root/Development/ray/src/util/fieldcomb.csh
Mon Nov 10 19:08:19 2008 UTC (17 years ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Tue Sep 6 15:34:46 2005 UTC (20 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.5: +9 -3 lines
Bug fix and new error message
Mon Sep 5 16:13:08 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.4: +10 -4 lines
Added -f option to output combined fields to a single frame
Sat Sep 3 20:44:08 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.3: +11 -2 lines
Made frame numbers 4 digits with leading zeroes
Fri Sep 2 14:43:43 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.2: +22 -9 lines
Added -e [default] and -o options for even/odd fields first
Fri Sep 2 04:24:37 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.1: +4 -2 lines
Diff to previous 2.1
Started scanline counting from top rather than bottom
Fri Sep 2 04:15:42 2005 UTC (20 years, 2 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate)
