1 |
#!/usr/bin/perl -w |
2 |
# RCSid $Id: genBSDF.pl,v 2.2 2010/09/03 23:53:50 greg Exp $ |
3 |
4 |
# Compute BSDF based on geometry and material description |
5 |
6 |
# G. Ward |
7 |
8 |
use strict; |
9 |
sub userror { |
10 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}mgf][{+|-}geom] [input ..]\n"; |
11 |
exit 1; |
12 |
13 |
my $td = `mktemp -d /tmp/genBSDF.XXXXXX`; |
14 |
chomp $td; |
15 |
my $nsamp = 1000; |
16 |
my $mgfin = 0; |
17 |
my $geout = 1; |
18 |
my $nproc = 1; |
19 |
my @dim; |
20 |
# Get options |
21 |
while ($#ARGV >= 0) { |
22 |
if ("$ARGV[0]" =~ /^[-+]m/) { |
23 |
$mgfin = ("$ARGV[0]" =~ /^\+/); |
24 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) { |
25 |
$geout = ("$ARGV[0]" =~ /^\+/); |
26 |
} elsif ("$ARGV[0]" eq "-c") { |
27 |
$nsamp = $ARGV[1]; |
28 |
shift @ARGV; |
29 |
} elsif ("$ARGV[0]" eq "-n") { |
30 |
$nproc = $ARGV[1]; |
31 |
shift @ARGV; |
32 |
} elsif ("$ARGV[0]" =~ /^-d/) { |
33 |
userror() if ($#ARGV < 6); |
34 |
@dim = "@ARGV[1..6]"; |
35 |
shift @ARGV for (1..6); |
36 |
} elsif ("$ARGV[0]" =~ /^[-+]./) { |
37 |
userror(); |
38 |
} else { |
39 |
last; |
40 |
41 |
shift @ARGV; |
42 |
43 |
# Get scene description and dimensions |
44 |
my $radscn = "$td/device.rad"; |
45 |
my $mgfscn = "$td/device.mgf"; |
46 |
my $octree = "$td/device.oct"; |
47 |
if ( $mgfin ) { |
48 |
system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn"; |
49 |
die "Could not load MGF input\n" if ( $? ); |
50 |
system "mgf2rad $mgfscn > $radscn"; |
51 |
} else { |
52 |
system "cat @ARGV | xform -e > $radscn"; |
53 |
die "Could not load Radiance input\n" if ( $? ); |
54 |
system "rad2mgf $radscn > $mgfscn" if ( $geout ); |
55 |
56 |
if ($#dim != 5) { |
57 |
@dim = split /\s+/, `getbbox -h $radscn`; |
58 |
shift @dim; |
59 |
60 |
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); |
61 |
# Add receiver surface (rectangle) |
62 |
my $modnm="_receiver_black_"; |
63 |
open(RADSCN, ">> $radscn"); |
64 |
print RADSCN "void glow $modnm\n0\n0\n4 0 0 0 0\n\n"; |
65 |
print RADSCN "$modnm polygon _receiver_\n0\n0\n12\n"; |
66 |
print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n"; |
67 |
print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n"; |
68 |
print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n"; |
69 |
print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n"; |
70 |
close RADSCN; |
71 |
# Generate octree |
72 |
system "oconv -w $radscn > $octree"; |
73 |
die "Could not compile scene\n" if ( $? ); |
74 |
# Set up sampling |
75 |
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms |
76 |
my $tcal = ' |
77 |
DEGREE : PI/180; |
78 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
79 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
80 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); |
81 |
Kmax : Kaccum(Knaz(0)); |
82 |
Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r); |
83 |
Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin)); |
84 |
Kcol = Kbin - Kaccum(Krow-1); |
85 |
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow); |
86 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); |
87 |
sin_kpol = sin(Kpol); |
88 |
Dx = -cos(Kazi)*sin_kpol; |
89 |
Dy = sin(Kazi)*sin_kpol; |
90 |
Dz = sqrt(1 - sin_kpol*sin_kpol); |
91 |
Komega = 2*PI*if(Kbin-.5, |
92 |
(cos(Kpola(Krow-1)*DEGREE) - cos(Kpola(Krow)*DEGREE))/Knaz(Krow), |
93 |
1 - cos(Kpola(1)*DEGREE)); |
94 |
95 |
# Compute Klems bin from exiting ray direction |
96 |
my $kcal = ' |
97 |
DEGREE : PI/180; |
98 |
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x))); |
99 |
posangle(a) : if(-a, a + 2*PI, a); |
100 |
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x)); |
101 |
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
102 |
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
103 |
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0); |
104 |
kfindrow(r, pol) : if(r-kpola(0)+.5, r, |
105 |
if(pol-kpola(r), kfindrow(r+1, pol), r) ); |
106 |
kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0); |
107 |
kbin2(pol,azi) = select(kfindrow(1, pol), |
108 |
kazn(azi,360/knaz(1)), |
109 |
kaccum(1) + kazn(azi,360/knaz(2)), |
110 |
kaccum(2) + kazn(azi,360/knaz(3)), |
111 |
kaccum(3) + kazn(azi,360/knaz(4)), |
112 |
kaccum(4) + kazn(azi,360/knaz(5)), |
113 |
kaccum(5) + kazn(azi,360/knaz(6)), |
114 |
kaccum(6) + kazn(azi,360/knaz(7)), |
115 |
kaccum(7) + kazn(azi,360/knaz(8)), |
116 |
kaccum(8) + kazn(azi,360/knaz(9)) |
117 |
118 |
kbin = kbin2(Acos(Dz), Atan2(Dy, -Dx)); |
119 |
120 |
my $ndiv = 145; |
121 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5); |
122 |
my $ny = int($nsamp/$nx + .5); |
123 |
$nsamp = $nx * $ny; |
124 |
# Compute scattering data using rtcontrib |
125 |
my $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " . |
126 |
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
127 |
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
128 |
"-e 'zp:$dim[4]-1e-5' " . |
129 |
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } . |
130 |
q{-e '$1=xp;$2=yp;$3=zp;$4=Dx;$5=Dy;$6=Dz' } . |
131 |
"| rtcontrib -h -ff -n $nproc -c $nsamp -e '$kcal' -b kbin -bn $ndiv " . |
132 |
"-m $modnm -w -ab 5 -ad 700 -lw 3e-6 $octree " . |
133 |
"| rcalc -e 'x1:.5;x2:.5;$tcal' -e 'Kbin=floor((recno-1)/$ndiv)' " . |
134 |
q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/(Komega*Dz)'}; |
135 |
my @darr = `$cmd`; |
136 |
die "Failure running: $cmd\n" if ( $? ); |
137 |
# Output XML prologue |
138 |
print |
139 |
'<?xml version="1.0" encoding="UTF-8"?> |
140 |
<WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd"> |
141 |
<WindowElementType>System</WindowElementType> |
142 |
<Optical> |
143 |
<Layer> |
144 |
<Material> |
145 |
<Name>Name</Name> |
146 |
<Manufacturer>Manufacturer</Manufacturer> |
147 |
148 |
printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4]; |
149 |
printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0]; |
150 |
printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2]; |
151 |
print "\t\t\t<DeviceType>Integral</DeviceType>\n"; |
152 |
# Output MGF description if requested |
153 |
if ( $geout ) { |
154 |
print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n"; |
155 |
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; |
156 |
system "cat $mgfscn"; |
157 |
print "xf\n"; |
158 |
print "\t\t\t</Geometry>\n"; |
159 |
160 |
print ' </Material> |
161 |
<DataDefinition> |
162 |
<IncidentDataStructure>Columns</IncidentDataStructure> |
163 |
<AngleBasis> |
164 |
<AngleBasisName>LBNL/Klems Full</AngleBasisName> |
165 |
<AngleBasisBlock> |
166 |
<Theta>0</Theta> |
167 |
<nPhis>1</nPhis> |
168 |
<ThetaBounds> |
169 |
<LowerTheta>0</LowerTheta> |
170 |
<UpperTheta>5</UpperTheta> |
171 |
</ThetaBounds> |
172 |
</AngleBasisBlock> |
173 |
<AngleBasisBlock> |
174 |
<Theta>10</Theta> |
175 |
<nPhis>8</nPhis> |
176 |
<ThetaBounds> |
177 |
<LowerTheta>5</LowerTheta> |
178 |
<UpperTheta>15</UpperTheta> |
179 |
</ThetaBounds> |
180 |
181 |
<AngleBasisBlock> |
182 |
<Theta>20</Theta> |
183 |
<nPhis>16</nPhis> |
184 |
<ThetaBounds> |
185 |
<LowerTheta>15</LowerTheta> |
186 |
<UpperTheta>25</UpperTheta> |
187 |
</ThetaBounds> |
188 |
189 |
<AngleBasisBlock> |
190 |
<Theta>30</Theta> |
191 |
<nPhis>20</nPhis> |
192 |
<ThetaBounds> |
193 |
<LowerTheta>25</LowerTheta> |
194 |
<UpperTheta>35</UpperTheta> |
195 |
</ThetaBounds> |
196 |
197 |
<AngleBasisBlock> |
198 |
<Theta>40</Theta> |
199 |
<nPhis>24</nPhis> |
200 |
<ThetaBounds> |
201 |
<LowerTheta>35</LowerTheta> |
202 |
<UpperTheta>45</UpperTheta> |
203 |
</ThetaBounds> |
204 |
205 |
<AngleBasisBlock> |
206 |
<Theta>50</Theta> |
207 |
<nPhis>24</nPhis> |
208 |
<ThetaBounds> |
209 |
<LowerTheta>45</LowerTheta> |
210 |
<UpperTheta>55</UpperTheta> |
211 |
</ThetaBounds> |
212 |
213 |
<AngleBasisBlock> |
214 |
<Theta>60</Theta> |
215 |
<nPhis>24</nPhis> |
216 |
<ThetaBounds> |
217 |
<LowerTheta>55</LowerTheta> |
218 |
<UpperTheta>65</UpperTheta> |
219 |
</ThetaBounds> |
220 |
221 |
<AngleBasisBlock> |
222 |
<Theta>70</Theta> |
223 |
<nPhis>16</nPhis> |
224 |
<ThetaBounds> |
225 |
<LowerTheta>65</LowerTheta> |
226 |
<UpperTheta>75</UpperTheta> |
227 |
</ThetaBounds> |
228 |
229 |
<AngleBasisBlock> |
230 |
<Theta>82.5</Theta> |
231 |
<nPhis>12</nPhis> |
232 |
<ThetaBounds> |
233 |
<LowerTheta>75</LowerTheta> |
234 |
<UpperTheta>90</UpperTheta> |
235 |
</ThetaBounds> |
236 |
237 |
</AngleBasis> |
238 |
</DataDefinition> |
239 |
<WavelengthData> |
240 |
<LayerNumber>System</LayerNumber> |
241 |
<Wavelength unit="Integral">Visible</Wavelength> |
242 |
<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum> |
243 |
<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum> |
244 |
<WavelengthDataBlock> |
245 |
<WavelengthDataDirection>Transmission Front</WavelengthDataDirection> |
246 |
<ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis> |
247 |
<RowAngleBasis>LBNL/Klems Full</RowAngleBasis> |
248 |
<ScatteringDataType>BTDF</ScatteringDataType> |
249 |
<ScatteringData> |
250 |
251 |
# Output computed data (transposed order) |
252 |
for (my $od = 0; $od < $ndiv; $od++) { |
253 |
for (my $id = 0; $id < $ndiv; $id++) { |
254 |
print $darr[$ndiv*$id + $od]; |
255 |
256 |
print "\n"; |
257 |
258 |
# Output XML epilogue |
259 |
print |
260 |
' </ScatteringData> |
261 |
</WavelengthDataBlock> |
262 |
</WavelengthData> |
263 |
</Layer> |
264 |
</Optical> |
265 |
</WindowElement> |
266 |
267 |
# Clean up temporary files |
268 |
system "rm -rf $td"; |
