root/radiance/ray/src/util/genBSDF.pl
Revision: 2.68
Committed: Fri Sep 16 20:01:29 2016 UTC (8 years, 9 months ago) by greg
Removed stray unused variable
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.67 2016/09/16 19:47:41 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 use File::Temp qw/ :mktemp /;
11 sub userror {
12 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
13 exit 1;
14 }
15 my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
16 my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph);
17 my ($curphase, $recovery);
18 if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) {
19 $td = $ARGV[1];
20 open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n";
21 @ARGV = <MYAVH>;
22 close MYAVH;
23 chomp @ARGV;
24 if (open(MYPH, "< $td/phase.txt")) {
25 while (<MYPH>) {
26 chomp($recovery = $_);
27 }
28 close MYPH;
29 }
30 } elsif ($windoz) {
31 my $tmploc = `echo \%TMP\%`;
32 chomp $tmploc;
33 $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
34 } else {
35 $td = mkdtemp("/tmp/genBSDF.XXXXXX");
36 chomp $td;
37 }
38 if ($windoz) {
39 $radscn = "$td\\device.rad";
40 $mgfscn = "$td\\device.mgf";
41 $octree = "$td\\device.oct";
42 $fsender = "$td\\fsender.rad";
43 $bsender = "$td\\bsender.rad";
44 $receivers = "$td\\receivers.rad";
45 $facedat = "$td\\face.dat";
46 $behinddat = "$td\\behind.dat";
47 $tf = "$td\\tf.dat";
48 $rf = "$td\\rf.dat";
49 $tb = "$td\\tb.dat";
50 $rb = "$td\\rb.dat";
51 $tfx = "$td\\tfx.dat";
52 $rfx = "$td\\rfx.dat";
53 $tbx = "$td\\tbx.dat";
54 $rbx = "$td\\rbx.dat";
55 $tfz = "$td\\tfz.dat";
56 $rfz = "$td\\rfz.dat";
57 $tbz = "$td\\tbz.dat";
58 $rbz = "$td\\rbz.dat";
59 $cph = "$td\\phase.txt";
60 $rmtmp = "rd /S /Q $td";
61 } else {
62 $radscn = "$td/device.rad";
63 $mgfscn = "$td/device.mgf";
64 $octree = "$td/device.oct";
65 $fsender = "$td/fsender.rad";
66 $bsender = "$td/bsender.rad";
67 $receivers = "$td/receivers.rad";
68 $facedat = "$td/face.dat";
69 $behinddat = "$td/behind.dat";
70 $tf = "$td/tf.dat";
71 $rf = "$td/rf.dat";
72 $tb = "$td/tb.dat";
73 $rb = "$td/rb.dat";
74 $tfx = "$td/tfx.dat";
75 $rfx = "$td/rfx.dat";
76 $tbx = "$td/tbx.dat";
77 $rbx = "$td/rbx.dat";
78 $tfz = "$td/tfz.dat";
79 $rfz = "$td/rfz.dat";
80 $tbz = "$td/tbz.dat";
81 $rbz = "$td/rbz.dat";
82 $cph = "$td/phase.txt";
83 $rmtmp = "rm -rf $td";
84 }
85 my @savedARGV = @ARGV;
86 my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6";
87 my $wrapper = "wrapBSDF";
88 my $tensortree = 0;
89 my $ttlog2 = 4;
90 my $nsamp = 2000;
91 my $mgfin = 0;
92 my $geout = 1;
93 my $nproc = 1;
94 my $docolor = 0;
95 my $doforw = 0;
96 my $doback = 1;
97 my $pctcull = 90;
98 my $gunit = "meter";
99 my $curspec = "Visible";
100 my @dim;
101 # Get options
102 while ($#ARGV >= 0) {
103 if ("$ARGV[0]" =~ /^[-+]m/) {
104 $mgfin = ("$ARGV[0]" =~ /^\+/);
105 } elsif ("$ARGV[0]" eq "-r") {
106 $rfluxmtx .= " $ARGV[1]";
107 shift @ARGV;
108 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
109 $geout = ("$ARGV[0]" =~ /^\+/);
110 $gunit = $ARGV[1];
111 if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
112 die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
113 }
114 shift @ARGV;
115 } elsif ("$ARGV[0]" =~ /^[-+]C/) {
116 $docolor = ("$ARGV[0]" =~ /^\+/);
117 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
118 $doforw = ("$ARGV[0]" =~ /^\+/);
119 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
120 $doback = ("$ARGV[0]" =~ /^\+/);
121 } elsif ("$ARGV[0]" eq "-t") {
122 # Use value < 0 for rttree_reduce bypass
123 $pctcull = $ARGV[1];
124 if ($pctcull >= 100) {
125 die "Illegal -t culling percentage, must be < 100\n";
126 }
127 shift @ARGV;
128 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
129 $tensortree = substr($ARGV[0], 2, 1);
130 $ttlog2 = $ARGV[1];
131 shift @ARGV;
132 } elsif ("$ARGV[0]" eq "-s") {
133 $wrapper .= " -f \"$ARGV[1]\"";
134 shift @ARGV;
135 } elsif ("$ARGV[0]" eq "-W") {
136 $wrapper .= " -W";
137 } elsif ("$ARGV[0]" eq "-c") {
138 $nsamp = $ARGV[1];
139 shift @ARGV;
140 } elsif ("$ARGV[0]" eq "-n") {
141 $nproc = $ARGV[1];
142 shift @ARGV;
143 } elsif ("$ARGV[0]" =~ /^-d/) {
144 userror() if ($#ARGV < 6);
145 @dim = @ARGV[1..6];
146 shift @ARGV for (1..6);
147 } elsif ("$ARGV[0]" =~ /^[-+]./) {
148 userror();
149 } else {
150 last;
151 }
152 shift @ARGV;
153 }
154 # Check that we're actually being asked to do something
155 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
156 $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
157 $wrapper .= " -u $gunit";
158 if ( !defined $recovery ) {
159 # Issue warning for unhandled reciprocity case
160 print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
161 ($tensortree==3 && !($doforw && $doback));
162 # Get scene description
163 if ( $mgfin ) {
164 system "mgf2rad @ARGV > $radscn";
165 die "Could not load MGF input\n" if ( $? );
166 } else {
167 system "xform -e @ARGV > $radscn";
168 die "Could not load Radiance input\n" if ( $? );
169 }
170 }
171 if ( $#dim != 5 ) {
172 @dim = split ' ', `getbbox -h $radscn`;
173 }
174 die "Device entirely inside room!\n" if ( $dim[4] >= 0 );
175 if ( $dim[5] > 1e-5 ) {
176 print STDERR "Warning: Device extends into room\n";
177 } elsif ( $dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2]) ) {
178 print STDERR "Warning: Device far behind Z==0 plane\n";
179 }
180 # Assume Zmax==0 to derive thickness so pkgBSDF will work
181 $wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
182 ';h=' . ($dim[3] - $dim[2]) . '"';
183 $wrapper .= " -g $mgfscn" if ( $geout );
184 # Calculate CIE (u',v') from Radiance RGB:
185 my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
186 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
187 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
188 'den=Xi+15*Yi+3*Zi;' .
189 'uprime=4*Xi/den;vprime=9*Yi/den;' ;
190 my $FEPS = 1e-5;
191 my $ns = 2**$ttlog2;
192 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
193 my $ny = int($nsamp/$nx + 1);
194 $nsamp = $nx * $ny;
195 $rfluxmtx .= " -n $nproc -c $nsamp";
196 if ( !defined $recovery ) {
197 open(MYAVH, "> $td/savedARGV.txt");
198 foreach (@savedARGV) {
199 print MYAVH "$_\n";
200 }
201 close MYAVH;
202 # Generate octree
203 system "oconv -w $radscn > $octree";
204 die "Could not compile scene\n" if ( $? );
205 # Add MGF description if requested
206 if ( $geout ) {
207 open(MGFSCN, "> $mgfscn");
208 printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
209 close MGFSCN;
210 if ( $mgfin ) {
211 system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
212 } else {
213 system "rad2mgf $radscn >> $mgfscn";
214 }
215 open(MGFSCN, ">> $mgfscn");
216 print MGFSCN "xf\n";
217 close MGFSCN;
218 }
219 # Create receiver & sender surfaces (rectangular)
220 open(RADSCN, "> $receivers");
221 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
222 print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
223 print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
224 print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
225 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
226 print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
227 print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
228 print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
229 close RADSCN;
230 # Prepare sender surfaces
231 if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
232 open (RADSCN, "> $fsender");
233 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
234 print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
235 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
236 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
237 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
238 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
239 close RADSCN;
240 open (RADSCN, "> $bsender");
241 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
242 print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
243 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
244 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
245 printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
246 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
247 close RADSCN;
248 }
249 print STDERR "Recover using: $0 -recover $td\n";
250 }
251 # Open unbuffered progress file
252 open(MYPH, ">> $td/phase.txt");
253 {
254 my $ofh = select MYPH;
255 $| = 1;
256 select $ofh;
257 }
258 $curphase = 0;
259 # Create data segments (all the work happens here)
260 if ( $tensortree ) {
261 do_tree_bsdf();
262 } else {
263 do_matrix_bsdf();
264 }
265 # Output XML
266 # print STDERR "Running: $wrapper\n";
267 system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
268 die "Could not wrap BSDF data\n" if ( $? );
269 # Clean up temporary files and exit
270 exec $rmtmp;
271
272 #============== End of main program segment ==============#
273
274 # Function to determine if next phase should be skipped or recovered
275 sub do_phase {
276 $curphase++;
277 if (defined $recovery) {
278 if ($recovery > $curphase) { return 0; }
279 if ($recovery == $curphase) { return -1; }
280 }
281 print MYPH "$curphase\n";
282 return 1;
283 }
284
285 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
286 sub do_tree_bsdf {
287
288 # Run rfluxmtx processes to compute each side
289 do_ttree_dir(0) if ( $doback );
290 do_ttree_dir(1) if ( $doforw );
291
292 } # end of sub do_tree_bsdf()
293
294 # Call rfluxmtx and process tensor tree BSDF for the given direction
295 sub do_ttree_dir {
296 my $forw = shift;
297 my $r = do_phase();
298 if (!$r) { return; }
299 $r = ($r < 0) ? " -r" : "";
300 my $cmd;
301 if ( $tensortree == 3 ) {
302 # Isotropic BSDF
303 my $ns2 = $ns / 2;
304 if ($windoz) {
305 $cmd = "cnt $ns2 $ny $nx " .
306 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
307 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
308 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
309 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
310 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
311 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
312 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
313 qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
314 qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
315 "| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree";
316 } else {
317 $cmd = "cnt $ns2 $ny $nx " .
318 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
319 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
320 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
321 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
322 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
323 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
324 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
325 qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
326 qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
327 "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree";
328 }
329 } else {
330 # Anisotropic BSDF
331 my $sender = ($bsender,$fsender)[$forw];
332 if ($windoz) {
333 $cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree";
334 } else {
335 $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree";
336 }
337 }
338 # print STDERR "Starting: $cmd\n";
339 system $cmd;
340 die "Failure running rfluxmtx" if ( $? );
341 ttree_out($forw);
342 } # end of do_ttree_dir()
343
344 # Simplify and store tensor tree results
345 sub ttree_out {
346 my $forw = shift;
347 my ($refldat,$transdat);
348 if ( $forw ) {
349 $transdat = $facedat;
350 $refldat = $behinddat;
351 } else {
352 $transdat = $behinddat;
353 $refldat = $facedat;
354 }
355 # Only output one transmitted anisotropic distribution, preferring backwards
356 if ( !$forw || !$doback || $tensortree==3 ) {
357 my $ttyp = ("tb","tf")[$forw];
358 ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
359 if ( $docolor ) {
360 ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
361 ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
362 }
363 }
364 # Output reflection
365 my $rtyp = ("rb","rf")[$forw];
366 ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
367 if ( $docolor ) {
368 ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
369 ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
370 }
371 } # end of ttree_out()
372
373 # Call rttree_reduce on the given component
374 sub ttree_comp {
375 my $typ = shift;
376 my $spec = shift;
377 my $src = shift;
378 my $dest = shift;
379 my $cmd;
380 if ($windoz) {
381 if ("$spec" eq "Visible") {
382 $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
383 q{-e "Ri=$1;Gi=$2;Bi=$3" } .
384 qq{-e "$CIEuv" } .
385 q{-e "$1=Yi/Omega"};
386 } elsif ("$spec" eq "CIE-u") {
387 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
388 qq{-e "$CIEuv" } .
389 q{-e "$1=uprime"};
390 } elsif ("$spec" eq "CIE-v") {
391 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
392 qq{-e "$CIEuv" } .
393 q{-e "$1=vprime"};
394 }
395 } else {
396 if ("$spec" eq "Visible") {
397 $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
398 q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
399 "-e '$CIEuv' " .
400 q{-e '$1=Yi/Omega'};
401 } elsif ("$spec" eq "CIE-u") {
402 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
403 "-e '$CIEuv' " .
404 q{-e '$1=uprime'};
405 } elsif ("$spec" eq "CIE-v") {
406 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
407 "-e '$CIEuv' " .
408 q{-e '$1=vprime'};
409 }
410 }
411 if ($pctcull >= 0) {
412 my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
413 my $pcull = ("$spec" eq "Visible") ? $pctcull :
414 (100 - (100-$pctcull)*.25) ;
415 if ($windoz) {
416 $cmd = "rcollate -ho -oc 1 $src | " .
417 $cmd .
418 " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
419 } else {
420 $cmd .= " -of $src " .
421 "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
422 }
423 # print STDERR "Running: $cmd\n";
424 system "$cmd > $dest";
425 die "Failure running rttree_reduce" if ( $? );
426 } else {
427 if ($windoz) {
428 $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
429 } else {
430 $cmd .= " $src";
431 }
432 open(DATOUT, "> $dest");
433 print DATOUT "{\n";
434 close DATOUT;
435 # print STDERR "Running: $cmd\n";
436 system "$cmd >> $dest";
437 die "Failure running rcalc" if ( $? );
438 open(DATOUT, ">> $dest");
439 for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
440 print DATOUT "0\n";
441 }
442 print DATOUT "}\n";
443 close DATOUT;
444 }
445 if ( "$spec" ne "$curspec" ) {
446 $wrapper .= " -s $spec";
447 $curspec = $spec;
448 }
449 $wrapper .= " -$typ $dest";
450 } # end of ttree_comp()
451
452 #------------- End of do_tree_bsdf() & subroutines -------------#
453
454 #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
455 sub do_matrix_bsdf {
456
457 # Run rfluxmtx processes to compute each side
458 do_matrix_dir(0) if ( $doback );
459 do_matrix_dir(1) if ( $doforw );
460
461 } # end of sub do_matrix_bsdf()
462
463 # Call rfluxmtx and process tensor tree BSDF for the given direction
464 sub do_matrix_dir {
465 my $forw = shift;
466 my $r = do_phase();
467 if (!$r) { return; }
468 $r = ($r < 0) ? " -r" : "";
469 my $cmd;
470 my $sender = ($bsender,$fsender)[$forw];
471 $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree";
472 # print STDERR "Starting: $cmd\n";
473 system $cmd;
474 die "Failure running rfluxmtx" if ( $? );
475 matrix_out($forw);
476 } # end of do_matrix_dir()
477
478 sub matrix_out {
479 my $forw = shift;
480 my ($refldat,$transdat);
481 if ( $forw ) {
482 $transdat = $facedat;
483 $refldat = $behinddat;
484 } else {
485 $transdat = $behinddat;
486 $refldat = $facedat;
487 }
488 # Output transmission
489 my $ttyp = ("tb","tf")[$forw];
490 matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
491 if ( $docolor ) {
492 matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
493 matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
494 }
495 # Output reflection
496 my $rtyp = ("rb","rf")[$forw];
497 matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
498 if ( $docolor ) {
499 matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
500 matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
501 }
502 } # end of matrix_out()
503
504 # Transpose matrix component data and save to file
505 sub matrix_comp {
506 my $typ = shift;
507 my $spec = shift;
508 my $src = shift;
509 my $dest = shift;
510 my $cmd = "rmtxop -fa -t";
511 if ("$spec" eq "Visible") {
512 $cmd .= " -c 0.2651 0.6701 0.0648";
513 } elsif ("$spec" eq "CIE-X") {
514 $cmd .= " -c 0.5141 0.3239 0.1620";
515 } elsif ("$spec" eq "CIE-Z") {
516 $cmd .= " -c 0.0241 0.1229 0.8530";
517 }
518 $cmd .= " $src | rcollate -ho -oc 145";
519 # print STDERR "Running: $cmd\n";
520 system "$cmd > $dest";
521 die "Failure running rmtxop" if ( $? );
522 if ( "$spec" ne "$curspec" ) {
523 $wrapper .= " -s $spec";
524 $curspec = $spec;
525 }
526 $wrapper .= " -$typ $dest";
527 } # end of matrix_comp()
528
529 #------------- End of do_matrix_bsdf() & subroutines --------------#
