root/radiance/ray/src/util/findglare.c
Revision: 2.18
Committed: Tue Jun 3 21:31:51 2025 UTC (3 days, 3 hours ago) by greg
2 static const char RCSid[] = "$Id: findglare.c,v 2.17 2023/01/15 16:38:10 greg Exp $";
5 * Find glare sources in a scene or image.
6 *
7 * Greg Ward March 1991
8 */
9
10 #include "glare.h"
11
12 char *rtargv[64] = {"rtrace", "-h-", "-ov", "-fff", "-ld-", "-i-", "-I-"};
13 int rtargc = 7;
14
15 VIEW ourview = STDVIEW; /* our view */
16 VIEW pictview = STDVIEW; /* picture view */
17 VIEW leftview, rightview; /* leftmost and rightmost views */
18
19 char *picture = NULL; /* picture file name */
20 char *octree = NULL; /* octree file name */
21
22 int verbose = 0; /* verbose reporting */
23
24 double threshold = 0.; /* glare threshold */
25
26 int sampdens = SAMPDENS; /* sample density */
27 ANGLE glarang[180] = {AEND}; /* glare calculation angles */
28 int nglarangs = 0;
29 double maxtheta; /* maximum angle (in radians) */
30 int hsize; /* horizontal size */
31
32 struct illum *indirect; /* array of indirect illuminances */
33
34 long npixinvw; /* number of pixels in view */
35 long npixmiss; /* number of pixels missed */
36
37 static int angcmp(const void *ap1, const void *ap2);
38 static void init(void);
39 static void cleanup(void);
40 static void printsources(void);
41 static void printillum(void);
42
43
44
45 int
46 main(
47 int argc,
48 char *argv[]
49 )
50 {
51 int combine = 1;
52 int gotview = 0;
53 int rval, i;
54 char *err;
55 /* set global progname */
56 fixargv0(argv[0]);
57 /* process options */
58 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
59 /* expand arguments */
60 while ((rval = expandarg(&argc, &argv, i)) > 0)
61 ;
62 if (rval < 0) {
63 fprintf(stderr, "%s: cannot expand '%s'\n",
64 argv[0], argv[i]);
65 exit(1);
66 }
67 rval = getviewopt(&ourview, argc-i, argv+i);
68 if (rval >= 0) {
69 i += rval;
70 gotview++;
71 continue;
72 }
73 switch (argv[i][1]) {
74 case 't':
75 threshold = atof(argv[++i]);
76 break;
77 case 'r':
78 sampdens = atoi(argv[++i])/2;
79 break;
80 case 'v':
81 if (argv[i][2] == '\0') {
82 verbose++;
83 break;
84 }
85 if (argv[i][2] != 'f')
86 goto userr;
87 rval = viewfile(argv[++i], &ourview, NULL);
88 if (rval < 0) {
89 fprintf(stderr,
90 "%s: cannot open view file \"%s\"\n",
91 progname, argv[i]);
92 exit(1);
93 } else if (rval == 0) {
94 fprintf(stderr,
95 "%s: bad view file \"%s\"\n",
96 progname, argv[i]);
97 exit(1);
98 } else
99 gotview++;
100 break;
101 case 'g':
102 if (argv[i][2] != 'a')
103 goto userr;
104 if (setscan(glarang, argv[++i]) < 0) {
105 fprintf(stderr, "%s: bad angle spec \"%s\"\n",
106 progname, argv[i]);
107 exit(1);
108 }
109 break;
110 case 'p':
111 picture = argv[++i];
112 break;
113 case 'c':
114 combine = !combine;
115 break;
116 case 'd':
117 rtargv[rtargc++] = argv[i];
118 if (argv[i][2] != 'v')
119 rtargv[rtargc++] = argv[++i];
120 break;
121 case 'l':
122 if (argv[i][2] == 'd')
123 break;
124 /* FALL THROUGH */
125 case 's':
126 case 'P':
127 case 'n':
128 rtargv[rtargc++] = argv[i];
129 rtargv[rtargc++] = argv[++i];
130 break;
131 case 'w':
132 case 'u':
133 case 'b':
134 rtargv[rtargc++] = argv[i];
135 break;
136 case 'a':
137 rtargv[rtargc++] = argv[i];
138 if (argv[i][2] == 'v') {
139 rtargv[rtargc++] = argv[++i];
140 rtargv[rtargc++] = argv[++i];
141 }
142 rtargv[rtargc++] = argv[++i];
143 break;
144 case 'm':
145 rtargv[rtargc++] = argv[i];
146 if ((argv[i][2] == 'e') | (argv[i][2] == 'a')) {
147 rtargv[rtargc++] = argv[++i];
148 rtargv[rtargc++] = argv[++i];
149 }
150 rtargv[rtargc++] = argv[++i];
151 break;
152 default:
153 goto userr;
154 }
155 }
156 /* get octree */
157 if (i < argc-1)
158 goto userr;
159 if (i == argc-1) {
160 rtargv[rtargc++] = octree = argv[i];
161 rtargv[rtargc] = NULL;
162 }
163 /* get view */
164 if (picture != NULL) {
165 rval = viewfile(picture, &pictview, NULL);
166 if (rval < 0) {
167 fprintf(stderr, "%s: cannot open picture file \"%s\"\n",
168 progname, picture);
169 exit(1);
170 } else if (rval == 0) {
171 fprintf(stderr,
172 "%s: cannot get view from picture \"%s\"\n",
173 progname, picture);
174 exit(1);
175 }
176 if (pictview.type == VT_PAR) {
177 fprintf(stderr, "%s: %s: cannot use parallel view\n",
178 progname, picture);
179 exit(1);
180 }
181 if ((err = setview(&pictview)) != NULL) {
182 fprintf(stderr, "%s: %s\n", picture, err);
183 exit(1);
184 }
185 }
186 if (!gotview) {
187 if (picture == NULL) {
188 fprintf(stderr, "%s: must have view or picture\n",
189 progname);
190 exit(1);
191 }
192 ourview = pictview;
193 } else if (picture != NULL && !VABSEQ(ourview.vp, pictview.vp)) {
194 fprintf(stderr, "%s: picture must have same viewpoint\n",
195 progname);
196 exit(1);
197 }
198 ourview.type = VT_HEM;
199 ourview.horiz = ourview.vert = 180.0;
200 ourview.hoff = ourview.voff = 0.0;
201 fvsum(ourview.vdir, ourview.vdir, ourview.vup,
202 -DOT(ourview.vdir,ourview.vup));
203 if ((err = setview(&ourview)) != NULL) {
204 fprintf(stderr, "%s: %s\n", progname, err);
205 exit(1);
206 }
207 if (octree == NULL && picture == NULL) {
208 fprintf(stderr,
209 "%s: must specify at least one of picture or octree\n",
210 progname);
211 exit(1);
212 }
213 init(); /* initialize program */
214 if (threshold <= FTINY)
215 comp_thresh(); /* compute glare threshold */
216 analyze(); /* analyze view */
217 if (combine)
218 absorb_specks(); /* eliminate tiny sources */
219 cleanup(); /* tidy up */
220 /* print header */
221 newheader("RADIANCE", stdout);
222 printargs(argc, argv, stdout);
223 fputs(VIEWSTR, stdout);
224 fprintview(&ourview, stdout);
225 printf("\n");
226 fputformat("ascii", stdout);
227 printf("\n");
228 printsources(); /* print glare sources */
229 printillum(); /* print illuminances */
230 exit(0);
231 userr:
232 fprintf(stderr,
233 "Usage: %s [view options][-ga angles][-p picture][[rtrace options] octree]\n",
234 progname);
235 exit(1);
236 }
237
238
239 static int
240 angcmp( /* compare two angles */
241 const void *ap1,
242 const void *ap2
243 )
244 {
245 int a1, a2;
246
247 a1 = *(ANGLE *)ap1;
248 a2 = *(ANGLE *)ap2;
249 if (a1 == a2) {
250 fprintf(stderr, "%s: duplicate glare angle (%d)\n",
251 progname, a1);
252 exit(1);
253 }
254 return(a1-a2);
255 }
256
257
258 static void
259 init(void) /* initialize global variables */
260 {
261 double d;
262 int i;
263
264 if (verbose)
265 fprintf(stderr, "%s: initializing data structures...\n",
266 progname);
267 /* set direction vectors */
268 for (i = 0; glarang[i] != AEND; i++)
269 ;
270 qsort(glarang, i, sizeof(ANGLE), angcmp);
271 if (i > 0 && (glarang[0] <= 0 || glarang[i-1] > 180)) {
272 fprintf(stderr, "%s: glare angles must be between 1 and 180\n",
273 progname);
274 exit(1);
275 }
276 nglarangs = i;
277 /* nglardirs = 2*nglarangs + 1; */
278 /* vsize = sampdens - 1; */
279 if (nglarangs > 0)
280 maxtheta = (PI/180.)*glarang[nglarangs-1];
281 else
282 maxtheta = 0.0;
283 hsize = hlim(0) + sampdens - 1;
284 if (hsize > (int)(PI*sampdens))
285 hsize = PI*sampdens;
286 indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum));
287 if (indirect == NULL)
288 memerr("indirect illuminances");
289 npixinvw = npixmiss = 0L;
290 leftview = ourview;
291 rightview = ourview;
292 spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta);
293 spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta);
294 setview(&leftview);
295 setview(&rightview);
296 indirect[nglarangs].lcos =
297 indirect[nglarangs].rcos = cos(maxtheta);
298 indirect[nglarangs].rsin =
299 -(indirect[nglarangs].lsin = sin(maxtheta));
300 indirect[nglarangs].theta = 0.0;
301 for (i = 0; i < nglarangs; i++) {
302 d = (glarang[nglarangs-1] - glarang[i])*(PI/180.);
303 indirect[nglarangs-i-1].lcos =
304 indirect[nglarangs+i+1].rcos = cos(d);
305 indirect[nglarangs+i+1].rsin =
306 -(indirect[nglarangs-i-1].lsin = sin(d));
307 d = (glarang[nglarangs-1] + glarang[i])*(PI/180.);
308 indirect[nglarangs-i-1].rcos =
309 indirect[nglarangs+i+1].lcos = cos(d);
310 indirect[nglarangs-i-1].rsin =
311 -(indirect[nglarangs+i+1].lsin = sin(d));
312 indirect[nglarangs-i-1].theta = (PI/180.)*glarang[i];
313 indirect[nglarangs+i+1].theta = -(PI/180.)*glarang[i];
314 }
315 /* open picture */
316 if (picture != NULL) {
317 if (verbose)
318 fprintf(stderr, "%s: opening picture file \"%s\"...\n",
319 progname, picture);
320 open_pict(picture);
321 }
322 /* start rtrace */
323 if (octree != NULL) {
324 if (verbose) {
325 fprintf(stderr,
326 "%s: starting luminance calculation...\n\t",
327 progname);
328 printargs(rtargc, rtargv, stderr);
329 }
330 fork_rtrace(rtargv);
331 }
332 }
333
334
335 static void
336 cleanup(void) /* close files, wait for children */
337 {
338 if (verbose)
339 fprintf(stderr, "%s: cleaning up... \n", progname);
340 if (picture != NULL)
341 close_pict();
342 if (octree != NULL)
343 done_rtrace();
344 if (npixinvw < 100*npixmiss)
345 fprintf(stderr, "%s: warning -- missing %d%% of samples\n",
346 progname, (int)(100L*npixmiss/npixinvw));
347 }
348
349
350 int
351 compdir( /* compute direction for x,y */
352 FVECT vd,
353 int x,
354 int y
355 )
356 {
357 int hl;
358 FVECT org; /* dummy variable */
359
360 hl = hlim(y);
361 if (x <= -hl) { /* left region */
362 if (x <= -hl-sampdens)
363 return(-1);
364 return(viewray(org, vd, &leftview,
365 (double)(x+hl)/(2*sampdens)+.5,
366 (double)y/(2*sampdens)+.5));
367 }
368 if (x >= hl) { /* right region */
369 if (x >= hl+sampdens)
370 return(-1);
371 return(viewray(org, vd, &rightview,
372 (double)(x-hl)/(2*sampdens)+.5,
373 (double)y/(2*sampdens)+.5));
374 }
375 /* central region */
376 if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0)
377 return(-1);
378 spinvector(vd, vd, ourview.vup, h_theta(x,y));
379 return(0);
380 }
381
382
383 double
384 pixsize( /* return the solid angle of pixel at (x,y) */
385 int x,
386 int y
387 )
388 {
389 int hl, xo;
390 double disc;
391
392 hl = hlim(y);
393 if (x < -hl)
394 xo = x+hl;
395 else if (x > hl)
396 xo = x-hl;
397 else
398 xo = 0;
399 disc = 1. - (double)((long)xo*xo + (long)y*y)/((long)sampdens*sampdens);
400 if (disc <= FTINY*FTINY)
401 return(0.);
402 return(1./(sampdens*sampdens*sqrt(disc)));
403 }
404
405
406 void
407 memerr( /* malloc failure */
408 char *s
409 )
410 {
411 fprintf(stderr, "%s: out of memory for %s\n", progname, s);
412 exit(1);
413 }
414
415
416 static void
417 printsources(void) /* print out glare sources */
418 {
419 struct source *sp;
420
421 printf("BEGIN glare source\n");
422 for (sp = donelist; sp != NULL; sp = sp->next)
423 printf("\t%f %f %f\t%e\t%e\n",
424 sp->dir[0], sp->dir[1], sp->dir[2],
425 sp->dom, sp->brt);
426 printf("END glare source\n");
427 }
428
429
430 static void
431 printillum(void) /* print out indirect illuminances */
432 {
433 int i;
434
435 printf("BEGIN indirect illuminance\n");
436 for (i = 0; i < nglardirs; i++)
437 if (indirect[i].n > FTINY)
438 printf("\t%.0f\t%f\n", (180.0/PI)*indirect[i].theta,
439 PI * indirect[i].sum / indirect[i].n);
440 printf("END indirect illuminance\n");
441 }
