root/radiance/ray/src/util/genBSDF.pl
Thu Oct 27 16:35:54 2011 UTC (12 years, 7 months ago) by greg
Diff to previous 2.26 , to selected 2.12
Tue Oct 25 20:51:10 2011 UTC (12 years, 7 months ago) by greg
Diff to previous 2.25 , to selected 2.12
Wed Aug 24 04:14:58 2011 UTC (12 years, 9 months ago) by greg
Diff to previous 2.24 , to selected 2.12
Tue Aug 23 14:02:41 2011 UTC (12 years, 9 months ago) by greg
Diff to previous 2.23 , to selected 2.12
Fri Jun 24 19:07:38 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.22 , to selected 2.12
Fri Jun 24 00:41:51 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.21 , to selected 2.12
Wed Jun 8 23:16:47 2011 UTC (13 years ago) by greg
Diff to previous 2.20 , to selected 2.12
Sat Jun 4 00:33:53 2011 UTC (13 years ago) by greg
Diff to previous 2.19 , to selected 2.12
Fri Jun 3 19:41:14 2011 UTC (13 years ago) by greg
Diff to previous 2.18 , to selected 2.12
Wed Jun 1 22:50:24 2011 UTC (13 years ago) by greg
Diff to previous 2.17 , to selected 2.12
Wed Jun 1 00:29:40 2011 UTC (13 years ago) by greg
Tue May 31 20:50:26 2011 UTC (13 years ago) by greg
Wed May 25 19:24:11 2011 UTC (13 years ago) by greg
Sat Apr 16 01:13:22 2011 UTC (13 years, 2 months ago) by greg
Eliminated Unix dependencies
Sat Apr 16 00:39:07 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.12
Bug fix for 32-bit OS
Thu Feb 24 20:27:00 2011 UTC (13 years, 3 months ago) by greg
Fixed usage message
Thu Feb 24 20:14:26 2011 UTC (13 years, 3 months ago) by greg
Tue Feb 22 22:51:23 2011 UTC (13 years, 3 months ago) by greg
Mon Feb 21 22:48:51 2011 UTC (13 years, 3 months ago) by greg
Sat Jan 29 16:44:01 2011 UTC (13 years, 4 months ago) by greg
Thu Jan 27 22:28:12 2011 UTC (13 years, 4 months ago) by greg
Wed Dec 15 17:23:58 2010 UTC (13 years, 6 months ago) by greg
Thu Dec 9 17:00:43 2010 UTC (13 years, 6 months ago) by greg
Thu Dec 9 06:14:04 2010 UTC (13 years, 6 months ago) by greg
Thu Sep 9 06:02:16 2010 UTC (13 years, 9 months ago) by greg
Fri Sep 3 23:53:50 2010 UTC (13 years, 9 months ago) by greg
Thu Sep 2 02:29:24 2010 UTC (13 years, 9 months ago) by greg
Diff to selected 2.12
