root/radiance/ray/src/util/genBSDF.pl
Revision: 2.5
Committed: Thu Dec 9 17:00:43 2010 UTC (14 years, 7 months ago) by greg
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.4 2010/12/09 06:14:04 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 sub userror {
10 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-dim xmin xmax ymin ymax zmin zmax][{+|-}mgf][{+|-}geom] [input ..]\n";
11 exit 1;
12 }
13 my $td = `mktemp -d /tmp/genBSDF.XXXXXX`;
14 chomp $td;
15 my $nsamp = 1000;
16 my $mgfin = 0;
17 my $geout = 1;
18 my $nproc = 1;
19 my @dim;
20 # Get options
21 while ($#ARGV >= 0) {
22 if ("$ARGV[0]" =~ /^[-+]m/) {
23 $mgfin = ("$ARGV[0]" =~ /^\+/);
24 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
25 $geout = ("$ARGV[0]" =~ /^\+/);
26 } elsif ("$ARGV[0]" eq "-c") {
27 $nsamp = $ARGV[1];
28 shift @ARGV;
29 } elsif ("$ARGV[0]" eq "-n") {
30 $nproc = $ARGV[1];
31 shift @ARGV;
32 } elsif ("$ARGV[0]" =~ /^-d/) {
33 userror() if ($#ARGV < 6);
34 @dim = "@ARGV[1..6]";
35 shift @ARGV for (1..6);
36 } elsif ("$ARGV[0]" =~ /^[-+]./) {
37 userror();
38 } else {
39 last;
40 }
41 shift @ARGV;
42 }
43 # Get scene description and dimensions
44 my $radscn = "$td/device.rad";
45 my $mgfscn = "$td/device.mgf";
46 my $octree = "$td/device.oct";
47 if ( $mgfin ) {
48 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
49 die "Could not load MGF input\n" if ( $? );
50 system "mgf2rad $mgfscn > $radscn";
51 } else {
52 system "cat @ARGV | xform -e > $radscn";
53 die "Could not load Radiance input\n" if ( $? );
54 system "rad2mgf $radscn > $mgfscn" if ( $geout );
55 }
56 if ($#dim != 5) {
57 @dim = split /\s+/, `getbbox -h $radscn`;
58 shift @dim;
59 }
60 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
61 # Add receiver surface (rectangle)
62 my $modnm="_receiver_black_";
63 open(RADSCN, ">> $radscn");
64 print RADSCN "void glow $modnm\n0\n0\n4 0 0 0 0\n\n";
65 print RADSCN "$modnm polygon _receiver_\n0\n0\n12\n";
66 print RADSCN "\t",$dim[0],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
67 print RADSCN "\t",$dim[0],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
68 print RADSCN "\t",$dim[1],"\t",$dim[3],"\t",$dim[5]+1e-5,"\n";
69 print RADSCN "\t",$dim[1],"\t",$dim[2],"\t",$dim[5]+1e-5,"\n";
70 close RADSCN;
71 # Generate octree
72 system "oconv -w $radscn > $octree";
73 die "Could not compile scene\n" if ( $? );
74 # Set up sampling
75 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
76 my $tcal = '
77 DEGREE : PI/180;
78 sq(x) : x*x;
79 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
80 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
81 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
82 Kmax : Kaccum(Knaz(0));
83 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
84 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
85 Kcol = Kbin - Kaccum(Krow-1);
86 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
87 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
88 sin_kpol = sin(Kpol);
89 Dx = -cos(Kazi)*sin_kpol;
90 Dy = sin(Kazi)*sin_kpol;
91 Dz = sqrt(1 - sin_kpol*sin_kpol);
92 KprojOmega = PI * if(Kbin-.5,
93 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
94 1 - sq(cos(Kpola(1)*DEGREE)));
95 ';
96 # Compute Klems bin from exiting ray direction
97 my $kcal = '
98 DEGREE : PI/180;
99 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
100 posangle(a) : if(-a, a + 2*PI, a);
101 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
102 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
103 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
104 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
105 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
106 if(pol-kpola(r), kfindrow(r+1, pol), r) );
107 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
108 kbin2(pol,azi) = select(kfindrow(1, pol),
109 kazn(azi,360/knaz(1)),
110 kaccum(1) + kazn(azi,360/knaz(2)),
111 kaccum(2) + kazn(azi,360/knaz(3)),
112 kaccum(3) + kazn(azi,360/knaz(4)),
113 kaccum(4) + kazn(azi,360/knaz(5)),
114 kaccum(5) + kazn(azi,360/knaz(6)),
115 kaccum(6) + kazn(azi,360/knaz(7)),
116 kaccum(7) + kazn(azi,360/knaz(8)),
117 kaccum(8) + kazn(azi,360/knaz(9))
118 );
119 kbin = kbin2(Acos(Dz), Atan2(Dy, -Dx));
120 ';
121 my $ndiv = 145;
122 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
123 my $ny = int($nsamp/$nx + .5);
124 $nsamp = $nx * $ny;
125 # Compute scattering data using rtcontrib
126 my $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
127 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
128 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
129 "-e 'zp:$dim[4]-1e-5' " .
130 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
131 q{-e '$1=xp;$2=yp;$3=zp;$4=Dx;$5=Dy;$6=Dz' } .
132 "| rtcontrib -h -ff -n $nproc -c $nsamp -e '$kcal' -b kbin -bn $ndiv " .
133 "-m $modnm -w -ab 5 -ad 700 -lw 3e-6 $octree " .
134 "| rcalc -e '$tcal' " .
135 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-1,$ndiv)' " .
136 q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
137 my @darr = `$cmd`;
138 die "Failure running: $cmd\n" if ( $? );
139 # Output XML prologue
140 print
141 '<?xml version="1.0" encoding="UTF-8"?>
142 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
143 <WindowElementType>System</WindowElementType>
144 <Optical>
145 <Layer>
146 <Material>
147 <Name>Name</Name>
148 <Manufacturer>Manufacturer</Manufacturer>
149 ';
150 printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4];
151 printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0];
152 printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2];
153 print "\t\t\t<DeviceType>Integral</DeviceType>\n";
154 # Output MGF description if requested
155 if ( $geout ) {
156 print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n";
157 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
158 system "cat $mgfscn";
159 print "xf\n";
160 print "\t\t\t</Geometry>\n";
161 }
162 print ' </Material>
163 <DataDefinition>
164 <IncidentDataStructure>Columns</IncidentDataStructure>
165 <AngleBasis>
166 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
167 <AngleBasisBlock>
168 <Theta>0</Theta>
169 <nPhis>1</nPhis>
170 <ThetaBounds>
171 <LowerTheta>0</LowerTheta>
172 <UpperTheta>5</UpperTheta>
173 </ThetaBounds>
174 </AngleBasisBlock>
175 <AngleBasisBlock>
176 <Theta>10</Theta>
177 <nPhis>8</nPhis>
178 <ThetaBounds>
179 <LowerTheta>5</LowerTheta>
180 <UpperTheta>15</UpperTheta>
181 </ThetaBounds>
182 </AngleBasisBlock>
183 <AngleBasisBlock>
184 <Theta>20</Theta>
185 <nPhis>16</nPhis>
186 <ThetaBounds>
187 <LowerTheta>15</LowerTheta>
188 <UpperTheta>25</UpperTheta>
189 </ThetaBounds>
190 </AngleBasisBlock>
191 <AngleBasisBlock>
192 <Theta>30</Theta>
193 <nPhis>20</nPhis>
194 <ThetaBounds>
195 <LowerTheta>25</LowerTheta>
196 <UpperTheta>35</UpperTheta>
197 </ThetaBounds>
198 </AngleBasisBlock>
199 <AngleBasisBlock>
200 <Theta>40</Theta>
201 <nPhis>24</nPhis>
202 <ThetaBounds>
203 <LowerTheta>35</LowerTheta>
204 <UpperTheta>45</UpperTheta>
205 </ThetaBounds>
206 </AngleBasisBlock>
207 <AngleBasisBlock>
208 <Theta>50</Theta>
209 <nPhis>24</nPhis>
210 <ThetaBounds>
211 <LowerTheta>45</LowerTheta>
212 <UpperTheta>55</UpperTheta>
213 </ThetaBounds>
214 </AngleBasisBlock>
215 <AngleBasisBlock>
216 <Theta>60</Theta>
217 <nPhis>24</nPhis>
218 <ThetaBounds>
219 <LowerTheta>55</LowerTheta>
220 <UpperTheta>65</UpperTheta>
221 </ThetaBounds>
222 </AngleBasisBlock>
223 <AngleBasisBlock>
224 <Theta>70</Theta>
225 <nPhis>16</nPhis>
226 <ThetaBounds>
227 <LowerTheta>65</LowerTheta>
228 <UpperTheta>75</UpperTheta>
229 </ThetaBounds>
230 </AngleBasisBlock>
231 <AngleBasisBlock>
232 <Theta>82.5</Theta>
233 <nPhis>12</nPhis>
234 <ThetaBounds>
235 <LowerTheta>75</LowerTheta>
236 <UpperTheta>90</UpperTheta>
237 </ThetaBounds>
238 </AngleBasisBlock>
239 </AngleBasis>
240 </DataDefinition>
241 <WavelengthData>
242 <LayerNumber>System</LayerNumber>
243 <Wavelength unit="Integral">Visible</Wavelength>
244 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
245 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
246 <WavelengthDataBlock>
247 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
248 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
249 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
250 <ScatteringDataType>BTDF</ScatteringDataType>
251 <ScatteringData>
252 ';
253 # Output computed data (transposed order)
254 for (my $od = 0; $od < $ndiv; $od++) {
255 for (my $id = 0; $id < $ndiv; $id++) {
256 print $darr[$ndiv*$id + $od];
257 }
258 print "\n";
259 }
260 # Output XML epilogue
261 print
262 ' </ScatteringData>
263 </WavelengthDataBlock>
264 </WavelengthData>
265 </Layer>
266 </Optical>
267 </WindowElement>
268 ';
269 # Clean up temporary files
270 system "rm -rf $td";
