--- ray/src/util/findglare.c 1991/04/12 10:28:40 1.17 +++ ray/src/util/findglare.c 2003/07/21 22:30:19 2.10 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: findglare.c,v 2.10 2003/07/21 22:30:19 schorsch Exp $"; #endif - /* * Find glare sources in a scene or image. * @@ -12,12 +9,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include "glare.h" -#define FEQ(a,b) ((a)-(b)<=FTINY&&(a)-(b)<=FTINY) +#define FEQ(a,b) ((a)-(b)<=FTINY&&(b)-(a)<=FTINY) #define VEQ(v1,v2) (FEQ((v1)[0],(v2)[0])&&FEQ((v1)[1],(v2)[1]) \ &&FEQ((v1)[2],(v2)[2])) -char *rtargv[32] = {"rtrace", "-h", "-ov", "-fff"}; -int rtargc = 4; +char *rtargv[64] = {"rtrace", "-h-", "-ov", "-fff", "-ld-", "-i-", "-I-"}; +int rtargc = 7; VIEW ourview = STDVIEW; /* our view */ VIEW pictview = STDVIEW; /* picture view */ @@ -36,7 +33,6 @@ ANGLE glarang[180] = {AEND}; /* glare calculation ang int nglarangs = 0; double maxtheta; /* maximum angle (in radians) */ int hsize; /* horizontal size */ -int hlim; /* central limit of horizontal */ struct illum *indirect; /* array of indirect illuminances */ @@ -56,6 +52,14 @@ char *argv[]; progname = argv[0]; /* process options */ for (i = 1; i < argc && argv[i][0] == '-'; i++) { + /* expand arguments */ + while ((rval = expandarg(&argc, &argv, i)) > 0) + ; + if (rval < 0) { + fprintf(stderr, "%s: cannot expand '%s'", + argv[0], argv[i]); + exit(1); + } rval = getviewopt(&ourview, argc-i, argv+i); if (rval >= 0) { i += rval; @@ -76,7 +80,7 @@ char *argv[]; } if (argv[i][2] != 'f') goto userr; - rval = viewfile(argv[++i], &ourview, 0, 0); + rval = viewfile(argv[++i], &ourview, NULL); if (rval < 0) { fprintf(stderr, "%s: cannot open view file \"%s\"\n", @@ -106,10 +110,22 @@ char *argv[]; combine = !combine; break; case 'd': + rtargv[rtargc++] = argv[i]; + if (argv[i][2] != 'v') + rtargv[rtargc++] = argv[++i]; + break; case 'l': + if (argv[i][2] == 'd') + break; + /* FALL THROUGH */ + case 's': + case 'P': rtargv[rtargc++] = argv[i]; rtargv[rtargc++] = argv[++i]; break; + case 'w': + rtargv[rtargc++] = argv[i]; + break; case 'a': rtargv[rtargc++] = argv[i]; if (argv[i][2] == 'v') { @@ -131,7 +147,7 @@ char *argv[]; } /* get view */ if (picture != NULL) { - rval = viewfile(picture, &pictview, 0, 0); + rval = viewfile(picture, &pictview, NULL); if (rval < 0) { fprintf(stderr, "%s: cannot open picture file \"%s\"\n", progname, picture); @@ -158,7 +174,7 @@ char *argv[]; progname); exit(1); } - copystruct(&ourview, &pictview); + ourview = pictview; } else if (picture != NULL && !VEQ(ourview.vp, pictview.vp)) { fprintf(stderr, "%s: picture must have same viewpoint\n", progname); @@ -187,10 +203,13 @@ char *argv[]; absorb_specks(); /* eliminate tiny sources */ cleanup(); /* tidy up */ /* print header */ + newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputs(VIEWSTR, stdout); fprintview(&ourview, stdout); - printf("\n\n"); + printf("\n"); + fputformat("ascii", stdout); + printf("\n"); printsources(); /* print glare sources */ printillum(); /* print illuminances */ exit(0); @@ -202,6 +221,23 @@ userr: } +int +angcmp(ap1, ap2) /* compare two angles */ +ANGLE *ap1, *ap2; +{ + register int a1, a2; + + a1 = *ap1; + a2 = *ap2; + if (a1 == a2) { + fprintf(stderr, "%s: duplicate glare angle (%d)\n", + progname, a1); + exit(1); + } + return(a1-a2); +} + + init() /* initialize global variables */ { double d; @@ -213,8 +249,9 @@ init() /* initialize global variables */ /* set direction vectors */ for (i = 0; glarang[i] != AEND; i++) ; - if (i > 0 && (glarang[0] <= 0 || glarang[i-1] >= 180)) { - fprintf(stderr, "%s: glare angles must be between 1 and 179\n", + qsort(glarang, i, sizeof(ANGLE), angcmp); + if (i > 0 && (glarang[0] <= 0 || glarang[i-1] > 180)) { + fprintf(stderr, "%s: glare angles must be between 1 and 180\n", progname); exit(1); } @@ -225,16 +262,15 @@ init() /* initialize global variables */ maxtheta = (PI/180.)*glarang[nglarangs-1]; else maxtheta = 0.0; - hlim = sampdens*maxtheta; - hsize = hlim + sampdens - 1; + hsize = hlim(0) + sampdens - 1; if (hsize > (int)(PI*sampdens)) hsize = PI*sampdens; indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum)); if (indirect == NULL) memerr("indirect illuminances"); npixinvw = npixmiss = 0L; - copystruct(&leftview, &ourview); - copystruct(&rightview, &ourview); + leftview = ourview; + rightview = ourview; spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta); spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta); setview(&leftview); @@ -287,46 +323,59 @@ cleanup() /* close files, wait for children */ if (octree != NULL) done_rtrace(); if (npixinvw < 100*npixmiss) - fprintf(stderr, "%s: warning -- missing %ld%% of samples\n", - progname, 100L*npixmiss/npixinvw); + fprintf(stderr, "%s: warning -- missing %d%% of samples\n", + progname, (int)(100L*npixmiss/npixinvw)); } -compdir(vd, x, y, se) /* compute direction for x,y */ +compdir(vd, x, y) /* compute direction for x,y */ FVECT vd; int x, y; -SPANERR *se; { + int hl; FVECT org; /* dummy variable */ - if (x <= -hlim) /* left region */ + hl = hlim(y); + if (x <= -hl) { /* left region */ + if (x <= -hl-sampdens) + return(-1); return(viewray(org, vd, &leftview, - (double)(x+hlim)/(2*sampdens)+.5, + (double)(x+hl)/(2*sampdens)+.5, (double)y/(2*sampdens)+.5)); - if (x >= hlim) /* right region */ + } + if (x >= hl) { /* right region */ + if (x >= hl+sampdens) + return(-1); return(viewray(org, vd, &rightview, - (double)(x-hlim)/(2*sampdens)+.5, + (double)(x-hl)/(2*sampdens)+.5, (double)y/(2*sampdens)+.5)); - /* central region */ - if (se != NULL) { /* avoid over-counting of poles */ - se->err += se->prob; - if (se->err <= 0.5) - return(-1); - se->err -= 1.0; } + /* central region */ if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0) return(-1); - spinvector(vd, vd, ourview.vup, h_theta(x)); + spinvector(vd, vd, ourview.vup, h_theta(x,y)); return(0); } -setspanerr(se, y) /* initialize span error at y */ -register SPANERR *se; -int y; +double +pixsize(x, y) /* return the solid angle of pixel at (x,y) */ +int x, y; { - se->err = 0.0; - se->prob = sqrt(1.0 - (double)((long)y*y)/((long)vsize*vsize)); + register int hl, xo; + double disc; + + hl = hlim(y); + if (x < -hl) + xo = x+hl; + else if (x > hl) + xo = x-hl; + else + xo = 0; + disc = 1. - (double)((long)xo*xo + (long)y*y)/((long)sampdens*sampdens); + if (disc <= FTINY*FTINY) + return(0.); + return(1./(sampdens*sampdens*sqrt(disc))); }
