1 |
#!/usr/bin/perl -w |
2 |
# RCSid $Id: genBSDF.pl,v 2.12 2011/02/24 20:27:00 greg Exp $ |
3 |
4 |
# Compute BSDF based on geometry and material description |
5 |
6 |
# G. Ward |
7 |
8 |
use strict; |
9 |
use File::Temp qw/ :mktemp /; |
10 |
sub userror { |
11 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n"; |
12 |
exit 1; |
13 |
14 |
my $td = mkdtemp("/tmp/genBSDF.XXXXXX"); |
15 |
chomp $td; |
16 |
my $nsamp = 1000; |
17 |
my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6"; |
18 |
my $mgfin = 0; |
19 |
my $geout = 1; |
20 |
my $nproc = 1; |
21 |
my $doforw = 0; |
22 |
my $doback = 1; |
23 |
my @dim; |
24 |
# Get options |
25 |
while ($#ARGV >= 0) { |
26 |
if ("$ARGV[0]" =~ /^[-+]m/) { |
27 |
$mgfin = ("$ARGV[0]" =~ /^\+/); |
28 |
} elsif ("$ARGV[0]" eq "-r") { |
29 |
$rtargs = "$rtargs $ARGV[1]"; |
30 |
shift @ARGV; |
31 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) { |
32 |
$geout = ("$ARGV[0]" =~ /^\+/); |
33 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) { |
34 |
$doforw = ("$ARGV[0]" =~ /^\+/); |
35 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) { |
36 |
$doback = ("$ARGV[0]" =~ /^\+/); |
37 |
} elsif ("$ARGV[0]" eq "-c") { |
38 |
$nsamp = $ARGV[1]; |
39 |
shift @ARGV; |
40 |
} elsif ("$ARGV[0]" eq "-n") { |
41 |
$nproc = $ARGV[1]; |
42 |
shift @ARGV; |
43 |
} elsif ("$ARGV[0]" =~ /^-d/) { |
44 |
userror() if ($#ARGV < 6); |
45 |
@dim = @ARGV[1..6]; |
46 |
shift @ARGV for (1..6); |
47 |
} elsif ("$ARGV[0]" =~ /^[-+]./) { |
48 |
userror(); |
49 |
} else { |
50 |
last; |
51 |
52 |
shift @ARGV; |
53 |
54 |
# Check that we're actually being asked to do something |
55 |
die "Must have at least one of +forward or +backward" if (!$doforw && !$doback); |
56 |
# Get scene description and dimensions |
57 |
my $radscn = "$td/device.rad"; |
58 |
my $mgfscn = "$td/device.mgf"; |
59 |
my $octree = "$td/device.oct"; |
60 |
if ( $mgfin ) { |
61 |
system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn"; |
62 |
die "Could not load MGF input\n" if ( $? ); |
63 |
system "mgf2rad $mgfscn > $radscn"; |
64 |
} else { |
65 |
system "xform -e @ARGV > $radscn"; |
66 |
die "Could not load Radiance input\n" if ( $? ); |
67 |
system "rad2mgf $radscn > $mgfscn" if ( $geout ); |
68 |
69 |
if ($#dim != 5) { |
70 |
@dim = split ' ', `getbbox -h $radscn`; |
71 |
72 |
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5); |
73 |
# Add receiver surfaces (rectangular) |
74 |
my $fmodnm="receiver_face"; |
75 |
my $bmodnm="receiver_behind"; |
76 |
open(RADSCN, ">> $radscn"); |
77 |
print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n"; |
78 |
print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n"; |
79 |
print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n"; |
80 |
print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n"; |
81 |
close RADSCN; |
82 |
# Generate octree |
83 |
system "oconv -w $radscn > $octree"; |
84 |
die "Could not compile scene\n" if ( $? ); |
85 |
# Set up sampling of interior portal |
86 |
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms |
87 |
my $tcal = ' |
88 |
DEGREE : PI/180; |
89 |
sq(x) : x*x; |
90 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
91 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
92 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); |
93 |
Kmax : Kaccum(Knaz(0)); |
94 |
Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r); |
95 |
Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin)); |
96 |
Kcol = Kbin - Kaccum(Krow-1); |
97 |
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow); |
98 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); |
99 |
sin_kpol = sin(Kpol); |
100 |
Dx = cos(Kazi)*sin_kpol; |
101 |
Dy = sin(Kazi)*sin_kpol; |
102 |
Dz = sqrt(1 - sin_kpol*sin_kpol); |
103 |
KprojOmega = PI * if(Kbin-.5, |
104 |
(sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow), |
105 |
1 - sq(cos(Kpola(1)*DEGREE))); |
106 |
107 |
# Compute Klems bin from exiting ray direction (forward or backward) |
108 |
my $kcal = ' |
109 |
DEGREE : PI/180; |
110 |
abs(x) : if(x, x, -x); |
111 |
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x))); |
112 |
posangle(a) : if(-a, a + 2*PI, a); |
113 |
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x)); |
114 |
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
115 |
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
116 |
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0); |
117 |
kfindrow(r, pol) : if(r-kpola(0)+.5, r, |
118 |
if(pol-kpola(r), kfindrow(r+1, pol), r) ); |
119 |
kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0); |
120 |
kbin2(pol,azi) = select(kfindrow(1, pol), |
121 |
kazn(azi,360/knaz(1)), |
122 |
kaccum(1) + kazn(azi,360/knaz(2)), |
123 |
kaccum(2) + kazn(azi,360/knaz(3)), |
124 |
kaccum(3) + kazn(azi,360/knaz(4)), |
125 |
kaccum(4) + kazn(azi,360/knaz(5)), |
126 |
kaccum(5) + kazn(azi,360/knaz(6)), |
127 |
kaccum(6) + kazn(azi,360/knaz(7)), |
128 |
kaccum(7) + kazn(azi,360/knaz(8)), |
129 |
kaccum(8) + kazn(azi,360/knaz(9)) |
130 |
131 |
kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx)); |
132 |
133 |
my $ndiv = 145; |
134 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5); |
135 |
my $ny = int($nsamp/$nx + .5); |
136 |
$nsamp = $nx * $ny; |
137 |
# Compute scattering data using rtcontrib |
138 |
my @tfarr; |
139 |
my @rfarr; |
140 |
my @tbarr; |
141 |
my @rbarr; |
142 |
my $cmd; |
143 |
my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " . |
144 |
"-e '$kcal' -b kbin -bn $ndiv " . |
145 |
"-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree"; |
146 |
my $rccmd = "rcalc -e '$tcal' " . |
147 |
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " . |
148 |
q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'}; |
149 |
if ( $doforw ) { |
150 |
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " . |
151 |
"-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
152 |
"-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
153 |
"-e 'zp:$dim[4]' " . |
154 |
q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } . |
155 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } . |
156 |
"| $rtcmd"; |
157 |
system "$cmd" || die "Failure running: $cmd\n"; |
158 |
@tfarr = `$rccmd $td/$fmodnm.flt`; |
159 |
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? ); |
160 |
@rfarr = `$rccmd $td/$bmodnm.flt`; |
161 |
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? ); |
162 |
163 |
if ( $doback ) { |
164 |
165 |
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " . |
166 |
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " . |
167 |
"-e 'zp:$dim[5]' " . |
168 |
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } . |
169 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } . |
170 |
"| $rtcmd"; |
171 |
172 |
@tbarr = `$rccmd $td/$bmodnm.flt`; |
173 |
174 |
@rbarr = `$rccmd $td/$fmodnm.flt`; |
175 |
176 |
177 |
# Output XML prologue |
178 |
print |
179 |
'<?xml version="1.0" encoding="UTF-8"?> |
180 |
<WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd"> |
181 |
<WindowElementType>System</WindowElementType> |
182 |
<Optical> |
183 |
<Layer> |
184 |
<Material> |
185 |
<Name>Name</Name> |
186 |
<Manufacturer>Manufacturer</Manufacturer> |
187 |
188 |
printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4]; |
189 |
printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0]; |
190 |
printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2]; |
191 |
print "\t\t\t<DeviceType>Integral</DeviceType>\n"; |
192 |
# Output MGF description if requested |
193 |
if ( $geout ) { |
194 |
print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n"; |
195 |
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2; |
196 |
system "cat $mgfscn"; |
197 |
print "xf\n"; |
198 |
print "\t\t\t</Geometry>\n"; |
199 |
200 |
print ' </Material> |
201 |
<DataDefinition> |
202 |
<IncidentDataStructure>Columns</IncidentDataStructure> |
203 |
<AngleBasis> |
204 |
<AngleBasisName>LBNL/Klems Full</AngleBasisName> |
205 |
<AngleBasisBlock> |
206 |
<Theta>0</Theta> |
207 |
<nPhis>1</nPhis> |
208 |
<ThetaBounds> |
209 |
<LowerTheta>0</LowerTheta> |
210 |
<UpperTheta>5</UpperTheta> |
211 |
</ThetaBounds> |
212 |
</AngleBasisBlock> |
213 |
<AngleBasisBlock> |
214 |
<Theta>10</Theta> |
215 |
<nPhis>8</nPhis> |
216 |
<ThetaBounds> |
217 |
<LowerTheta>5</LowerTheta> |
218 |
<UpperTheta>15</UpperTheta> |
219 |
</ThetaBounds> |
220 |
221 |
<AngleBasisBlock> |
222 |
<Theta>20</Theta> |
223 |
<nPhis>16</nPhis> |
224 |
<ThetaBounds> |
225 |
<LowerTheta>15</LowerTheta> |
226 |
<UpperTheta>25</UpperTheta> |
227 |
</ThetaBounds> |
228 |
229 |
<AngleBasisBlock> |
230 |
<Theta>30</Theta> |
231 |
<nPhis>20</nPhis> |
232 |
<ThetaBounds> |
233 |
<LowerTheta>25</LowerTheta> |
234 |
<UpperTheta>35</UpperTheta> |
235 |
</ThetaBounds> |
236 |
237 |
<AngleBasisBlock> |
238 |
<Theta>40</Theta> |
239 |
<nPhis>24</nPhis> |
240 |
<ThetaBounds> |
241 |
<LowerTheta>35</LowerTheta> |
242 |
<UpperTheta>45</UpperTheta> |
243 |
</ThetaBounds> |
244 |
245 |
<AngleBasisBlock> |
246 |
<Theta>50</Theta> |
247 |
<nPhis>24</nPhis> |
248 |
<ThetaBounds> |
249 |
<LowerTheta>45</LowerTheta> |
250 |
<UpperTheta>55</UpperTheta> |
251 |
</ThetaBounds> |
252 |
253 |
<AngleBasisBlock> |
254 |
<Theta>60</Theta> |
255 |
<nPhis>24</nPhis> |
256 |
<ThetaBounds> |
257 |
<LowerTheta>55</LowerTheta> |
258 |
<UpperTheta>65</UpperTheta> |
259 |
</ThetaBounds> |
260 |
261 |
<AngleBasisBlock> |
262 |
<Theta>70</Theta> |
263 |
<nPhis>16</nPhis> |
264 |
<ThetaBounds> |
265 |
<LowerTheta>65</LowerTheta> |
266 |
<UpperTheta>75</UpperTheta> |
267 |
</ThetaBounds> |
268 |
269 |
<AngleBasisBlock> |
270 |
<Theta>82.5</Theta> |
271 |
<nPhis>12</nPhis> |
272 |
<ThetaBounds> |
273 |
<LowerTheta>75</LowerTheta> |
274 |
<UpperTheta>90</UpperTheta> |
275 |
</ThetaBounds> |
276 |
277 |
</AngleBasis> |
278 |
</DataDefinition> |
279 |
280 |
if ( $doforw ) { |
281 |
print ' <WavelengthData> |
282 |
<LayerNumber>System</LayerNumber> |
283 |
<Wavelength unit="Integral">Visible</Wavelength> |
284 |
<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum> |
285 |
<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum> |
286 |
<WavelengthDataBlock> |
287 |
<WavelengthDataDirection>Transmission Front</WavelengthDataDirection> |
288 |
<ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis> |
289 |
<RowAngleBasis>LBNL/Klems Full</RowAngleBasis> |
290 |
<ScatteringDataType>BTDF</ScatteringDataType> |
291 |
<ScatteringData> |
292 |
293 |
# Output front transmission (transposed order) |
294 |
for (my $od = 0; $od < $ndiv; $od++) { |
295 |
for (my $id = 0; $id < $ndiv; $id++) { |
296 |
print $tfarr[$ndiv*$id + $od]; |
297 |
298 |
print "\n"; |
299 |
300 |
print |
301 |
' </ScatteringData> |
302 |
</WavelengthDataBlock> |
303 |
</WavelengthData> |
304 |
<WavelengthData> |
305 |
306 |
307 |
308 |
309 |
310 |
<WavelengthDataDirection>Reflection Front</WavelengthDataDirection> |
311 |
312 |
313 |
<ScatteringDataType>BRDF</ScatteringDataType> |
314 |
<ScatteringData> |
315 |
316 |
# Output front reflection (transposed order) |
317 |
318 |
319 |
print $rfarr[$ndiv*$id + $od]; |
320 |
321 |
print "\n"; |
322 |
323 |
print |
324 |
325 |
326 |
</WavelengthData> |
327 |
328 |
329 |
if ( $doback ) { |
330 |
331 |
332 |
333 |
334 |
335 |
336 |
<WavelengthDataDirection>Transmission Back</WavelengthDataDirection> |
337 |
338 |
339 |
340 |
<ScatteringData> |
341 |
342 |
# Output back transmission (transposed order) |
343 |
344 |
345 |
print $tbarr[$ndiv*$id + $od]; |
346 |
347 |
print "\n"; |
348 |
349 |
print |
350 |
351 |
352 |
</WavelengthData> |
353 |
<WavelengthData> |
354 |
355 |
356 |
357 |
358 |
359 |
<WavelengthDataDirection>Reflection Back</WavelengthDataDirection> |
360 |
361 |
362 |
363 |
<ScatteringData> |
364 |
365 |
# Output back reflection (transposed order) |
366 |
367 |
368 |
print $rbarr[$ndiv*$id + $od]; |
369 |
370 |
print "\n"; |
371 |
372 |
print |
373 |
374 |
375 |
</WavelengthData> |
376 |
377 |
378 |
# Output XML epilogue |
379 |
print '</Layer> |
380 |
</Optical> |
381 |
</WindowElement> |
382 |
383 |
# Clean up temporary files |
384 |
system "rm -rf $td"; |
