1 |
#!/usr/bin/perl -w |
2 |
# RCSid $Id: genBSDF.pl,v 2.47 2014/04/24 23:08:08 greg Exp $ |
3 |
4 |
# Compute BSDF based on geometry and material description |
5 |
6 |
# G. Ward |
7 |
8 |
use strict; |
9 |
my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64"); |
10 |
use File::Temp qw/ :mktemp /; |
11 |
sub userror { |
12 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n"; |
13 |
exit 1; |
14 |
15 |
my ($td,$radscn,$mgfscn,$octree,$cnttmp,$rmtmp); |
16 |
if ($windoz) { |
17 |
my $tmploc = `echo \%TMP\%`; |
18 |
chomp($tmploc); |
19 |
$td = mkdtemp("$tmploc\\genBSDF.XXXXXX"); |
20 |
$radscn = "$td\\device.rad"; |
21 |
$mgfscn = "$td\\device.mgf"; |
22 |
$octree = "$td\\device.oct"; |
23 |
chomp $td; |
24 |
$rmtmp = "rmdir /S /Q $td"; |
25 |
} else{ |
26 |
$td = mkdtemp("/tmp/genBSDF.XXXXXX"); |
27 |
chomp $td; |
28 |
$radscn = "$td/device.rad"; |
29 |
$mgfscn = "$td/device.mgf"; |
30 |
$octree = "$td/device.oct"; |
31 |
$rmtmp = "rm -rf $td"; |
32 |
33 |
my @savedARGV = @ARGV; |
34 |
my $tensortree = 0; |
35 |
my $ttlog2 = 4; |
36 |
my $nsamp = 2000; |
37 |
my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6"; |
38 |
my $mgfin = 0; |
39 |
my $geout = 1; |
40 |
my $nproc = 1; |
41 |
my $doforw = 0; |
42 |
my $doback = 1; |
43 |
my $pctcull = 90; |
44 |
my $gunit = "meter"; |
45 |
my @dim; |
46 |
# Get options |
47 |
while ($#ARGV >= 0) { |
48 |
if ("$ARGV[0]" =~ /^[-+]m/) { |
49 |
$mgfin = ("$ARGV[0]" =~ /^\+/); |
50 |
} elsif ("$ARGV[0]" eq "-r") { |
51 |
$rtargs = "$rtargs $ARGV[1]"; |
52 |
shift @ARGV; |
53 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) { |
54 |
$geout = ("$ARGV[0]" =~ /^\+/); |
55 |
$gunit = $ARGV[1]; |
56 |
if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) { |
57 |
die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n"; |
58 |
59 |
shift @ARGV; |
60 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) { |
61 |
$doforw = ("$ARGV[0]" =~ /^\+/); |
62 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) { |
63 |
$doback = ("$ARGV[0]" =~ /^\+/); |
64 |
} elsif ("$ARGV[0]" eq "-t") { |
65 |
# Use value < 0 for rttree_reduce bypass |
66 |
$pctcull = $ARGV[1]; |
67 |
shift @ARGV; |
68 |
} elsif ("$ARGV[0]" =~ /^-t[34]$/) { |
69 |
$tensortree = substr($ARGV[0], 2, 1); |
70 |
$ttlog2 = $ARGV[1]; |
71 |
shift @ARGV; |
72 |
} elsif ("$ARGV[0]" eq "-c") { |
73 |
$nsamp = $ARGV[1]; |
74 |
shift @ARGV; |
75 |
} elsif ("$ARGV[0]" eq "-n") { |
76 |
$nproc = $ARGV[1]; |
77 |
shift @ARGV; |
78 |
} elsif ("$ARGV[0]" =~ /^-d/) { |
79 |
userror() if ($#ARGV < 6); |
80 |
@dim = @ARGV[1..6]; |
81 |
shift @ARGV for (1..6); |
82 |
} elsif ("$ARGV[0]" =~ /^[-+]./) { |
83 |
userror(); |
84 |
} else { |
85 |
last; |
86 |
87 |
shift @ARGV; |
88 |
89 |
# Check that we're actually being asked to do something |
90 |
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback); |
91 |
# Issue warning for unhandled reciprocity case |
92 |
print STDERR "Warning: recommend both +forward and +backward with -t3" if |
93 |
($tensortree==3 && !($doforw && $doback)); |
94 |
# Get scene description and dimensions |
95 |
96 |
if ( $mgfin ) { |
97 |
system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV > $mgfscn}; |
98 |
die "Could not load MGF input\n" if ( $? ); |
99 |
system "mgf2rad $mgfscn > $radscn"; |
100 |
} else { |
101 |
system "xform -e @ARGV > $radscn"; |
102 |
die "Could not load Radiance input\n" if ( $? ); |
103 |
system "rad2mgf $radscn > $mgfscn" if ( $geout ); |
104 |
105 |
if ($#dim != 5) { |
106 |
@dim = split ' ', `getbbox -h $radscn`; |
107 |
108 |
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); |
109 |
# Add receiver surfaces (rectangular) |
110 |
my $fmodnm="receiver_face"; |
111 |
my $bmodnm="receiver_behind"; |
112 |
open(RADSCN, ">> $radscn"); |
113 |
print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n"; |
114 |
print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n"; |
115 |
print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n"; |
116 |
print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n"; |
117 |
close RADSCN; |
118 |
# Generate octree |
119 |
system "oconv -w $radscn > $octree"; |
120 |
die "Could not compile scene\n" if ( $? ); |
121 |
# Output XML prologue |
122 |
print |
123 |
'<?xml version="1.0" encoding="UTF-8"?> |
124 |
<WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd"> |
125 |
126 |
print "<!-- File produced by: genBSDF @savedARGV -->\n"; |
127 |
print |
128 |
'<WindowElementType>System</WindowElementType> |
129 |
<FileType>BSDF</FileType> |
130 |
<Optical> |
131 |
<Layer> |
132 |
<Material> |
133 |
<Name>Name</Name> |
134 |
<Manufacturer>Manufacturer</Manufacturer> |
135 |
136 |
printf qq{\t\t<Thickness unit="$gunit">%.6f</Thickness>\n}, $dim[5] - $dim[4]; |
137 |
printf qq{\t\t<Width unit="$gunit">%.6f</Width>\n}, $dim[1] - $dim[0]; |
138 |
printf qq{\t\t<Height unit="$gunit">%.6f</Height>\n}, $dim[3] - $dim[2]; |
139 |
print "\t\t<DeviceType>Other</DeviceType>\n"; |
140 |
print "\t</Material>\n"; |
141 |
# Output MGF description if requested |
142 |
if ( $geout ) { |
143 |
print qq{\t\t<Geometry format="MGF">\n}; |
144 |
print qq{\t\t<MGFblock unit="$gunit">\n}; |
145 |
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; |
146 |
open(MGFSCN, "< $mgfscn"); |
147 |
while (<MGFSCN>) { print $_; } |
148 |
close MGFSCN; |
149 |
print "xf\n"; |
150 |
print "</MGFblock>\n"; |
151 |
print "\t</Geometry>\n"; |
152 |
153 |
# Set up surface sampling |
154 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1); |
155 |
my $ny = int($nsamp/$nx + 1); |
156 |
$nsamp = $nx * $ny; |
157 |
my $ns = 2**$ttlog2; |
158 |
my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal); |
159 |
# Create data segments (all the work happens here) |
160 |
if ( $tensortree ) { |
161 |
do_tree_bsdf(); |
162 |
} else { |
163 |
do_matrix_bsdf(); |
164 |
165 |
# Output XML epilogue |
166 |
print |
167 |
'</Layer> |
168 |
</Optical> |
169 |
</WindowElement> |
170 |
171 |
# Clean up temporary files and exit |
172 |
system $rmtmp; |
173 |
174 |
#-------------- End of main program segment --------------# |
175 |
176 |
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++# |
177 |
sub do_tree_bsdf { |
178 |
# Shirley-Chiu mapping from unit square to disk |
179 |
$sq2disk = 'in_square_a = 2*in_square_x - 1; ' . |
180 |
'in_square_b = 2*in_square_y - 1; ' . |
181 |
'in_square_rgn = if(in_square_a + in_square_b, ' . |
182 |
'if(in_square_a - in_square_b, 1, 2), ' . |
183 |
'if(in_square_b - in_square_a, 3, 4)); ' . |
184 |
'out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b, ' . |
185 |
'-in_square_a, -in_square_b); ' . |
186 |
'out_disk_phi = PI/4 * select(in_square_rgn, ' . |
187 |
'in_square_b/in_square_a, ' . |
188 |
'2 - in_square_a/in_square_b, ' . |
189 |
'4 + in_square_b/in_square_a, ' . |
190 |
'if(in_square_b*in_square_b, ' . |
191 |
'6 - in_square_a/in_square_b, 0)); ' . |
192 |
'Dx = out_disk_r*cos(out_disk_phi); ' . |
193 |
'Dy = out_disk_r*sin(out_disk_phi); ' . |
194 |
'Dz = sqrt(1 - out_disk_r*out_disk_r);' ; |
195 |
# Shirley-Chiu mapping from unit disk to square |
196 |
$disk2sq = 'norm_radians(p) : if(-p - PI/4, p + 2*PI, p); ' . |
197 |
'in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy); ' . |
198 |
'in_disk_phi = norm_radians(atan2(Dy, Dx)); ' . |
199 |
'in_disk_rgn = floor((.999995*in_disk_phi + PI/4)/(PI/2)) + 1; ' . |
200 |
'out_square_a = select(in_disk_rgn, ' . |
201 |
'in_disk_r, ' . |
202 |
'(PI/2 - in_disk_phi)*in_disk_r/(PI/4), ' . |
203 |
'-in_disk_r, ' . |
204 |
'(in_disk_phi - 3*PI/2)*in_disk_r/(PI/4)); ' . |
205 |
'out_square_b = select(in_disk_rgn, ' . |
206 |
'in_disk_phi*in_disk_r/(PI/4), ' . |
207 |
'in_disk_r, ' . |
208 |
'(PI - in_disk_phi)*in_disk_r/(PI/4), ' . |
209 |
'-in_disk_r); ' . |
210 |
'out_square_x = (out_square_a + 1)/2; ' . |
211 |
'out_square_y = (out_square_b + 1)/2;'; |
212 |
# Announce ourselves in XML output |
213 |
print "\t<DataDefinition>\n"; |
214 |
print "\t\t<IncidentDataStructure>TensorTree$tensortree</IncidentDataStructure>\n"; |
215 |
print "\t</DataDefinition>\n"; |
216 |
217 |
# Start rcontrib processes for compute each side |
218 |
do_tree_rtcontrib(0) if ( $doback ); |
219 |
do_tree_rtcontrib(1) if ( $doforw ); |
220 |
221 |
} # end of sub do_tree_bsdf() |
222 |
223 |
# Run rcontrib process to generate tensor tree samples |
224 |
sub do_tree_rtcontrib { |
225 |
my $forw = shift; |
226 |
my $cmd; |
227 |
my $matargs = "-m $bmodnm"; |
228 |
if ( !$forw || !$doback || $tensortree==3 ) { $matargs .= " -m $fmodnm"; } |
229 |
if ($windoz) { |
230 |
$cmd = "rcontrib $rtargs -h -faa -fo -n $nproc -c $nsamp " . |
231 |
qq{-e "$disk2sq" -bn "$ns*$ns" } . |
232 |
qq{-b "$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)" } . |
233 |
"-o $td/%s.flt $matargs $octree"; |
234 |
} else { |
235 |
$cmd = "rcontrib $rtargs -h -fff -fo -n $nproc -c $nsamp " . |
236 |
237 |
238 |
239 |
240 |
if ( $tensortree == 3 ) { |
241 |
# Isotropic BSDF |
242 |
my $ns2 = $ns / 2; |
243 |
if ($windoz) { |
244 |
$cmd = "cnt $ns2 $ny $nx " . |
245 |
qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } . |
246 |
qq{-e "r2=rand(-5.37138*recno+67.1737811)" } . |
247 |
qq{-e "r3=rand(+3.17603772*recno+83.766771)" } . |
248 |
qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } . |
249 |
qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . |
250 |
qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . |
251 |
qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } . |
252 |
qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } . |
253 |
qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } . |
254 |
"| $cmd"; |
255 |
} else { |
256 |
257 |
258 |
259 |
260 |
261 |
262 |
263 |
264 |
qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } . |
265 |
qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } . |
266 |
"| $cmd"; |
267 |
268 |
} else { |
269 |
# Anisotropic BSDF |
270 |
# Sample area vertically to improve load balance, since |
271 |
# shading systems usually have bilateral symmetry (L-R) |
272 |
if ($windoz) { |
273 |
$cmd = "cnt $ns $ns $ny $nx " . |
274 |
275 |
276 |
qq{-e "r3=rand(3.17603772*recno+83.766771)" } . |
277 |
qq{-e "r4=rand(-2.3857833*recno-964.72738)" } . |
278 |
qq{-e "in_square_x=(\$1+r1)/$ns" } . |
279 |
qq{-e "in_square_y=(\$2+r2)/$ns" -e "$sq2disk" } . |
280 |
qq{-e "xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . |
281 |
qq{-e "yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . |
282 |
283 |
284 |
285 |
"| $cmd"; |
286 |
} else { |
287 |
288 |
289 |
290 |
291 |
292 |
293 |
294 |
295 |
296 |
297 |
298 |
299 |
"| $cmd"; |
300 |
301 |
302 |
# print STDERR "Starting: $cmd\n"; |
303 |
system "$cmd" || die "Failure running rcontrib"; |
304 |
ttree_out($forw); |
305 |
} # end of do_tree_rtcontrib() |
306 |
307 |
# Simplify and output tensor tree results |
308 |
sub ttree_out { |
309 |
my $forw = shift; |
310 |
my $side = ("Back","Front")[$forw]; |
311 |
my $cmd; |
312 |
# Only output one transmitted anisotropic distribution, preferring backwards |
313 |
if ( !$forw || !$doback || $tensortree==3 ) { |
314 |
print |
315 |
' <WavelengthData> |
316 |
<LayerNumber>System</LayerNumber> |
317 |
<Wavelength unit="Integral">Visible</Wavelength> |
318 |
<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum> |
319 |
<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum> |
320 |
<WavelengthDataBlock>' ; |
321 |
print "\t\t\t<WavelengthDataDirection>Transmission $side</WavelengthDataDirection>\n"; |
322 |
print |
323 |
' <AngleBasis>LBNL/Shirley-Chiu</AngleBasis> |
324 |
<ScatteringDataType>BTDF</ScatteringDataType> |
325 |
<ScatteringData> |
326 |
327 |
if ($windoz) { |
328 |
$cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } . |
329 |
q{-e "$1=(0.265*$1+0.670*$2+0.065*$3)/Omega" }; |
330 |
} else { |
331 |
$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " . |
332 |
q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' }; |
333 |
334 |
if ($pctcull >= 0) { |
335 |
if ($windoz) { |
336 |
$cmd = "rcollate -h -oc 1 $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt | " . |
337 |
$cmd . |
338 |
"| rttree_reduce -h -fa -t $pctcull -r $tensortree -g $ttlog2"; |
339 |
} else { |
340 |
$cmd .= "-of $td/" . ($bmodnm,$fmodnm)[$forw] . ".flt " . |
341 |
" | rttree_reduce -h -ff -t $pctcull -r $tensortree -g $ttlog2"; |
342 |
343 |
system "$cmd" || die "Failure running rttree_reduce"; |
344 |
} else { |
345 |
if ($windoz) { |
346 |
347 |
$cmd ; |
348 |
} else { |
349 |
$cmd .= "$td/" . ($bmodnm,$fmodnm)[$forw] . ".flt"; |
350 |
351 |
print "{\n"; |
352 |
system "$cmd" || die "Failure running rcalc"; |
353 |
for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) { |
354 |
print "0\n"; |
355 |
356 |
print "}\n"; |
357 |
358 |
print |
359 |
' </ScatteringData> |
360 |
</WavelengthDataBlock> |
361 |
</WavelengthData> |
362 |
363 |
364 |
# Output reflection |
365 |
print |
366 |
367 |
368 |
369 |
370 |
371 |
<WavelengthDataBlock> |
372 |
373 |
print "\t\t\t<WavelengthDataDirection>Reflection $side</WavelengthDataDirection>\n"; |
374 |
print |
375 |
376 |
377 |
<ScatteringData> |
378 |
379 |
if ($windoz) { |
380 |
381 |
382 |
}else { |
383 |
384 |
385 |
386 |
387 |
if ($windoz) { |
388 |
$cmd = "rcollate -h -oc 1 $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt |" . |
389 |
$cmd . |
390 |
" | rttree_reduce -a -h -fa -t $pctcull -r $tensortree -g $ttlog2"; |
391 |
392 |
} else { |
393 |
$cmd .= "-of $td/" . ($fmodnm,$bmodnm)[$forw] . ".flt " . |
394 |
"| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2"; |
395 |
396 |
397 |
} else { |
398 |
if ($windoz) { |
399 |
400 |
$cmd ; |
401 |
} else { |
402 |
$cmd .= "$td/" . ($fmodnm,$bmodnm)[$forw] . ".flt"; |
403 |
404 |
print "{\n"; |
405 |
406 |
407 |
print "0\n"; |
408 |
409 |
print "}\n"; |
410 |
411 |
print |
412 |
413 |
414 |
</WavelengthData> |
415 |
416 |
} # end of ttree_out() |
417 |
418 |
#------------- End of do_tree_bsdf() & subroutines -------------# |
419 |
420 |
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++# |
421 |
sub do_matrix_bsdf { |
422 |
# Set up sampling of portal |
423 |
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms |
424 |
$tcal = 'DEGREE : PI/180; ' . |
425 |
'sq(x) : x*x; ' . |
426 |
'Kpola(r) : select(r+1, 0, 5, 15, 25, 35, 45, 55, 65, 75, 90); ' . |
427 |
'Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); ' . |
428 |
'Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); ' . |
429 |
'Kmax : Kaccum(Knaz(0)); ' . |
430 |
'Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r); ' . |
431 |
'Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin)); ' . |
432 |
'Kcol = Kbin - Kaccum(Krow-1); ' . |
433 |
'Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow); ' . |
434 |
'Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); ' . |
435 |
'sin_kpol = sin(Kpol); ' . |
436 |
'Dx = cos(Kazi)*sin_kpol; ' . |
437 |
'Dy = sin(Kazi)*sin_kpol; ' . |
438 |
'Dz = sqrt(1 - sin_kpol*sin_kpol); ' . |
439 |
'KprojOmega = PI * if(Kbin-.5, ' . |
440 |
'(sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow), ' . |
441 |
'1 - sq(cos(Kpola(1)*DEGREE))); '; |
442 |
# Compute Klems bin from exiting ray direction (forward or backward) |
443 |
$kcal = 'DEGREE : PI/180; ' . |
444 |
'abs(x) : if(x, x, -x); ' . |
445 |
'Acos(x) : if(x-1, 0, if(-1-x, PI, acos(x)))/DEGREE; ' . |
446 |
'posangle(a) : if(-a, a + 2*PI, a); ' . |
447 |
'Atan2(y,x) : posangle(atan2(y,x))/DEGREE; ' . |
448 |
'kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90); ' . |
449 |
'knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); ' . |
450 |
'kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0); ' . |
451 |
'kfindrow(r, pol) : if(r-kpola(0)+.5, r, ' . |
452 |
'if(pol-kpola(r), kfindrow(r+1, pol), r) ); ' . |
453 |
'kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0); ' . |
454 |
'kbin2(pol,azi) = select(kfindrow(1, pol), ' . |
455 |
'kazn(azi,360/knaz(1)), ' . |
456 |
'kaccum(1) + kazn(azi,360/knaz(2)), ' . |
457 |
'kaccum(2) + kazn(azi,360/knaz(3)), ' . |
458 |
'kaccum(3) + kazn(azi,360/knaz(4)), ' . |
459 |
'kaccum(4) + kazn(azi,360/knaz(5)), ' . |
460 |
'kaccum(5) + kazn(azi,360/knaz(6)), ' . |
461 |
'kaccum(6) + kazn(azi,360/knaz(7)), ' . |
462 |
'kaccum(7) + kazn(azi,360/knaz(8)), ' . |
463 |
'kaccum(8) + kazn(azi,360/knaz(9)) ' . |
464 |
465 |
'kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));'; |
466 |
my $ndiv = 145; |
467 |
# Compute scattering data using rcontrib |
468 |
my @tfarr; |
469 |
my @rfarr; |
470 |
my @tbarr; |
471 |
my @rbarr; |
472 |
my (@data,@line); # for windows |
473 |
my $cmd; |
474 |
my $rtcmd; |
475 |
my $rccmd; |
476 |
if ($windoz) { |
477 |
$rtcmd = "rcontrib $rtargs -h -fo -n $nproc -c $nsamp " . |
478 |
qq{-e "$kcal" -b kbin -bn $ndiv } . |
479 |
qq{-o "$td\\%s.flt" -m $fmodnm -m $bmodnm $octree }; |
480 |
$rccmd = qq{rcalc -e "$tcal" } . |
481 |
qq{-e "mod(n,d):n-floor(n/d)*d" -e "Kbin=mod(recno-.999,$ndiv)" } . |
482 |
q{ -e "$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega" }; |
483 |
} else { |
484 |
$rtcmd = "rcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " . |
485 |
"-e '$kcal' -b kbin -bn $ndiv " . |
486 |
"-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree"; |
487 |
$rccmd = "rcalc -e '$tcal' " . |
488 |
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " . |
489 |
q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' }; |
490 |
491 |
if ( $doforw ) { |
492 |
if ($windoz) { |
493 |
$cmd = qq{cnt $ndiv $ny $nx | rcalc -e "$tcal" } . |
494 |
qq{-e "xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . |
495 |
qq{-e "yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . |
496 |
qq{-e "zp:$dim[4]" } . |
497 |
q{-e "Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)" } . |
498 |
q{-e "$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz" } . |
499 |
"| $rtcmd "; |
500 |
} else { |
501 |
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " . |
502 |
"-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
503 |
"-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
504 |
"-e 'zp:$dim[4]' " . |
505 |
q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } . |
506 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } . |
507 |
"| $rtcmd"; |
508 |
509 |
system "$cmd" || die "Failure running: $cmd\n"; |
510 |
if ($windoz) { |
511 |
@tfarr = `rcollate -h -oc 1 $td\\$fmodnm.flt | $rccmd`; |
512 |
} else { |
513 |
@tfarr = `$rccmd $td/$fmodnm.flt`; |
514 |
515 |
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? ); |
516 |
if ($windoz) { |
517 |
@rfarr = `rcollate -h -oc 1 $td\\$bmodnm.flt | $rccmd`; |
518 |
} else { |
519 |
@rfarr = `$rccmd $td/$bmodnm.flt`; |
520 |
521 |
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? ); |
522 |
523 |
if ( $doback ) { |
524 |
if ($windoz) { |
525 |
526 |
qq{-e "xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . |
527 |
qq{-e "yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . |
528 |
qq{-e "zp:$dim[5]" } . |
529 |
q{-e "Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)" } . |
530 |
q{-e "$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz" } . |
531 |
"| $rtcmd"; |
532 |
} else { |
533 |
534 |
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
535 |
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
536 |
"-e 'zp:$dim[5]' " . |
537 |
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } . |
538 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } . |
539 |
"| $rtcmd"; |
540 |
541 |
542 |
if ($windoz) { |
543 |
@tbarr = `rcollate -h -oc 1 $td\\$bmodnm.flt | $rccmd`; |
544 |
} else { |
545 |
@tbarr = `$rccmd $td/$bmodnm.flt`; |
546 |
547 |
548 |
chomp(@tbarr); |
549 |
if ($windoz) { |
550 |
@rbarr = `rcollate -h -oc 1 $td\\$fmodnm.flt | $rccmd`; |
551 |
} else { |
552 |
@rbarr = `$rccmd $td/$fmodnm.flt`; |
553 |
554 |
555 |
chomp(@rbarr); |
556 |
557 |
558 |
# Output angle basis |
559 |
print |
560 |
' <DataDefinition> |
561 |
<IncidentDataStructure>Columns</IncidentDataStructure> |
562 |
<AngleBasis> |
563 |
<AngleBasisName>LBNL/Klems Full</AngleBasisName> |
564 |
<AngleBasisBlock> |
565 |
<Theta>0</Theta> |
566 |
<nPhis>1</nPhis> |
567 |
<ThetaBounds> |
568 |
<LowerTheta>0</LowerTheta> |
569 |
<UpperTheta>5</UpperTheta> |
570 |
</ThetaBounds> |
571 |
</AngleBasisBlock> |
572 |
<AngleBasisBlock> |
573 |
<Theta>10</Theta> |
574 |
<nPhis>8</nPhis> |
575 |
<ThetaBounds> |
576 |
<LowerTheta>5</LowerTheta> |
577 |
<UpperTheta>15</UpperTheta> |
578 |
</ThetaBounds> |
579 |
580 |
<AngleBasisBlock> |
581 |
<Theta>20</Theta> |
582 |
<nPhis>16</nPhis> |
583 |
<ThetaBounds> |
584 |
<LowerTheta>15</LowerTheta> |
585 |
<UpperTheta>25</UpperTheta> |
586 |
</ThetaBounds> |
587 |
588 |
<AngleBasisBlock> |
589 |
<Theta>30</Theta> |
590 |
<nPhis>20</nPhis> |
591 |
<ThetaBounds> |
592 |
<LowerTheta>25</LowerTheta> |
593 |
<UpperTheta>35</UpperTheta> |
594 |
</ThetaBounds> |
595 |
596 |
<AngleBasisBlock> |
597 |
<Theta>40</Theta> |
598 |
<nPhis>24</nPhis> |
599 |
<ThetaBounds> |
600 |
<LowerTheta>35</LowerTheta> |
601 |
<UpperTheta>45</UpperTheta> |
602 |
</ThetaBounds> |
603 |
604 |
<AngleBasisBlock> |
605 |
<Theta>50</Theta> |
606 |
<nPhis>24</nPhis> |
607 |
<ThetaBounds> |
608 |
<LowerTheta>45</LowerTheta> |
609 |
<UpperTheta>55</UpperTheta> |
610 |
</ThetaBounds> |
611 |
612 |
<AngleBasisBlock> |
613 |
<Theta>60</Theta> |
614 |
<nPhis>24</nPhis> |
615 |
<ThetaBounds> |
616 |
<LowerTheta>55</LowerTheta> |
617 |
<UpperTheta>65</UpperTheta> |
618 |
</ThetaBounds> |
619 |
620 |
<AngleBasisBlock> |
621 |
<Theta>70</Theta> |
622 |
<nPhis>16</nPhis> |
623 |
<ThetaBounds> |
624 |
<LowerTheta>65</LowerTheta> |
625 |
<UpperTheta>75</UpperTheta> |
626 |
</ThetaBounds> |
627 |
628 |
<AngleBasisBlock> |
629 |
<Theta>82.5</Theta> |
630 |
<nPhis>12</nPhis> |
631 |
<ThetaBounds> |
632 |
<LowerTheta>75</LowerTheta> |
633 |
<UpperTheta>90</UpperTheta> |
634 |
</ThetaBounds> |
635 |
636 |
</AngleBasis> |
637 |
</DataDefinition> |
638 |
639 |
if ( $doforw ) { |
640 |
print |
641 |
642 |
643 |
644 |
645 |
646 |
647 |
<WavelengthDataDirection>Transmission Front</WavelengthDataDirection> |
648 |
<ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis> |
649 |
<RowAngleBasis>LBNL/Klems Full</RowAngleBasis> |
650 |
651 |
<ScatteringData> |
652 |
653 |
# Output front transmission (transposed order) |
654 |
for (my $od = 0; $od < $ndiv; $od++) { |
655 |
for (my $id = 0; $id < $ndiv; $id++) { |
656 |
chomp $tfarr[$ndiv*$id + $od]; |
657 |
print $tfarr[$ndiv*$id + $od], ",\t"; |
658 |
659 |
print "\n"; |
660 |
661 |
print |
662 |
663 |
664 |
</WavelengthData> |
665 |
<WavelengthData> |
666 |
667 |
668 |
669 |
670 |
671 |
<WavelengthDataDirection>Reflection Front</WavelengthDataDirection> |
672 |
673 |
674 |
675 |
<ScatteringData> |
676 |
677 |
# Output front reflection (transposed order) |
678 |
679 |
680 |
chomp $rfarr[$ndiv*$id + $od]; |
681 |
print $rfarr[$ndiv*$id + $od], ",\t"; |
682 |
683 |
print "\n"; |
684 |
685 |
print |
686 |
687 |
688 |
</WavelengthData> |
689 |
690 |
691 |
if ( $doback ) { |
692 |
print |
693 |
694 |
695 |
696 |
697 |
698 |
699 |
<WavelengthDataDirection>Transmission Back</WavelengthDataDirection> |
700 |
701 |
702 |
703 |
<ScatteringData> |
704 |
705 |
# Output back transmission (transposed order) |
706 |
707 |
708 |
chomp $tbarr[$ndiv*$id + $od]; |
709 |
print $tbarr[$ndiv*$id + $od], ",\t"; |
710 |
711 |
print "\n"; |
712 |
713 |
print |
714 |
715 |
716 |
</WavelengthData> |
717 |
<WavelengthData> |
718 |
719 |
720 |
721 |
722 |
723 |
<WavelengthDataDirection>Reflection Back</WavelengthDataDirection> |
724 |
725 |
726 |
727 |
<ScatteringData> |
728 |
729 |
# Output back reflection (transposed order) |
730 |
731 |
732 |
chomp $rbarr[$ndiv*$id + $od]; |
733 |
print $rbarr[$ndiv*$id + $od], ",\t"; |
734 |
735 |
print "\n"; |
736 |
737 |
print |
738 |
739 |
740 |
</WavelengthData> |
741 |
742 |
743 |
744 |
#------------- End of do_matrix_bsdf() --------------# |
