--- ray/src/util/genBSDF.pl 2016/02/09 23:05:26 2.63 +++ ray/src/util/genBSDF.pl 2016/09/19 16:28:21 2.71 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.63 2016/02/09 23:05:26 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.71 2016/09/19 16:28:21 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -13,11 +13,30 @@ sub userror { exit 1; } my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp); -my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz); -if ($windoz) { +my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph); +my ($curphase, $recovery); +if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) { + $td = $ARGV[1]; + open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n"; + @ARGV = ; + close MYAVH; + chomp @ARGV; + $recovery = 0; + if (open(MYPH, "< $td/phase.txt")) { + while () { + chomp($recovery = $_); + } + close MYPH; + } +} elsif ($windoz) { my $tmploc = `echo \%TMP\%`; - chomp($tmploc); + chomp $tmploc; $td = mkdtemp("$tmploc\\genBSDF.XXXXXX"); +} else { + $td = mkdtemp("/tmp/genBSDF.XXXXXX"); + chomp $td; +} +if ($windoz) { $radscn = "$td\\device.rad"; $mgfscn = "$td\\device.mgf"; $octree = "$td\\device.oct"; @@ -38,11 +57,9 @@ if ($windoz) { $rfz = "$td\\rfz.dat"; $tbz = "$td\\tbz.dat"; $rbz = "$td\\rbz.dat"; - chomp $td; + $cph = "$td\\phase.txt"; $rmtmp = "rd /S /Q $td"; } else { - $td = mkdtemp("/tmp/genBSDF.XXXXXX"); - chomp $td; $radscn = "$td/device.rad"; $mgfscn = "$td/device.mgf"; $octree = "$td/device.oct"; @@ -63,6 +80,7 @@ if ($windoz) { $rfz = "$td/rfz.dat"; $tbz = "$td/tbz.dat"; $rbz = "$td/rbz.dat"; + $cph = "$td/phase.txt"; $rmtmp = "rm -rf $td"; } my @savedARGV = @ARGV; @@ -136,85 +154,109 @@ while ($#ARGV >= 0) { } # Check that we're actually being asked to do something die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback); -# Issue warning for unhandled reciprocity case -print STDERR "Warning: recommend both +forward and +backward with -t3\n" if - ($tensortree==3 && !($doforw && $doback)); $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c"; $wrapper .= " -u $gunit"; -# Get scene description and dimensions -if ( $mgfin ) { - system "mgf2rad @ARGV > $radscn"; - die "Could not load MGF input\n" if ( $? ); -} else { - system "xform -e @ARGV > $radscn"; - die "Could not load Radiance input\n" if ( $? ); -} -if ($#dim != 5) { - @dim = split ' ', `getbbox -h $radscn`; -} -print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); -$wrapper .= ' -f "t=' . ($dim[5] - $dim[4]) . ';w=' . ($dim[1] - $dim[0]) . - ';h=' . ($dim[3] - $dim[2]) . '"'; -# Generate octree -system "oconv -w $radscn > $octree"; -die "Could not compile scene\n" if ( $? ); -# Add MGF description if requested -if ( $geout ) { - open(MGFSCN, "> $mgfscn"); - printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; - close MGFSCN; +if ( !defined $recovery ) { + # Issue warning for unhandled reciprocity case + print STDERR "Warning: recommend both +forward and +backward with -t3\n" if + ($tensortree==3 && !($doforw && $doback)); + # Get scene description if ( $mgfin ) { - system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn}; + system "mgf2rad @ARGV > $radscn"; + die "Could not load MGF input\n" if ( $? ); } else { - system "rad2mgf $radscn >> $mgfscn"; + system "xform -e @ARGV > $radscn"; + die "Could not load Radiance input\n" if ( $? ); } - open(MGFSCN, ">> $mgfscn"); - print MGFSCN "xf\n"; - close MGFSCN; - $wrapper .= " -g $mgfscn"; } -# Create receiver & sender surfaces (rectangular) -my $FEPS = 1e-5; -my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1); -my $ny = int($nsamp/$nx + 1); -$nsamp = $nx * $ny; -my $ns = 2**$ttlog2; -open(RADSCN, "> $receivers"); -print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n"); -print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n"; -print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n"; -print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n"; -print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n"); -print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n"; -print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n"; -print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n"; -close RADSCN; -# Finish rfluxmtx command and prepare sender surfaces -$rfluxmtx .= " -n $nproc -c $nsamp"; -if ( $tensortree != 3 ) { # Isotropic tensor tree is exception - open (RADSCN, "> $fsender"); - print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n"); - print RADSCN "void polygon fwd_sender\n0\n0\n12\n"; - printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS; - close RADSCN; - open (RADSCN, "> $bsender"); - print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n"); - print RADSCN "void polygon bwd_sender\n0\n0\n12\n"; - printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS; - printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS; - close RADSCN; +if ( $#dim != 5 ) { + @dim = split ' ', `getbbox -h $radscn`; } +die "Device entirely inside room!\n" if ( $dim[4] >= 0 ); +if ( $dim[5] > 1e-5 ) { + print STDERR "Warning: Device extends into room\n"; +} elsif ( $dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2]) ) { + print STDERR "Warning: Device far behind Z==0 plane\n"; +} +# Assume Zmax==0 to derive thickness so pkgBSDF will work +$wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) . + ';h=' . ($dim[3] - $dim[2]) . '"'; +$wrapper .= " -g $mgfscn" if ( $geout ); # Calculate CIE (u',v') from Radiance RGB: my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' . 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' . 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' . 'den=Xi+15*Yi+3*Zi;' . 'uprime=4*Xi/den;vprime=9*Yi/den;' ; +my $FEPS = 1e-5; +my $ns = 2**$ttlog2; +my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1); +my $ny = int($nsamp/$nx + 1); +$nsamp = $nx * $ny; +$rfluxmtx .= " -n $nproc -c $nsamp"; +if ( !defined $recovery ) { + open(MYAVH, "> $td/savedARGV.txt"); + foreach (@savedARGV) { + print MYAVH "$_\n"; + } + close MYAVH; + # Generate octree + system "oconv -w $radscn > $octree"; + die "Could not compile scene\n" if ( $? ); + # Add MGF description if requested + if ( $geout ) { + open(MGFSCN, "> $mgfscn"); + printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; + close MGFSCN; + if ( $mgfin ) { + system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn}; + } else { + system "rad2mgf $radscn >> $mgfscn"; + } + open(MGFSCN, ">> $mgfscn"); + print MGFSCN "xf\n"; + close MGFSCN; + } + # Create receiver & sender surfaces (rectangular) + open(RADSCN, "> $receivers"); + print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n"); + print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n"; + print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n"; + print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n"; + print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n"); + print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n"; + print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n"; + print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n"; + close RADSCN; + # Prepare sender surfaces + if ( $tensortree != 3 ) { # Isotropic tensor tree is exception + open (RADSCN, "> $fsender"); + print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n"); + print RADSCN "void polygon fwd_sender\n0\n0\n12\n"; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS; + close RADSCN; + open (RADSCN, "> $bsender"); + print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n"); + print RADSCN "void polygon bwd_sender\n0\n0\n12\n"; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS; + printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS; + close RADSCN; + } + print STDERR "Recover using: $0 -recover $td\n"; +} +# Open unbuffered progress file +open(MYPH, ">> $td/phase.txt"); +{ + my $ofh = select MYPH; + $| = 1; + select $ofh; +} +$curphase = 0; # Create data segments (all the work happens here) if ( $tensortree ) { do_tree_bsdf(); @@ -228,8 +270,37 @@ die "Could not wrap BSDF data\n" if ( $? ); # Clean up temporary files and exit exec $rmtmp; -#-------------- End of main program segment --------------# +#============== End of main program segment ==============# +# Function to determine if next phase should be skipped or recovered +sub do_phase { + $curphase++; + if ( defined $recovery ) { + if ( $recovery > $curphase ) { return 0; } + if ( $recovery == $curphase ) { return -1; } + } + print MYPH "$curphase\n"; + return 1; +} + +# Check if we are in active phase (not skipping parts) +sub active_phase { + if ( defined $recovery ) { + if ( $recovery > $curphase ) { return 0; } + if ( $recovery == $curphase ) { return -1; } + } + return 1; +} + +# Function to run program and check output if in active phase +sub run_check { + if ( !active_phase() ) { return; } + my $cmd = shift; + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running: $cmd\n" if ( $? ); +} + #++++++++++++++ Tensor tree BSDF generation ++++++++++++++# sub do_tree_bsdf { @@ -242,6 +313,8 @@ sub do_tree_bsdf { # Call rfluxmtx and process tensor tree BSDF for the given direction sub do_ttree_dir { my $forw = shift; + my $dop = do_phase(); + my $r = ($dop < 0) ? " -r" : ""; my $cmd; if ( $tensortree == 3 ) { # Isotropic BSDF @@ -257,7 +330,7 @@ sub do_ttree_dir { qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } . qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } . qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } . - "| $rfluxmtx -fa -y $ns2 - $receivers -i $octree"; + "| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree"; } else { $cmd = "cnt $ns2 $ny $nx " . qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } . @@ -269,20 +342,22 @@ sub do_ttree_dir { qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } . qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } . qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } . - "| $rfluxmtx -h -ff -y $ns2 - $receivers -i $octree"; + "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree"; } } else { # Anisotropic BSDF my $sender = ($bsender,$fsender)[$forw]; if ($windoz) { - $cmd = "$rfluxmtx -fa $sender $receivers -i $octree"; + $cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree"; } else { - $cmd = "$rfluxmtx -h -ff $sender $receivers -i $octree"; + $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree"; } } - # print STDERR "Starting: $cmd\n"; - system $cmd; - die "Failure running rfluxmtx" if ( $? ); + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } ttree_out($forw); } # end of do_ttree_dir() @@ -365,27 +440,27 @@ sub ttree_comp { $cmd .= " -of $src " . "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2"; } - # print STDERR "Running: $cmd\n"; - system "$cmd > $dest"; - die "Failure running rttree_reduce" if ( $? ); + run_check "$cmd > $dest"; } else { if ($windoz) { $cmd = "rcollate -ho -oc 1 $src | " . $cmd ; } else { $cmd .= " $src"; } - open(DATOUT, "> $dest"); - print DATOUT "{\n"; - close DATOUT; - # print STDERR "Running: $cmd\n"; - system "$cmd >> $dest"; - die "Failure running rcalc" if ( $? ); - open(DATOUT, ">> $dest"); - for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { - print DATOUT "0\n"; + if ( active_phase() ) { + open(DATOUT, "> $dest"); + print DATOUT "{\n"; + close DATOUT; + # print STDERR "Running: $cmd\n"; + system "$cmd >> $dest"; + die "Failure running rcalc" if ( $? ); + open(DATOUT, ">> $dest"); + for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { + print DATOUT "0\n"; + } + print DATOUT "}\n"; + close DATOUT; } - print DATOUT "}\n"; - close DATOUT; } if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; @@ -408,12 +483,15 @@ sub do_matrix_bsdf { # Call rfluxmtx and process tensor tree BSDF for the given direction sub do_matrix_dir { my $forw = shift; - my $cmd; + my $dop = do_phase(); + my $r = ($dop < 0) ? " -r" : ""; my $sender = ($bsender,$fsender)[$forw]; - $cmd = "$rfluxmtx -fd $sender $receivers -i $octree"; - # print STDERR "Starting: $cmd\n"; - system $cmd; - die "Failure running rfluxmtx" if ( $? ); + my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree"; + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } matrix_out($forw); } # end of do_matrix_dir() @@ -458,9 +536,7 @@ sub matrix_comp { $cmd .= " -c 0.0241 0.1229 0.8530"; } $cmd .= " $src | rcollate -ho -oc 145"; - # print STDERR "Running: $cmd\n"; - system "$cmd > $dest"; - die "Failure running rmtxop" if ( $? ); + run_check "$cmd > $dest"; if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; $curspec = $spec;
