--- ray/src/util/fieldcomb.csh 2005/09/03 20:44:08 2.4 +++ ray/src/util/fieldcomb.csh 2005/09/06 15:34:46 2.6 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: fieldcomb.csh,v 2.4 2005/09/03 20:44:08 greg Exp $ +# RCSid $Id: fieldcomb.csh,v 2.6 2005/09/06 15:34:46 greg Exp $ # # Combine alternate lines in full frames for field rendering # @@ -23,6 +23,10 @@ while ($#argv > 1) case -e*: set odd_first=0 breaksw + case -f*: + shift argv + set outfile="$argv[1]" + breaksw default: if ("$argv[1]" !~ -*) break echo "Unknown option: $argv[1]" @@ -31,9 +35,13 @@ while ($#argv > 1) shift argv end if ($#argv < 2) then - echo "Usage: $0 [-e|-o][-r] field1.pic field2.pic .." + echo "Usage: $0 [-e|-o][-r] [-f combined.pic] field1.pic field2.pic .." exit 1 endif +if ($?outfile && $#argv > 2) then + echo "Cannot use -f option with more than two input files" + exit 1 +endif set f1=$argv[1]:q set ext=$f1:e set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`" @@ -56,11 +64,15 @@ while ($curfi < $#fields) else set fid=$curfr endif + set outf="${basenm}C$fid.$ext" + if ($?outfile) then + set outf=$outfile:q + endif pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \ -e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \ -e "fld=if(odd,2-$odd_first,1+$odd_first)" \ $fields[$curfi]:q $fields[$nextfi]:q \ - > "${basenm}C$fid.$ext" + > $outf:q if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q @ curfr++ @ curfi = $nextfi + 1
