--- ray/src/util/findglare.c 1991/04/05 14:26:47 1.15 +++ ray/src/util/findglare.c 1991/04/12 10:28:40 1.17 @@ -48,6 +48,7 @@ main(argc, argv) int argc; char *argv[]; { + int combine = 1; int gotview = 0; int rval, i; char *err; @@ -101,6 +102,9 @@ char *argv[]; case 'p': picture = argv[++i]; break; + case 'c': + combine = !combine; + break; case 'd': case 'l': rtargv[rtargc++] = argv[i]; @@ -179,6 +183,8 @@ char *argv[]; if (threshold <= FTINY) comp_thresh(); /* compute glare threshold */ analyze(); /* analyze view */ + if (combine) + absorb_specks(); /* eliminate tiny sources */ cleanup(); /* tidy up */ /* print header */ printargs(argc, argv, stdout); @@ -275,7 +281,7 @@ init() /* initialize global variables */ cleanup() /* close files, wait for children */ { if (verbose) - fprintf(stderr, "%s: cleaning up...\n", progname); + fprintf(stderr, "%s: cleaning up... \n", progname); if (picture != NULL) close_pict(); if (octree != NULL) @@ -286,13 +292,11 @@ cleanup() /* close files, wait for children */ } -compdir(vd, x, y) /* compute direction for x,y */ +compdir(vd, x, y, se) /* compute direction for x,y */ FVECT vd; int x, y; +SPANERR *se; { - static int cury = 10000; - static double err, cmpval; - long t; FVECT org; /* dummy variable */ if (x <= -hlim) /* left region */ @@ -304,20 +308,25 @@ int x, y; (double)(x-hlim)/(2*sampdens)+.5, (double)y/(2*sampdens)+.5)); /* central region */ - /* avoid over-counting of poles */ - if (cury != y) { - err = 0.0; - cmpval = sqrt(1.0 - (double)((long)y*y)/((long)vsize*vsize)); - cury = y; + if (se != NULL) { /* avoid over-counting of poles */ + se->err += se->prob; + if (se->err <= 0.5) + return(-1); + se->err -= 1.0; } - err += cmpval; - if (err <= 0.5) - return(-1); - err -= 1.0; if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0) return(-1); spinvector(vd, vd, ourview.vup, h_theta(x)); return(0); +} + + +setspanerr(se, y) /* initialize span error at y */ +register SPANERR *se; +int y; +{ + se->err = 0.0; + se->prob = sqrt(1.0 - (double)((long)y*y)/((long)vsize*vsize)); }
