Added missing support for rtrace -n, -bv, and -m* options
Added missing newline to error statement
Continued ANSIfication.
Ansification.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added option expansion and newheader() call
minor changes for 16-bit integers (not checked)
added -P and -PP option for rtrace
added provisions for -dv and -w rtrace switches
minor problems
added switch for -st -sj options of rtrace
fixed bug in floating point comparison
*** empty log message ***
added qsort call to insure angles are sorted properly
minor optimization of compdir()
ASCII -> ascii
minor changes and bug fixes
removed call to random() in compdir()
corrected for improper sample spacing in compdir()
added conditional to printillum()
bug in if statement
made theta consistently positive to the left (bug fix)
added standard defaults to ourview
changed resolution
added -r option for sample resolution
fixed orientation of theta
