--- ray/src/util/fieldcomb.csh 2005/09/02 14:43:43 2.3 +++ ray/src/util/fieldcomb.csh 2005/09/05 16:13:08 2.5 @@ -1,5 +1,5 @@ #!/bin/csh -f -# RCSid $Id: fieldcomb.csh,v 2.3 2005/09/02 14:43:43 greg Exp $ +# RCSid $Id: fieldcomb.csh,v 2.5 2005/09/05 16:13:08 greg Exp $ # # Combine alternate lines in full frames for field rendering # @@ -23,6 +23,10 @@ while ($#argv > 1) case -e*: set odd_first=0 breaksw + case -f*: + shift argv + set outfile="$argv[1]" + breaksw default: if ("$argv[1]" !~ -*) break echo "Unknown option: $argv[1]" @@ -30,8 +34,8 @@ while ($#argv > 1) endsw shift argv end -if ($#argv < 2) then - echo "Usage: $0 [-e|-o][-r] field1.pic field2.pic .." +if ($#argv < 2 || ($?outfile && $#argv > 2)) then + echo "Usage: $0 [-e|-o][-r] [-f combined.pic] field1.pic field2.pic .." exit 1 endif set f1=$argv[1]:q @@ -47,11 +51,22 @@ endif set curfi=1 while ($curfi < $#fields) @ nextfi = $curfi + 1 + if ($curfr < 10) then + set fid=000$curfr + else if ($curfr < 100) then + set fid=00$curfr + else if ($curfr < 1000) then + set fid=0$curfr + else + set fid=$curfr + endif + set outf="${basenm}C$fid.$ext" + if ($?outfile) set outf=$outfile:q pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \ -e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \ -e "fld=if(odd,2-$odd_first,1+$odd_first)" \ $fields[$curfi]:q $fields[$nextfi]:q \ - > "${basenm}C$curfr.$ext" + > $outf:q if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q @ curfr++ @ curfi = $nextfi + 1
