| 1 |
#!/bin/csh -f
| 2 |
# RCSid $Id: fieldcomb.csh,v 2.3 2005/09/02 14:43:43 greg Exp $
| 3 |
| 4 |
# Combine alternate lines in full frames for field rendering
| 5 |
| 6 |
# Expects numbered frames on command line, as given by ranimate
| 7 |
| 8 |
# If an odd number of frames is provided, the spare frame at the
| 9 |
# end is linked to $spare_name for the next run
| 10 |
| 11 |
# Written by Greg Ward for Iebele Abel in August 2005
| 12 |
| 13 |
set spare_name=spare_fieldcomb_frame.pic
| 14 |
set odd_first=0
| 15 |
while ($#argv > 1)
| 16 |
switch ($argv[1])
| 17 |
case -r*:
| 18 |
set remove_orig
| 19 |
breaksw
| 20 |
case -o*:
| 21 |
set odd_first=1
| 22 |
breaksw
| 23 |
case -e*:
| 24 |
set odd_first=0
| 25 |
breaksw
| 26 |
default:
| 27 |
if ("$argv[1]" !~ -*) break
| 28 |
echo "Unknown option: $argv[1]"
| 29 |
exit 1
| 30 |
endsw
| 31 |
shift argv
| 32 |
end
| 33 |
if ($#argv < 2) then
| 34 |
echo "Usage: $0 [-e|-o][-r] field1.pic field2.pic .."
| 35 |
exit 1
| 36 |
endif
| 37 |
set f1=$argv[1]:q
| 38 |
set ext=$f1:e
| 39 |
set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`"
| 40 |
set curfi=`echo $f1:q | sed 's/^[^1-9]*\(.[0-9]*\)\.'$ext'$/\1/'`
| 41 |
set fields=($argv[*]:q)
| 42 |
if (-r $spare_name) then
| 43 |
set fields=($spare_name $fields:q)
| 44 |
@ curfi--
| 45 |
endif
| 46 |
@ curfr = $curfi / 2
| 47 |
set curfi=1
| 48 |
while ($curfi < $#fields)
| 49 |
@ nextfi = $curfi + 1
| 50 |
if ($curfr < 10) then
| 51 |
set fid=000$curfr
| 52 |
else if ($curfr < 100) then
| 53 |
set fid=00$curfr
| 54 |
else if ($curfr < 1000) then
| 55 |
set fid=0$curfr
| 56 |
else
| 57 |
set fid=$curfr
| 58 |
endif
| 59 |
pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \
| 60 |
-e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \
| 61 |
-e "fld=if(odd,2-$odd_first,1+$odd_first)" \
| 62 |
$fields[$curfi]:q $fields[$nextfi]:q \
| 63 |
> "${basenm}C$fid.$ext"
| 64 |
if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q
| 65 |
@ curfr++
| 66 |
@ curfi = $nextfi + 1
| 67 |
end
| 68 |
rm -f $spare_name
| 69 |
if ($curfi == $#fields) ln "${basenm}$curfi.$ext" $spare_name
