| 1 |
greg |
2.2 |
file.hlp 2.1 10/27/94
| 2 |
greg |
2.1 |
| 3 |
This help file is associated with the getfile.tcl routines, which
| 4 |
produce a screen for browsing and naming files.
| 5 |
| 6 |
.Directory.Intro
| 7 |
| 8 |
The current directory may be set either by choosing a new directory
| 9 |
by double-clicking on a directory in the file window, or by
| 10 |
explicitly changing the directory named in the entry window.
| 11 |
| 12 |
A directory may be given absolutely,
| 13 |
relative to the current path, or relative to your home directory or
| 14 |
that of another user using the tilde (~) shorthand.
| 15 |
| 16 |
Hitting <return> in the directory entry window has the same effect as
| 17 |
pressing the "List" button.
| 18 |
That is, the interface changes to that directory and lists all files
| 19 |
matching the given pattern(s).
| 20 |
| 21 |
If an attempt is made to change to a non-existent or read-protected
| 22 |
directory, an error message is printed in red and the interface
| 23 |
returns to the previously selected directory.
| 24 |
| 25 |
.Directory.Match
| 26 |
| 27 |
One or more matching (i.e. globbing) patterns may be given in this window,
| 28 |
separated by white spaces.
| 29 |
| 30 |
Nothing or a single asterisk (*) matches all files in
| 31 |
this directory.
| 32 |
Whatever the selected pattern, directories will always be listed,
| 33 |
followed by a slash (/).
| 34 |
This makes changing directories more convenient.
| 35 |
| 36 |
To list files beginning with a period (.), use the ".*" pattern.
| 37 |
Thus, it is possible to include all files in the directory listing by
| 38 |
entering ".* *" in the pattern window.
| 39 |
| 40 |
Hitting <return> in the pattern entry window has the same effect as
| 41 |
| 42 |
| 43 |
.Directory.List
| 44 |
| 45 |
The "List" button causes the interface to change to the selected
| 46 |
directory and list all files there matching the given pattern(s).
| 47 |
| 48 |
The same effect may be achieved by hitting <return> in either the
| 49 |
directory entry or pattern entry window.
| 50 |
| 51 |
.File.Intro
| 52 |
| 53 |
The file list box shows all files in the given directory matching the
| 54 |
specified pattern(s).
| 55 |
In addition, all subdirectories and the parent directory are listed
| 56 |
unconditionally.
| 57 |
| 58 |
Double-clicking on a directory in the file list box is the most
| 59 |
convenient method of filesystem navigation.
| 60 |
| 61 |
Clicking on a file selects it for editing, but does not enter it.
| 62 |
Double-click on a file if you wish to enter it.
| 63 |
| 64 |
.File.Entry
| 65 |
| 66 |
The file entry field allows you to enter the name of a file that may
| 67 |
or may not exist in the current directory.
| 68 |
| 69 |
Hitting <return> in this field is equivalent to
| 70 |
pressing the "OK" button (if it exists).
| 71 |
| 72 |
.File.View
| 73 |
| 74 |
The "View" button, if it exists, permits you to edit the highlighted
| 75 |
file from the directory listing, using either xedit or the editor
| 76 |
indicated by the EDITOR environment variable, if defined.
