root/radiance/ray/src/util/findglare.c
Revision: 1.19
Committed: Fri Apr 19 17:40:59 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.18: +26 -21 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Find glare sources in a scene or image.
9 *
10 * Greg Ward March 1991
11 */
12
13 #include "glare.h"
14
15 #define FEQ(a,b) ((a)-(b)<=FTINY&&(a)-(b)<=FTINY)
16 #define VEQ(v1,v2) (FEQ((v1)[0],(v2)[0])&&FEQ((v1)[1],(v2)[1]) \
17 &&FEQ((v1)[2],(v2)[2]))
18
19 char *rtargv[32] = {"rtrace", "-h", "-ov", "-fff"};
20 int rtargc = 4;
21
22 VIEW ourview = STDVIEW; /* our view */
23 VIEW pictview = STDVIEW; /* picture view */
24 VIEW leftview, rightview; /* leftmost and rightmost views */
25
26 char *picture = NULL; /* picture file name */
27 char *octree = NULL; /* octree file name */
28
29 int verbose = 0; /* verbose reporting */
30 char *progname; /* global argv[0] */
31
32 double threshold = 0.; /* glare threshold */
33
34 int sampdens = SAMPDENS; /* sample density */
35 ANGLE glarang[180] = {AEND}; /* glare calculation angles */
36 int nglarangs = 0;
37 double maxtheta; /* maximum angle (in radians) */
38 int hsize; /* horizontal size */
39
40 struct illum *indirect; /* array of indirect illuminances */
41
42 long npixinvw; /* number of pixels in view */
43 long npixmiss; /* number of pixels missed */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 int combine = 1;
51 int gotview = 0;
52 int rval, i;
53 char *err;
54
55 progname = argv[0];
56 /* process options */
57 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
58 rval = getviewopt(&ourview, argc-i, argv+i);
59 if (rval >= 0) {
60 i += rval;
61 gotview++;
62 continue;
63 }
64 switch (argv[i][1]) {
65 case 't':
66 threshold = atof(argv[++i]);
67 break;
68 case 'r':
69 sampdens = atoi(argv[++i])/2;
70 break;
71 case 'v':
72 if (argv[i][2] == '\0') {
73 verbose++;
74 break;
75 }
76 if (argv[i][2] != 'f')
77 goto userr;
78 rval = viewfile(argv[++i], &ourview, 0, 0);
79 if (rval < 0) {
80 fprintf(stderr,
81 "%s: cannot open view file \"%s\"\n",
82 progname, argv[i]);
83 exit(1);
84 } else if (rval == 0) {
85 fprintf(stderr,
86 "%s: bad view file \"%s\"\n",
87 progname, argv[i]);
88 exit(1);
89 } else
90 gotview++;
91 break;
92 case 'g':
93 if (argv[i][2] != 'a')
94 goto userr;
95 if (setscan(glarang, argv[++i]) < 0) {
96 fprintf(stderr, "%s: bad angle spec \"%s\"\n",
97 progname, argv[i]);
98 exit(1);
99 }
100 break;
101 case 'p':
102 picture = argv[++i];
103 break;
104 case 'c':
105 combine = !combine;
106 break;
107 case 'd':
108 case 'l':
109 rtargv[rtargc++] = argv[i];
110 rtargv[rtargc++] = argv[++i];
111 break;
112 case 'a':
113 rtargv[rtargc++] = argv[i];
114 if (argv[i][2] == 'v') {
115 rtargv[rtargc++] = argv[++i];
116 rtargv[rtargc++] = argv[++i];
117 }
118 rtargv[rtargc++] = argv[++i];
119 break;
120 default:
121 goto userr;
122 }
123 }
124 /* get octree */
125 if (i < argc-1)
126 goto userr;
127 if (i == argc-1) {
128 rtargv[rtargc++] = octree = argv[i];
129 rtargv[rtargc] = NULL;
130 }
131 /* get view */
132 if (picture != NULL) {
133 rval = viewfile(picture, &pictview, 0, 0);
134 if (rval < 0) {
135 fprintf(stderr, "%s: cannot open picture file \"%s\"\n",
136 progname, picture);
137 exit(1);
138 } else if (rval == 0) {
139 fprintf(stderr,
140 "%s: cannot get view from picture \"%s\"\n",
141 progname, picture);
142 exit(1);
143 }
144 if (pictview.type == VT_PAR) {
145 fprintf(stderr, "%s: %s: cannot use parallel view\n",
146 progname, picture);
147 exit(1);
148 }
149 if ((err = setview(&pictview)) != NULL) {
150 fprintf(stderr, "%s: %s\n", picture, err);
151 exit(1);
152 }
153 }
154 if (!gotview) {
155 if (picture == NULL) {
156 fprintf(stderr, "%s: must have view or picture\n",
157 progname);
158 exit(1);
159 }
160 copystruct(&ourview, &pictview);
161 } else if (picture != NULL && !VEQ(ourview.vp, pictview.vp)) {
162 fprintf(stderr, "%s: picture must have same viewpoint\n",
163 progname);
164 exit(1);
165 }
166 ourview.type = VT_HEM;
167 ourview.horiz = ourview.vert = 180.0;
168 ourview.hoff = ourview.voff = 0.0;
169 fvsum(ourview.vdir, ourview.vdir, ourview.vup,
170 -DOT(ourview.vdir,ourview.vup));
171 if ((err = setview(&ourview)) != NULL) {
172 fprintf(stderr, "%s: %s\n", progname, err);
173 exit(1);
174 }
175 if (octree == NULL && picture == NULL) {
176 fprintf(stderr,
177 "%s: must specify at least one of picture or octree\n",
178 progname);
179 exit(1);
180 }
181 init(); /* initialize program */
182 if (threshold <= FTINY)
183 comp_thresh(); /* compute glare threshold */
184 analyze(); /* analyze view */
185 if (combine)
186 absorb_specks(); /* eliminate tiny sources */
187 cleanup(); /* tidy up */
188 /* print header */
189 printargs(argc, argv, stdout);
190 fputs(VIEWSTR, stdout);
191 fprintview(&ourview, stdout);
192 printf("\n");
193 fputformat("ASCII", stdout);
194 printf("\n");
195 printsources(); /* print glare sources */
196 printillum(); /* print illuminances */
197 exit(0);
198 userr:
199 fprintf(stderr,
200 "Usage: %s [view options][-ga angles][-p picture][[rtrace options] octree]\n",
201 progname);
202 exit(1);
203 }
204
205
206 init() /* initialize global variables */
207 {
208 double d;
209 register int i;
210
211 if (verbose)
212 fprintf(stderr, "%s: initializing data structures...\n",
213 progname);
214 /* set direction vectors */
215 for (i = 0; glarang[i] != AEND; i++)
216 ;
217 if (i > 0 && (glarang[0] <= 0 || glarang[i-1] >= 180)) {
218 fprintf(stderr, "%s: glare angles must be between 1 and 179\n",
219 progname);
220 exit(1);
221 }
222 nglarangs = i;
223 /* nglardirs = 2*nglarangs + 1; */
224 /* vsize = sampdens - 1; */
225 if (nglarangs > 0)
226 maxtheta = (PI/180.)*glarang[nglarangs-1];
227 else
228 maxtheta = 0.0;
229 hsize = hlim(0) + sampdens - 1;
230 if (hsize > (int)(PI*sampdens))
231 hsize = PI*sampdens;
232 indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum));
233 if (indirect == NULL)
234 memerr("indirect illuminances");
235 npixinvw = npixmiss = 0L;
236 copystruct(&leftview, &ourview);
237 copystruct(&rightview, &ourview);
238 spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta);
239 spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta);
240 setview(&leftview);
241 setview(&rightview);
242 indirect[nglarangs].lcos =
243 indirect[nglarangs].rcos = cos(maxtheta);
244 indirect[nglarangs].rsin =
245 -(indirect[nglarangs].lsin = sin(maxtheta));
246 indirect[nglarangs].theta = 0.0;
247 for (i = 0; i < nglarangs; i++) {
248 d = (glarang[nglarangs-1] - glarang[i])*(PI/180.);
249 indirect[nglarangs-i-1].lcos =
250 indirect[nglarangs+i+1].rcos = cos(d);
251 indirect[nglarangs+i+1].rsin =
252 -(indirect[nglarangs-i-1].lsin = sin(d));
253 d = (glarang[nglarangs-1] + glarang[i])*(PI/180.);
254 indirect[nglarangs-i-1].rcos =
255 indirect[nglarangs+i+1].lcos = cos(d);
256 indirect[nglarangs-i-1].rsin =
257 -(indirect[nglarangs+i+1].lsin = sin(d));
258 indirect[nglarangs-i-1].theta = (PI/180.)*glarang[i];
259 indirect[nglarangs+i+1].theta = -(PI/180.)*glarang[i];
260 }
261 /* open picture */
262 if (picture != NULL) {
263 if (verbose)
264 fprintf(stderr, "%s: opening picture file \"%s\"...\n",
265 progname, picture);
266 open_pict(picture);
267 }
268 /* start rtrace */
269 if (octree != NULL) {
270 if (verbose) {
271 fprintf(stderr,
272 "%s: starting luminance calculation...\n\t",
273 progname);
274 printargs(rtargc, rtargv, stderr);
275 }
276 fork_rtrace(rtargv);
277 }
278 }
279
280
281 cleanup() /* close files, wait for children */
282 {
283 if (verbose)
284 fprintf(stderr, "%s: cleaning up... \n", progname);
285 if (picture != NULL)
286 close_pict();
287 if (octree != NULL)
288 done_rtrace();
289 if (npixinvw < 100*npixmiss)
290 fprintf(stderr, "%s: warning -- missing %ld%% of samples\n",
291 progname, 100L*npixmiss/npixinvw);
292 }
293
294
295 compdir(vd, x, y) /* compute direction for x,y */
296 FVECT vd;
297 int x, y;
298 {
299 int hl;
300 FVECT org; /* dummy variable */
301
302 hl = hlim(y);
303 if (x <= -hl) /* left region */
304 return(viewray(org, vd, &leftview,
305 (double)(x+hl)/(2*sampdens)+.5,
306 (double)y/(2*sampdens)+.5));
307 if (x >= hl) /* right region */
308 return(viewray(org, vd, &rightview,
309 (double)(x-hl)/(2*sampdens)+.5,
310 (double)y/(2*sampdens)+.5));
311 /* central region */
312 if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0)
313 return(-1);
314 spinvector(vd, vd, ourview.vup, h_theta(x,y));
315 return(0);
316 }
317
318
319 double
320 pixsize(x, y) /* return the solid angle of pixel at (x,y) */
321 int x, y;
322 {
323 register int hl, xo;
324 double disc;
325
326 hl = hlim(y);
327 if (x < -hl)
328 xo = x+hl;
329 else if (x > hl)
330 xo = x-hl;
331 else
332 xo = 0;
333 disc = 1. - (xo*xo + y*y)/(sampdens*sampdens);
334 if (disc <= FTINY)
335 return(0.);
336 return(1./(sampdens*sampdens*sqrt(disc)));
337 }
338
339
340 memerr(s) /* malloc failure */
341 char *s;
342 {
343 fprintf(stderr, "%s: out of memory for %s\n", progname, s);
344 exit(1);
345 }
346
347
348 printsources() /* print out glare sources */
349 {
350 register struct source *sp;
351
352 printf("BEGIN glare source\n");
353 for (sp = donelist; sp != NULL; sp = sp->next)
354 printf("\t%f %f %f\t%f\t%f\n",
355 sp->dir[0], sp->dir[1], sp->dir[2],
356 sp->dom, sp->brt);
357 printf("END glare source\n");
358 }
359
360
361 printillum() /* print out indirect illuminances */
362 {
363 register int i;
364
365 printf("BEGIN indirect illuminance\n");
366 for (i = 0; i < nglardirs; i++)
367 if (indirect[i].n > FTINY)
368 printf("\t%.0f\t%f\n", (180.0/PI)*indirect[i].theta,
369 PI * indirect[i].sum / indirect[i].n);
370 printf("END indirect illuminance\n");
371 }
