root/radiance/ray/src/util/fieldcomb.csh
Revision: 2.1
Committed: Fri Sep 2 04:15:42 2005 UTC (18 years, 9 months ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 #
3 # Combine alternate lines in full frames for field rendering
4 #
5 # Expects numbered frames on command line, as given by ranimate
6 #
7 # If an odd number of frames is provided, the spare frame at the
8 # end is linked to $spare_name for the next run
9 #
10 # Written by Greg Ward for Iebele Atelier in August 2005
11 #
12 set spare_name=spare_fieldcomb_frame.pic
13 if ($#argv > 1) then
14 if ("$argv[1]" == "-r") then
15 set remove_orig
16 shift argv
17 endif
18 endif
19 if ($#argv < 2) then
20 echo "Usage: $0 [-r] field1.pic field2.pic .."
21 exit 1
22 endif
23 set f1=$argv[1]:q
24 set ext=$f1:e
25 set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`"
26 set curfi=`echo $f1:q | sed 's/^[^1-9]*\(.[0-9]*\)\.'$ext'$/\1/'`
27 set fields=($argv[*]:q)
28 if (-r $spare_name) then
29 set fields=($spare_name $fields:q)
30 @ curfi--
31 endif
32 @ curfr = $curfi / 2
33 set curfi=1
34 while ($curfi < $#fields)
35 @ nextfi = $curfi + 1
36 pcomb -e 'ro=ri(fld);go=gi(fld);bo=bi(fld)' \
37 -e 'odd=.5*y-floor(.5*y)-.25' -e 'fld=if(odd,1,2)' \
38 $fields[$curfi]:q $fields[$nextfi]:q \
39 > "${basenm}C$curfr.$ext"
40 if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q
41 @ curfr++
42 @ curfi = $nextfi + 1
43 end
44 rm -f $spare_name
45 if ($curfi == $#fields) ln "${basenm}$curfi.$ext" $spare_name
