--- ray/src/util/genBSDF.pl 2015/05/29 07:22:33 2.58 +++ ray/src/util/genBSDF.pl 2016/02/08 00:51:32 2.62 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.58 2015/05/29 07:22:33 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.62 2016/02/08 00:51:32 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -222,13 +222,8 @@ if ( $tensortree ) { do_matrix_bsdf(); } # Output XML -my $old_fh = select(STDOUT); -$| = 1; -select($old_fh); -print "\n"; -print "\n"; # print STDERR "Running: $wrapper\n"; -system $wrapper; +system "$wrapper -C \"Created by: genBSDF @savedARGV\""; die "Could not wrap BSDF data\n" if ( $? ); # Clean up temporary files and exit exec $rmtmp; @@ -465,7 +460,7 @@ sub matrix_comp { $cmd .= " $src | rcollate -ho -oc 145"; # print STDERR "Running: $cmd\n"; system "$cmd > $dest"; - die "Failure running rttree_reduce" if ( $? ); + die "Failure running rmtxop" if ( $? ); if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec"; $curspec = $spec;
