sub do_matrix_bsdf {
$tcal = '
DEGREE : PI/180;
sq(x) : x*x;
-Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
+Kpola(r) : select(r+1, 0, 5, 15, 25, 35, 45, 55, 65, 75, 90);
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
Kmax : Kaccum(Knaz(0));
@@ -399,9 +361,9 @@ KprojOmega = PI * if(Kbin-.5,
$kcal = '
DEGREE : PI/180;
abs(x) : if(x, x, -x);
-Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
+Acos(x) : if(x-1, 0, if(-1-x, PI, acos(x))) / DEGREE;
posangle(a) : if(-a, a + 2*PI, a);
-Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
+Atan2(y,x) : posangle(atan2(y,x)) / DEGREE;
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
@@ -422,19 +384,18 @@ kbin2(pol,azi) = select(kfindrow(1, pol),
kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
my $ndiv = 145;
-# Compute scattering data using rtcontrib
+# Compute scattering data using rcontrib
my @tfarr;
my @rfarr;
my @tbarr;
my @rbarr;
my $cmd;
-my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
+my $rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
"-e '$kcal' -b kbin -bn $ndiv " .
"-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
my $rccmd = "rcalc -e '$tcal' " .
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
- q{-if3 -e 'oval=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' } .
- q[-o '${ oval },'];
+ q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' };
if ( $doforw ) {
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
"-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
@@ -446,8 +407,10 @@ $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
system "$cmd" || die "Failure running: $cmd\n";
@tfarr = `$rccmd $td/$fmodnm.flt`;
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
+chomp(@tfarr);
@rfarr = `$rccmd $td/$bmodnm.flt`;
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
+chomp(@rfarr);
if ( $doback ) {
@@ -460,8 +423,10 @@ $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
@tbarr = `$rccmd $td/$bmodnm.flt`;
+chomp(@tbarr);
@rbarr = `$rccmd $td/$fmodnm.flt`;
+chomp(@rbarr);
# Output angle basis
print
@@ -470,77 +435,77 @@ print
LBNL/Klems Full
- 0
- 1
- 0
- 5
- 10
- 8
- 5
- 15
- 20
- 16
- 15
- 25
- 30
- 20
- 25
- 35
- 40
- 24
- 35
- 45
- 50
- 24
- 45
- 55
- 60
- 24
- 55
- 65
- 70
- 16
- 65
- 75
- 82.5
- 12
- 75
- 90
+ 0
+ 1
+ 0
+ 5
+ 10
+ 8
+ 5
+ 15
+ 20
+ 16
+ 15
+ 25
+ 30
+ 20
+ 25
+ 35
+ 40
+ 24
+ 35
+ 45
+ 50
+ 24
+ 45
+ 55
+ 60
+ 24
+ 55
+ 65
+ 70
+ 16
+ 65
+ 75
+ 82.5
+ 12
+ 75
+ 90
@@ -561,7 +526,7 @@ print
# Output front transmission (transposed order)
for (my $od = 0; $od < $ndiv; $od++) {
for (my $id = 0; $id < $ndiv; $id++) {
- print $tfarr[$ndiv*$id + $od];
+ print $tfarr[$ndiv*$id + $od], ",\n";
print "\n";
@@ -578,13 +543,13 @@ print
Reflection Front
LBNL/Klems Full
LBNL/Klems Full
- BRDF
+ BTDF
# Output front reflection (transposed order)
- print $rfarr[$ndiv*$id + $od];
+ print $rfarr[$ndiv*$id + $od], ",\n";
print "\n";
@@ -611,7 +576,7 @@ print
# Output back transmission (transposed order)
- print $tbarr[$ndiv*$id + $od];
+ print $tbarr[$ndiv*$id + $od], ",\n";
print "\n";
@@ -628,13 +593,13 @@ print
Reflection Back
LBNL/Klems Full
LBNL/Klems Full
- BRDF
+ BTDF
# Output back reflection (transposed order)
- print $rbarr[$ndiv*$id + $od];
+ print $rbarr[$ndiv*$id + $od], ",\n";
print "\n";
