root/radiance/ray/src/util/fieldcomb.csh
Revision: 2.3
Committed: Fri Sep 2 14:43:43 2005 UTC (19 years, 9 months ago) by greg
Content type: application/x-csh
Changes since 2.2: +22 -9 lines
Added -e [default] and -o options for even/odd fields first
1 #!/bin/csh -f
2 # RCSid $Id: fieldcomb.csh,v 2.2 2005/09/02 04:24:37 greg Exp $
3 #
4 # Combine alternate lines in full frames for field rendering
5 #
6 # Expects numbered frames on command line, as given by ranimate
7 #
8 # If an odd number of frames is provided, the spare frame at the
9 # end is linked to $spare_name for the next run
10 #
11 # Written by Greg Ward for Iebele Abel in August 2005
12 #
13 set spare_name=spare_fieldcomb_frame.pic
14 set odd_first=0
15 while ($#argv > 1)
16 switch ($argv[1])
17 case -r*:
18 set remove_orig
19 breaksw
20 case -o*:
21 set odd_first=1
22 breaksw
23 case -e*:
24 set odd_first=0
25 breaksw
26 default:
27 if ("$argv[1]" !~ -*) break
28 echo "Unknown option: $argv[1]"
29 exit 1
30 endsw
31 shift argv
32 end
33 if ($#argv < 2) then
34 echo "Usage: $0 [-e|-o][-r] field1.pic field2.pic .."
35 exit 1
36 endif
37 set f1=$argv[1]:q
38 set ext=$f1:e
39 set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`"
40 set curfi=`echo $f1:q | sed 's/^[^1-9]*\(.[0-9]*\)\.'$ext'$/\1/'`
41 set fields=($argv[*]:q)
42 if (-r $spare_name) then
43 set fields=($spare_name $fields:q)
44 @ curfi--
45 endif
46 @ curfr = $curfi / 2
47 set curfi=1
48 while ($curfi < $#fields)
49 @ nextfi = $curfi + 1
50 pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \
51 -e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \
52 -e "fld=if(odd,2-$odd_first,1+$odd_first)" \
53 $fields[$curfi]:q $fields[$nextfi]:q \
54 > "${basenm}C$curfr.$ext"
55 if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q
56 @ curfr++
57 @ curfi = $nextfi + 1
58 end
59 rm -f $spare_name
60 if ($curfi == $#fields) ln "${basenm}$curfi.$ext" $spare_name
