--- ray/src/util/genBSDF.pl 2016/09/19 16:20:08 2.70 +++ ray/src/util/genBSDF.pl 2023/09/22 18:01:32 2.90 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: genBSDF.pl,v 2.70 2016/09/19 16:20:08 greg Exp $ +# RCSid $Id: genBSDF.pl,v 2.90 2023/09/22 18:01:32 greg Exp $ # # Compute BSDF based on geometry and material description # @@ -9,11 +9,11 @@ use strict; my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64"); use File::Temp qw/ :mktemp /; sub userror { - print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n"; + print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}a][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n"; exit 1; } my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp); -my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph); +my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz); my ($curphase, $recovery); if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) { $td = $ARGV[1]; @@ -57,7 +57,6 @@ if ($windoz) { $rfz = "$td\\rfz.dat"; $tbz = "$td\\tbz.dat"; $rbz = "$td\\rbz.dat"; - $cph = "$td\\phase.txt"; $rmtmp = "rd /S /Q $td"; } else { $radscn = "$td/device.rad"; @@ -80,14 +79,14 @@ if ($windoz) { $rfz = "$td/rfz.dat"; $tbz = "$td/tbz.dat"; $rbz = "$td/rbz.dat"; - $cph = "$td/phase.txt"; $rmtmp = "rm -rf $td"; } my @savedARGV = @ARGV; -my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6"; +my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6 -w-"; my $wrapper = "wrapBSDF"; my $tensortree = 0; my $ttlog2 = 4; +my $dorecip = 1; my $nsamp = 2000; my $mgfin = 0; my $geout = 1; @@ -115,6 +114,8 @@ while ($#ARGV >= 0) { shift @ARGV; } elsif ("$ARGV[0]" =~ /^[-+]C/) { $docolor = ("$ARGV[0]" =~ /^\+/); + } elsif ("$ARGV[0]" =~ /^[-+]a/) { + $dorecip = ("$ARGV[0]" =~ /^\+/); } elsif ("$ARGV[0]" =~ /^[-+]f/) { $doforw = ("$ARGV[0]" =~ /^\+/); } elsif ("$ARGV[0]" =~ /^[-+]b/) { @@ -170,7 +171,7 @@ if ( !defined $recovery ) { } } if ( $#dim != 5 ) { - @dim = split ' ', `getbbox -h $radscn`; + @dim = split ' ', `getbbox -h -w $radscn`; } die "Device entirely inside room!\n" if ( $dim[4] >= 0 ); if ( $dim[5] > 1e-5 ) { @@ -187,7 +188,8 @@ my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' . 'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' . 'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' . 'den=Xi+15*Yi+3*Zi;' . - 'uprime=4*Xi/den;vprime=9*Yi/den;' ; + 'uprime=if(Yi,4*Xi/den,4/19);' . + 'vprime=if(Yi,9*Yi/den,9/19);' ; my $FEPS = 1e-5; my $ns = 2**$ttlog2; my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1); @@ -209,6 +211,7 @@ if ( !defined $recovery ) { printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; close MGFSCN; if ( $mgfin ) { + die "+mgf requires input file with +geom\n" if ($#ARGV < 0); system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn}; } else { system "rad2mgf $radscn >> $mgfscn"; @@ -249,13 +252,6 @@ if ( !defined $recovery ) { } print STDERR "Recover using: $0 -recover $td\n"; } -# Open unbuffered progress file -open(MYPH, ">> $td/phase.txt"); -{ - my $ofh = select MYPH; - $| = 1; - select $ofh; -} $curphase = 0; # Create data segments (all the work happens here) if ( $tensortree ) { @@ -279,7 +275,9 @@ sub do_phase { if ( $recovery > $curphase ) { return 0; } if ( $recovery == $curphase ) { return -1; } } + open(MYPH, ">> $td/phase.txt"); print MYPH "$curphase\n"; + close MYPH; return 1; } @@ -324,7 +322,11 @@ sub do_ttree_dir { qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } . qq{-e "r2=rand(-5.37138*recno+67.1737811)" } . qq{-e "r3=rand(+3.17603772*recno+83.766771)" } . - qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } . + qq{-e "r4=rand(-1.5839226*recno-59.82712)" } . + qq{-e "odds(n):if(.5*n-floor(.5*n)-.25,-1,1)"} . + qq{-e "Dx=1-(\$1+r1)/$ns2" } . + qq{-e "Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2" } . + qq{-e "Dz=sqrt(1-Dx*Dx-Dy*Dy)" } . qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } . @@ -333,13 +335,17 @@ sub do_ttree_dir { "| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree"; } else { $cmd = "cnt $ns2 $ny $nx " . - qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } . - qq{-e "r2=rand(-5.37138*recno+67.1737811)" } . - qq{-e "r3=rand(+3.17603772*recno+83.766771)" } . - qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } . - qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } . - qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } . - qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } . + qq{| rcalc -e 'r1=rand(.8681*recno-.673892)' } . + qq{-e 'r2=rand(-5.37138*recno+67.1737811)' } . + qq{-e 'r3=rand(+3.17603772*recno+83.766771)' } . + qq{-e 'r4=rand(-1.5839226*recno-59.82712)' } . + qq{-e 'odds(n):if(.5*n-floor(.5*n)-.25,-1,1)' } . + qq{-e 'Dx=1-(\$1+r1)/$ns2' } . + qq{-e 'Dy=min(1/$ns,sqrt(1-Dx*Dx))*odds(\$1)*r2' } . + qq{-e 'Dz=sqrt(1-Dx*Dx-Dy*Dy)' } . + qq{-e 'xp=(\$3+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' } . + qq{-e 'yp=(\$2+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' } . + qq{-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' } . qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } . qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } . "| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree"; @@ -353,7 +359,11 @@ sub do_ttree_dir { $cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree"; } } - run_check $cmd; + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } ttree_out($forw); } # end of do_ttree_dir() @@ -425,7 +435,7 @@ sub ttree_comp { } } if ($pctcull >= 0) { - my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : ""; + my $avg = ( $dorecip && ( $tensortree == 3 || "$typ" =~ /^r[fb]/ ) ) ? " -a" : ""; my $pcull = ("$spec" eq "Visible") ? $pctcull : (100 - (100-$pctcull)*.25) ; if ($windoz) { @@ -482,7 +492,12 @@ sub do_matrix_dir { my $dop = do_phase(); my $r = ($dop < 0) ? " -r" : ""; my $sender = ($bsender,$fsender)[$forw]; - run_check "$rfluxmtx$r -fd $sender $receivers -i $octree"; + my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree"; + if ( $dop ) { + # print STDERR "Running: $cmd\n"; + system $cmd; + die "Failure running rfluxmtx" if ( $? ); + } matrix_out($forw); } # end of do_matrix_dir() @@ -526,7 +541,7 @@ sub matrix_comp { } elsif ("$spec" eq "CIE-Z") { $cmd .= " -c 0.0241 0.1229 0.8530"; } - $cmd .= " $src | rcollate -ho -oc 145"; + $cmd .= " $src | getinfo -"; run_check "$cmd > $dest"; if ( "$spec" ne "$curspec" ) { $wrapper .= " -s $spec";
