root/radiance/ray/src/util/fieldcomb.csh
Revision: 2.7
Committed: Mon Nov 10 19:08:19 2008 UTC (15 years, 5 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
# User Rev Content
1 greg 2.1 #!/bin/csh -f
2 greg 2.7 # RCSid $Id: fieldcomb.csh,v 2.6 2005/09/06 15:34:46 greg Exp $
3 greg 2.1 #
4     # Combine alternate lines in full frames for field rendering
5     #
6     # Expects numbered frames on command line, as given by ranimate
7     #
8     # If an odd number of frames is provided, the spare frame at the
9     # end is linked to $spare_name for the next run
10     #
11 greg 2.3 # Written by Greg Ward for Iebele Abel in August 2005
12 greg 2.1 #
13 greg 2.7 set spare_name=spare_fieldcomb_frame.hdr
14 greg 2.3 set odd_first=0
15     while ($#argv > 1)
16     switch ($argv[1])
17     case -r*:
18 greg 2.1 set remove_orig
19 greg 2.3 breaksw
20     case -o*:
21     set odd_first=1
22     breaksw
23     case -e*:
24     set odd_first=0
25     breaksw
26 greg 2.5 case -f*:
27     shift argv
28     set outfile="$argv[1]"
29     breaksw
30 greg 2.3 default:
31     if ("$argv[1]" !~ -*) break
32     echo "Unknown option: $argv[1]"
33     exit 1
34     endsw
35     shift argv
36     end
37 greg 2.6 if ($#argv < 2) then
38 greg 2.7 echo "Usage: $0 [-e|-o][-r] [-f combined.hdr] field1.hdr field2.hdr .."
39 greg 2.1 exit 1
40     endif
41 greg 2.6 if ($?outfile && $#argv > 2) then
42     echo "Cannot use -f option with more than two input files"
43     exit 1
44     endif
45 greg 2.1 set f1=$argv[1]:q
46     set ext=$f1:e
47     set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`"
48     set curfi=`echo $f1:q | sed 's/^[^1-9]*\(.[0-9]*\)\.'$ext'$/\1/'`
49     set fields=($argv[*]:q)
50     if (-r $spare_name) then
51     set fields=($spare_name $fields:q)
52     @ curfi--
53     endif
54     @ curfr = $curfi / 2
55     set curfi=1
56     while ($curfi < $#fields)
57     @ nextfi = $curfi + 1
58 greg 2.4 if ($curfr < 10) then
59     set fid=000$curfr
60     else if ($curfr < 100) then
61     set fid=00$curfr
62     else if ($curfr < 1000) then
63     set fid=0$curfr
64     else
65     set fid=$curfr
66     endif
67 greg 2.5 set outf="${basenm}C$fid.$ext"
68 greg 2.6 if ($?outfile) then
69     set outf=$outfile:q
70     endif
71 greg 2.2 pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \
72     -e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \
73 greg 2.3 -e "fld=if(odd,2-$odd_first,1+$odd_first)" \
74 greg 2.1 $fields[$curfi]:q $fields[$nextfi]:q \
75 greg 2.5 > $outf:q
76 greg 2.1 if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q
77     @ curfr++
78     @ curfi = $nextfi + 1
79     end
80     rm -f $spare_name
81     if ($curfi == $#fields) ln "${basenm}$curfi.$ext" $spare_name
