| 1 |
/* EVALGLARE V1.17
| 2 |
* Evalglare Software License, Version 1.0
| 3 |
| 4 |
* Copyright (c) 1995 - 2015 Fraunhofer ISE, EPFL.
| 5 |
* All rights reserved.
| 6 |
| 7 |
| 8 |
* Redistribution and use in source and binary forms, WITHOUT
| 9 |
* modification, are permitted provided that the following all conditions
| 10 |
* are met:
| 11 |
| 12 |
* 1. Redistributions of source code must retain the above copyright
| 13 |
* notice, this list of conditions and the following disclaimer.
| 14 |
| 15 |
* 2. Redistributions in binary form must reproduce the above copyright
| 16 |
* notice, this list of conditions and the following disclaimer in
| 17 |
* the documentation and/or other materials provided with the
| 18 |
* distribution.
| 19 |
| 20 |
* 3. The end-user documentation included with the redistribution,
| 21 |
* if any, must include the following acknowledgments:
| 22 |
* "This product includes the evalglare software,
| 23 |
developed at Fraunhofer ISE by J. Wienold" and
| 24 |
* "This product includes Radiance software
| 25 |
* (http://radsite.lbl.gov/)
| 26 |
* developed by the Lawrence Berkeley National Laboratory
| 27 |
* (http://www.lbl.gov/)."
| 28 |
* Alternately, this acknowledgment may appear in the software itself,
| 29 |
* if and wherever such third-party acknowledgments normally appear.
| 30 |
| 31 |
* 4. The names "Evalglare," and "Fraunhofer ISE" must
| 32 |
* not be used to endorse or promote products derived from this
| 33 |
* software without prior written permission. For written
| 34 |
* permission, please contact [email protected]
| 35 |
| 36 |
* 5. Products derived from this software may not be called "evalglare",
| 37 |
* nor may "evalglare" appear in their name, without prior written
| 38 |
* permission of Fraunhofer ISE.
| 39 |
| 40 |
| 41 |
* modification, are permitted provided that the following conditions
| 42 |
* are met:
| 43 |
| 44 |
| 45 |
* conditions 1.-5. apply
| 46 |
| 47 |
* 6. In order to ensure scientific correctness, any modification in source code imply fulfilling all following comditions:
| 48 |
* a) A written permission from Fraunhofer ISE. For written permission, please contact [email protected].
| 49 |
* b) The permission can be applied via email and must contain the applied changes in source code and at least two example calculations,
| 50 |
* comparing the results of the modified version and the current version of evalglare.
| 51 |
* b) Any redistribution of a modified version of evalglare must contain following note:
| 52 |
* "This software uses a modified version of the source code of evalglare."
| 53 |
| 54 |
| 55 |
| 56 |
| 57 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 58 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 59 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 60 |
* DISCLAIMED. IN NO EVENT SHALL Fraunhofer ISE OR
| 61 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 62 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 63 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 64 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 65 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 66 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 67 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 68 |
* SUCH DAMAGE.
| 69 |
| 70 |
| 71 |
* This product includes Radiance software
| 72 |
| 73 |
| 74 |
| 75 |
| 76 |
* The Radiance Software License, Version 1.0
| 77 |
| 78 |
* Copyright (c) 1990 - 2009 The Regents of the University of California,
| 79 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 80 |
| 81 |
* Redistribution and use in source and binary forms, with or without
| 82 |
| 83 |
* are met:
| 84 |
| 85 |
| 86 |
| 87 |
| 88 |
| 89 |
| 90 |
| 91 |
* distribution.
| 92 |
| 93 |
| 94 |
* if any, must include the following acknowledgment:
| 95 |
| 96 |
| 97 |
| 98 |
| 99 |
| 100 |
| 101 |
| 102 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 103 |
* and "The Regents of the University of California" must
| 104 |
| 105 |
| 106 |
* permission, please contact [email protected].
| 107 |
| 108 |
* 5. Products derived from this software may not be called "Radiance",
| 109 |
* nor may "Radiance" appear in their name, without prior written
| 110 |
* permission of Lawrence Berkeley National Laboratory.
| 111 |
| 112 |
| 113 |
| 114 |
| 115 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 116 |
| 117 |
| 118 |
| 119 |
| 120 |
| 121 |
| 122 |
| 123 |
* SUCH DAMAGE.
| 124 |
| 125 |
| 126 |
/* evalglare.c, v0.2 2005/08/21 18:00:00 wienold */
| 127 |
/* evalglare.c, v0.3 2006/06/01 16:20:00 wienold
| 128 |
changes to the v02 version:
| 129 |
-fix problem with non-square pictures
| 130 |
-set luminance values in the hemisphere behind the line of sight to 0
| 131 |
-fix error in vcp calculation */
| 132 |
/* evalglare.c, v0.4 2006/11/13 15:10:00 wienold
| 133 |
changes to the v03 version:
| 134 |
-fix problem with tabulator in picture header "cannot read view"
| 135 |
-fix missing pixels in task area
| 136 |
evalglare.c, v0.5 2006/11/29 9:30 wienold
| 137 |
changes to the v04 version:
| 138 |
- fix problem with glare sources at the edge of the picture
| 139 |
| 140 |
/* evalglare.c, v0.6 2006/11/29 9:30 wienold
| 141 |
changes to the v05 version:
| 142 |
- add luminance restriction parameters in order to take into account restrictions of measuring systems
| 143 |
| 144 |
| 145 |
/* evalglare.c, v0.7 2007/07/11 18:00 wienold
| 146 |
changes to the v06 version:
| 147 |
- add external provision of vertical illuminance
| 148 |
| 149 |
| 150 |
/* evalglare.c, v0.8 2007/12/04 1:35 wienold
| 151 |
changes to the v07 version:
| 152 |
- limit dgp to max 1.0
| 153 |
- fill up cutted pictures with last known values
| 154 |
- add second detailed output
| 155 |
| 156 |
| 157 |
/* evalglare.c, v0.9 2008/07/02 wienold
| 158 |
changes to the v08 version:
| 159 |
- add version number in picheader
| 160 |
- add option for showing version numer
| 161 |
| 162 |
/* evalglare.c, v0.9a 2008/09/20 wienold
| 163 |
changes to the v09 version:
| 164 |
- reduce fix value threshold from 500 to 100
| 165 |
| 166 |
| 167 |
/* evalglare.c, v0.9b 2008/11/12 wienold
| 168 |
changes to the v09a version:
| 169 |
- check view type vta, if wrong than exit
| 170 |
| 171 |
/* evalglare.c, v0.9c 2009/03/31 wienold
| 172 |
changes to the v09b version:
| 173 |
- peak extraction is default now (-y) , for deactivation use -x
| 174 |
| 175 |
| 176 |
/* evalglare.c, v0.9d 2009/06/24 wienold
| 177 |
changes to the v09c version:
| 178 |
- fixed memory problem while using strcat
| 179 |
| 180 |
/* evalglare.c, v0.9e 2009/10/10 wienold
| 181 |
changes to the v09d version:
| 182 |
- fixed problem while reading .pic of windows version
| 183 |
| 184 |
/* evalglare.c, v0.9f 2009/10/21 wienold
| 185 |
changes to the v09e version:
| 186 |
- piping of input pictures possible, allow also vtv and vtc viewtyps
| 187 |
| 188 |
| 189 |
/* evalglare.c, v0.9g 2009/10/21 wienold
| 190 |
changes to the v09f version:
| 191 |
- modified pictool.c
| 192 |
- added -V (calc only vertical illuminance)
| 193 |
| 194 |
/* evalglare.c, v0.9h 2011/10/10 wienold
| 195 |
changes to the v09g version:
| 196 |
- include disability glare for age factor of 1
| 197 |
| 198 |
| 199 |
/* evalglare.c, v0.9i 2011/10/17 wienold
| 200 |
changes to the v09h version:
| 201 |
- M option: Correct wrong (measured) luminance images by feeding Ev and a luminance value, which should be replaced
| 202 |
| 203 |
| 204 |
/* evalglare.c, v1.0 2012/02/08 wienold
| 205 |
| 206 |
- include all view types
| 207 |
- check view option in header
| 208 |
- add view options in command line
| 209 |
- option for cutting out GUTH field of view
| 210 |
| 211 |
| 212 |
| 213 |
/* evalglare.c, v1.02 2012/03/01 wienold,reetz,grobe
| 214 |
changes to the v1.0 version:
| 215 |
- fixed buffer overflow for string variable version[40]
| 216 |
- replaced various strings to handle release by #define
| 217 |
- removed most unused variables
| 218 |
- initialized variables
| 219 |
- removed nested functions
| 220 |
- compiles now with -ansi -pedantic
| 221 |
| 222 |
| 223 |
| 224 |
/* evalglare.c, v1.03 2012/04/17 wienold
| 225 |
- include low light correction
| 226 |
| 227 |
| 228 |
| 229 |
/* evalglare.c, v1.04 2012/04/23 wienold
| 230 |
- remove bug for gen_dgp_profile output
| 231 |
| 232 |
| 233 |
/* evalglare.c, v1.05 2012/05/29 wienold
| 234 |
- remove variable overflow of low-light-correction for large Ev
| 235 |
| 236 |
/* evalglare.c, v1.06 2012/05/29 wienold
| 237 |
- initiate low-light-correction-variable
| 238 |
| 239 |
/* evalglare.c, v1.07 2012/05/29 wienold
| 240 |
- remove edge pixels from evaluation, when center of pixel is behind view (stability)
| 241 |
| 242 |
| 243 |
/* evalglare.c, v1.08 2012/09/09 wienold
| 244 |
- add direction vector in detailed output for each glare source
| 245 |
- include age correction
| 246 |
| 247 |
/* evalglare.c, v1.09 2012/09/09 wienold
| 248 |
- faster calculation for the use of gen_dgp_profile: no vertical illuminance calculation, only dgp is calculated, second scan + split is deactivated, when no pixel >15000 is found
| 249 |
| 250 |
/* evalglare.c, v1.10 2012/09/09 wienold
| 251 |
| 252 |
| 253 |
/* evalglare.c, v1.11 2013/01/17 wienold
| 254 |
- fix output bug of dgp, when using -i or -I
| 255 |
| 256 |
| 257 |
/* evalglare.c, v1.12 2013/10/31 wienold
| 258 |
- include CIE equation for disability glare, Stiles-Holladay
| 259 |
| 260 |
/* evalglare.c, v1.13 2014/04/06 wienold
| 261 |
- remove bug: initialize Lveil_cie_sum
| 262 |
used for the CIE equation for disability glare
| 263 |
| 264 |
| 265 |
/* evalglare.c, v1.14 buggy changes... removed...
| 266 |
| 267 |
/* evalglare.c, v1.15 add option for uniform colored glare sources
| 268 |
| 269 |
/* evalglare.c, v1.16 2015/05/05 remove bugs: background luminance is now calculated not cos-weighted any more, to switch on cos-weighting use -n option
| 270 |
calculation of the background luminance is now based on the real solid angle and not hard coded 2*PI any more
| 271 |
fast calculation mode: total solid angle =2*PI (before PI)
| 272 |
| 273 |
| 274 |
/* evalglare.c, v1.17 2015/07/15 add option for calculating band luminance -B angle_of_band
| 275 |
remove of age factor due to non proven statistical evidence
| 276 |
| 277 |
| 278 |
#define EVALGLARE
| 279 |
| 280 |
#define PROGNAME "evalglare"
| 281 |
#define VERSION "1.17 release 15.07.2015 by EPFL, J.Wienold"
| 282 |
#define RELEASENAME PROGNAME " " VERSION
| 283 |
| 284 |
#include "rtio.h"
| 285 |
#include "platform.h"
| 286 |
#include "pictool.h"
| 287 |
#include <math.h>
| 288 |
#include <string.h>
| 289 |
char *progname;
| 290 |
| 291 |
/* subroutine to add a pixel to a glare source */
| 292 |
void add_pixel_to_gs(pict * p, int x, int y, int gsn)
| 293 |
| 294 |
double old_av_posx, old_av_posy, old_av_lum, old_omega, act_omega,
| 295 |
new_omega, act_lum;
| 296 |
| 297 |
| 298 |
pict_get_npix(p, gsn) = pict_get_npix(p, gsn) + 1;
| 299 |
old_av_posx = pict_get_av_posx(p, gsn);
| 300 |
old_av_posy = pict_get_av_posy(p, gsn);
| 301 |
old_av_lum = pict_get_av_lum(p, gsn);
| 302 |
old_omega = pict_get_av_omega(p, gsn);
| 303 |
| 304 |
act_omega = pict_get_omega(p, x, y);
| 305 |
act_lum = luminance(pict_get_color(p, x, y));
| 306 |
new_omega = old_omega + act_omega;
| 307 |
pict_get_av_posx(p, gsn) =
| 308 |
(old_av_posx * old_omega + x * act_omega) / new_omega;
| 309 |
pict_get_av_posy(p, gsn) =
| 310 |
(old_av_posy * old_omega + y * act_omega) / new_omega;
| 311 |
if (isnan((pict_get_av_posx(p, gsn))))
| 312 |
fprintf(stderr,"error in add_pixel_to_gs %d %d %f %f %f %f\n", x, y, old_av_posy, old_omega, act_omega, new_omega);
| 313 |
| 314 |
pict_get_av_lum(p, gsn) =
| 315 |
(old_av_lum * old_omega + act_lum * act_omega) / new_omega;
| 316 |
pict_get_av_omega(p, gsn) = new_omega;
| 317 |
pict_get_gsn(p, x, y) = gsn;
| 318 |
if (act_lum < pict_get_lum_min(p, gsn)) {
| 319 |
pict_get_lum_min(p, gsn) = act_lum;
| 320 |
| 321 |
if (act_lum > pict_get_lum_max(p, gsn)) {
| 322 |
pict_get_lum_max(p, gsn) = act_lum;
| 323 |
| 324 |
| 325 |
/* printf("gsn,x,y,av_posx,av_posy,av_lum %i %f %f %f %f %f\n",gsn,x,y,pict_get_av_posx(p, gsn),pict_get_av_posy(p, gsn),pict_get_av_lum(p, gsn)); */
| 326 |
| 327 |
| 328 |
| 329 |
/* subroutine for peak extraction */
| 330 |
int
| 331 |
find_split(pict * p, int x, int y, double r, int i_split_start,
| 332 |
int i_split_end)
| 333 |
| 334 |
int i_find_split, x_min, x_max, y_min, y_max, ix, iy, iix, iiy, dx, dy,
| 335 |
out_r;
| 336 |
double r_actual;
| 337 |
| 338 |
i_find_split = 0;
| 339 |
| 340 |
x_min = 0;
| 341 |
y_min = 0;
| 342 |
x_max = pict_get_ysize(p) - 1;
| 343 |
| 344 |
y_max = pict_get_ysize(p) - 1;
| 345 |
| 346 |
for (iiy = 1; iiy <= 2; iiy++) {
| 347 |
dy = iiy * 2 - 3;
| 348 |
if (dy == -1) {
| 349 |
iy = y;
| 350 |
} else {
| 351 |
iy = y + 1;
| 352 |
| 353 |
while (iy <= y_max && iy >= y_min) {
| 354 |
out_r = 0;
| 355 |
for (iix = 1; iix <= 2; iix++) {
| 356 |
dx = iix * 2 - 3;
| 357 |
if (dx == -1) {
| 358 |
ix = x;
| 359 |
} else {
| 360 |
ix = x + 1;
| 361 |
| 362 |
while (ix <= x_max && ix >= x_min && iy >= y_min) {
| 363 |
| 364 |
r_actual =
| 365 |
acos(DOT(pict_get_cached_dir(p, x, y),
| 366 |
pict_get_cached_dir(p, ix, iy))) * 2;
| 367 |
if (r_actual <= r) {
| 368 |
out_r = 1;
| 369 |
if (pict_get_gsn(p, ix, iy) >= i_split_start
| 370 |
&& pict_get_gsn(p, ix, iy) <= i_split_end) {
| 371 |
i_find_split = pict_get_gsn(p, ix, iy);
| 372 |
| 373 |
} else {
| 374 |
ix = -99;
| 375 |
| 376 |
ix = ix + dx;
| 377 |
| 378 |
| 379 |
if (out_r == 0) {
| 380 |
iy = -99;
| 381 |
| 382 |
iy = iy + dy;
| 383 |
| 384 |
| 385 |
| 386 |
| 387 |
| 388 |
| 389 |
return i_find_split;
| 390 |
| 391 |
| 392 |
| 393 |
static int icomp(int* a,int* b)
| 394 |
| 395 |
if (*a < *b)
| 396 |
return -1;
| 397 |
if (*a > *b)
| 398 |
return 1;
| 399 |
return 0;
| 400 |
| 401 |
| 402 |
| 403 |
| 404 |
/* subroutine to find nearby glare source pixels */
| 405 |
| 406 |
int
| 407 |
find_near_pgs(pict * p, int x, int y, float r, int act_gsn, int max_gsn,
| 408 |
int min_gsn)
| 409 |
| 410 |
int dx, dy, i_near_gs, xx, yy, x_min, x_max, y_min, y_max, ix, iy, iix,
| 411 |
iiy, old_gsn, new_gsn, find_gsn, change, stop_y_search,
| 412 |
stop_x_search;
| 413 |
double r_actual;
| 414 |
int ixm[3];
| 415 |
| 416 |
i_near_gs = 0;
| 417 |
stop_y_search = 0;
| 418 |
stop_x_search = 0;
| 419 |
x_min = 0;
| 420 |
y_min = 0;
| 421 |
if (act_gsn == 0) {
| 422 |
x_max = x;
| 423 |
} else {
| 424 |
x_max = pict_get_xsize(p) - 1;
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
old_gsn = pict_get_gsn(p, x, y);
| 430 |
new_gsn = old_gsn;
| 431 |
change = 0;
| 432 |
if (act_gsn > 0) {
| 433 |
i_near_gs = pict_get_gsn(p, x, y);
| 434 |
| 435 |
| 436 |
dy = iiy * 2 - 3;
| 437 |
if (dy == -1) {
| 438 |
iy = y;
| 439 |
} else {
| 440 |
iy = y + 1;
| 441 |
| 442 |
ixm[1] = x;
| 443 |
ixm[2] = x;
| 444 |
stop_y_search = 0;
| 445 |
| 446 |
| 447 |
| 448 |
| 449 |
dx = iix * 2 - 3;
| 450 |
ix = (ixm[1] + ixm[2]) / 2;
| 451 |
stop_x_search = 0;
| 452 |
while (ix <= x_max && ix >= x_min && stop_x_search == 0
| 453 |
&& stop_y_search == 0) {
| 454 |
/* printf(" dx,act_gsn, x,y,x_max, x_min, ix ,iy , ymax,ymin %i %i %i %i %i %i %i %i %i %i\n",dx,act_gsn,x,y,x_max,x_min,ix,iy,y_max,y_min);*/
| 455 |
r_actual =
| 456 |
| 457 |
| 458 |
| 459 |
if (pict_get_gsn(p, ix, iy) > 0) {
| 460 |
if (act_gsn == 0) {
| 461 |
i_near_gs = pict_get_gsn(p, ix, iy);
| 462 |
stop_x_search = 1;
| 463 |
stop_y_search = 1;
| 464 |
} else {
| 465 |
find_gsn = pict_get_gsn(p, ix, iy);
| 466 |
if (pict_get_av_omega(p, old_gsn) <
| 467 |
pict_get_av_omega(p, find_gsn)
| 468 |
&& pict_get_av_omega(p,
| 469 |
find_gsn) >
| 470 |
pict_get_av_omega(p, new_gsn)
| 471 |
&& find_gsn >= min_gsn
| 472 |
&& find_gsn <= max_gsn) {
| 473 |
/* other primary glare source found with larger solid angle -> add together all */
| 474 |
new_gsn = find_gsn;
| 475 |
change = 1;
| 476 |
stop_x_search = 1;
| 477 |
stop_y_search = 1;
| 478 |
| 479 |
| 480 |
| 481 |
} else {
| 482 |
ixm[iix] = ix - dx;
| 483 |
stop_x_search = 1;
| 484 |
| 485 |
ix = ix + dx;
| 486 |
| 487 |
| 488 |
iy = iy + dy;
| 489 |
| 490 |
| 491 |
if (change > 0) {
| 492 |
pict_get_av_lum(p, old_gsn) = 0.;
| 493 |
pict_get_av_omega(p, old_gsn) = 0.;
| 494 |
pict_get_npix(p, old_gsn) = 0.;
| 495 |
pict_get_lum_max(p, old_gsn) = 0.;
| 496 |
| 497 |
| 498 |
i_near_gs = new_gsn;
| 499 |
/* printf(" changing gs no %i",old_gsn);
| 500 |
printf(" to %i\n",new_gsn);
| 501 |
| 502 |
for (xx = 0; xx < pict_get_xsize(p); xx++)
| 503 |
for (yy = 0; yy < pict_get_ysize(p); yy++) {
| 504 |
if (pict_is_validpixel(p, x, y)) {
| 505 |
if (pict_get_gsn(p, xx, yy) == old_gsn) {
| 506 |
add_pixel_to_gs(p, xx, yy, new_gsn);
| 507 |
| 508 |
| 509 |
| 510 |
| 511 |
| 512 |
return i_near_gs;
| 513 |
| 514 |
| 515 |
| 516 |
| 517 |
/* subroutine for calculation of task luminance */
| 518 |
double get_task_lum(pict * p, int x, int y, float r, int task_color)
| 519 |
| 520 |
int x_min, x_max, y_min, y_max, ix, iy;
| 521 |
double r_actual, av_lum, omega_sum, act_lum;
| 522 |
| 523 |
| 524 |
| 525 |
| 526 |
x_min = 0;
| 527 |
y_min = 0;
| 528 |
| 529 |
| 530 |
| 531 |
av_lum = 0.0;
| 532 |
omega_sum = 0.0;
| 533 |
| 534 |
for (iy = y_min; iy <= y_max; iy++) {
| 535 |
for (ix = x_min; ix <= x_max; ix++) {
| 536 |
| 537 |
/* if (DOT(pict_get_cached_dir(p,ix,iy),p->view.vdir) < 0.0)
| 538 |
continue;*/
| 539 |
r_actual =
| 540 |
| 541 |
| 542 |
act_lum = luminance(pict_get_color(p, ix, iy));
| 543 |
| 544 |
| 545 |
| 546 |
av_lum += pict_get_omega(p, ix, iy) * act_lum;
| 547 |
omega_sum += pict_get_omega(p, ix, iy);
| 548 |
if (task_color == 1) {
| 549 |
pict_get_color(p, ix, iy)[RED] = 0.0;
| 550 |
pict_get_color(p, ix, iy)[GRN] = 0.0;
| 551 |
pict_get_color(p, ix, iy)[BLU] =
| 552 |
act_lum / WHTEFFICACY / CIE_bf;
| 553 |
| 554 |
| 555 |
| 556 |
| 557 |
| 558 |
av_lum = av_lum / omega_sum;
| 559 |
/* printf("average luminance of task %f \n",av_lum);
| 560 |
printf("solid angle of task %f \n",omega_sum);*/
| 561 |
return av_lum;
| 562 |
| 563 |
| 564 |
/* subroutine for calculation of band luminance */
| 565 |
double get_band_lum(pict * p, float r, int task_color)
| 566 |
| 567 |
int x_min, x_max, y_min, y_max, ix, iy, y_mid;
| 568 |
| 569 |
| 570 |
| 571 |
| 572 |
| 573 |
x_min = 0;
| 574 |
y_min = 0;
| 575 |
y_mid = rint(y_max/2);
| 576 |
| 577 |
| 578 |
| 579 |
av_lum = 0.0;
| 580 |
omega_sum = 0.0;
| 581 |
| 582 |
| 583 |
| 584 |
| 585 |
| 586 |
continue;*/
| 587 |
r_actual =
| 588 |
acos(DOT(pict_get_cached_dir(p, ix, y_mid),
| 589 |
pict_get_cached_dir(p, ix, iy))) ;
| 590 |
| 591 |
| 592 |
if ((r_actual <= r) || (iy == y_mid) ) {
| 593 |
| 594 |
| 595 |
| 596 |
| 597 |
| 598 |
pict_get_color(p, ix, iy)[GRN] = act_lum / WHTEFFICACY / CIE_gf;
| 599 |
pict_get_color(p, ix, iy)[BLU] = 0.0;
| 600 |
| 601 |
| 602 |
| 603 |
| 604 |
| 605 |
| 606 |
/* printf("average luminance of band %f \n",av_lum);*/
| 607 |
/* printf("solid angle of band %f \n",omega_sum);*/
| 608 |
return av_lum;
| 609 |
| 610 |
| 611 |
| 612 |
| 613 |
| 614 |
| 615 |
/* subroutine for coloring the glare sources
| 616 |
red is used only for explicit call of the subroutine with acol=0 , e.g. for disability glare
| 617 |
-1: set to grey*/
| 618 |
int setglcolor(pict * p, int x, int y, int acol, int uniform_gs, double u_r, double u_g ,double u_b)
| 619 |
| 620 |
int icol;
| 621 |
double pcol[3][1000], act_lum, l;
| 622 |
| 623 |
l=u_r+u_g+u_b ;
| 624 |
| 625 |
pcol[RED][0] = 1.0 / CIE_rf;
| 626 |
pcol[GRN][0] = 0.;
| 627 |
pcol[BLU][0] = 0.;
| 628 |
| 629 |
pcol[RED][1] = 0.;
| 630 |
pcol[GRN][1] = 1.0 / CIE_gf;
| 631 |
pcol[BLU][1] = 0.;
| 632 |
| 633 |
pcol[RED][2] = 0.;
| 634 |
pcol[GRN][2] = 0.;
| 635 |
pcol[BLU][2] = 1 / CIE_bf;
| 636 |
| 637 |
pcol[RED][3] = 1.0 / (1.0 - CIE_bf);
| 638 |
pcol[GRN][3] = 1.0 / (1.0 - CIE_bf);
| 639 |
pcol[BLU][3] = 0.;
| 640 |
| 641 |
pcol[RED][4] = 1.0 / (1.0 - CIE_gf);
| 642 |
pcol[GRN][4] = 0.;
| 643 |
pcol[BLU][4] = 1.0 / (1.0 - CIE_gf);
| 644 |
| 645 |
pcol[RED][5] = 0.;
| 646 |
pcol[GRN][5] = 1.0 / (1.0 - CIE_rf);
| 647 |
pcol[BLU][5] = 1.0 / (1.0 - CIE_rf);
| 648 |
| 649 |
pcol[RED][6] = 0.;
| 650 |
pcol[GRN][6] = 1.0 / (1.0 - CIE_rf);
| 651 |
pcol[BLU][6] = 1.0 / (1.0 - CIE_rf);
| 652 |
| 653 |
| 654 |
pcol[RED][999] = 1.0 / WHTEFFICACY;
| 655 |
pcol[GRN][999] = 1.0 / WHTEFFICACY;
| 656 |
pcol[BLU][999] = 1.0 / WHTEFFICACY;
| 657 |
| 658 |
| 659 |
pcol[RED][998] = u_r /(l* CIE_rf) ;
| 660 |
pcol[GRN][998] = u_g /(l* CIE_gf);
| 661 |
pcol[BLU][998] = u_b /(l* CIE_bf);
| 662 |
/* printf("CIE_rf,CIE_gf,CIE_bf,l=%f %f %f %f\n",CIE_rf,CIE_gf,CIE_bf,l);*/
| 663 |
icol = acol ;
| 664 |
if ( acol == -1) {icol=999;
| 665 |
}else{if (acol>0){icol = acol % 5 +1;
| 666 |
| 667 |
if ( uniform_gs == 1) {icol=998;
| 668 |
| 669 |
| 670 |
| 671 |
| 672 |
pict_get_color(p, x, y)[RED] = pcol[RED][icol] * act_lum / WHTEFFICACY;
| 673 |
pict_get_color(p, x, y)[GRN] = pcol[GRN][icol] * act_lum / WHTEFFICACY;
| 674 |
pict_get_color(p, x, y)[BLU] = pcol[BLU][icol] * act_lum / WHTEFFICACY;
| 675 |
| 676 |
return icol;
| 677 |
| 678 |
| 679 |
/* this is the smooting subroutine */
| 680 |
void add_secondary_gs(pict * p, int x, int y, float r, int act_gs, int uniform_gs, double u_r, double u_g ,double u_b)
| 681 |
| 682 |
int x_min, x_max, y_min, y_max, ix, iy, icol;
| 683 |
double r_actual, omega_gs, omega_total, om;
| 684 |
| 685 |
| 686 |
| 687 |
omega_gs = 0.0;
| 688 |
omega_total = 0.0;
| 689 |
x_min = x - r;
| 690 |
if (x_min < 0) {
| 691 |
x_min = 0;
| 692 |
| 693 |
x_max = x + r;
| 694 |
if (x_max > pict_get_xsize(p) - 1) {
| 695 |
x_max = pict_get_xsize(p) - 2;
| 696 |
| 697 |
y_min = y - r;
| 698 |
if (y_min < 0) {
| 699 |
y_min = 0;
| 700 |
| 701 |
y_max = y + r;
| 702 |
if (y_max > pict_get_ysize(p) - 1) {
| 703 |
y_max = pict_get_ysize(p) - 2;
| 704 |
| 705 |
| 706 |
| 707 |
| 708 |
r_actual = sqrt((x - ix) * (x - ix) + (y - iy) * (y - iy));
| 709 |
| 710 |
om = pict_get_omega(p, ix, iy);
| 711 |
omega_total += om;
| 712 |
if (pict_get_gsn(p, ix, iy) == act_gs
| 713 |
&& pict_get_pgs(p, ix, iy) == 1) {
| 714 |
omega_gs = omega_gs + 1 * om;
| 715 |
| 716 |
| 717 |
| 718 |
| 719 |
| 720 |
if (omega_gs / omega_total > 0.2) {
| 721 |
/* add pixel to gs */
| 722 |
| 723 |
add_pixel_to_gs(p, x, y, act_gs);
| 724 |
| 725 |
/* color pixel of gs */
| 726 |
| 727 |
icol = setglcolor(p, x, y, act_gs, uniform_gs, u_r, u_g , u_b);
| 728 |
| 729 |
| 730 |
| 731 |
| 732 |
/* subroutine for removing a pixel from a glare source */
| 733 |
void split_pixel_from_gs(pict * p, int x, int y, int new_gsn, int uniform_gs, double u_r, double u_g , double u_b)
| 734 |
| 735 |
int old_gsn, icol;
| 736 |
| 737 |
new_omega, act_lum;
| 738 |
| 739 |
| 740 |
/* change existing gs */
| 741 |
| 742 |
pict_get_npix(p, old_gsn) = pict_get_npix(p, old_gsn) - 1;
| 743 |
| 744 |
| 745 |
old_av_posx = pict_get_av_posx(p, old_gsn);
| 746 |
old_av_posy = pict_get_av_posy(p, old_gsn);
| 747 |
old_omega = pict_get_av_omega(p, old_gsn);
| 748 |
| 749 |
new_omega = old_omega - act_omega;
| 750 |
pict_get_av_omega(p, old_gsn) = new_omega;
| 751 |
pict_get_av_posx(p, old_gsn) =
| 752 |
(old_av_posx * old_omega - x * act_omega) / new_omega;
| 753 |
pict_get_av_posy(p, old_gsn) =
| 754 |
(old_av_posy * old_omega - y * act_omega) / new_omega;
| 755 |
| 756 |
| 757 |
| 758 |
old_av_lum = pict_get_av_lum(p, old_gsn);
| 759 |
| 760 |
(old_av_lum * old_omega - act_lum * act_omega) / new_omega;
| 761 |
/* add pixel to new gs */
| 762 |
| 763 |
add_pixel_to_gs(p, x, y, new_gsn);
| 764 |
| 765 |
/* color pixel of new gs */
| 766 |
| 767 |
icol = setglcolor(p, x, y, new_gsn, uniform_gs, u_r, u_g , u_b);
| 768 |
| 769 |
| 770 |
| 771 |
| 772 |
/* subroutine for the calculation of the position index */
| 773 |
float get_posindex(pict * p, float x, float y, int postype)
| 774 |
| 775 |
float posindex;
| 776 |
double teta, phi, sigma, tau, deg, d, s, r, fact;
| 777 |
| 778 |
| 779 |
pict_get_vangle(p, x, y, p->view.vdir, p->view.vup, &phi);
| 780 |
pict_get_hangle(p, x, y, p->view.vdir, p->view.vup, &teta);
| 781 |
pict_get_sigma(p, x, y, p->view.vdir, p->view.vup, &sigma);
| 782 |
pict_get_tau(p, x, y, p->view.vdir, p->view.vup, &tau);
| 783 |
| 784 |
/* return (phi+teta+2*3.1415927); */
| 785 |
| 786 |
deg = 180 / 3.1415927;
| 787 |
fact = 0.8;
| 788 |
if (phi == 0) {
| 789 |
phi = 0.00001;
| 790 |
| 791 |
if (sigma <= 0) {
| 792 |
sigma = -sigma;
| 793 |
| 794 |
if (teta == 0) {
| 795 |
teta = 0.0001;
| 796 |
| 797 |
tau = tau * deg;
| 798 |
sigma = sigma * deg;
| 799 |
| 800 |
posindex =
| 801 |
exp((35.2 - 0.31889 * tau -
| 802 |
1.22 * exp(-2 * tau / 9)) / 1000 * sigma + (21 +
| 803 |
0.26667 * tau -
| 804 |
0.002963 * tau *
| 805 |
tau) / 100000 *
| 806 |
sigma * sigma);
| 807 |
/* below line of sight, using Iwata model */
| 808 |
if (phi < 0) {
| 809 |
d = 1 / tan(phi);
| 810 |
s = tan(teta) / tan(phi);
| 811 |
r = sqrt(1 / d * 1 / d + s * s / d / d);
| 812 |
if (r > 0.6)
| 813 |
fact = 1.2;
| 814 |
if (r > 3) {
| 815 |
fact = 1.2;
| 816 |
r = 3;
| 817 |
| 818 |
| 819 |
posindex = 1 + fact * r;
| 820 |
| 821 |
if (posindex > 16)
| 822 |
posindex = 16;
| 823 |
| 824 |
return posindex;
| 825 |
| 826 |
| 827 |
| 828 |
| 829 |
| 830 |
double get_upper_cut_2eyes(float teta)
| 831 |
| 832 |
double phi;
| 833 |
| 834 |
phi=pow(7.7458218+0.00057407915*teta-0.00021746318*teta*teta+8.5572726e-6*teta*teta*teta,2);
| 835 |
| 836 |
return phi;
| 837 |
| 838 |
double get_lower_cut_2eyes(float teta)
| 839 |
| 840 |
double phi;
| 841 |
| 842 |
phi=1/(-0.014699242-1.5541106e-5*teta+4.6898068e-6*teta*teta-5.1539687e-8*teta*teta*teta);
| 843 |
| 844 |
return phi;
| 845 |
| 846 |
| 847 |
double get_lower_cut_central(float teta)
| 848 |
| 849 |
double phi;
| 850 |
| 851 |
phi=(68.227109-2.9524084*teta+0.046674262*teta*teta)/(1-0.042317294*teta+0.00075698419*teta*teta-6.5364285e-7*teta*teta*teta);
| 852 |
| 853 |
if (teta>73) {
| 854 |
phi=60;
| 855 |
| 856 |
| 857 |
return phi;
| 858 |
| 859 |
| 860 |
/* subroutine for the cutting the total field of view */
| 861 |
void cut_view_1(pict*p)
| 862 |
| 863 |
int x,y;
| 864 |
double border,ang,teta,phi,phi2;
| 865 |
for(x=0;x<pict_get_xsize(p)-1;x++)
| 866 |
for(y=0;y<pict_get_ysize(p)-1;y++) {
| 867 |
if (pict_get_hangle(p,x,y,p->view.vdir,p->view.vup,&ang)) {
| 868 |
| 869 |
pict_get_vangle(p,x,y,p->view.vdir,p->view.vup,&phi2);
| 870 |
pict_get_sigma(p,x,y,p->view.vdir,p->view.vup,&phi);
| 871 |
pict_get_tau(p,x,y,p->view.vdir,p->view.vup,&teta);
| 872 |
phi=phi*180/3.1415927;
| 873 |
phi2=phi2*180/3.1415927;
| 874 |
teta=teta*180/3.1415927;
| 875 |
if (teta<0) {
| 876 |
teta=-teta;
| 877 |
| 878 |
if(phi2>0){
| 879 |
border=get_upper_cut_2eyes(teta);
| 880 |
| 881 |
if (phi>border) {
| 882 |
pict_get_color(p,x,y)[RED]=0;
| 883 |
pict_get_color(p,x,y)[GRN]=0;
| 884 |
pict_get_color(p,x,y)[BLU]=0;
| 885 |
| 886 |
}else{
| 887 |
border=get_lower_cut_2eyes(180-teta);
| 888 |
if (-phi<border && teta>135) {
| 889 |
| 890 |
| 891 |
| 892 |
| 893 |
| 894 |
| 895 |
| 896 |
| 897 |
}else{
| 898 |
| 899 |
| 900 |
| 901 |
| 902 |
| 903 |
| 904 |
| 905 |
/* printf("teta,phi,border=%f %f %f\n",teta,phi,border);*/
| 906 |
| 907 |
| 908 |
| 909 |
| 910 |
return;
| 911 |
| 912 |
| 913 |
/* subroutine for the cutting the field of view seen by both eyes*/
| 914 |
void cut_view_2(pict*p)
| 915 |
| 916 |
| 917 |
int x,y;
| 918 |
| 919 |
| 920 |
| 921 |
| 922 |
| 923 |
| 924 |
pict_get_hangle(p,x,y,p->view.vdir,p->view.vup,&teta);
| 925 |
| 926 |
| 927 |
| 928 |
| 929 |
| 930 |
/* printf("x,y,teta,phi,border=%i %i %f %f %f\n",x,y,teta,phi,border);*/
| 931 |
if (teta<0) {
| 932 |
teta=-teta;
| 933 |
| 934 |
if(phi2>0){
| 935 |
border=60;
| 936 |
| 937 |
if (phi>border) {
| 938 |
| 939 |
| 940 |
| 941 |
| 942 |
}else{
| 943 |
border=get_lower_cut_central(180-teta);
| 944 |
if (phi>border) {
| 945 |
| 946 |
| 947 |
| 948 |
| 949 |
| 950 |
| 951 |
| 952 |
| 953 |
}else{
| 954 |
| 955 |
| 956 |
| 957 |
| 958 |
| 959 |
| 960 |
| 961 |
| 962 |
| 963 |
| 964 |
return;
| 965 |
| 966 |
| 967 |
| 968 |
| 969 |
luminance is modified by position index - just for experiments - undocumented */
| 970 |
void cut_view_3(pict*p)
| 971 |
| 972 |
| 973 |
int x,y;
| 974 |
double border,ang,teta,phi,phi2,lum,newlum;
| 975 |
| 976 |
| 977 |
| 978 |
if (DOT(pict_get_cached_dir(p,x,y),p->view.vdir) >= 0.0) {
| 979 |
| 980 |
| 981 |
| 982 |
| 983 |
| 984 |
| 985 |
| 986 |
lum=luminance(pict_get_color(p,x,y));
| 987 |
| 988 |
newlum=lum/get_posindex(p,x,y,0);
| 989 |
| 990 |
pict_get_color(p,x,y)[RED]=newlum/WHTEFFICACY;
| 991 |
pict_get_color(p,x,y)[GRN]=newlum/WHTEFFICACY;
| 992 |
pict_get_color(p,x,y)[BLU]=newlum/WHTEFFICACY;
| 993 |
| 994 |
| 995 |
| 996 |
| 997 |
| 998 |
if (teta<0) {
| 999 |
teta=-teta;
| 1000 |
| 1001 |
if(phi2>0){
| 1002 |
border=60;
| 1003 |
| 1004 |
if (phi>border) {
| 1005 |
| 1006 |
| 1007 |
| 1008 |
| 1009 |
}else{
| 1010 |
| 1011 |
if (phi>border) {
| 1012 |
| 1013 |
| 1014 |
| 1015 |
| 1016 |
| 1017 |
| 1018 |
| 1019 |
| 1020 |
}else{
| 1021 |
| 1022 |
| 1023 |
| 1024 |
| 1025 |
| 1026 |
| 1027 |
| 1028 |
| 1029 |
| 1030 |
| 1031 |
return;
| 1032 |
| 1033 |
| 1034 |
| 1035 |
/* subroutine for the calculation of the daylight glare index */
| 1036 |
| 1037 |
| 1038 |
float get_dgi(pict * p, float lum_backg, int igs, int posindex_2)
| 1039 |
| 1040 |
float dgi, sum_glare, omega_s;
| 1041 |
int i;
| 1042 |
| 1043 |
| 1044 |
sum_glare = 0;
| 1045 |
omega_s = 0;
| 1046 |
| 1047 |
for (i = 0; i <= igs; i++) {
| 1048 |
| 1049 |
if (pict_get_npix(p, i) > 0) {
| 1050 |
omega_s =
| 1051 |
pict_get_av_omega(p, i) / get_posindex(p,pict_get_av_posx(p,i), pict_get_av_posy(p,i),posindex_2) /
| 1052 |
get_posindex(p, pict_get_av_posx(p, i), pict_get_av_posy(p, i), posindex_2);
| 1053 |
sum_glare += 0.478 * pow(pict_get_av_lum(p, i), 1.6) * pow(omega_s,0.8) / (lum_backg + 0.07 * pow(pict_get_av_omega(p, i),0.5) * pict_get_av_lum(p, i));
| 1054 |
/* printf("i,sum_glare %i %f\n",i,sum_glare); */
| 1055 |
| 1056 |
| 1057 |
dgi = 10 * log10(sum_glare);
| 1058 |
| 1059 |
return dgi;
| 1060 |
| 1061 |
| 1062 |
| 1063 |
/* subroutine for the calculation of the daylight glare probability */
| 1064 |
double
| 1065 |
get_dgp(pict * p, double E_v, int igs, double a1, double a2, double a3,
| 1066 |
double a4, double a5, double c1, double c2, double c3,
| 1067 |
int posindex_2)
| 1068 |
| 1069 |
double dgp;
| 1070 |
double sum_glare;
| 1071 |
int i;
| 1072 |
| 1073 |
sum_glare = 0;
| 1074 |
if (igs > 0) {
| 1075 |
| 1076 |
| 1077 |
| 1078 |
sum_glare +=
| 1079 |
| 1080 |
a1) / pow(get_posindex(p, pict_get_av_posx(p, i),
| 1081 |
| 1082 |
posindex_2),
| 1083 |
a4) * pow(pict_get_av_omega(p, i), a2);
| 1084 |
/* printf("i,sum_glare %i %f\n",i,sum_glare);*/
| 1085 |
| 1086 |
| 1087 |
dgp =
| 1088 |
c1 * pow(E_v,
| 1089 |
a5) + c3 + c2 * log10(1 + sum_glare / pow(E_v, a3));
| 1090 |
} else {
| 1091 |
dgp = c3 + c1 * pow(E_v, a5);
| 1092 |
| 1093 |
| 1094 |
if (dgp > 1) {
| 1095 |
dgp = 1;
| 1096 |
| 1097 |
/* printf("dgp %f\n",dgp);*/
| 1098 |
return dgp;
| 1099 |
| 1100 |
| 1101 |
| 1102 |
/* subroutine for the calculation of the visual comfort probability */
| 1103 |
float get_vcp(pict * p, double lum_a, int igs, int posindex_2)
| 1104 |
| 1105 |
float vcp;
| 1106 |
double sum_glare, dgr;
| 1107 |
int i, i_glare;
| 1108 |
| 1109 |
| 1110 |
sum_glare = 0;
| 1111 |
i_glare = 0;
| 1112 |
| 1113 |
| 1114 |
| 1115 |
i_glare = i_glare + 1;
| 1116 |
sum_glare +=
| 1117 |
(0.5 * pict_get_av_lum(p, i) *
| 1118 |
(20.4 * pict_get_av_omega(p, i) +
| 1119 |
1.52 * pow(pict_get_av_omega(p, i),
| 1120 |
0.2) - 0.075)) / (get_posindex(p,
| 1121 |
pict_get_av_posx
| 1122 |
(p, i),
| 1123 |
pict_get_av_posy
| 1124 |
(p, i),
| 1125 |
posindex_2) *
| 1126 |
pow(lum_a, 0.44));
| 1127 |
| 1128 |
| 1129 |
| 1130 |
dgr = pow(sum_glare, pow(i_glare, -0.0914));
| 1131 |
| 1132 |
vcp = 50 * erf((6.347 - 1.3227 * log(dgr)) / 1.414213562373) + 50;
| 1133 |
if (dgr > 750) {
| 1134 |
vcp = 0;
| 1135 |
| 1136 |
if (dgr < 20) {
| 1137 |
vcp = 100;
| 1138 |
| 1139 |
| 1140 |
| 1141 |
return vcp;
| 1142 |
| 1143 |
| 1144 |
| 1145 |
/* subroutine for the calculation of the unified glare rating */
| 1146 |
float get_ugr(pict * p, double lum_backg, int igs, int posindex_2)
| 1147 |
| 1148 |
float ugr;
| 1149 |
double sum_glare;
| 1150 |
int i, i_glare;
| 1151 |
| 1152 |
| 1153 |
sum_glare = 0;
| 1154 |
i_glare = 0;
| 1155 |
| 1156 |
| 1157 |
| 1158 |
| 1159 |
sum_glare +=
| 1160 |
pow(pict_get_av_lum(p, i) /
| 1161 |
| 1162 |
pict_get_av_posy(p, i), posindex_2),
| 1163 |
2) * pict_get_av_omega(p, i);
| 1164 |
| 1165 |
| 1166 |
| 1167 |
ugr = 8 * log10(0.25 / lum_backg * sum_glare);
| 1168 |
| 1169 |
return ugr;
| 1170 |
| 1171 |
| 1172 |
| 1173 |
| 1174 |
/* subroutine for the calculation of the disability glare according to Poynter */
| 1175 |
float get_disability(pict * p, double lum_backg, int igs)
| 1176 |
| 1177 |
float disab;
| 1178 |
double sum_glare, sigma, deg;
| 1179 |
int i, i_glare;
| 1180 |
| 1181 |
| 1182 |
sum_glare = 0;
| 1183 |
i_glare = 0;
| 1184 |
| 1185 |
| 1186 |
| 1187 |
| 1188 |
| 1189 |
pict_get_sigma(p, pict_get_av_posx(p, i),
| 1190 |
pict_get_av_posy(p, i), p->view.vdir,
| 1191 |
| 1192 |
| 1193 |
sum_glare +=
| 1194 |
pict_get_av_lum(p,
| 1195 |
i) * cos(sigma +
| 1196 |
0.00000000001) *
| 1197 |
| 1198 |
/ (deg * sigma + 0.00000000001);
| 1199 |
if (isnan(sum_glare)) {
| 1200 |
printf("sigma for %f %f\n", pict_get_av_posx(p, i), pict_get_av_posy(p, i));
| 1201 |
printf("omega for %f %f\n", pict_get_av_posx(p, i), pict_get_av_posy(p, i));
| 1202 |
printf("avlum for %f %f\n", pict_get_av_posx(p, i), pict_get_av_posy(p, i));
| 1203 |
printf("avlum for %f %f %f\n", pict_get_av_posx(p, i), pict_get_av_posy(p, i), sigma);
| 1204 |
| 1205 |
| 1206 |
| 1207 |
| 1208 |
disab = 5 * sum_glare;
| 1209 |
| 1210 |
return disab;
| 1211 |
| 1212 |
| 1213 |
| 1214 |
| 1215 |
| 1216 |
| 1217 |
| 1218 |
| 1219 |
/* subroutine for the calculation of the cie glare index */
| 1220 |
| 1221 |
float
| 1222 |
get_cgi(pict * p, double E_v, double E_v_dir, int igs, int posindex_2)
| 1223 |
| 1224 |
float cgi;
| 1225 |
double sum_glare;
| 1226 |
int i, i_glare;
| 1227 |
| 1228 |
| 1229 |
sum_glare = 0;
| 1230 |
i_glare = 0;
| 1231 |
| 1232 |
| 1233 |
| 1234 |
| 1235 |
sum_glare +=
| 1236 |
| 1237 |
| 1238 |
| 1239 |
| 1240 |
| 1241 |
| 1242 |
| 1243 |
cgi = 8 * log10((2 * (1 + E_v_dir / 500) / E_v) * sum_glare);
| 1244 |
| 1245 |
return cgi;
| 1246 |
| 1247 |
| 1248 |
| 1249 |
| 1250 |
#ifdef EVALGLARE
| 1251 |
| 1252 |
| 1253 |
/* main program
| 1254 |
| 1255 |
| 1256 |
| 1257 |
int main(int argc, char **argv)
| 1258 |
| 1259 |
#define CLINEMAX 4095 /* memory allocated for command line string */
| 1260 |
pict *p = pict_create();
| 1261 |
int skip_second_scan,calcfast,age_corr,cut_view,cut_view_type,calc_vill, output, detail_out2, y1, fill, yfillmax, yfillmin,
| 1262 |
ext_vill, set_lum_max, set_lum_max2, task_color, i_splitstart,
| 1263 |
i_split, posindex_2, task_lum, checkfile, rval, i, i_max, x, y,x2,y2,
| 1264 |
igs, actual_igs, icol, xt, yt, change, before_igs, sgs, splithigh,uniform_gs,
| 1265 |
detail_out, posindex_picture, non_cos_lb, rx, ry, rmx, rmy,apply_disability,band_calc,band_color;
| 1266 |
double lum_total_max,age_corr_factor,age,dgp_ext,dgp,low_light_corr,omega_cos_contr, setvalue, lum_ideal, E_v_contr, sigma,
| 1267 |
E_vl_ext, lum_max, new_lum_max, r_center,
| 1268 |
search_pix, a1, a2, a3, a4, a5, c3, c1, c2, r_split, max_angle,
| 1269 |
omegat, sang, E_v, E_v2, E_v_dir, avlum, act_lum, ang,
| 1270 |
l_max, lum_backg, lum_backg_cos, omega_sources, lum_sources,
| 1271 |
lum, lum_source,teta,Lveil_cie,Lveil_cie_sum,disability_thresh,u_r,u_g,u_b,band_angle,band_avlum;
| 1272 |
float lum_task, lum_thres, dgi, vcp, cgi, ugr, limit,
| 1273 |
abs_max, Lveil;
| 1274 |
char file_out[500], file_out2[500], version[500];
| 1275 |
char *cline;
| 1276 |
VIEW userview = STDVIEW;
| 1277 |
int gotuserview = 0;
| 1278 |
| 1279 |
/*set required user view parameters to invalid values*/
| 1280 |
uniform_gs = 0;
| 1281 |
apply_disability = 0;
| 1282 |
disability_thresh = 0;
| 1283 |
Lveil_cie_sum=0.0;
| 1284 |
skip_second_scan=0;
| 1285 |
lum_total_max=0.0;
| 1286 |
calcfast=0;
| 1287 |
age_corr_factor = 1.0;
| 1288 |
age_corr = 0;
| 1289 |
age = 20.0;
| 1290 |
userview.horiz = 0;
| 1291 |
userview.vert = 0;
| 1292 |
userview.type = 0;
| 1293 |
dgp_ext = 0;
| 1294 |
E_vl_ext = 0.0;
| 1295 |
new_lum_max = 0.0;
| 1296 |
lum_max = 0.0;
| 1297 |
omegat = 0.0;
| 1298 |
yt = 0;
| 1299 |
xt = 0;
| 1300 |
yfillmin = 0;
| 1301 |
yfillmax = 0;
| 1302 |
cut_view = 0;
| 1303 |
cut_view_type = 0;
| 1304 |
setvalue = 2e09;
| 1305 |
omega_cos_contr = 0.0;
| 1306 |
lum_ideal = 0.0;
| 1307 |
max_angle = 0.2;
| 1308 |
lum_thres = 5.0;
| 1309 |
task_lum = 0;
| 1310 |
sgs = 0;
| 1311 |
splithigh = 1;
| 1312 |
detail_out = 0;
| 1313 |
detail_out2 = 0;
| 1314 |
posindex_picture = 0;
| 1315 |
checkfile = 0;
| 1316 |
ext_vill = 0;
| 1317 |
fill = 0;
| 1318 |
a1 = 2.0;
| 1319 |
a2 = 1.0;
| 1320 |
a3 = 1.87;
| 1321 |
a4 = 2.0;
| 1322 |
a5 = 1.0;
| 1323 |
c1 = 5.87e-05;
| 1324 |
c2 = 0.092;
| 1325 |
c3 = 0.159;
| 1326 |
non_cos_lb = 1;
| 1327 |
posindex_2 = 0;
| 1328 |
task_color = 0;
| 1329 |
limit = 50000.0;
| 1330 |
set_lum_max = 0;
| 1331 |
set_lum_max2 = 0;
| 1332 |
abs_max = 0;
| 1333 |
progname = argv[0];
| 1334 |
E_v_contr = 0.0;
| 1335 |
strcpy(version, "1.15 release 05.02.2015 by J.Wienold");
| 1336 |
low_light_corr=1.0;
| 1337 |
output = 0;
| 1338 |
calc_vill = 0;
| 1339 |
band_avlum = -99;
| 1340 |
band_calc = 0;
| 1341 |
/* command line for output picture*/
| 1342 |
| 1343 |
cline = (char *) malloc(CLINEMAX+1);
| 1344 |
cline[0] = '\0';
| 1345 |
for (i = 0; i < argc; i++) {
| 1346 |
/* fprintf(stderr, "%d %d \n",i,strlen(argv[i]));*/
| 1347 |
if (strlen(cline)+strlen(argv[i])+strlen(RELEASENAME)+2 >=CLINEMAX) {
| 1348 |
exit (-1);
| 1349 |
| 1350 |
else {
| 1351 |
strcat(cline, argv[i]);
| 1352 |
strcat(cline, " ");
| 1353 |
| 1354 |
| 1355 |
strcat(cline, "\n");
| 1356 |
strcat(cline, RELEASENAME);
| 1357 |
| 1358 |
| 1359 |
| 1360 |
/* program options */
| 1361 |
| 1362 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 1363 |
/* expand arguments */
| 1364 |
while ((rval = expandarg(&argc, &argv, i)) > 0);
| 1365 |
if (rval < 0) {
| 1366 |
fprintf(stderr, "%s: cannot expand '%s'", argv[0], argv[i]);
| 1367 |
exit(1);
| 1368 |
| 1369 |
rval = getviewopt(&userview, argc - i, argv + i);
| 1370 |
if (rval >= 0) {
| 1371 |
i += rval;
| 1372 |
gotuserview++;
| 1373 |
continue;
| 1374 |
| 1375 |
switch (argv[i][1]) {
| 1376 |
case 'a':
| 1377 |
age = atof(argv[++i]);
| 1378 |
age_corr = 1;
| 1379 |
printf("age factor not supported any more \n");
| 1380 |
exit(1);
| 1381 |
break;
| 1382 |
case 'b':
| 1383 |
lum_thres = atof(argv[++i]);
| 1384 |
break;
| 1385 |
case 'c':
| 1386 |
checkfile = 1;
| 1387 |
strcpy(file_out, argv[++i]);
| 1388 |
break;
| 1389 |
case 'u':
| 1390 |
uniform_gs = 1;
| 1391 |
u_r = atof(argv[++i]);
| 1392 |
u_g = atof(argv[++i]);
| 1393 |
u_b = atof(argv[++i]);
| 1394 |
break;
| 1395 |
case 'r':
| 1396 |
max_angle = atof(argv[++i]);
| 1397 |
break;
| 1398 |
case 's':
| 1399 |
sgs = 1;
| 1400 |
break;
| 1401 |
case 'k':
| 1402 |
apply_disability = 1;
| 1403 |
disability_thresh = atof(argv[++i]);
| 1404 |
break;
| 1405 |
| 1406 |
case 'p':
| 1407 |
posindex_picture = 1;
| 1408 |
break;
| 1409 |
| 1410 |
case 'y':
| 1411 |
splithigh = 1;
| 1412 |
break;
| 1413 |
case 'x':
| 1414 |
splithigh = 0;
| 1415 |
break;
| 1416 |
case 'Y':
| 1417 |
splithigh = 1;
| 1418 |
limit = atof(argv[++i]);
| 1419 |
break;
| 1420 |
| 1421 |
case 'i':
| 1422 |
ext_vill = 1;
| 1423 |
E_vl_ext = atof(argv[++i]);
| 1424 |
break;
| 1425 |
case 'I':
| 1426 |
ext_vill = 1;
| 1427 |
fill = 1;
| 1428 |
| 1429 |
yfillmax = atoi(argv[++i]);
| 1430 |
yfillmin = atoi(argv[++i]);
| 1431 |
break;
| 1432 |
case 'd':
| 1433 |
detail_out = 1;
| 1434 |
break;
| 1435 |
case 'D':
| 1436 |
detail_out2 = 1;
| 1437 |
break;
| 1438 |
case 'm':
| 1439 |
set_lum_max = 1;
| 1440 |
lum_max = atof(argv[++i]);
| 1441 |
new_lum_max = atof(argv[++i]);
| 1442 |
strcpy(file_out2, argv[++i]);
| 1443 |
/* printf("max lum set to %f\n",new_lum_max);*/
| 1444 |
break;
| 1445 |
| 1446 |
case 'M':
| 1447 |
set_lum_max2 = 1;
| 1448 |
| 1449 |
| 1450 |
| 1451 |
| 1452 |
break;
| 1453 |
case 'n':
| 1454 |
non_cos_lb = 0;
| 1455 |
break;
| 1456 |
| 1457 |
case 't':
| 1458 |
task_lum = 1;
| 1459 |
xt = atoi(argv[++i]);
| 1460 |
yt = atoi(argv[++i]);
| 1461 |
omegat = atof(argv[++i]);
| 1462 |
task_color = 0;
| 1463 |
break;
| 1464 |
case 'T':
| 1465 |
task_lum = 1;
| 1466 |
| 1467 |
| 1468 |
/* omegat= DEG2RAD(atof(argv[++i]));*/
| 1469 |
| 1470 |
task_color = 1;
| 1471 |
break;
| 1472 |
case 'B':
| 1473 |
band_calc = 1;
| 1474 |
band_angle = atof(argv[++i]);
| 1475 |
band_color = 1;
| 1476 |
break;
| 1477 |
| 1478 |
| 1479 |
case 'w':
| 1480 |
a1 = atof(argv[++i]);
| 1481 |
a2 = atof(argv[++i]);
| 1482 |
a3 = atof(argv[++i]);
| 1483 |
a4 = atof(argv[++i]);
| 1484 |
a5 = atof(argv[++i]);
| 1485 |
c1 = atof(argv[++i]);
| 1486 |
c2 = atof(argv[++i]);
| 1487 |
c3 = atof(argv[++i]);
| 1488 |
break;
| 1489 |
case 'V':
| 1490 |
calc_vill = 1;
| 1491 |
break;
| 1492 |
case 'G':
| 1493 |
cut_view = 1;
| 1494 |
cut_view_type= atof(argv[++i]);
| 1495 |
break;
| 1496 |
case 'g':
| 1497 |
cut_view = 2;
| 1498 |
| 1499 |
break;
| 1500 |
| 1501 |
/*case 'v':
| 1502 |
printf("evalglare %s \n",version);
| 1503 |
exit(1); */
| 1504 |
| 1505 |
case '1':
| 1506 |
output = 1;
| 1507 |
break;
| 1508 |
| 1509 |
case 'v':
| 1510 |
if (argv[i][2] == '\0') {
| 1511 |
printf("%s \n",RELEASENAME);
| 1512 |
exit(1);
| 1513 |
| 1514 |
if (argv[i][2] != 'f')
| 1515 |
goto userr;
| 1516 |
rval = viewfile(argv[++i], &userview, NULL);
| 1517 |
if (rval < 0) {
| 1518 |
fprintf(stderr,
| 1519 |
"%s: cannot open view file \"%s\"\n",
| 1520 |
progname, argv[i]);
| 1521 |
exit(1);
| 1522 |
} else if (rval == 0) {
| 1523 |
fprintf(stderr,
| 1524 |
"%s: bad view file \"%s\"\n", progname, argv[i]);
| 1525 |
exit(1);
| 1526 |
} else {
| 1527 |
gotuserview++;
| 1528 |
| 1529 |
break;
| 1530 |
| 1531 |
| 1532 |
default:
| 1533 |
goto userr;
| 1534 |
| 1535 |
| 1536 |
| 1537 |
/*fast calculation, if gendgp_profile is used: No Vertical illuminance calculation, only dgp is calculated*/
| 1538 |
| 1539 |
if (output == 1 && ext_vill == 1) {
| 1540 |
calcfast=1;
| 1541 |
| 1542 |
| 1543 |
/* read picture file */
| 1544 |
if (i == argc) {
| 1545 |
SET_FILE_BINARY(stdin);
| 1546 |
FILE *fp = fdopen(fileno(stdin), "rb");
| 1547 |
if (!(fp)) {
| 1548 |
fprintf(stderr, "fdopen on stdin failed\n");
| 1549 |
return EXIT_FAILURE;
| 1550 |
| 1551 |
if (!(pict_read_fp(p, fp)))
| 1552 |
return EXIT_FAILURE;;
| 1553 |
} else {
| 1554 |
if (!pict_read(p, argv[i]))
| 1555 |
| 1556 |
| 1557 |
if (gotuserview) {
| 1558 |
if (p->valid_view)
| 1559 |
fprintf(stderr,
| 1560 |
"warning: overriding image view by commandline argument\n");
| 1561 |
if ((userview.horiz == 0) || (userview.vert == 0) || (userview.type == 0)) {
| 1562 |
fprintf(stderr, "error: if specified, a view must at least contain -vt -vv and -vh\n");
| 1563 |
| 1564 |
| 1565 |
p->view = userview;
| 1566 |
if (!(pict_update_view(p))) {
| 1567 |
fprintf(stderr, "error: invalid view specified");
| 1568 |
| 1569 |
| 1570 |
pict_update_evalglare_caches(p);
| 1571 |
} else if (!(p->valid_view)) {
| 1572 |
fprintf(stderr, "error: no valid view specified\n");
| 1573 |
| 1574 |
| 1575 |
| 1576 |
/* fprintf(stderr,"Picture read!");*/
| 1577 |
| 1578 |
| 1579 |
| 1580 |
pict_set_comment(p, cline);
| 1581 |
| 1582 |
if (p->view.type == VT_PAR) {
| 1583 |
fprintf(stderr, "wrong view type! must not be parallel ! \n");
| 1584 |
exit(1);
| 1585 |
| 1586 |
| 1587 |
| 1588 |
/* Check size of search radius */
| 1589 |
rmx = (pict_get_xsize(p) / 2);
| 1590 |
rmy = (pict_get_ysize(p) / 2);
| 1591 |
rx = (pict_get_xsize(p) / 2 + 10);
| 1592 |
ry = (pict_get_ysize(p) / 2 + 10);
| 1593 |
r_center =
| 1594 |
acos(DOT(pict_get_cached_dir(p, rmx, rmy),
| 1595 |
pict_get_cached_dir(p, rx, ry))) * 2 / 10;
| 1596 |
search_pix = max_angle / r_center;
| 1597 |
if (search_pix < 1.0) {
| 1598 |
fprintf(stderr,
| 1599 |
"warning: search radius less than 1 pixel! deactivating smoothing and peak extraction...\n");
| 1600 |
splithigh = 0;
| 1601 |
sgs = 0;
| 1602 |
| 1603 |
} else {
| 1604 |
if (search_pix < 3.0) {
| 1605 |
fprintf(stderr,
| 1606 |
"warning: search radius less than 3 pixels! -> %f \n",
| 1607 |
search_pix);
| 1608 |
| 1609 |
| 1610 |
| 1611 |
| 1612 |
/* Check task position */
| 1613 |
| 1614 |
if (task_lum == 1) {
| 1615 |
if (xt >= pict_get_xsize(p) || yt >= pict_get_ysize(p) || xt < 0
| 1616 |
|| yt < 0) {
| 1617 |
fprintf(stderr,
| 1618 |
"error: task position outside picture!! exit...");
| 1619 |
exit(1);
| 1620 |
| 1621 |
| 1622 |
| 1623 |
| 1624 |
/* printf("resolution: %dx%d\n",pict_get_xsize(p),pict_get_ysize(p)); */
| 1625 |
| 1626 |
sang = 0.0;
| 1627 |
E_v = 0.0;
| 1628 |
E_v_dir = 0.0;
| 1629 |
avlum = 0.0;
| 1630 |
pict_new_gli(p);
| 1631 |
igs = 0;
| 1632 |
| 1633 |
/* cut out GUTH field of view and exit without glare evaluation */
| 1634 |
if (cut_view==2) {
| 1635 |
if (cut_view_type==1) {
| 1636 |
cut_view_1(p);
| 1637 |
}else{
| 1638 |
| 1639 |
if (cut_view_type==2) {
| 1640 |
cut_view_2(p);
| 1641 |
}else{
| 1642 |
if (cut_view_type==3) {
| 1643 |
fprintf(stderr,"warning: pixel luminance is weighted by position index - do not use image for glare evaluations!!");
| 1644 |
cut_view_3(p);
| 1645 |
}else{
| 1646 |
fprintf(stderr,"error: no valid option for view cutting!!");
| 1647 |
exit(1);
| 1648 |
| 1649 |
| 1650 |
pict_write(p, file_out);
| 1651 |
exit(1); }
| 1652 |
| 1653 |
| 1654 |
| 1655 |
| 1656 |
| 1657 |
| 1658 |
/* write positionindex into checkfile and exit, activated by option -p */
| 1659 |
if (posindex_picture == 1) {
| 1660 |
for (x = 0; x < pict_get_xsize(p); x++)
| 1661 |
for (y = 0; y < pict_get_ysize(p); y++) {
| 1662 |
if (pict_get_hangle
| 1663 |
(p, x, y, p->view.vdir, p->view.vup, &ang)) {
| 1664 |
| 1665 |
lum =
| 1666 |
get_posindex(p, x, y,
| 1667 |
posindex_2) / WHTEFFICACY;
| 1668 |
| 1669 |
pict_get_color(p, x, y)[RED] = lum;
| 1670 |
pict_get_color(p, x, y)[GRN] = lum;
| 1671 |
pict_get_color(p, x, y)[BLU] = lum;
| 1672 |
lum_task = luminance(pict_get_color(p, x, y));
| 1673 |
/*printf("x,y,posindex=%i %i %f %f\n",x,y,lum*WHTEFFICACY,lum_task);*/
| 1674 |
| 1675 |
| 1676 |
| 1677 |
| 1678 |
exit(1);
| 1679 |
| 1680 |
| 1681 |
| 1682 |
/* calculation of vertical illuminance, average luminance, in case of filling activated-> fill picture */
| 1683 |
/* fill, if necessary from 0 to yfillmin */
| 1684 |
| 1685 |
if (fill == 1) {
| 1686 |
| 1687 |
for (y = yfillmin; y > 0; y = y - 1) {
| 1688 |
y1 = y + 1;
| 1689 |
lum = luminance(pict_get_color(p, x, y1));
| 1690 |
pict_get_color(p, x, y)[RED] = lum / 179.0;
| 1691 |
pict_get_color(p, x, y)[GRN] = lum / 179.0;
| 1692 |
pict_get_color(p, x, y)[BLU] = lum / 179.0;
| 1693 |
| 1694 |
| 1695 |
| 1696 |
if (calcfast == 0) {
| 1697 |
| 1698 |
| 1699 |
if (pict_get_hangle(p, x, y, p->view.vdir, p->view.vup, &ang)) {
| 1700 |
| 1701 |
| 1702 |
if (fill == 1 && y >= yfillmax) {
| 1703 |
y1 = y - 1;
| 1704 |
| 1705 |
| 1706 |
| 1707 |
| 1708 |
| 1709 |
| 1710 |
if (lum > abs_max) {
| 1711 |
abs_max = lum;
| 1712 |
| 1713 |
/* set luminance restriction, if -m is set */
| 1714 |
if (set_lum_max == 1 && lum >= lum_max) {
| 1715 |
pict_get_color(p, x, y)[RED] = new_lum_max / 179.0;
| 1716 |
pict_get_color(p, x, y)[GRN] = new_lum_max / 179.0;
| 1717 |
pict_get_color(p, x, y)[BLU] = new_lum_max / 179.0;
| 1718 |
/* printf("old lum, new lum %f %f \n",lum,luminance(pict_get_color(p,x,y))); */
| 1719 |
| 1720 |
| 1721 |
| 1722 |
if (set_lum_max2 == 1 && lum >= lum_max) {
| 1723 |
| 1724 |
E_v_contr +=
| 1725 |
DOT(p->view.vdir,
| 1726 |
| 1727 |
y)) * pict_get_omega(p,
| 1728 |
x,
| 1729 |
y)
| 1730 |
* lum;
| 1731 |
omega_cos_contr +=
| 1732 |
DOT(p->view.vdir,
| 1733 |
| 1734 |
| 1735 |
x,
| 1736 |
y)
| 1737 |
* 1;
| 1738 |
| 1739 |
| 1740 |
| 1741 |
sang += pict_get_omega(p, x, y);
| 1742 |
E_v +=
| 1743 |
DOT(p->view.vdir,
| 1744 |
| 1745 |
y)) * pict_get_omega(p, x,
| 1746 |
y) *
| 1747 |
lum;
| 1748 |
avlum +=
| 1749 |
| 1750 |
y) * luminance(pict_get_color(p, x,
| 1751 |
y));
| 1752 |
} else {
| 1753 |
pict_get_color(p, x, y)[RED] = 0.0;
| 1754 |
pict_get_color(p, x, y)[GRN] = 0.0;
| 1755 |
pict_get_color(p, x, y)[BLU] = 0.0;
| 1756 |
| 1757 |
| 1758 |
| 1759 |
| 1760 |
| 1761 |
if (set_lum_max2 == 1 && E_v_contr > 0 && (E_vl_ext - E_v) > 0) {
| 1762 |
| 1763 |
lum_ideal = (E_vl_ext - E_v + E_v_contr) / omega_cos_contr;
| 1764 |
if (lum_ideal > 0 && lum_ideal < setvalue) {
| 1765 |
setvalue = lum_ideal;
| 1766 |
| 1767 |
printf
| 1768 |
("change luminance values!! lum_ideal,setvalue,E_vl_ext,E_v,E_v_contr %f %f %f %f %f\n",
| 1769 |
lum_ideal, setvalue, E_vl_ext, E_v, E_v_contr);
| 1770 |
| 1771 |
| 1772 |
| 1773 |
| 1774 |
if (pict_get_hangle
| 1775 |
| 1776 |
| 1777 |
| 1778 |
| 1779 |
| 1780 |
| 1781 |
setvalue / 179.0;
| 1782 |
| 1783 |
setvalue / 179.0;
| 1784 |
| 1785 |
setvalue / 179.0;
| 1786 |
| 1787 |
| 1788 |
| 1789 |
| 1790 |
| 1791 |
| 1792 |
pict_write(p, file_out2);
| 1793 |
| 1794 |
| 1795 |
if (set_lum_max == 1) {
| 1796 |
| 1797 |
| 1798 |
| 1799 |
| 1800 |
if (calc_vill == 1) {
| 1801 |
printf("%f\n", E_v);
| 1802 |
exit(1);
| 1803 |
| 1804 |
}else{
| 1805 |
/* in fast calculation mode: ev=ev_ext and sang=2*pi */
| 1806 |
sang=2*3.14159265359;
| 1807 |
lum_task =E_vl_ext/sang;
| 1808 |
E_v=E_vl_ext;
| 1809 |
/* printf("calc fast!! %f %f\n", sang,lum_task);*/
| 1810 |
| 1811 |
| 1812 |
| 1813 |
| 1814 |
/* cut out GUTH field of view for glare evaluation */
| 1815 |
if (cut_view==1) {
| 1816 |
| 1817 |
cut_view_1(p);
| 1818 |
}else{
| 1819 |
| 1820 |
| 1821 |
cut_view_2(p);
| 1822 |
}else{
| 1823 |
| 1824 |
| 1825 |
cut_view_3(p);
| 1826 |
}else{
| 1827 |
| 1828 |
exit(1);
| 1829 |
| 1830 |
| 1831 |
| 1832 |
| 1833 |
| 1834 |
avlum = avlum / sang;
| 1835 |
lum_task = avlum;
| 1836 |
| 1837 |
/* if (ext_vill==1) {
| 1838 |
E_v=E_vl_ext;
| 1839 |
avlum=E_v/3.1415927;
| 1840 |
| 1841 |
| 1842 |
| 1843 |
lum_task = get_task_lum(p, xt, yt, omegat, task_color);
| 1844 |
| 1845 |
lum_source = lum_thres * lum_task;
| 1846 |
/* printf("Task Luminance=%f\n",lum_task);
| 1847 |
pict_write(p,"task.pic");*/
| 1848 |
| 1849 |
if (lum_thres > 100) {
| 1850 |
lum_source = lum_thres;
| 1851 |
| 1852 |
| 1853 |
/* printf("Ev, avlum, Omega_tot%f %f %f \n",E_v, avlum, sang); */
| 1854 |
| 1855 |
/* first glare source scan: find primary glare sources */
| 1856 |
| 1857 |
| 1858 |
| 1859 |
| 1860 |
| 1861 |
if (act_lum > lum_source) {
| 1862 |
if (act_lum >lum_total_max) {
| 1863 |
lum_total_max=act_lum;
| 1864 |
| 1865 |
| 1866 |
actual_igs =
| 1867 |
find_near_pgs(p, x, y, max_angle, 0, igs, 1);
| 1868 |
if (actual_igs == 0) {
| 1869 |
igs = igs + 1;
| 1870 |
pict_new_gli(p);
| 1871 |
pict_get_lum_min(p, igs) = HUGE_VAL;
| 1872 |
pict_get_Eglare(p,igs) = 0.0;
| 1873 |
pict_get_Dglare(p,igs) = 0.0;
| 1874 |
actual_igs = igs;
| 1875 |
| 1876 |
icol = setglcolor(p, x, y, actual_igs, uniform_gs, u_r, u_g , u_b);
| 1877 |
pict_get_gsn(p, x, y) = actual_igs;
| 1878 |
pict_get_pgs(p, x, y) = 1;
| 1879 |
add_pixel_to_gs(p, x, y, actual_igs);
| 1880 |
| 1881 |
} else {
| 1882 |
pict_get_pgs(p, x, y) = 0;
| 1883 |
| 1884 |
| 1885 |
| 1886 |
| 1887 |
/* pict_write(p,"firstscan.pic"); */
| 1888 |
| 1889 |
if (calcfast == 1 ) {
| 1890 |
skip_second_scan=1;
| 1891 |
| 1892 |
| 1893 |
/* second glare source scan: combine glare sources facing each other */
| 1894 |
change = 1;
| 1895 |
while (change == 1 && skip_second_scan==0) {
| 1896 |
change = 0;
| 1897 |
| 1898 |
| 1899 |
before_igs = pict_get_gsn(p, x, y);
| 1900 |
if (pict_get_hangle
| 1901 |
| 1902 |
if (pict_is_validpixel(p, x, y) && before_igs > 0) {
| 1903 |
actual_igs =
| 1904 |
find_near_pgs(p, x, y, max_angle, before_igs,
| 1905 |
igs, 1);
| 1906 |
if (!(actual_igs == before_igs)) {
| 1907 |
change = 1;
| 1908 |
| 1909 |
if (before_igs > 0) {
| 1910 |
actual_igs = pict_get_gsn(p, x, y);
| 1911 |
| 1912 |
| 1913 |
| 1914 |
| 1915 |
| 1916 |
| 1917 |
/* pict_write(p,"secondscan.pic");*/
| 1918 |
| 1919 |
| 1920 |
| 1921 |
/*smoothing: add secondary glare sources */
| 1922 |
i_max = igs;
| 1923 |
if (sgs == 1) {
| 1924 |
| 1925 |
/* simplified search radius: constant for entire picture, alway circle not an angle due to performance */
| 1926 |
| 1927 |
| 1928 |
| 1929 |
| 1930 |
r_center =
| 1931 |
| 1932 |
| 1933 |
search_pix = max_angle / r_center / 1.75;
| 1934 |
| 1935 |
for (x = 0; x < pict_get_xsize(p); x++) {
| 1936 |
| 1937 |
if (pict_get_hangle
| 1938 |
| 1939 |
| 1940 |
&& pict_get_gsn(p, x, y) == 0) {
| 1941 |
for (i = 1; i <= i_max; i++) {
| 1942 |
| 1943 |
| 1944 |
add_secondary_gs(p, x, y, search_pix, i, uniform_gs, u_r, u_g , u_b);
| 1945 |
| 1946 |
| 1947 |
| 1948 |
| 1949 |
| 1950 |
| 1951 |
| 1952 |
| 1953 |
| 1954 |
| 1955 |
/* extract extremes from glare sources to extra glare source */
| 1956 |
if (splithigh == 1 && lum_total_max>limit) {
| 1957 |
| 1958 |
r_split = max_angle / 2.0;
| 1959 |
for (i = 0; i <= i_max; i++) {
| 1960 |
| 1961 |
| 1962 |
l_max = pict_get_lum_max(p, i);
| 1963 |
i_splitstart = igs + 1;
| 1964 |
if (l_max >= limit) {
| 1965 |
| 1966 |
| 1967 |
if (pict_get_hangle
| 1968 |
| 1969 |
| 1970 |
| 1971 |
&& luminance(pict_get_color(p, x, y))
| 1972 |
>= limit
| 1973 |
&& pict_get_gsn(p, x, y) == i) {
| 1974 |
if (i_splitstart == (igs + 1)) {
| 1975 |
igs = igs + 1;
| 1976 |
pict_new_gli(p);
| 1977 |
| 1978 |
| 1979 |
| 1980 |
99999999999999.999;
| 1981 |
i_split = igs;
| 1982 |
} else {
| 1983 |
i_split =
| 1984 |
find_split(p, x, y, r_split,
| 1985 |
i_splitstart, igs);
| 1986 |
| 1987 |
if (i_split == 0) {
| 1988 |
igs = igs + 1;
| 1989 |
pict_new_gli(p);
| 1990 |
| 1991 |
| 1992 |
| 1993 |
99999999999999.999;
| 1994 |
i_split = igs;
| 1995 |
| 1996 |
split_pixel_from_gs(p, x, y, i_split, uniform_gs, u_r, u_g , u_b);
| 1997 |
| 1998 |
| 1999 |
| 2000 |
| 2001 |
| 2002 |
| 2003 |
change = 1;
| 2004 |
while (change == 1) {
| 2005 |
change = 0;
| 2006 |
| 2007 |
| 2008 |
| 2009 |
if (before_igs >= i_splitstart) {
| 2010 |
if (pict_get_hangle
| 2011 |
| 2012 |
&ang)) {
| 2013 |
| 2014 |
| 2015 |
actual_igs =
| 2016 |
| 2017 |
max_angle,
| 2018 |
before_igs, igs,
| 2019 |
i_splitstart);
| 2020 |
| 2021 |
change = 1;
| 2022 |
| 2023 |
| 2024 |
actual_igs =
| 2025 |
| 2026 |
icol =
| 2027 |
setglcolor(p, x, y,
| 2028 |
| 2029 |
| 2030 |
| 2031 |
| 2032 |
| 2033 |
| 2034 |
| 2035 |
| 2036 |
| 2037 |
| 2038 |
| 2039 |
| 2040 |
| 2041 |
| 2042 |
| 2043 |
/* calculation of direct vertical illuminance for CGI and for disability glare*/
| 2044 |
| 2045 |
| 2046 |
| 2047 |
| 2048 |
| 2049 |
| 2050 |
| 2051 |
if (pict_get_gsn(p, x, y) > 0) {
| 2052 |
pict_get_Eglare(p,pict_get_gsn(p, x, y)) +=
| 2053 |
DOT(p->view.vdir, pict_get_cached_dir(p, x, y))
| 2054 |
* pict_get_omega(p, x, y)
| 2055 |
* luminance(pict_get_color(p, x, y));
| 2056 |
E_v_dir +=
| 2057 |
| 2058 |
| 2059 |
| 2060 |
| 2061 |
| 2062 |
| 2063 |
| 2064 |
lum_backg_cos = (E_v - E_v_dir) / 3.1415927;
| 2065 |
lum_backg = lum_backg_cos;
| 2066 |
| 2067 |
/* calc of band luminance if applied */
| 2068 |
if (band_calc == 1) {
| 2069 |
band_avlum=get_band_lum( p, band_angle, band_color);
| 2070 |
| 2071 |
| 2072 |
/*printf("total number of glare sources: %i\n",igs); */
| 2073 |
lum_sources = 0;
| 2074 |
omega_sources = 0;
| 2075 |
for (x = 0; x <= igs; x++) {
| 2076 |
lum_sources += pict_get_av_lum(p, x) * pict_get_av_omega(p, x);
| 2077 |
omega_sources += pict_get_av_omega(p, x);
| 2078 |
| 2079 |
if (non_cos_lb == 1) {
| 2080 |
lum_backg =
| 2081 |
(sang * avlum - lum_sources) / (sang - omega_sources);
| 2082 |
| 2083 |
/* print detailed output */
| 2084 |
if (detail_out == 1) {
| 2085 |
i = 0;
| 2086 |
| 2087 |
/* resorting glare source numbers */
| 2088 |
if (pict_get_npix(p, x) > 0) {
| 2089 |
i = i + 1;
| 2090 |
| 2091 |
| 2092 |
| 2093 |
| 2094 |
| 2095 |
printf
| 2096 |
("%i No pixels x-pos y-pos L_s Omega_s Posindx L_b L_t E_vert Edir Max_Lum Sigma xdir ydir zdir Eglare_cie Lveil_cie \n",
| 2097 |
i);
| 2098 |
if (i == 0) {
| 2099 |
printf("%i %f %f %f %f %.10f %f %f %f %f %f %f\n", i, 0.0, 0.0,
| 2100 |
0.0, 0.0, 0.0, 0.0, lum_backg, lum_task, E_v, E_v_dir,
| 2101 |
abs_max);
| 2102 |
| 2103 |
} else {
| 2104 |
i = 0;
| 2105 |
| 2106 |
| 2107 |
i = i + 1;
| 2108 |
pict_get_sigma(p, pict_get_av_posx(p, x),
| 2109 |
pict_get_av_posy(p, x), p->view.vdir,
| 2110 |
| 2111 |
| 2112 |
x2=pict_get_av_posx(p, x);
| 2113 |
y2=pict_get_av_posy(p, x);
| 2114 |
teta = 180.0 / 3.1415927 * acos(DOT(p->view.vdir, pict_get_cached_dir(p, x2, y2)));
| 2115 |
Lveil_cie = 10*pict_get_Eglare(p,x)/(teta*teta+0.0000000000000001);
| 2116 |
| 2117 |
if (apply_disability == 1 && Lveil_cie <=disability_thresh) {
| 2118 |
Lveil_cie =0 ;
| 2119 |
| 2120 |
Lveil_cie_sum = Lveil_cie_sum + Lveil_cie;
| 2121 |
printf("%i %f %f %f %f %.10f %f %f %f %f %f %f %f %f %f %f %f %f %f\n",
| 2122 |
i, pict_get_npix(p, x), pict_get_av_posx(p, x),
| 2123 |
pict_get_ysize(p) - pict_get_av_posy(p, x),
| 2124 |
pict_get_av_lum(p, x), pict_get_av_omega(p, x),
| 2125 |
get_posindex(p, pict_get_av_posx(p, x),
| 2126 |
| 2127 |
posindex_2), lum_backg, lum_task,
| 2128 |
E_v, E_v_dir, abs_max, sigma * 180 / 3.1415927
| 2129 |
,pict_get_cached_dir(p, x2,y2)[0],pict_get_cached_dir(p, x2,y2)[1],pict_get_cached_dir(p, x2,y2)[2],pict_get_Eglare(p,x),Lveil_cie,teta
| 2130 |
| 2131 |
| 2132 |
| 2133 |
| 2134 |
| 2135 |
| 2136 |
| 2137 |
| 2138 |
| 2139 |
/* calculation of indicees */
| 2140 |
| 2141 |
/* check vertical illuminance range */
| 2142 |
E_v2 = E_v;
| 2143 |
| 2144 |
if (E_v2 < 100) {
| 2145 |
fprintf(stderr,
| 2146 |
"Notice: Vertical illuminance is below 100 lux !!\n");
| 2147 |
| 2148 |
dgp =
| 2149 |
get_dgp(p, E_v2, igs, a1, a2, a3, a4, a5, c1, c2, c3, posindex_2);
| 2150 |
/* low light correction */
| 2151 |
if (E_v < 1000) {
| 2152 |
low_light_corr=1.0*exp(0.024*E_v-4)/(1+exp(0.024*E_v-4));} else {low_light_corr=1.0 ;}
| 2153 |
dgp =low_light_corr*dgp;
| 2154 |
| 2155 |
/* age correction */
| 2156 |
| 2157 |
if (age_corr == 1) {
| 2158 |
age_corr_factor=1.0/(1.1-0.5*age/100.0);
| 2159 |
| 2160 |
dgp =age_corr_factor*dgp;
| 2161 |
| 2162 |
| 2163 |
if (ext_vill == 1) {
| 2164 |
if (E_vl_ext < 100) {
| 2165 |
fprintf(stderr,
| 2166 |
| 2167 |
| 2168 |
| 2169 |
| 2170 |
| 2171 |
dgi = get_dgi(p, lum_backg, igs, posindex_2);
| 2172 |
ugr = get_ugr(p, lum_backg, igs, posindex_2);
| 2173 |
cgi = get_cgi(p, E_v, E_v_dir, igs, posindex_2);
| 2174 |
vcp = get_vcp(p, avlum, igs, posindex_2);
| 2175 |
Lveil = get_disability(p, avlum, igs);
| 2176 |
| 2177 |
/* check dgp range */
| 2178 |
if (dgp <= 0.2) {
| 2179 |
fprintf(stderr,
| 2180 |
"Notice: Low brightness scene. dgp below 0.2! dgp might underestimate glare sources\n");
| 2181 |
| 2182 |
if (E_v < 380) {
| 2183 |
fprintf(stderr,
| 2184 |
"Notice: Low brightness scene. Vertical illuminance less than 380 lux! dgp might underestimate glare sources\n");
| 2185 |
| 2186 |
| 2187 |
| 2188 |
| 2189 |
if (output == 0) {
| 2190 |
| 2191 |
| 2192 |
dgp_ext =
| 2193 |
get_dgp(p, E_vl_ext, igs, a1, a2, a3, a4, a5, c1, c2, c3,
| 2194 |
posindex_2);
| 2195 |
dgp = dgp_ext;
| 2196 |
if (E_vl_ext < 1000) {
| 2197 |
low_light_corr=1.0*exp(0.024*E_vl_ext-4)/(1+exp(0.024*E_vl_ext-4));} else {low_light_corr=1.0 ;}
| 2198 |
| 2199 |
| 2200 |
| 2201 |
| 2202 |
printf
| 2203 |
("dgp,av_lum,E_v,lum_backg,E_v_dir,dgi,ugr,vcp,cgi,lum_sources,omega_sources,Lveil,Lveil_cie,band_avlum: %f %f %f %f %f %f %f %f %f %f %f %f %f %f \n",
| 2204 |
dgp, avlum, E_v, lum_backg, E_v_dir, dgi, ugr, vcp, cgi,
| 2205 |
lum_sources / omega_sources, omega_sources, Lveil,Lveil_cie_sum,band_avlum);
| 2206 |
} else {
| 2207 |
if (detail_out2 == 1) {
| 2208 |
| 2209 |
printf
| 2210 |
("dgp,dgi,ugr,vcp,cgi,dgp_ext,Ev_calc,abs_max,Lveil: %f %f %f %f %f %f %f %f %f \n",
| 2211 |
dgp, dgi, ugr, vcp, cgi, dgp_ext, E_v, abs_max,
| 2212 |
Lveil);
| 2213 |
| 2214 |
} else {
| 2215 |
| 2216 |
dgp_ext = get_dgp(p, E_vl_ext, igs, a1, a2, a3, a4, a5, c1, c2, c3,posindex_2);
| 2217 |
| 2218 |
| 2219 |
| 2220 |
dgp =low_light_corr*dgp_ext;
| 2221 |
| 2222 |
| 2223 |
printf("dgp,dgi,ugr,vcp,cgi,Lveil: %f %f %f %f %f %f \n",
| 2224 |
dgp, dgi, ugr, vcp, cgi, Lveil);
| 2225 |
| 2226 |
| 2227 |
| 2228 |
} else {
| 2229 |
dgp_ext =
| 2230 |
| 2231 |
posindex_2);
| 2232 |
dgp = dgp_ext;
| 2233 |
| 2234 |
low_light_corr=1.0*exp(0.024*E_vl_ext-4)/(1+exp(0.024*E_vl_ext-4)); } else {low_light_corr=1.0 ;}
| 2235 |
| 2236 |
| 2237 |
printf("%f\n", dgp);
| 2238 |
| 2239 |
| 2240 |
| 2241 |
/*printf("lowlight=%f\n", low_light_corr); */
| 2242 |
| 2243 |
| 2244 |
/* printf("hallo \n");
| 2245 |
| 2246 |
| 2247 |
| 2248 |
| 2249 |
coloring of disability glare sources red, remove all other colors
| 2250 |
| 2251 |
| 2252 |
| 2253 |
this function was removed because of bugs....
| 2254 |
has to be re-written from scratch....
| 2255 |
| 2256 |
| 2257 |
| 2258 |
| 2259 |
| 2260 |
| 2261 |
| 2262 |
| 2263 |
| 2264 |
| 2265 |
| 2266 |
/*output */
| 2267 |
if (checkfile == 1) {
| 2268 |
| 2269 |
| 2270 |
| 2271 |
| 2272 |
| 2273 |
return EXIT_SUCCESS;
| 2274 |
exit(0);
| 2275 |
| 2276 |
userr:
| 2277 |
fprintf(stderr,
| 2278 |
"Usage: %s [-s][-d][-c picture][-t xpos ypos angle] [-T xpos ypos angle] [-b fact] [-r angle] [-y] [-Y lum] [-i Ev] [-I Ev ymax ymin] [-v] picfile\n",
| 2279 |
progname);
| 2280 |
exit(1);
| 2281 |
| 2282 |
| 2283 |
| 2284 |
| 2285 |
#endif
