root/radiance/ray/src/util/genBSDF.pl
Revision: 2.10
Committed: Tue Feb 22 22:51:23 2011 UTC (14 years, 2 months ago) by greg
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.9 2011/02/21 22:48:51 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 sub userror {
10 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
11 exit 1;
12 }
13 my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
14 chomp $td;
15 my $nsamp = 1000;
16 my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
17 my $mgfin = 0;
18 my $geout = 1;
19 my $nproc = 1;
20 my $doforw = 0;
21 my $doback = 1;
22 my @dim;
23 # Get options
24 while ($#ARGV >= 0) {
25 if ("$ARGV[0]" =~ /^[-+]m/) {
26 $mgfin = ("$ARGV[0]" =~ /^\+/);
27 } elsif ("$ARGV[0]" eq "-r") {
28 $rtargs = "$rtargs $ARGV[1]";
29 shift @ARGV;
30 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
31 $geout = ("$ARGV[0]" =~ /^\+/);
32 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
33 $doforw = ("$ARGV[0]" =~ /^\+/);
34 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
35 $doback = ("$ARGV[0]" =~ /^\+/);
36 } elsif ("$ARGV[0]" eq "-c") {
37 $nsamp = $ARGV[1];
38 shift @ARGV;
39 } elsif ("$ARGV[0]" eq "-n") {
40 $nproc = $ARGV[1];
41 shift @ARGV;
42 } elsif ("$ARGV[0]" =~ /^-d/) {
43 userror() if ($#ARGV < 6);
44 @dim = @ARGV[1..6];
45 shift @ARGV for (1..6);
46 } elsif ("$ARGV[0]" =~ /^[-+]./) {
47 userror();
48 } else {
49 last;
50 }
51 shift @ARGV;
52 }
53 # Check that we're actually being asked to do something
54 die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
55 # Get scene description and dimensions
56 my $radscn = "$td/device.rad";
57 my $mgfscn = "$td/device.mgf";
58 my $octree = "$td/device.oct";
59 if ( $mgfin ) {
60 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
61 die "Could not load MGF input\n" if ( $? );
62 system "mgf2rad $mgfscn > $radscn";
63 } else {
64 system "cat @ARGV | xform -e > $radscn";
65 die "Could not load Radiance input\n" if ( $? );
66 system "rad2mgf $radscn > $mgfscn" if ( $geout );
67 }
68 if ($#dim != 5) {
69 @dim = split ' ', `getbbox -h $radscn`;
70 }
71 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
72 # Add receiver surfaces (rectangular)
73 my $fmodnm="receiver_face";
74 my $bmodnm="receiver_behind";
75 open(RADSCN, ">> $radscn");
76 print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
77 print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
78 print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
79 print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
80 close RADSCN;
81 # Generate octree
82 system "oconv -w $radscn > $octree";
83 die "Could not compile scene\n" if ( $? );
84 # Set up sampling of interior portal
85 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
86 my $tcal = '
87 DEGREE : PI/180;
88 sq(x) : x*x;
89 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
90 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
91 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
92 Kmax : Kaccum(Knaz(0));
93 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
94 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
95 Kcol = Kbin - Kaccum(Krow-1);
96 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
97 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
98 sin_kpol = sin(Kpol);
99 Dx = cos(Kazi)*sin_kpol;
100 Dy = sin(Kazi)*sin_kpol;
101 Dz = sqrt(1 - sin_kpol*sin_kpol);
102 KprojOmega = PI * if(Kbin-.5,
103 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
104 1 - sq(cos(Kpola(1)*DEGREE)));
105 ';
106 # Compute Klems bin from exiting ray direction (forward or backward)
107 my $kcal = '
108 DEGREE : PI/180;
109 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
110 posangle(a) : if(-a, a + 2*PI, a);
111 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
112 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
113 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
114 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
115 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
116 if(pol-kpola(r), kfindrow(r+1, pol), r) );
117 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
118 kbin2(pol,azi) = select(kfindrow(1, pol),
119 kazn(azi,360/knaz(1)),
120 kaccum(1) + kazn(azi,360/knaz(2)),
121 kaccum(2) + kazn(azi,360/knaz(3)),
122 kaccum(3) + kazn(azi,360/knaz(4)),
123 kaccum(4) + kazn(azi,360/knaz(5)),
124 kaccum(5) + kazn(azi,360/knaz(6)),
125 kaccum(6) + kazn(azi,360/knaz(7)),
126 kaccum(7) + kazn(azi,360/knaz(8)),
127 kaccum(8) + kazn(azi,360/knaz(9))
128 );
129 kbin = if(Dz, kbin2(Acos(Dz),Atan2(Dy,Dx)), kbin2(Acos(-Dz),Atan2(-Dy,-Dx)));
130 ';
131 my $ndiv = 145;
132 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
133 my $ny = int($nsamp/$nx + .5);
134 $nsamp = $nx * $ny;
135 # Compute scattering data using rtcontrib
136 my @tfarr;
137 my @rfarr;
138 my @tbarr;
139 my @rbarr;
140 my $cmd;
141 my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
142 "-e '$kcal' -b kbin -bn $ndiv " .
143 "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
144 my $rccmd = "rcalc -e '$tcal' " .
145 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
146 q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
147 if ( $doforw ) {
148 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
149 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
150 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
151 "-e 'zp:$dim[4]' " .
152 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
153 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
154 "| $rtcmd";
155 system "$cmd" || die "Failure running: $cmd\n";
156 @tfarr = `$rccmd $td/$fmodnm.flt`;
157 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
158 @rfarr = `$rccmd $td/$bmodnm.flt`;
159 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
160 }
161 if ( $doback ) {
162 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
163 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
164 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
165 "-e 'zp:$dim[5]' " .
166 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
167 q{-e '$1=xp+Dx;$2=yp+Dy;$3=zp+Dz;$4=-Dx;$5=-Dy;$6=-Dz' } .
168 "| $rtcmd";
169 system "$cmd" || die "Failure running: $cmd\n";
170 @tbarr = `$rccmd $td/$bmodnm.flt`;
171 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
172 @rbarr = `$rccmd $td/$fmodnm.flt`;
173 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
174 }
175 # Output XML prologue
176 print
177 '<?xml version="1.0" encoding="UTF-8"?>
178 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
179 <WindowElementType>System</WindowElementType>
180 <Optical>
181 <Layer>
182 <Material>
183 <Name>Name</Name>
184 <Manufacturer>Manufacturer</Manufacturer>
185 ';
186 printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4];
187 printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0];
188 printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2];
189 print "\t\t\t<DeviceType>Integral</DeviceType>\n";
190 # Output MGF description if requested
191 if ( $geout ) {
192 print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n";
193 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
194 system "cat $mgfscn";
195 print "xf\n";
196 print "\t\t\t</Geometry>\n";
197 }
198 print ' </Material>
199 <DataDefinition>
200 <IncidentDataStructure>Columns</IncidentDataStructure>
201 <AngleBasis>
202 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
203 <AngleBasisBlock>
204 <Theta>0</Theta>
205 <nPhis>1</nPhis>
206 <ThetaBounds>
207 <LowerTheta>0</LowerTheta>
208 <UpperTheta>5</UpperTheta>
209 </ThetaBounds>
210 </AngleBasisBlock>
211 <AngleBasisBlock>
212 <Theta>10</Theta>
213 <nPhis>8</nPhis>
214 <ThetaBounds>
215 <LowerTheta>5</LowerTheta>
216 <UpperTheta>15</UpperTheta>
217 </ThetaBounds>
218 </AngleBasisBlock>
219 <AngleBasisBlock>
220 <Theta>20</Theta>
221 <nPhis>16</nPhis>
222 <ThetaBounds>
223 <LowerTheta>15</LowerTheta>
224 <UpperTheta>25</UpperTheta>
225 </ThetaBounds>
226 </AngleBasisBlock>
227 <AngleBasisBlock>
228 <Theta>30</Theta>
229 <nPhis>20</nPhis>
230 <ThetaBounds>
231 <LowerTheta>25</LowerTheta>
232 <UpperTheta>35</UpperTheta>
233 </ThetaBounds>
234 </AngleBasisBlock>
235 <AngleBasisBlock>
236 <Theta>40</Theta>
237 <nPhis>24</nPhis>
238 <ThetaBounds>
239 <LowerTheta>35</LowerTheta>
240 <UpperTheta>45</UpperTheta>
241 </ThetaBounds>
242 </AngleBasisBlock>
243 <AngleBasisBlock>
244 <Theta>50</Theta>
245 <nPhis>24</nPhis>
246 <ThetaBounds>
247 <LowerTheta>45</LowerTheta>
248 <UpperTheta>55</UpperTheta>
249 </ThetaBounds>
250 </AngleBasisBlock>
251 <AngleBasisBlock>
252 <Theta>60</Theta>
253 <nPhis>24</nPhis>
254 <ThetaBounds>
255 <LowerTheta>55</LowerTheta>
256 <UpperTheta>65</UpperTheta>
257 </ThetaBounds>
258 </AngleBasisBlock>
259 <AngleBasisBlock>
260 <Theta>70</Theta>
261 <nPhis>16</nPhis>
262 <ThetaBounds>
263 <LowerTheta>65</LowerTheta>
264 <UpperTheta>75</UpperTheta>
265 </ThetaBounds>
266 </AngleBasisBlock>
267 <AngleBasisBlock>
268 <Theta>82.5</Theta>
269 <nPhis>12</nPhis>
270 <ThetaBounds>
271 <LowerTheta>75</LowerTheta>
272 <UpperTheta>90</UpperTheta>
273 </ThetaBounds>
274 </AngleBasisBlock>
275 </AngleBasis>
276 </DataDefinition>
277 ';
278 if ( $doforw ) {
279 print ' <WavelengthData>
280 <LayerNumber>System</LayerNumber>
281 <Wavelength unit="Integral">Visible</Wavelength>
282 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
283 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
284 <WavelengthDataBlock>
285 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
286 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
287 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
288 <ScatteringDataType>BTDF</ScatteringDataType>
289 <ScatteringData>
290 ';
291 # Output front transmission (transposed order)
292 for (my $od = 0; $od < $ndiv; $od++) {
293 for (my $id = 0; $id < $ndiv; $id++) {
294 print $tfarr[$ndiv*$id + $od];
295 }
296 print "\n";
297 }
298 print
299 ' </ScatteringData>
300 </WavelengthDataBlock>
301 </WavelengthData>
302 <WavelengthData>
303 <LayerNumber>System</LayerNumber>
304 <Wavelength unit="Integral">Visible</Wavelength>
305 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
306 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
307 <WavelengthDataBlock>
308 <WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
309 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
310 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
311 <ScatteringDataType>BRDF</ScatteringDataType>
312 <ScatteringData>
313 ';
314 # Output front reflection (transposed order)
315 for (my $od = 0; $od < $ndiv; $od++) {
316 for (my $id = 0; $id < $ndiv; $id++) {
317 print $rfarr[$ndiv*$id + $od];
318 }
319 print "\n";
320 }
321 print
322 ' </ScatteringData>
323 </WavelengthDataBlock>
324 </WavelengthData>
325 ';
326 }
327 if ( $doback ) {
328 print ' <WavelengthData>
329 <LayerNumber>System</LayerNumber>
330 <Wavelength unit="Integral">Visible</Wavelength>
331 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
332 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
333 <WavelengthDataBlock>
334 <WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
335 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
336 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
337 <ScatteringDataType>BTDF</ScatteringDataType>
338 <ScatteringData>
339 ';
340 # Output back transmission (transposed order)
341 for (my $od = 0; $od < $ndiv; $od++) {
342 for (my $id = 0; $id < $ndiv; $id++) {
343 print $tbarr[$ndiv*$id + $od];
344 }
345 print "\n";
346 }
347 print
348 ' </ScatteringData>
349 </WavelengthDataBlock>
350 </WavelengthData>
351 <WavelengthData>
352 <LayerNumber>System</LayerNumber>
353 <Wavelength unit="Integral">Visible</Wavelength>
354 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
355 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
356 <WavelengthDataBlock>
357 <WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
358 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
359 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
360 <ScatteringDataType>BRDF</ScatteringDataType>
361 <ScatteringData>
362 ';
363 # Output back reflection (transposed order)
364 for (my $od = 0; $od < $ndiv; $od++) {
365 for (my $id = 0; $id < $ndiv; $id++) {
366 print $rbarr[$ndiv*$id + $od];
367 }
368 print "\n";
369 }
370 print
371 ' </ScatteringData>
372 </WavelengthDataBlock>
373 </WavelengthData>
374 ';
375 }
376 # Output XML epilogue
377 print '</Layer>
378 </Optical>
379 </WindowElement>
380 ';
381 # Clean up temporary files
382 system "rm -rf $td";
