--- ray/src/util/findglare.c 1991/03/18 12:15:38 1.1 +++ ray/src/util/findglare.c 2021/02/12 00:53:56 2.15 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: findglare.c,v 2.15 2021/02/12 00:53:56 greg Exp $"; #endif - /* * Find glare sources in a scene or image. * @@ -12,14 +9,10 @@ static char SCCSid[] = "$SunId$ LBL"; #include "glare.h" -#define FEQ(a,b) ((a)-(b)<=FTINY&&(a)-(b)<=FTINY) -#define VEQ(v1,v2) (FEQ((v1)[0],(v2)[0])&&FEQ((v1)[1],(v2)[1]) \ - &&FEQ((v1)[2],(v2)[2])) +char *rtargv[64] = {"rtrace", "-h-", "-ov", "-fff", "-ld-", "-i-", "-I-"}; +int rtargc = 7; -char *rtargv[32] = {"rtrace", "-h", "-ov", "-fff"}; -int rtargc = 4; - -VIEW ourview; /* our view */ +VIEW ourview = STDVIEW; /* our view */ VIEW pictview = STDVIEW; /* picture view */ VIEW leftview, rightview; /* leftmost and rightmost views */ @@ -29,18 +22,34 @@ char *octree = NULL; /* octree file name */ int verbose = 0; /* verbose reporting */ char *progname; /* global argv[0] */ +double threshold = 0.; /* glare threshold */ + +int sampdens = SAMPDENS; /* sample density */ ANGLE glarang[180] = {AEND}; /* glare calculation angles */ int nglarangs = 0; +double maxtheta; /* maximum angle (in radians) */ int hsize; /* horizontal size */ -int hlim; /* central limit of horizontal */ struct illum *indirect; /* array of indirect illuminances */ +long npixinvw; /* number of pixels in view */ +long npixmiss; /* number of pixels missed */ -main(argc, argv) -int argc; -char *argv[]; +static int angcmp(const void *ap1, const void *ap2); +static void init(void); +static void cleanup(void); +static void printsources(void); +static void printillum(void); + + + +int +main( + int argc, + char *argv[] +) { + int combine = 1; int gotview = 0; int rval, i; char *err; @@ -48,6 +57,14 @@ char *argv[]; progname = argv[0]; /* process options */ for (i = 1; i < argc && argv[i][0] == '-'; i++) { + /* expand arguments */ + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + fprintf(stderr, "%s: cannot expand '%s'\n", + argv[0], argv[i]); + exit(1); + } rval = getviewopt(&ourview, argc-i, argv+i); if (rval >= 0) { i += rval; @@ -55,6 +72,12 @@ char *argv[]; continue; } switch (argv[i][1]) { + case 't': + threshold = atof(argv[++i]); + break; + case 'r': + sampdens = atoi(argv[++i])/2; + break; case 'v': if (argv[i][2] == '\0') { verbose++; @@ -62,7 +85,7 @@ char *argv[]; } if (argv[i][2] != 'f') goto userr; - rval = viewfile(argv[++i], &ourview, 0, 0); + rval = viewfile(argv[++i], &ourview, NULL); if (rval < 0) { fprintf(stderr, "%s: cannot open view file \"%s\"\n", @@ -88,11 +111,29 @@ char *argv[]; case 'p': picture = argv[++i]; break; + case 'c': + combine = !combine; + break; case 'd': + rtargv[rtargc++] = argv[i]; + if (argv[i][2] != 'v') + rtargv[rtargc++] = argv[++i]; + break; case 'l': + if (argv[i][2] == 'd') + break; + /* FALL THROUGH */ + case 's': + case 'P': + case 'n': rtargv[rtargc++] = argv[i]; rtargv[rtargc++] = argv[++i]; break; + case 'w': + case 'u': + case 'b': + rtargv[rtargc++] = argv[i]; + break; case 'a': rtargv[rtargc++] = argv[i]; if (argv[i][2] == 'v') { @@ -101,6 +142,14 @@ char *argv[]; } rtargv[rtargc++] = argv[++i]; break; + case 'm': + rtargv[rtargc++] = argv[i]; + if ((argv[i][2] == 'e') | (argv[i][2] == 'a')) { + rtargv[rtargc++] = argv[++i]; + rtargv[rtargc++] = argv[++i]; + } + rtargv[rtargc++] = argv[++i]; + break; default: goto userr; } @@ -114,7 +163,7 @@ char *argv[]; } /* get view */ if (picture != NULL) { - rval = viewfile(picture, &pictview, 0, 0); + rval = viewfile(picture, &pictview, NULL); if (rval < 0) { fprintf(stderr, "%s: cannot open picture file \"%s\"\n", progname, picture); @@ -141,8 +190,8 @@ char *argv[]; progname); exit(1); } - copystruct(&ourview, &pictview); - } else if (picture != NULL && !VEQ(ourview.vp, pictview.vp)) { + ourview = pictview; + } else if (picture != NULL && !VABSEQ(ourview.vp, pictview.vp)) { fprintf(stderr, "%s: picture must have same viewpoint\n", progname); exit(1); @@ -163,14 +212,20 @@ char *argv[]; exit(1); } init(); /* initialize program */ - comp_thresh(); /* compute glare threshold */ + if (threshold <= FTINY) + comp_thresh(); /* compute glare threshold */ analyze(); /* analyze view */ + if (combine) + absorb_specks(); /* eliminate tiny sources */ cleanup(); /* tidy up */ /* print header */ + newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputs(VIEWSTR, stdout); fprintview(&ourview, stdout); - printf("\n\n"); + printf("\n"); + fputformat("ascii", stdout); + printf("\n"); printsources(); /* print glare sources */ printillum(); /* print illuminances */ exit(0); @@ -182,8 +237,28 @@ userr: } -init() /* initialize global variables */ +static int +angcmp( /* compare two angles */ + const void *ap1, + const void *ap2 +) { + register int a1, a2; + + a1 = *(ANGLE *)ap1; + a2 = *(ANGLE *)ap2; + if (a1 == a2) { + fprintf(stderr, "%s: duplicate glare angle (%d)\n", + progname, a1); + exit(1); + } + return(a1-a2); +} + + +static void +init(void) /* initialize global variables */ +{ double d; register int i; @@ -193,46 +268,50 @@ init() /* initialize global variables */ /* set direction vectors */ for (i = 0; glarang[i] != AEND; i++) ; - if (glarang[0] <= 0 || glarang[i-1] >= 180) { - fprintf(stderr, "%s: glare angles must be between 1 and 179\n", + qsort(glarang, i, sizeof(ANGLE), angcmp); + if (i > 0 && (glarang[0] <= 0 || glarang[i-1] > 180)) { + fprintf(stderr, "%s: glare angles must be between 1 and 180\n", progname); exit(1); } nglarangs = i; /* nglardirs = 2*nglarangs + 1; */ - /* maxtheta = (PI/180.)*glarang[nglarangs-1]; */ - /* vsize = SAMPDENS; */ - hlim = SAMPDENS*maxtheta; - hsize = SAMPDENS + hlim; - if (hsize > (int)(PI*SAMPDENS)) - hsize = PI*SAMPDENS; + /* vsize = sampdens - 1; */ + if (nglarangs > 0) + maxtheta = (PI/180.)*glarang[nglarangs-1]; + else + maxtheta = 0.0; + hsize = hlim(0) + sampdens - 1; + if (hsize > (int)(PI*sampdens)) + hsize = PI*sampdens; indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum)); if (indirect == NULL) memerr("indirect illuminances"); - copystruct(&leftview, &ourview); - copystruct(&rightview, &ourview); - spinvector(leftview.vdir, ourview.vdir, ourview.vup, -maxtheta); - spinvector(rightview.vdir, ourview.vdir, ourview.vup, maxtheta); + npixinvw = npixmiss = 0L; + leftview = ourview; + rightview = ourview; + spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta); + spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta); setview(&leftview); setview(&rightview); indirect[nglarangs].lcos = indirect[nglarangs].rcos = cos(maxtheta); - indirect[nglarangs].lsin = - -(indirect[nglarangs].rsin = sin(maxtheta)); + indirect[nglarangs].rsin = + -(indirect[nglarangs].lsin = sin(maxtheta)); indirect[nglarangs].theta = 0.0; for (i = 0; i < nglarangs; i++) { d = (glarang[nglarangs-1] - glarang[i])*(PI/180.); indirect[nglarangs-i-1].lcos = indirect[nglarangs+i+1].rcos = cos(d); - indirect[nglarangs-i-1].lsin = - -(indirect[nglarangs+i+1].rsin = sin(d)); + indirect[nglarangs+i+1].rsin = + -(indirect[nglarangs-i-1].lsin = sin(d)); d = (glarang[nglarangs-1] + glarang[i])*(PI/180.); indirect[nglarangs-i-1].rcos = indirect[nglarangs+i+1].lcos = cos(d); - indirect[nglarangs+i+1].lsin = - -(indirect[nglarangs-i-1].rsin = sin(d)); - indirect[nglarangs-i-1].theta = -(PI/180.)*glarang[i]; - indirect[nglarangs+i+1].theta = (PI/180.)*glarang[i]; + indirect[nglarangs-i-1].rsin = + -(indirect[nglarangs+i+1].lsin = sin(d)); + indirect[nglarangs-i-1].theta = (PI/180.)*glarang[i]; + indirect[nglarangs+i+1].theta = -(PI/180.)*glarang[i]; } /* open picture */ if (picture != NULL) { @@ -254,67 +333,89 @@ init() /* initialize global variables */ } -cleanup() /* close files, wait for children */ +static void +cleanup(void) /* close files, wait for children */ { if (verbose) - fprintf(stderr, "%s: cleaning up...\n", progname); + fprintf(stderr, "%s: cleaning up... \n", progname); if (picture != NULL) close_pict(); if (octree != NULL) done_rtrace(); + if (npixinvw < 100*npixmiss) + fprintf(stderr, "%s: warning -- missing %d%% of samples\n", + progname, (int)(100L*npixmiss/npixinvw)); } -compdir(vd, x, y) /* compute direction for x,y */ -FVECT vd; -int x, y; +extern int +compdir( /* compute direction for x,y */ + FVECT vd, + int x, + int y +) { + int hl; FVECT org; /* dummy variable */ - if (x <= -hlim) /* left region */ + hl = hlim(y); + if (x <= -hl) { /* left region */ + if (x <= -hl-sampdens) + return(-1); return(viewray(org, vd, &leftview, - (x+hlim)/(2.*SAMPDENS)+.5, - y/(2.*SAMPDENS)+.5)); - if (x >= hlim) /* right region */ + (double)(x+hl)/(2*sampdens)+.5, + (double)y/(2*sampdens)+.5)); + } + if (x >= hl) { /* right region */ + if (x >= hl+sampdens) + return(-1); return(viewray(org, vd, &rightview, - (x-hlim)/(2.*SAMPDENS)+.5, - y/(2.*SAMPDENS)+.5)); - /* central region */ - if (viewray(org, vd, &ourview, .5, y/(2.*SAMPDENS)+.5) < 0) + (double)(x-hl)/(2*sampdens)+.5, + (double)y/(2*sampdens)+.5)); + } + /* central region */ + if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0) return(-1); - spinvector(vd, vd, ourview.vup, h_theta(x)); + spinvector(vd, vd, ourview.vup, h_theta(x,y)); return(0); } -spinvector(vres, vorig, vnorm, theta) /* rotate vector around normal */ -FVECT vres, vorig, vnorm; -double theta; +extern double +pixsize( /* return the solid angle of pixel at (x,y) */ + int x, + int y +) { - extern double sin(), cos(); - double sint, cost, dotp; - FVECT vperp; - register int i; - - sint = sin(theta); - cost = cos(theta); - dotp = DOT(vorig, vnorm); - fcross(vperp, vnorm, vorig); - for (i = 0; i < 3; i++) - vres[i] = vnorm[i]*dotp*(1.-cost) + - vorig[i]*cost + vperp[i]*sint; + register int hl, xo; + double disc; + + hl = hlim(y); + if (x < -hl) + xo = x+hl; + else if (x > hl) + xo = x-hl; + else + xo = 0; + disc = 1. - (double)((long)xo*xo + (long)y*y)/((long)sampdens*sampdens); + if (disc <= FTINY*FTINY) + return(0.); + return(1./(sampdens*sampdens*sqrt(disc))); } -memerr(s) /* malloc failure */ -char *s; +extern void +memerr( /* malloc failure */ + char *s +) { - fprintf(stderr, "%s: out of memory for %s\n", s); + fprintf(stderr, "%s: out of memory for %s\n", progname, s); exit(1); } -printsources() /* print out glare sources */ +static void +printsources(void) /* print out glare sources */ { register struct source *sp; @@ -327,13 +428,15 @@ printsources() /* print out glare sources */ } -printillum() /* print out indirect illuminances */ +static void +printillum(void) /* print out indirect illuminances */ { register int i; printf("BEGIN indirect illuminance\n"); for (i = 0; i < nglardirs; i++) - printf("\t%f\t%f\n", (180.0/PI)*indirect[i].theta, - PI * indirect[i].sum / (double)indirect[i].n); - printf("END indirect illuminances\n"); + if (indirect[i].n > FTINY) + printf("\t%.0f\t%f\n", (180.0/PI)*indirect[i].theta, + PI * indirect[i].sum / indirect[i].n); + printf("END indirect illuminance\n"); }
