root/radiance/ray/src/util/genBSDF.pl
Revision: 2.28
Committed: Mon Nov 21 20:07:50 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.27: +7 -7 lines
Added reciprocity averaging
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.27 2011/10/27 16:35:54 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 use File::Temp qw/ :mktemp /;
10 sub userror {
11 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
12 exit 1;
13 }
14 my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
15 chomp $td;
16 my @savedARGV = @ARGV;
17 my $tensortree = 0;
18 my $ttlog2 = 4;
19 my $nsamp = 2000;
20 my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
21 my $mgfin = 0;
22 my $geout = 1;
23 my $nproc = 1;
24 my $doforw = 0;
25 my $doback = 1;
26 my $pctcull = 95;
27 my $gunit = "Meter";
28 my @dim;
29 # Get options
30 while ($#ARGV >= 0) {
31 if ("$ARGV[0]" =~ /^[-+]m/) {
32 $mgfin = ("$ARGV[0]" =~ /^\+/);
33 } elsif ("$ARGV[0]" eq "-r") {
34 $rtargs = "$rtargs $ARGV[1]";
35 shift @ARGV;
36 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
37 $geout = ("$ARGV[0]" =~ /^\+/);
38 $gunit = $ARGV[1];
39 if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
40 die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
41 }
42 shift @ARGV;
43 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
44 $doforw = ("$ARGV[0]" =~ /^\+/);
45 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
46 $doback = ("$ARGV[0]" =~ /^\+/);
47 } elsif ("$ARGV[0]" eq "-t") {
48 $pctcull = $ARGV[1];
49 shift @ARGV;
50 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
51 $tensortree = substr($ARGV[0], 2, 1);
52 $ttlog2 = $ARGV[1];
53 shift @ARGV;
54 } elsif ("$ARGV[0]" eq "-c") {
55 $nsamp = $ARGV[1];
56 shift @ARGV;
57 } elsif ("$ARGV[0]" eq "-n") {
58 $nproc = $ARGV[1];
59 shift @ARGV;
60 } elsif ("$ARGV[0]" =~ /^-d/) {
61 userror() if ($#ARGV < 6);
62 @dim = @ARGV[1..6];
63 shift @ARGV for (1..6);
64 } elsif ("$ARGV[0]" =~ /^[-+]./) {
65 userror();
66 } else {
67 last;
68 }
69 shift @ARGV;
70 }
71 # Check that we're actually being asked to do something
72 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
73 # Name our own persist file?
74 my $persistfile;
75 if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) {
76 $persistfile = "$td/pfile.txt";
77 $rtargs = "-PP $persistfile $rtargs";
78 }
79 # Get scene description and dimensions
80 my $radscn = "$td/device.rad";
81 my $mgfscn = "$td/device.mgf";
82 my $octree = "$td/device.oct";
83 if ( $mgfin ) {
84 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
85 die "Could not load MGF input\n" if ( $? );
86 system "mgf2rad $mgfscn > $radscn";
87 } else {
88 system "xform -e @ARGV > $radscn";
89 die "Could not load Radiance input\n" if ( $? );
90 system "rad2mgf $radscn > $mgfscn" if ( $geout );
91 }
92 if ($#dim != 5) {
93 @dim = split ' ', `getbbox -h $radscn`;
94 }
95 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
96 # Add receiver surfaces (rectangular)
97 my $fmodnm="receiver_face";
98 my $bmodnm="receiver_behind";
99 open(RADSCN, ">> $radscn");
100 print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
101 print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
102 print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
103 print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
104 close RADSCN;
105 # Generate octree
106 system "oconv -w $radscn > $octree";
107 die "Could not compile scene\n" if ( $? );
108 # Output XML prologue
109 print
110 '<?xml version="1.0" encoding="UTF-8"?>
111 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
112 ';
113 print "<!-- File produced by: genBSDF @savedARGV -->\n";
114 print
115 '<WindowElementType>System</WindowElementType>
116 <Optical>
117 <Layer>
118 <Material>
119 <Name>Name</Name>
120 <Manufacturer>Manufacturer</Manufacturer>
121 ';
122 printf "\t\t<Thickness unit=\"$gunit\">%.3f</Thickness>\n", $dim[5] - $dim[4];
123 printf "\t\t<Width unit=\"$gunit\">%.3f</Width>\n", $dim[1] - $dim[0];
124 printf "\t\t<Height unit=\"$gunit\">%.3f</Height>\n", $dim[3] - $dim[2];
125 print "\t\t<DeviceType>Integral</DeviceType>\n";
126 # Output MGF description if requested
127 if ( $geout ) {
128 print "\t\t<Geometry format=\"MGF\" unit=\"$gunit\">\n";
129 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
130 open(MGFSCN, "< $mgfscn");
131 while (<MGFSCN>) { print $_; }
132 close MGFSCN;
133 print "xf\n";
134 print "\t\t</Geometry>\n";
135 }
136 print " </Material>\n";
137 # Set up surface sampling
138 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
139 my $ny = int($nsamp/$nx + .5);
140 $nsamp = $nx * $ny;
141 my $ns = 2**$ttlog2;
142 my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
143 # Create data segments (all the work happens here)
144 if ( $tensortree ) {
145 do_tree_bsdf();
146 } else {
147 do_matrix_bsdf();
148 }
149 # Output XML epilogue
150 print
151 '</Layer>
152 </Optical>
153 </WindowElement>
154 ';
155 # Clean up temporary files and exit
156 exec("rm -rf $td");
157
158 #-------------- End of main program segment --------------#
159
160 #++++++++++++++ Kill persistent rtrace +++++++++++++++++++#
161 sub persist_end {
162 if ( $persistfile && open(PFI, "< $persistfile") ) {
163 while (<PFI>) {
164 s/^[^ ]* //;
165 kill('ALRM', $_);
166 last;
167 }
168 close PFI;
169 }
170 }
171
172 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
173 sub do_tree_bsdf {
174 # Get sampling rate and subdivide task
175 my $ns2 = $ns;
176 $ns2 /= 2 if ( $tensortree == 3 );
177 my $nsplice = $nproc;
178 $nsplice *= 10 if ($nproc > 1);
179 $nsplice = $ns2 if ($nsplice > $ns2);
180 $nsplice = 999 if ($nsplice > 999);
181 @pdiv = (0, int($ns2/$nsplice));
182 my $nrem = $ns2 % $nsplice;
183 for (my $i = 1; $i < $nsplice; $i++) {
184 my $nv = $pdiv[$i] + $pdiv[1];
185 ++$nv if ( $nrem-- > 0 );
186 push @pdiv, $nv;
187 }
188 die "Script error 1" if ($pdiv[-1] != $ns2);
189 # Shirley-Chiu mapping from unit square to disk
190 $sq2disk = '
191 in_square_a = 2*in_square_x - 1;
192 in_square_b = 2*in_square_y - 1;
193 in_square_rgn = if(in_square_a + in_square_b,
194 if(in_square_a - in_square_b, 1, 2),
195 if(in_square_b - in_square_a, 3, 4));
196 out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
197 -in_square_a, -in_square_b);
198 out_disk_phi = PI/4 * select(in_square_rgn,
199 in_square_b/in_square_a,
200 2 - in_square_a/in_square_b,
201 4 + in_square_b/in_square_a,
202 if(in_square_b*in_square_b,
203 6 - in_square_a/in_square_b, 0));
204 Dx = out_disk_r*cos(out_disk_phi);
205 Dy = out_disk_r*sin(out_disk_phi);
206 Dz = sqrt(1 - out_disk_r*out_disk_r);
207 ';
208 # Shirley-Chiu mapping from unit disk to square
209 $disk2sq = '
210 norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
211 in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
212 in_disk_phi = norm_radians(atan2(Dy, Dx));
213 in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
214 out_square_a = select(in_disk_rgn,
215 in_disk_r,
216 (PI/2 - in_disk_phi)*in_disk_r/(PI/4),
217 -in_disk_r,
218 (in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
219 out_square_b = select(in_disk_rgn,
220 in_disk_phi*in_disk_r/(PI/4),
221 in_disk_r,
222 (PI - in_disk_phi)*in_disk_r/(PI/4),
223 -in_disk_r);
224 out_square_x = (out_square_a + 1)/2;
225 out_square_y = (out_square_b + 1)/2;
226 ';
227 # Announce ourselves in XML output
228 print "\t<DataDefinition>\n";
229 print "\t\t<IncidentDataStructure>TensorTree$tensortree</IncidentDataStructure>\n";
230 print "\t</DataDefinition>\n";
231 # Fork parallel rtcontrib processes to compute each side
232 my $npleft = $nproc;
233 if ( $doback ) {
234 for (my $splice = 0; $splice < $nsplice; $splice++) {
235 if (! $npleft ) {
236 wait();
237 die "rtcontrib process reported error" if ( $? );
238 $npleft++;
239 }
240 bg_tree_rtcontrib(0, $splice);
241 $npleft--;
242 }
243 while (wait() >= 0) {
244 die "rtcontrib process reported error" if ( $? );
245 $npleft++;
246 }
247 persist_end();
248 ttree_out(0);
249 }
250 if ( $doforw ) {
251 for (my $splice = 0; $splice < $nsplice; $splice++) {
252 if (! $npleft ) {
253 wait();
254 die "rtcontrib process reported error" if ( $? );
255 $npleft++;
256 }
257 bg_tree_rtcontrib(1, $splice);
258 $npleft--;
259 }
260 while (wait() >= 0) {
261 die "rtcontrib process reported error" if ( $? );
262 $npleft++;
263 }
264 persist_end();
265 ttree_out(1);
266 }
267 } # end of sub do_tree_bsdf()
268
269 # Run rtcontrib process in background to generate tensor tree samples
270 sub bg_tree_rtcontrib {
271 my $pid = fork();
272 die "Cannot fork new process" unless defined $pid;
273 if ($pid > 0) { return $pid; }
274 my $forw = shift;
275 my $pn = shift;
276 my $pbeg = $pdiv[$pn];
277 my $plen = $pdiv[$pn+1] - $pbeg;
278 my $matargs = "-m $bmodnm";
279 if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
280 my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " .
281 "-e '$disk2sq' -bn '$ns*$ns' " .
282 "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
283 "-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree";
284 if ( $tensortree == 3 ) {
285 # Isotropic BSDF
286 $cmd = "cnt $plen $ny $nx " .
287 "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
288 "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
289 "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
290 "-e 'Dx=1-2*($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
291 "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
292 "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
293 "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
294 "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
295 "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
296 "| $cmd";
297 } else {
298 # Anisotropic BSDF
299 # Sample area vertically to improve load balance, since
300 # shading systems usually have bilateral symmetry (L-R)
301 $cmd = "cnt $plen $ns $ny $nx " .
302 "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
303 "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
304 "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
305 "-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " .
306 "-e 'in_square_x=($pbeg+\$1+r1)/$ns' " .
307 "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
308 "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
309 "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
310 "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
311 "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
312 "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
313 "| $cmd";
314 }
315 # print STDERR "Starting: $cmd\n";
316 exec($cmd); # no return; status report to parent via wait
317 die "Cannot exec: $cmd\n";
318 } # end of bg_tree_rtcontrib()
319
320 # Simplify and output tensor tree results
321 sub ttree_out {
322 my $forw = shift;
323 my $side = ("Back","Front")[$forw];
324 # Only output one transmitted distribution, preferring backwards
325 if ( !$forw || !$doback ) {
326 print
327 ' <WavelengthData>
328 <LayerNumber>System</LayerNumber>
329 <Wavelength unit="Integral">Visible</Wavelength>
330 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
331 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
332 <WavelengthDataBlock>
333 <WavelengthDataDirection>Transmission</WavelengthDataDirection>
334 <AngleBasis>LBNL/Shirley-Chiu</AngleBasis>
335 <ScatteringDataType>BTDF</ScatteringDataType>
336 <ScatteringData>
337 ';
338 system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
339 q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
340 "$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " .
341 "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
342 die "Failure running rttree_reduce" if ( $? );
343 print
344 ' </ScatteringData>
345 </WavelengthDataBlock>
346 </WavelengthData>
347 ';
348 }
349 # Output reflection
350 print
351 ' <WavelengthData>
352 <LayerNumber>System</LayerNumber>
353 <Wavelength unit="Integral">Visible</Wavelength>
354 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
355 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
356 <WavelengthDataBlock>
357 ';
358 print "\t\t\t<WavelengthDataDirection>Reflection $side</WavelengthDataDirection>\n";
359 print
360 ' <AngleBasis>LBNL/Shirley-Chiu</AngleBasis>
361 <ScatteringDataType>BRDF</ScatteringDataType>
362 <ScatteringData>
363 ';
364 system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
365 q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
366 "$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " .
367 "| rttree_reduce -a -h -ff -t $pctcull -r $tensortree -g $ttlog2";
368 die "Failure running rttree_reduce" if ( $? );
369 print
370 ' </ScatteringData>
371 </WavelengthDataBlock>
372 </WavelengthData>
373 ';
374 } # end of ttree_out()
375
376 #------------- End of do_tree_bsdf() & subroutines -------------#
377
378 #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
379 sub do_matrix_bsdf {
380 # Set up sampling of portal
381 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
382 $tcal = '
383 DEGREE : PI/180;
384 sq(x) : x*x;
385 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
386 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
387 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
388 Kmax : Kaccum(Knaz(0));
389 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
390 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
391 Kcol = Kbin - Kaccum(Krow-1);
392 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
393 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
394 sin_kpol = sin(Kpol);
395 Dx = cos(Kazi)*sin_kpol;
396 Dy = sin(Kazi)*sin_kpol;
397 Dz = sqrt(1 - sin_kpol*sin_kpol);
398 KprojOmega = PI * if(Kbin-.5,
399 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
400 1 - sq(cos(Kpola(1)*DEGREE)));
401 ';
402 # Compute Klems bin from exiting ray direction (forward or backward)
403 $kcal = '
404 DEGREE : PI/180;
405 abs(x) : if(x, x, -x);
406 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
407 posangle(a) : if(-a, a + 2*PI, a);
408 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
409 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
410 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
411 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
412 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
413 if(pol-kpola(r), kfindrow(r+1, pol), r) );
414 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
415 kbin2(pol,azi) = select(kfindrow(1, pol),
416 kazn(azi,360/knaz(1)),
417 kaccum(1) + kazn(azi,360/knaz(2)),
418 kaccum(2) + kazn(azi,360/knaz(3)),
419 kaccum(3) + kazn(azi,360/knaz(4)),
420 kaccum(4) + kazn(azi,360/knaz(5)),
421 kaccum(5) + kazn(azi,360/knaz(6)),
422 kaccum(6) + kazn(azi,360/knaz(7)),
423 kaccum(7) + kazn(azi,360/knaz(8)),
424 kaccum(8) + kazn(azi,360/knaz(9))
425 );
426 kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
427 ';
428 my $ndiv = 145;
429 # Compute scattering data using rtcontrib
430 my @tfarr;
431 my @rfarr;
432 my @tbarr;
433 my @rbarr;
434 my $cmd;
435 my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
436 "-e '$kcal' -b kbin -bn $ndiv " .
437 "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
438 my $rccmd = "rcalc -e '$tcal' " .
439 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
440 q{-if3 -e 'oval=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' } .
441 q[-o '${ oval },'];
442 if ( $doforw ) {
443 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
444 "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
445 "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
446 "-e 'zp:$dim[4]' " .
447 q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
448 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
449 "| $rtcmd";
450 system "$cmd" || die "Failure running: $cmd\n";
451 @tfarr = `$rccmd $td/$fmodnm.flt`;
452 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
453 @rfarr = `$rccmd $td/$bmodnm.flt`;
454 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
455 }
456 if ( $doback ) {
457 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
458 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
459 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
460 "-e 'zp:$dim[5]' " .
461 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
462 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
463 "| $rtcmd";
464 system "$cmd" || die "Failure running: $cmd\n";
465 @tbarr = `$rccmd $td/$bmodnm.flt`;
466 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
467 @rbarr = `$rccmd $td/$fmodnm.flt`;
468 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
469 }
470 # Output angle basis
471 print
472 ' <DataDefinition>
473 <IncidentDataStructure>Columns</IncidentDataStructure>
474 <AngleBasis>
475 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
476 <AngleBasisBlock>
477 <Theta>0</Theta>
478 <nPhis>1</nPhis>
479 <ThetaBounds>
480 <LowerTheta>0</LowerTheta>
481 <UpperTheta>5</UpperTheta>
482 </ThetaBounds>
483 </AngleBasisBlock>
484 <AngleBasisBlock>
485 <Theta>10</Theta>
486 <nPhis>8</nPhis>
487 <ThetaBounds>
488 <LowerTheta>5</LowerTheta>
489 <UpperTheta>15</UpperTheta>
490 </ThetaBounds>
491 </AngleBasisBlock>
492 <AngleBasisBlock>
493 <Theta>20</Theta>
494 <nPhis>16</nPhis>
495 <ThetaBounds>
496 <LowerTheta>15</LowerTheta>
497 <UpperTheta>25</UpperTheta>
498 </ThetaBounds>
499 </AngleBasisBlock>
500 <AngleBasisBlock>
501 <Theta>30</Theta>
502 <nPhis>20</nPhis>
503 <ThetaBounds>
504 <LowerTheta>25</LowerTheta>
505 <UpperTheta>35</UpperTheta>
506 </ThetaBounds>
507 </AngleBasisBlock>
508 <AngleBasisBlock>
509 <Theta>40</Theta>
510 <nPhis>24</nPhis>
511 <ThetaBounds>
512 <LowerTheta>35</LowerTheta>
513 <UpperTheta>45</UpperTheta>
514 </ThetaBounds>
515 </AngleBasisBlock>
516 <AngleBasisBlock>
517 <Theta>50</Theta>
518 <nPhis>24</nPhis>
519 <ThetaBounds>
520 <LowerTheta>45</LowerTheta>
521 <UpperTheta>55</UpperTheta>
522 </ThetaBounds>
523 </AngleBasisBlock>
524 <AngleBasisBlock>
525 <Theta>60</Theta>
526 <nPhis>24</nPhis>
527 <ThetaBounds>
528 <LowerTheta>55</LowerTheta>
529 <UpperTheta>65</UpperTheta>
530 </ThetaBounds>
531 </AngleBasisBlock>
532 <AngleBasisBlock>
533 <Theta>70</Theta>
534 <nPhis>16</nPhis>
535 <ThetaBounds>
536 <LowerTheta>65</LowerTheta>
537 <UpperTheta>75</UpperTheta>
538 </ThetaBounds>
539 </AngleBasisBlock>
540 <AngleBasisBlock>
541 <Theta>82.5</Theta>
542 <nPhis>12</nPhis>
543 <ThetaBounds>
544 <LowerTheta>75</LowerTheta>
545 <UpperTheta>90</UpperTheta>
546 </ThetaBounds>
547 </AngleBasisBlock>
548 </AngleBasis>
549 </DataDefinition>
550 ';
551 if ( $doforw ) {
552 print
553 ' <WavelengthData>
554 <LayerNumber>System</LayerNumber>
555 <Wavelength unit="Integral">Visible</Wavelength>
556 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
557 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
558 <WavelengthDataBlock>
559 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
560 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
561 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
562 <ScatteringDataType>BTDF</ScatteringDataType>
563 <ScatteringData>
564 ';
565 # Output front transmission (transposed order)
566 for (my $od = 0; $od < $ndiv; $od++) {
567 for (my $id = 0; $id < $ndiv; $id++) {
568 print $tfarr[$ndiv*$id + $od];
569 }
570 print "\n";
571 }
572 print
573 ' </ScatteringData>
574 </WavelengthDataBlock>
575 </WavelengthData>
576 <WavelengthData>
577 <LayerNumber>System</LayerNumber>
578 <Wavelength unit="Integral">Visible</Wavelength>
579 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
580 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
581 <WavelengthDataBlock>
582 <WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
583 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
584 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
585 <ScatteringDataType>BRDF</ScatteringDataType>
586 <ScatteringData>
587 ';
588 # Output front reflection (reciprocity averaging)
589 for (my $od = 0; $od < $ndiv; $od++) {
590 for (my $id = 0; $id < $ndiv; $id++) {
591 print .5*($rfarr[$ndiv*$id + $od] + $rfarr[$ndiv*$od + $id]);
592 }
593 print "\n";
594 }
595 print
596 ' </ScatteringData>
597 </WavelengthDataBlock>
598 </WavelengthData>
599 ';
600 }
601 if ( $doback ) {
602 print
603 ' <WavelengthData>
604 <LayerNumber>System</LayerNumber>
605 <Wavelength unit="Integral">Visible</Wavelength>
606 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
607 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
608 <WavelengthDataBlock>
609 <WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
610 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
611 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
612 <ScatteringDataType>BTDF</ScatteringDataType>
613 <ScatteringData>
614 ';
615 # Output back transmission (transposed order)
616 for (my $od = 0; $od < $ndiv; $od++) {
617 for (my $id = 0; $id < $ndiv; $id++) {
618 print $tbarr[$ndiv*$id + $od];
619 }
620 print "\n";
621 }
622 print
623 ' </ScatteringData>
624 </WavelengthDataBlock>
625 </WavelengthData>
626 <WavelengthData>
627 <LayerNumber>System</LayerNumber>
628 <Wavelength unit="Integral">Visible</Wavelength>
629 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
630 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
631 <WavelengthDataBlock>
632 <WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
633 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
634 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
635 <ScatteringDataType>BRDF</ScatteringDataType>
636 <ScatteringData>
637 ';
638 # Output back reflection (reciprocity averaging)
639 for (my $od = 0; $od < $ndiv; $od++) {
640 for (my $id = 0; $id < $ndiv; $id++) {
641 print .5*($rbarr[$ndiv*$id + $od] + $rbarr[$ndiv*$od + $id]);
642 }
643 print "\n";
644 }
645 print
646 ' </ScatteringData>
647 </WavelengthDataBlock>
648 </WavelengthData>
649 ';
650 }
651 }
652 #------------- End of do_matrix_bsdf() --------------#
