1 |
#!/bin/csh -f |
2 |
# RCSid $Id: fieldcomb.csh,v 2.3 2005/09/02 14:43:43 greg Exp $ |
3 |
4 |
# Combine alternate lines in full frames for field rendering |
5 |
6 |
# Expects numbered frames on command line, as given by ranimate |
7 |
8 |
# If an odd number of frames is provided, the spare frame at the |
9 |
# end is linked to $spare_name for the next run |
10 |
11 |
# Written by Greg Ward for Iebele Abel in August 2005 |
12 |
13 |
set spare_name=spare_fieldcomb_frame.pic |
14 |
set odd_first=0 |
15 |
while ($#argv > 1) |
16 |
switch ($argv[1]) |
17 |
case -r*: |
18 |
set remove_orig |
19 |
breaksw |
20 |
case -o*: |
21 |
set odd_first=1 |
22 |
breaksw |
23 |
case -e*: |
24 |
set odd_first=0 |
25 |
breaksw |
26 |
default: |
27 |
if ("$argv[1]" !~ -*) break |
28 |
echo "Unknown option: $argv[1]" |
29 |
exit 1 |
30 |
endsw |
31 |
shift argv |
32 |
end |
33 |
if ($#argv < 2) then |
34 |
echo "Usage: $0 [-e|-o][-r] field1.pic field2.pic .." |
35 |
exit 1 |
36 |
endif |
37 |
set f1=$argv[1]:q |
38 |
set ext=$f1:e |
39 |
set basenm="`echo $f1:q | sed 's/[0-9]*\.'$ext'//'`" |
40 |
set curfi=`echo $f1:q | sed 's/^[^1-9]*\(.[0-9]*\)\.'$ext'$/\1/'` |
41 |
set fields=($argv[*]:q) |
42 |
if (-r $spare_name) then |
43 |
set fields=($spare_name $fields:q) |
44 |
@ curfi-- |
45 |
endif |
46 |
@ curfr = $curfi / 2 |
47 |
set curfi=1 |
48 |
while ($curfi < $#fields) |
49 |
@ nextfi = $curfi + 1 |
50 |
if ($curfr < 10) then |
51 |
set fid=000$curfr |
52 |
else if ($curfr < 100) then |
53 |
set fid=00$curfr |
54 |
else if ($curfr < 1000) then |
55 |
set fid=0$curfr |
56 |
else |
57 |
set fid=$curfr |
58 |
endif |
59 |
pcomb -e 'ro=ri(fld); go=gi(fld); bo=bi(fld)' \ |
60 |
-e 'yd=yres-1-y; odd=.5*yd-floor(.5*yd)-.25' \ |
61 |
-e "fld=if(odd,2-$odd_first,1+$odd_first)" \ |
62 |
$fields[$curfi]:q $fields[$nextfi]:q \ |
63 |
> "${basenm}C$fid.$ext" |
64 |
if ($?remove_orig) rm $fields[$curfi]:q $fields[$nextfi]:q |
65 |
@ curfr++ |
66 |
@ curfi = $nextfi + 1 |
67 |
end |
68 |
rm -f $spare_name |
69 |
if ($curfi == $#fields) ln "${basenm}$curfi.$ext" $spare_name |
