root/radiance/ray/src/util/findglare.c
Diff to previous 2.11 , to selected 1.24
Continued ANSIfication.
Changes since 2.10: +43 -21 lines
Diff to previous 2.10 , to selected 1.24
Ansification.
Diff to previous 2.9 , to selected 1.24
Changes since 2.8: +8 -10 lines
Diff to previous 2.8 , to selected 1.24
Mon Oct 20 16:35:30 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.7: +8 -6 lines
Diff to previous 2.7 , to selected 1.24
Sun Mar 6 12:52:58 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.6: +8 -0 lines
Diff to previous 2.6 , to selected 1.24
added option expansion and newheader() call
Mon Jun 7 10:31:35 1993 UTC (30 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 1.24
minor changes for 16-bit integers (not checked)
Wed Feb 3 17:55:34 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.24
added -P and -PP option for rtrace
Mon Dec 7 09:13:58 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.3: +8 -0 lines
Diff to previous 2.3 , to selected 1.24
added provisions for -dv and -w rtrace switches
Fri Nov 13 13:19:16 1992 UTC (31 years, 5 months ago) by greg
Diff to previous 2.2 , to selected 1.24
minor problems
Tue May 12 09:36:14 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 1.24
added switch for -st -sj options of rtrace
Tue Nov 12 17:19:13 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.25 , to selected 1.24
Tue Nov 12 13:21:01 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.24
fixed bug in floating point comparison
Revision 1.24 - (view) (download) (annotate) - [selected]
Tue Jul 30 15:42:56 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.23: +1 -1 lines
Diff to previous 1.23
*** empty log message ***
Wed May 1 16:14:13 1991 UTC (33 years ago) by greg
Changes since 1.22: +20 -2 lines
Diff to previous 1.22 , to selected 1.24
added qsort call to insure angles are sorted properly
Mon Apr 22 14:56:28 1991 UTC (33 years ago) by greg
Changes since 1.21: +8 -2 lines
Diff to previous 1.21 , to selected 1.24
minor optimization of compdir()
Mon Apr 22 10:11:23 1991 UTC (33 years ago) by greg
Changes since 1.20: +1 -1 lines
Diff to previous 1.20 , to selected 1.24
ASCII -> ascii
Mon Apr 22 08:21:01 1991 UTC (33 years ago) by greg
Diff to previous 1.19 , to selected 1.24
Fri Apr 19 17:40:59 1991 UTC (33 years ago) by greg
Changes since 1.18: +26 -21 lines
Diff to previous 1.18 , to selected 1.24
Thu Apr 18 15:18:22 1991 UTC (33 years ago) by greg
Diff to previous 1.17 , to selected 1.24
Fri Apr 12 10:28:40 1991 UTC (33 years ago) by greg
Changes since 1.16: +17 -14 lines
Diff to previous 1.16 , to selected 1.24
minor changes and bug fixes
Wed Apr 10 15:59:07 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.15: +6 -0 lines
Diff to previous 1.15 , to selected 1.24
Fri Apr 5 14:26:47 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.14: +10 -4 lines
Diff to previous 1.14 , to selected 1.24
removed call to random() in compdir()
Tue Apr 2 16:47:03 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.13: +8 -1 lines
Diff to previous 1.13 , to selected 1.24
corrected for improper sample spacing in compdir()
Tue Apr 2 14:29:15 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.12: +12 -5 lines
Diff to previous 1.12 , to selected 1.24
Mon Mar 25 14:40:10 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 1.24
added conditional to printillum()
Thu Mar 21 17:11:46 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.10 , to selected 1.24
Wed Mar 20 12:30:37 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 1.24
bug in if statement
Wed Mar 20 12:20:38 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.8: +8 -8 lines
Diff to previous 1.8 , to selected 1.24
made theta consistently positive to the left (bug fix)
Tue Mar 19 17:21:34 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.7: +7 -1 lines
Diff to previous 1.7 , to selected 1.24
Tue Mar 19 17:06:21 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.6: +0 -19 lines
Diff to previous 1.6 , to selected 1.24
Tue Mar 19 11:19:23 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.5 , to selected 1.24
added standard defaults to ourview
Tue Mar 19 09:08:18 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.4: +3 -3 lines
Diff to previous 1.4 , to selected 1.24
changed resolution
Mon Mar 18 16:21:09 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +14 -10 lines
Diff to previous 1.3 , to selected 1.24
added -r option for sample resolution
Mon Mar 18 15:06:49 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 1.24
fixed orientation of theta
Mon Mar 18 14:32:12 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 1.24
Mon Mar 18 12:15:38 1991 UTC (33 years, 1 month ago) by greg
Diff to selected 1.24
