root/radiance/ray/src/util/genBSDF.pl
Wed Jul 9 15:03:11 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.47: +4 -1 lines
Diff to previous 2.47 , to selected 2.28
Added warning for -t3 w/o +forward and +backward
Thu Apr 24 23:08:08 2014 UTC (10 years ago) by greg
Changes since 2.46: +293 -166 lines
Diff to previous 2.46 , to selected 2.28
Andy finished making genBSDF Windows-compatible
Mon Apr 7 21:33:25 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.45 , to selected 2.28
Added protection against very small dimension(s)
Thu Oct 3 17:27:41 2013 UTC (10 years, 7 months ago) by greg
Diff to previous 2.44 , to selected 2.28
Re-allowed rttree_reduce -a option for isotropic transmission
Sat Sep 7 17:56:02 2013 UTC (10 years, 8 months ago) by greg
Diff to previous 2.43 , to selected 2.28
Bug fix for round-off error at phi=315 degrees
Mon Aug 5 22:56:50 2013 UTC (10 years, 9 months ago) by greg
Diff to previous 2.42 , to selected 2.28
Tue Apr 23 23:22:09 2013 UTC (11 years ago) by greg
Diff to previous 2.41 , to selected 2.28
Correction to last change
Tue Apr 23 23:19:09 2013 UTC (11 years ago) by greg
Diff to previous 2.40 , to selected 2.28
Sat Oct 13 20:15:43 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.39: +11 -8 lines
Diff to previous 2.39 , to selected 2.28
Mon Sep 10 18:06:08 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.38: +3 -1 lines
Diff to previous 2.38 , to selected 2.28
Hopeful fixes to tensor tree reciprocity and orientation
Sun Sep 2 15:33:16 2012 UTC (11 years, 8 months ago) by greg
Changes since 2.37: +9 -7 lines
Diff to previous 2.37 , to selected 2.28
Thu Jun 14 22:42:21 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.36: +5 -5 lines
Diff to previous 2.36 , to selected 2.28
Thu Jun 14 18:35:03 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.35: +29 -98 lines
Diff to previous 2.35 , to selected 2.28
Simplified and called new rcontrib program
Wed May 9 17:40:17 2012 UTC (12 years ago) by greg
Changes since 2.34: +72 -72 lines
Diff to previous 2.34 , to selected 2.28
Minor changes that should not affect results
Thu Mar 15 02:32:19 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.33: +7 -1 lines
Diff to previous 2.33 , to selected 2.28
Fix for -t3 N -t -1
Tue Mar 6 04:41:31 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.32: +27 -11 lines
Diff to previous 2.32 , to selected 2.28
Changed default -t to 90 and set up -t -1 to skip rttree_reduce call
Thu Feb 23 21:28:42 2012 UTC (12 years, 2 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.28
Fixed problem with extra newlines
Mon Feb 20 04:54:49 2012 UTC (12 years, 3 months ago) by greg
Changes since 2.30: +4 -4 lines
Diff to previous 2.30 , to selected 2.28
Took out reciprocity averaging for matrix data, which wasn't being done properly
Mon Feb 20 02:56:19 2012 UTC (12 years, 3 months ago) by greg
Diff to previous 2.29 , to selected 2.28
Minor fix for corner case
Fri Feb 17 00:14:46 2012 UTC (12 years, 3 months ago) by greg
Changes since 2.28: +7 -8 lines
Diff to previous 2.28
Revision 2.28 - (view) (download) (annotate) - [selected]
Mon Nov 21 20:07:50 2011 UTC (12 years, 5 months ago) by greg
Changes since 2.27: +7 -7 lines
Diff to previous 2.27
Added reciprocity averaging
Thu Oct 27 16:35:54 2011 UTC (12 years, 6 months ago) by greg
Diff to previous 2.26 , to selected 2.28
Tue Oct 25 20:51:10 2011 UTC (12 years, 6 months ago) by greg
Diff to previous 2.25 , to selected 2.28
Wed Aug 24 04:14:58 2011 UTC (12 years, 8 months ago) by greg
Diff to previous 2.24 , to selected 2.28
Tue Aug 23 14:02:41 2011 UTC (12 years, 8 months ago) by greg
Diff to previous 2.23 , to selected 2.28
Fri Jun 24 19:07:38 2011 UTC (12 years, 10 months ago) by greg
Diff to previous 2.22 , to selected 2.28
Fri Jun 24 00:41:51 2011 UTC (12 years, 10 months ago) by greg
Diff to previous 2.21 , to selected 2.28
Wed Jun 8 23:16:47 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.20 , to selected 2.28
Sat Jun 4 00:33:53 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.19 , to selected 2.28
Fri Jun 3 19:41:14 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.28
Wed Jun 1 22:50:24 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.17 , to selected 2.28
Wed Jun 1 00:29:40 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.16 , to selected 2.28
Tue May 31 20:50:26 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.15 , to selected 2.28
Wed May 25 19:24:11 2011 UTC (12 years, 11 months ago) by greg
Diff to previous 2.14 , to selected 2.28
Sat Apr 16 01:13:22 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.28
Eliminated Unix dependencies
Sat Apr 16 00:39:07 2011 UTC (13 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.28
Bug fix for 32-bit OS
Thu Feb 24 20:27:00 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 2.28
Fixed usage message
Thu Feb 24 20:14:26 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.10 , to selected 2.28
Tue Feb 22 22:51:23 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 2.28
Mon Feb 21 22:48:51 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 2.28
Sat Jan 29 16:44:01 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 2.28
Thu Jan 27 22:28:12 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.6 , to selected 2.28
Wed Dec 15 17:23:58 2010 UTC (13 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 2.28
Thu Dec 9 17:00:43 2010 UTC (13 years, 5 months ago) by greg
Diff to previous 2.4 , to selected 2.28
Thu Dec 9 06:14:04 2010 UTC (13 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.28
Thu Sep 9 06:02:16 2010 UTC (13 years, 8 months ago) by greg
Diff to previous 2.2 , to selected 2.28
Fri Sep 3 23:53:50 2010 UTC (13 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.28
Thu Sep 2 02:29:24 2010 UTC (13 years, 8 months ago) by greg
Diff to selected 2.28
