root/radiance/ray/src/util/findglare.c
Revision: 2.14
Committed: Tue Jul 29 21:36:08 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3
Changes since 2.13: +12 -1 lines
Added missing support for rtrace -n, -bv, and -m* options
2 static const char RCSid[] = "$Id: findglare.c,v 2.13 2009/02/07 05:40:47 greg Exp $";
5 * Find glare sources in a scene or image.
6 *
7 * Greg Ward March 1991
8 */
9
10 #include "glare.h"
11
12 #define FEQ(a,b) ((a)-(b)<=FTINY&&(b)-(a)<=FTINY)
13 #define VEQ(v1,v2) (FEQ((v1)[0],(v2)[0])&&FEQ((v1)[1],(v2)[1]) \
14 &&FEQ((v1)[2],(v2)[2]))
15
16 char *rtargv[64] = {"rtrace", "-h-", "-ov", "-fff", "-ld-", "-i-", "-I-"};
17 int rtargc = 7;
18
19 VIEW ourview = STDVIEW; /* our view */
20 VIEW pictview = STDVIEW; /* picture view */
21 VIEW leftview, rightview; /* leftmost and rightmost views */
22
23 char *picture = NULL; /* picture file name */
24 char *octree = NULL; /* octree file name */
25
26 int verbose = 0; /* verbose reporting */
27 char *progname; /* global argv[0] */
28
29 double threshold = 0.; /* glare threshold */
30
31 int sampdens = SAMPDENS; /* sample density */
32 ANGLE glarang[180] = {AEND}; /* glare calculation angles */
33 int nglarangs = 0;
34 double maxtheta; /* maximum angle (in radians) */
35 int hsize; /* horizontal size */
36
37 struct illum *indirect; /* array of indirect illuminances */
38
39 long npixinvw; /* number of pixels in view */
40 long npixmiss; /* number of pixels missed */
41
42 static int angcmp(const void *ap1, const void *ap2);
43 static void init(void);
44 static void cleanup(void);
45 static void printsources(void);
46 static void printillum(void);
47
48
49
50 int
51 main(
52 int argc,
53 char *argv[]
54 )
55 {
56 int combine = 1;
57 int gotview = 0;
58 int rval, i;
59 char *err;
60
61 progname = argv[0];
62 /* process options */
63 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
64 /* expand arguments */
65 while ((rval = expandarg(&argc, &argv, i)) > 0)
66 ;
67 if (rval < 0) {
68 fprintf(stderr, "%s: cannot expand '%s'\n",
69 argv[0], argv[i]);
70 exit(1);
71 }
72 rval = getviewopt(&ourview, argc-i, argv+i);
73 if (rval >= 0) {
74 i += rval;
75 gotview++;
76 continue;
77 }
78 switch (argv[i][1]) {
79 case 't':
80 threshold = atof(argv[++i]);
81 break;
82 case 'r':
83 sampdens = atoi(argv[++i])/2;
84 break;
85 case 'v':
86 if (argv[i][2] == '\0') {
87 verbose++;
88 break;
89 }
90 if (argv[i][2] != 'f')
91 goto userr;
92 rval = viewfile(argv[++i], &ourview, NULL);
93 if (rval < 0) {
94 fprintf(stderr,
95 "%s: cannot open view file \"%s\"\n",
96 progname, argv[i]);
97 exit(1);
98 } else if (rval == 0) {
99 fprintf(stderr,
100 "%s: bad view file \"%s\"\n",
101 progname, argv[i]);
102 exit(1);
103 } else
104 gotview++;
105 break;
106 case 'g':
107 if (argv[i][2] != 'a')
108 goto userr;
109 if (setscan(glarang, argv[++i]) < 0) {
110 fprintf(stderr, "%s: bad angle spec \"%s\"\n",
111 progname, argv[i]);
112 exit(1);
113 }
114 break;
115 case 'p':
116 picture = argv[++i];
117 break;
118 case 'c':
119 combine = !combine;
120 break;
121 case 'd':
122 rtargv[rtargc++] = argv[i];
123 if (argv[i][2] != 'v')
124 rtargv[rtargc++] = argv[++i];
125 break;
126 case 'l':
127 if (argv[i][2] == 'd')
128 break;
129 /* FALL THROUGH */
130 case 's':
131 case 'P':
132 case 'n':
133 rtargv[rtargc++] = argv[i];
134 rtargv[rtargc++] = argv[++i];
135 break;
136 case 'w':
137 case 'u':
138 case 'b':
139 rtargv[rtargc++] = argv[i];
140 break;
141 case 'a':
142 rtargv[rtargc++] = argv[i];
143 if (argv[i][2] == 'v') {
144 rtargv[rtargc++] = argv[++i];
145 rtargv[rtargc++] = argv[++i];
146 }
147 rtargv[rtargc++] = argv[++i];
148 break;
149 case 'm':
150 rtargv[rtargc++] = argv[i];
151 if ((argv[i][2] == 'e') | (argv[i][2] == 'a')) {
152 rtargv[rtargc++] = argv[++i];
153 rtargv[rtargc++] = argv[++i];
154 }
155 rtargv[rtargc++] = argv[++i];
156 break;
157 default:
158 goto userr;
159 }
160 }
161 /* get octree */
162 if (i < argc-1)
163 goto userr;
164 if (i == argc-1) {
165 rtargv[rtargc++] = octree = argv[i];
166 rtargv[rtargc] = NULL;
167 }
168 /* get view */
169 if (picture != NULL) {
170 rval = viewfile(picture, &pictview, NULL);
171 if (rval < 0) {
172 fprintf(stderr, "%s: cannot open picture file \"%s\"\n",
173 progname, picture);
174 exit(1);
175 } else if (rval == 0) {
176 fprintf(stderr,
177 "%s: cannot get view from picture \"%s\"\n",
178 progname, picture);
179 exit(1);
180 }
181 if (pictview.type == VT_PAR) {
182 fprintf(stderr, "%s: %s: cannot use parallel view\n",
183 progname, picture);
184 exit(1);
185 }
186 if ((err = setview(&pictview)) != NULL) {
187 fprintf(stderr, "%s: %s\n", picture, err);
188 exit(1);
189 }
190 }
191 if (!gotview) {
192 if (picture == NULL) {
193 fprintf(stderr, "%s: must have view or picture\n",
194 progname);
195 exit(1);
196 }
197 ourview = pictview;
198 } else if (picture != NULL && !VEQ(ourview.vp, pictview.vp)) {
199 fprintf(stderr, "%s: picture must have same viewpoint\n",
200 progname);
201 exit(1);
202 }
203 ourview.type = VT_HEM;
204 ourview.horiz = ourview.vert = 180.0;
205 ourview.hoff = ourview.voff = 0.0;
206 fvsum(ourview.vdir, ourview.vdir, ourview.vup,
207 -DOT(ourview.vdir,ourview.vup));
208 if ((err = setview(&ourview)) != NULL) {
209 fprintf(stderr, "%s: %s\n", progname, err);
210 exit(1);
211 }
212 if (octree == NULL && picture == NULL) {
213 fprintf(stderr,
214 "%s: must specify at least one of picture or octree\n",
215 progname);
216 exit(1);
217 }
218 init(); /* initialize program */
219 if (threshold <= FTINY)
220 comp_thresh(); /* compute glare threshold */
221 analyze(); /* analyze view */
222 if (combine)
223 absorb_specks(); /* eliminate tiny sources */
224 cleanup(); /* tidy up */
225 /* print header */
226 newheader("RADIANCE", stdout);
227 printargs(argc, argv, stdout);
228 fputs(VIEWSTR, stdout);
229 fprintview(&ourview, stdout);
230 printf("\n");
231 fputformat("ascii", stdout);
232 printf("\n");
233 printsources(); /* print glare sources */
234 printillum(); /* print illuminances */
235 exit(0);
236 userr:
237 fprintf(stderr,
238 "Usage: %s [view options][-ga angles][-p picture][[rtrace options] octree]\n",
239 progname);
240 exit(1);
241 }
242
243
244 static int
245 angcmp( /* compare two angles */
246 const void *ap1,
247 const void *ap2
248 )
249 {
250 register int a1, a2;
251
252 a1 = *(ANGLE *)ap1;
253 a2 = *(ANGLE *)ap2;
254 if (a1 == a2) {
255 fprintf(stderr, "%s: duplicate glare angle (%d)\n",
256 progname, a1);
257 exit(1);
258 }
259 return(a1-a2);
260 }
261
262
263 static void
264 init(void) /* initialize global variables */
265 {
266 double d;
267 register int i;
268
269 if (verbose)
270 fprintf(stderr, "%s: initializing data structures...\n",
271 progname);
272 /* set direction vectors */
273 for (i = 0; glarang[i] != AEND; i++)
274 ;
275 qsort(glarang, i, sizeof(ANGLE), angcmp);
276 if (i > 0 && (glarang[0] <= 0 || glarang[i-1] > 180)) {
277 fprintf(stderr, "%s: glare angles must be between 1 and 180\n",
278 progname);
279 exit(1);
280 }
281 nglarangs = i;
282 /* nglardirs = 2*nglarangs + 1; */
283 /* vsize = sampdens - 1; */
284 if (nglarangs > 0)
285 maxtheta = (PI/180.)*glarang[nglarangs-1];
286 else
287 maxtheta = 0.0;
288 hsize = hlim(0) + sampdens - 1;
289 if (hsize > (int)(PI*sampdens))
290 hsize = PI*sampdens;
291 indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum));
292 if (indirect == NULL)
293 memerr("indirect illuminances");
294 npixinvw = npixmiss = 0L;
295 leftview = ourview;
296 rightview = ourview;
297 spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta);
298 spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta);
299 setview(&leftview);
300 setview(&rightview);
301 indirect[nglarangs].lcos =
302 indirect[nglarangs].rcos = cos(maxtheta);
303 indirect[nglarangs].rsin =
304 -(indirect[nglarangs].lsin = sin(maxtheta));
305 indirect[nglarangs].theta = 0.0;
306 for (i = 0; i < nglarangs; i++) {
307 d = (glarang[nglarangs-1] - glarang[i])*(PI/180.);
308 indirect[nglarangs-i-1].lcos =
309 indirect[nglarangs+i+1].rcos = cos(d);
310 indirect[nglarangs+i+1].rsin =
311 -(indirect[nglarangs-i-1].lsin = sin(d));
312 d = (glarang[nglarangs-1] + glarang[i])*(PI/180.);
313 indirect[nglarangs-i-1].rcos =
314 indirect[nglarangs+i+1].lcos = cos(d);
315 indirect[nglarangs-i-1].rsin =
316 -(indirect[nglarangs+i+1].lsin = sin(d));
317 indirect[nglarangs-i-1].theta = (PI/180.)*glarang[i];
318 indirect[nglarangs+i+1].theta = -(PI/180.)*glarang[i];
319 }
320 /* open picture */
321 if (picture != NULL) {
322 if (verbose)
323 fprintf(stderr, "%s: opening picture file \"%s\"...\n",
324 progname, picture);
325 open_pict(picture);
326 }
327 /* start rtrace */
328 if (octree != NULL) {
329 if (verbose) {
330 fprintf(stderr,
331 "%s: starting luminance calculation...\n\t",
332 progname);
333 printargs(rtargc, rtargv, stderr);
334 }
335 fork_rtrace(rtargv);
336 }
337 }
338
339
340 static void
341 cleanup(void) /* close files, wait for children */
342 {
343 if (verbose)
344 fprintf(stderr, "%s: cleaning up... \n", progname);
345 if (picture != NULL)
346 close_pict();
347 if (octree != NULL)
348 done_rtrace();
349 if (npixinvw < 100*npixmiss)
350 fprintf(stderr, "%s: warning -- missing %d%% of samples\n",
351 progname, (int)(100L*npixmiss/npixinvw));
352 }
353
354
355 extern int
356 compdir( /* compute direction for x,y */
357 FVECT vd,
358 int x,
359 int y
360 )
361 {
362 int hl;
363 FVECT org; /* dummy variable */
364
365 hl = hlim(y);
366 if (x <= -hl) { /* left region */
367 if (x <= -hl-sampdens)
368 return(-1);
369 return(viewray(org, vd, &leftview,
370 (double)(x+hl)/(2*sampdens)+.5,
371 (double)y/(2*sampdens)+.5));
372 }
373 if (x >= hl) { /* right region */
374 if (x >= hl+sampdens)
375 return(-1);
376 return(viewray(org, vd, &rightview,
377 (double)(x-hl)/(2*sampdens)+.5,
378 (double)y/(2*sampdens)+.5));
379 }
380 /* central region */
381 if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0)
382 return(-1);
383 spinvector(vd, vd, ourview.vup, h_theta(x,y));
384 return(0);
385 }
386
387
388 extern double
389 pixsize( /* return the solid angle of pixel at (x,y) */
390 int x,
391 int y
392 )
393 {
394 register int hl, xo;
395 double disc;
396
397 hl = hlim(y);
398 if (x < -hl)
399 xo = x+hl;
400 else if (x > hl)
401 xo = x-hl;
402 else
403 xo = 0;
404 disc = 1. - (double)((long)xo*xo + (long)y*y)/((long)sampdens*sampdens);
405 if (disc <= FTINY*FTINY)
406 return(0.);
407 return(1./(sampdens*sampdens*sqrt(disc)));
408 }
409
410
411 extern void
412 memerr( /* malloc failure */
413 char *s
414 )
415 {
416 fprintf(stderr, "%s: out of memory for %s\n", progname, s);
417 exit(1);
418 }
419
420
421 static void
422 printsources(void) /* print out glare sources */
423 {
424 register struct source *sp;
425
426 printf("BEGIN glare source\n");
427 for (sp = donelist; sp != NULL; sp = sp->next)
428 printf("\t%f %f %f\t%f\t%f\n",
429 sp->dir[0], sp->dir[1], sp->dir[2],
430 sp->dom, sp->brt);
431 printf("END glare source\n");
432 }
433
434
435 static void
436 printillum(void) /* print out indirect illuminances */
437 {
438 register int i;
439
440 printf("BEGIN indirect illuminance\n");
441 for (i = 0; i < nglardirs; i++)
442 if (indirect[i].n > FTINY)
443 printf("\t%.0f\t%f\n", (180.0/PI)*indirect[i].theta,
444 PI * indirect[i].sum / indirect[i].n);
445 printf("END indirect illuminance\n");
446 }
