root/radiance/ray/src/util/genBSDF.pl
Thu Oct 27 16:35:54 2011 UTC (12 years, 7 months ago) by greg
Diff to previous 2.26
Revision 2.26 - (view) (download) (annotate) - [selected]
Tue Oct 25 20:51:10 2011 UTC (12 years, 7 months ago) by greg
Diff to previous 2.25
Wed Aug 24 04:14:58 2011 UTC (12 years, 9 months ago) by greg
Diff to previous 2.24 , to selected 2.26
Tue Aug 23 14:02:41 2011 UTC (12 years, 9 months ago) by greg
Diff to previous 2.23 , to selected 2.26
Fri Jun 24 19:07:38 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.22 , to selected 2.26
Fri Jun 24 00:41:51 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.21 , to selected 2.26
Wed Jun 8 23:16:47 2011 UTC (13 years ago) by greg
Diff to previous 2.20 , to selected 2.26
Sat Jun 4 00:33:53 2011 UTC (13 years ago) by greg
Diff to previous 2.19 , to selected 2.26
Fri Jun 3 19:41:14 2011 UTC (13 years ago) by greg
Diff to previous 2.18 , to selected 2.26
Wed Jun 1 22:50:24 2011 UTC (13 years ago) by greg
Diff to previous 2.17 , to selected 2.26
Wed Jun 1 00:29:40 2011 UTC (13 years ago) by greg
Diff to previous 2.16 , to selected 2.26
Tue May 31 20:50:26 2011 UTC (13 years ago) by greg
Diff to previous 2.15 , to selected 2.26
Wed May 25 19:24:11 2011 UTC (13 years ago) by greg
Diff to previous 2.14 , to selected 2.26
Sat Apr 16 01:13:22 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.26
Eliminated Unix dependencies
Sat Apr 16 00:39:07 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.26
Bug fix for 32-bit OS
Thu Feb 24 20:27:00 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.11 , to selected 2.26
Fixed usage message
Thu Feb 24 20:14:26 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.26
Tue Feb 22 22:51:23 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 2.26
Mon Feb 21 22:48:51 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.8 , to selected 2.26
Sat Jan 29 16:44:01 2011 UTC (13 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 2.26
Thu Jan 27 22:28:12 2011 UTC (13 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.26
Wed Dec 15 17:23:58 2010 UTC (13 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 2.26
Thu Dec 9 17:00:43 2010 UTC (13 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 2.26
Thu Dec 9 06:14:04 2010 UTC (13 years, 6 months ago) by greg
Diff to previous 2.3 , to selected 2.26
Thu Sep 9 06:02:16 2010 UTC (13 years, 9 months ago) by greg
Diff to previous 2.2 , to selected 2.26
Fri Sep 3 23:53:50 2010 UTC (13 years, 9 months ago) by greg
Diff to previous 2.1 , to selected 2.26
Thu Sep 2 02:29:24 2010 UTC (13 years, 9 months ago) by greg
Diff to selected 2.26
