--- ray/src/util/evalglare.c 2017/08/12 15:11:09 2.7 +++ ray/src/util/evalglare.c 2020/06/30 15:57:30 2.11 @@ -1,10 +1,10 @@ #ifndef lint -static const char RCSid[] = "$Id: evalglare.c,v 2.7 2017/08/12 15:11:09 greg Exp $"; +static const char RCSid[] = "$Id: evalglare.c,v 2.11 2020/06/30 15:57:30 greg Exp $"; #endif -/* EVALGLARE V2.00 +/* EVALGLARE V2.10 * Evalglare Software License, Version 2.0 * - * Copyright (c) 1995 - 2016 Fraunhofer ISE, EPFL. + * Copyright (c) 1995 - 2020 Fraunhofer ISE, EPFL. * All rights reserved. * * @@ -318,17 +318,48 @@ changed masking threshold to 0.05 cd/m2 */ /* evalglare.c, v2.02 2017/02/28 change of warning message, when invalid exposure setting is found. Reason: tab removal is not in all cases the right measure - it depends which tool caused the invalid exposure entry */ -/* evalglare.c, v2.03 2017/08/12 ad of -O option - disk replacement by providing luminance, not documented -remove some minor memory leakages, clean up initialization by C. Reetz +/* evalglare.c, v2.03 2017/08/04 ad of -O option - disk replacement by providing luminance, not documented */ +/* evalglare.c, v2.04 2017/08/04 adding -q option: use of Ev/pi as background luminance. not documented. no combination with -n option!!! + */ - -#ifndef EVALGLARE +/* evalglare.c, v2.05 2018/08/28 change of the -q option for the choice of the background luminance calculation mode: 0: CIE method (Ev-Edir)/pi, 1: mathematical correct average background luminance, 2: Ev/pi. +change of default options: +- cosinus weighted calculation of the background luminance (according to CIE) is now default. +- absolute threshold for the glare source detection is now default (2000cd/m2), based on study of C. Pierson + */ + +/* evalglare.c, v2.06 2018/08/29 +change of default value of multiplier b to 5.0, if task options (-t or -T ) are activated AND -b NOT used. To be downward compatible when using the task method. + */ + +/* evalglare.c, v2.07 2018/11/17 +bugfix: correction of error in the equations of PGSV_con and PGSV_sat +all three PGSV equations are calculated now +illuminance from the masking area (E_v_mask) is also printed +bugfix: in VCPs error fuction equation, value of 6.347 replaced by 6.374 + */ + +/* evalglare.c, v2.08 2018/11/27 +bugfix: checkroutine for same image size for the masking corrected + */ + +/* evalglare.c, v2.09 2019/01/18 +calculate "illuminance-contribution of zones" +-switch to turn off low-light correction: 4 + */ + + /* evalglare.c, v2.10 2019/07/30, 2020/06/25 +-add multiimage-mode for annual glare evaluation -Q +-extra output for multiimage mode +2020/06/22 - added Ev contribution from each glare source as output to the multiimage mode +-switch for correction modes (-C), value of 0 switches off all corrections + */ + #define EVALGLARE -#endif #define PROGNAME "evalglare" -#define VERSION "2.03 release 12.08.2017 by EPFL, J.Wienold" +#define VERSION "2.10 release 25.06.2020 by EPFL, J.Wienold" #define RELEASENAME PROGNAME " " VERSION @@ -739,7 +770,7 @@ void add_secondary_gs(pict * p, int x, int y, float r, void split_pixel_from_gs(pict * p, int x, int y, int new_gsn, int uniform_gs, double u_r, double u_g , double u_b) { int old_gsn, icol; - double old_av_posx, old_av_posy, old_av_lum, old_omega, act_omega, + double old_av_posx, old_av_posy, old_av_lum, old_omega, act_omega, delta_E, new_omega, act_lum; @@ -751,6 +782,9 @@ void split_pixel_from_gs(pict * p, int x, int y, int n old_av_posx = pict_get_av_posx(p, old_gsn); old_av_posy = pict_get_av_posy(p, old_gsn); old_omega = pict_get_av_omega(p, old_gsn); + + + new_omega = old_omega - act_omega; pict_get_av_omega(p, old_gsn) = new_omega; @@ -768,6 +802,9 @@ void split_pixel_from_gs(pict * p, int x, int y, int n add_pixel_to_gs(p, x, y, new_gsn); + + + /* color pixel of new gs */ /* icol = setglcolor(p, x, y, new_gsn, uniform_gs, u_r, u_g , u_b); */ @@ -1180,7 +1217,7 @@ float get_vcp(float dgr ) { float vcp; - vcp = 50 * erf((6.347 - 1.3227 * log(dgr)) / 1.414213562373) + 50; + vcp = 50 * erf((6.374 - 1.3227 * log(dgr)) / 1.414213562373) + 50; if (dgr > 750) { vcp = 0; } @@ -1351,18 +1388,23 @@ float get_cgi(pict * p, double E_v, double E_v_dir, in return cgi; } -/* subroutine for the calculation of the PGSV; is only applied, when masking is done, since it refers only to the window. Important: masking area must be the window! */ -float get_pgsv(double E_v, double E_mask,double omega_mask,double lum_mask_av) + + +/* subroutine for the calculation of the PGSV_con; is only applied, when masking is done, since it refers only to the window. Important: masking area must be the window! */ +float get_pgsv_con(double E_v, double E_mask,double omega_mask,double lum_mask_av, double Lavg) { - float pgsv; + float pgsv_con; double Lb; - Lb = (E_v-E_mask)/1.414213562373; +/* Lb = (E_v-E_mask)/3.14159265359; */ +/* Lb = (2*E_v-lum_mask_av*omega_mask)/(2*3.14159265359-omega_mask); */ + Lb = (2*3.14159265359*Lavg-lum_mask_av*omega_mask)/(2*3.14159265359-omega_mask); - pgsv =3.2*log10(lum_mask_av)-0.64*log10(omega_mask)+(0.79*log10(omega_mask)-0.61)*log10(Lb)-8.2 ; + pgsv_con =3.2*log10(lum_mask_av)-0.64*log10(omega_mask)+(0.79*log10(omega_mask)-0.61)*log10(Lb)-8.2 ; - return pgsv; + + return pgsv_con; } /* subroutine for the calculation of the PGSV_saturation; is only applied, when masking is done, since it refers only to the window. Important: masking area must be the window! */ @@ -1370,15 +1412,38 @@ float get_pgsv_sat(double E_v) { float pgsv_sat; - pgsv_sat =3.3-(0.57+3.3)/pow((1+E_v/1.414213562373/1250),1.7); + pgsv_sat =3.3-(0.57+3.3)/(1+pow(E_v/3.14159265359/1250,1.7)); return pgsv_sat; } +/* subroutine for the calculation of the PGSV; is only applied, when masking is done, since it refers only to the window. Important: masking area must be the window! */ +float get_pgsv(double E_v, double E_mask,double omega_mask,double lum_mask_av,double Ltask, double Lavg) +{ + float pgsv; + double Lb; +/* Lb = (E_v-E_mask)/3.14159265359; */ +/* Lb = (2*E_v-lum_mask_av*omega_mask)/(2*3.14159265359-omega_mask); */ + Lb = (2*3.14159265359*Lavg-lum_mask_av*omega_mask)/(2*3.14159265359-omega_mask); + + if (Lb==0.0 ) { + fprintf(stderr, " warning: Background luminance is 0 or masking area = full image! pgsv cannot be calculated (set to -99)!!\n"); + pgsv=-99; + }else{ + if ( (lum_mask_av/Lb) > (E_v/(3.14159265359*Ltask))) { + pgsv=get_pgsv_con(E_v,E_mask,omega_mask,lum_mask_av, Lavg); + }else{ + pgsv=get_pgsv_sat(E_v) ; + }} + return pgsv; +} + + + #ifdef EVALGLARE @@ -1388,18 +1453,19 @@ float get_pgsv_sat(double E_v) int main(int argc, char **argv) { - #define CLINEMAX 4095 /* memory allocated for command line string */ + #define CLINEMAX 999999999 /* memory allocated for command line string */ pict *p = pict_create(); pict *pm = pict_create(); - int skip_second_scan,calcfast,age_corr,cut_view,cut_view_type,calc_vill, output, detail_out2, x1,y1, fill, yfillmax, yfillmin, - ext_vill, set_lum_max, set_lum_max2, img_corr,x_disk,y_disk,task_color, i_splitstart,zones,act_gsn,splitgs, - i_split, posindex_2, task_lum, checkfile, rval, i, i_max, x, y,x2,y2,x_zone,y_zone, i_z1, i_z2, + pict *pcoeff = pict_create(); + int lowlight,skip_second_scan,calcfast,age_corr,cut_view,cut_view_type,calc_vill, output, detail_out2, x1,y1, fill, yfillmax, yfillmin, + ext_vill, set_lum_max, set_lum_max2, img_corr,x_disk,y_disk,task_color, i_splitstart,zones,act_gsn,splitgs,j,multi_image_mode, + i_split, posindex_2, task_lum, checkfile, rval, i, i_max, x, y,x2,y2,x_zone,y_zone, i_z1, i_z2, thres_activate,num_images,xmap,ymap, igs, actual_igs, lastpixelwas_gs, icol, xt, yt, change,checkpixels, before_igs, sgs, splithigh,uniform_gs,x_max, y_max,y_mid, - detail_out, posindex_picture, non_cos_lb, rx, ry, rmx,rmy,apply_disability,band_calc,band_color,masking,i_mask,no_glaresources,force; + detail_out, posindex_picture, non_cos_lb, rx, ry,lastpixelwas_peak, rmx,rmy,apply_disability,band_calc,band_color,masking,i_mask,no_glaresources,force; double LUM_replace,lum_total_max,age_corr_factor,age,dgp_ext,dgp,low_light_corr,omega_cos_contr, setvalue, lum_ideal, E_v_contr, sigma,om,delta_E, - E_vl_ext, lum_max, new_lum_max, r_center, ugp, ugr_exp, dgi_mod,lum_a, pgsv,E_v_mask,pgsv_sat,angle_disk,dist,n_corner_px,zero_corner_px, + E_vl_ext, lum_max, new_lum_max, r_center, ugp, ugr_exp, dgi_mod,lum_a, E_v_mask,angle_disk,dist,n_corner_px,zero_corner_px, search_pix, a1, a2, a3, a4, a5, c3, c1, c2, r_split, max_angle,r_actual,lum_actual,dir_ill, - omegat, sang, E_v, E_v2, E_v_dir, avlum, act_lum, ang, angle_z1, angle_z2,per_95_band,per_75_band,pos, + omegat, sang,Ez1,Ez2, E_v, E_v2, E_v_dir, avlum, act_lum, ang, angle_z1, angle_z2,per_95_band,per_75_band,pos, l_max, lum_backg, lum_backg_cos, omega_sources, lum_sources,per_75_mask,per_95_mask,per_75_z1,per_95_z1,per_75_z2,per_95_z2, lum, lum_source,teta,Lveil_cie,Lveil_cie_sum,disability_thresh,u_r,u_g,u_b,band_angle,band_avlum, lum_mask[1],lum_mask_av,lum_mask_std[1],lum_mask_median[1],omega_mask,bbox[2], @@ -1407,52 +1473,54 @@ int main(int argc, char **argv) lum_z1[1],lum_z1_av,lum_z1_std[1],lum_z1_median[1],omega_z1,bbox_z1[2], lum_z2[1],lum_z2_av,lum_z2_std[1],lum_z2_median[1],omega_z2,bbox_z2[2], lum_pos[1],lum_nopos_median[1],lum_pos_median[1],lum_pos2_median[1],lum_pos_mean,lum_pos2_mean; - float lum_task, lum_thres, dgi, vcp, cgi, ugr, limit, dgr, + float lum_task, lum_thres, dgi, vcp, cgi, ugr, limit, dgr,pgsv ,pgsv_sat,pgsv_con, abs_max, Lveil; - char maskfile[500],file_out[500], file_out2[500], version[500]; - char *cline = NULL; + char maskfile[500],file_out[500], file_out2[500], version[500],correction_type[500]; + char *cline; + char** temp_image_name; + int *x_temp_img, *y_temp_img; VIEW userview = STDVIEW; int gotuserview = 0; - struct muc_rvar* s_mask = NULL; - struct muc_rvar* s_band = NULL; - struct muc_rvar* s_z1 = NULL; - struct muc_rvar* s_z2 = NULL; - struct muc_rvar* s_noposweight = NULL; - struct muc_rvar* s_posweight = NULL; - struct muc_rvar* s_posweight2 = NULL; - - // initializing variables .... - Lveil = lum_backg_cos = 0; - dgi = ugr = ugp = ugr_exp = dgi_mod = cgi = dgr = vcp = 0.0; - lum_task = lum_thres = limit = 0; + + struct muc_rvar* s_mask; s_mask = muc_rvar_create(); - muc_rvar_set_dim(s_mask, 1); + muc_rvar_set_dim(s_mask, 1); muc_rvar_clear(s_mask); + struct muc_rvar* s_band; s_band = muc_rvar_create(); - muc_rvar_set_dim(s_band, 1); + muc_rvar_set_dim(s_band, 1); muc_rvar_clear(s_band); + struct muc_rvar* s_z1; s_z1 = muc_rvar_create(); - muc_rvar_set_dim(s_z1, 1); + muc_rvar_set_dim(s_z1, 1); muc_rvar_clear(s_z1); + struct muc_rvar* s_z2; s_z2 = muc_rvar_create(); - muc_rvar_set_dim(s_z2, 1); + muc_rvar_set_dim(s_z2, 1); muc_rvar_clear(s_z2); + struct muc_rvar* s_noposweight; s_noposweight = muc_rvar_create(); - muc_rvar_set_dim(s_noposweight, 1); + muc_rvar_set_dim(s_noposweight, 1); muc_rvar_clear(s_noposweight); + struct muc_rvar* s_posweight; s_posweight = muc_rvar_create(); - muc_rvar_set_dim(s_posweight, 1); + muc_rvar_set_dim(s_posweight, 1); muc_rvar_clear(s_posweight); + struct muc_rvar* s_posweight2; s_posweight2 = muc_rvar_create(); - muc_rvar_set_dim(s_posweight2, 1); + muc_rvar_set_dim(s_posweight2, 1); muc_rvar_clear(s_posweight2); /*set required user view parameters to invalid values*/ - dir_ill=0.0; + lowlight=1; + multi_image_mode=0; + lastpixelwas_peak=0; + num_images=0; + dir_ill=0.0; delta_E=0.0; no_glaresources=0; n_corner_px=0; @@ -1474,8 +1542,11 @@ int main(int argc, char **argv) lum_band_av = 0.0; omega_band = 0.0; pgsv = 0.0 ; + pgsv_con = 0.0 ; pgsv_sat = 0.0 ; E_v_mask = 0.0; + Ez1 = 0.0; + Ez2 = 0.0; lum_z1_av = 0.0; omega_z1 = 0.0; lum_z2_av = 0.0; @@ -1515,7 +1586,8 @@ int main(int argc, char **argv) omega_cos_contr = 0.0; lum_ideal = 0.0; max_angle = 0.2; - lum_thres = 5.0; + lum_thres = 2000.0; + lum_task = 0.0; task_lum = 0; sgs = 0; splithigh = 1; @@ -1533,7 +1605,7 @@ int main(int argc, char **argv) c1 = 5.87e-05; c2 = 0.092; c3 = 0.159; - non_cos_lb = 1; + non_cos_lb = 0; posindex_2 = 0; task_color = 0; limit = 50000.0; @@ -1556,9 +1628,10 @@ int main(int argc, char **argv) i_mask=0; actual_igs=0; LUM_replace=0; + thres_activate=0; /* command line for output picture*/ - cline = (char *) malloc(CLINEMAX+1); + cline = (char *) malloc(CLINEMAX+100); cline[0] = '\0'; for (i = 0; i < argc; i++) { /* fprintf(stderr, "%d %d \n",i,strlen(argv[i]));*/ @@ -1606,6 +1679,8 @@ int main(int argc, char **argv) break; case 'b': lum_thres = atof(argv[++i]); + lum_source =lum_thres; + thres_activate = 1; break; case 'c': checkfile = 1; @@ -1706,9 +1781,13 @@ int main(int argc, char **argv) break; - case 'n': +/* deactivated case 'n': non_cos_lb = 0; break; +*/ + case 'q': + non_cos_lb = atoi(argv[++i]); + break; case 't': task_lum = 1; @@ -1773,7 +1852,25 @@ int main(int argc, char **argv) /*case 'v': printf("evalglare %s \n",version); exit(1); */ + case 'C': + strcpy(correction_type,argv[++i]); + + if (!strcmp(correction_type,"l-") ){ + /* printf("low light off!\n"); */ + lowlight = 0; } + if (!strcmp(correction_type,"l+") ){ + /* printf("low light on!\n"); */ + lowlight = 1; } + if (!strcmp(correction_type,"0") ){ + /* printf("all corrections off!\n"); */ + lowlight = 0; } + + break; + /*case 'v': + printf("evalglare %s \n",version); + exit(1); */ + case '1': output = 1; break; @@ -1781,7 +1878,33 @@ int main(int argc, char **argv) output = 2; dir_ill = atof(argv[++i]); break; - + case '3': + output = 3; + break; + case '4': + lowlight = 0; + break; + case 'Q': + multi_image_mode=1; + output= 3; + calcfast=1; + num_images =atoi(argv[++i]); + temp_image_name = malloc(sizeof(char*)*num_images); + + x_temp_img=(int *) malloc(sizeof(int) * num_images); + y_temp_img=(int *) malloc(sizeof(int) * num_images); + + + /* iterate through all images and allocate 256 characters to each: */ + for (j = 0; j < num_images; j++) { + temp_image_name[j] = malloc(256*sizeof(char)); + strcpy(temp_image_name[j], argv[++i]); + x_temp_img[j] = atoi(argv[++i]); + y_temp_img[j] = atoi(argv[++i]); + } + + + break; case 'v': if (argv[i][2] == '\0') { printf("%s \n",RELEASENAME); @@ -1810,6 +1933,11 @@ int main(int argc, char **argv) } } +/* set multiplier for task method to 5, if not specified */ + +if ( task_lum == 1 && thres_activate == 0){ + lum_thres = 5.0; +} /*fast calculation, if gendgp_profile is used: No Vertical illuminance calculation, only dgp is calculated*/ if (output == 1 && ext_vill == 1 ) { @@ -1880,7 +2008,7 @@ if (masking ==1 && zones >0) { if (masking == 1) { - if (!pict_get_xsize(p)==pict_get_xsize(pm) || !pict_get_ysize(p)==pict_get_ysize(pm)) { + if (pict_get_xsize(p)!=pict_get_xsize(pm) || pict_get_ysize(p)!=pict_get_ysize(pm)) { fprintf(stderr, "error: masking image has other resolution than main image ! \n"); fprintf(stderr, "size must be identical \n"); printf("resolution main image : %dx%d\n",pict_get_xsize(p),pict_get_ysize(p)); @@ -1915,7 +2043,8 @@ if (masking ==1 && zones >0) { } } - + + /* Check task position */ if (task_lum == 1) { @@ -1939,7 +2068,9 @@ if (masking ==1 && zones >0) { pict_get_z1_gsn(p,igs) = 0; pict_get_z2_gsn(p,igs) = 0; +if (multi_image_mode<1) { + /* cut out GUTH field of view and exit without glare evaluation */ if (cut_view==2) { if (cut_view_type==1) { @@ -2108,8 +2239,7 @@ if (cut_view==2) { lum_pos_mean= lum_pos_mean/sang; lum_pos2_mean= lum_pos2_mean/sang; - // XXX: sure this works? I'd suggest parenthesis. - if ((set_lum_max2 >= 1 && E_v_contr > 0 && (E_vl_ext - E_v) > 0) || set_lum_max2==3) { + if ((set_lum_max2 >= 1 && E_v_contr > 0 && (E_vl_ext - E_v) > 0 ) || set_lum_max2==3) { if (set_lum_max2<3){ lum_ideal = (E_vl_ext - E_v + E_v_contr) / omega_cos_contr; @@ -2229,7 +2359,8 @@ if (cut_view==1) { /* first glare source scan: find primary glare sources */ for (x = 0; x < pict_get_xsize(p); x++) { -/* lastpixelwas_gs=0; */ + lastpixelwas_gs=0; +/* lastpixelwas_peak=0; */ for (y = 0; y < pict_get_ysize(p); y++) { if (pict_get_hangle(p, x, y, p->view.vdir, p->view.vup, &ang)) { if (pict_is_validpixel(p, x, y)) { @@ -2239,11 +2370,11 @@ if (cut_view==1) { lum_total_max=act_lum; } /* speed improvement first scan: when last pixel was glare source, then use this glare source number instead of searching. - has been deactivated with v1.25 + has been deactivated with v1.25, reactivated with v2.10 */ - if (lastpixelwas_gs==0 || search_pix <= 1.0 ) { */ + if (lastpixelwas_gs==0 || search_pix <= 1.0 ) { actual_igs = find_near_pgs(p, x, y, max_angle, 0, igs, 1); -/* }*/ + } if (actual_igs == 0) { igs = igs + 1; pict_new_gli(p); @@ -2259,11 +2390,11 @@ if (cut_view==1) { pict_get_gsn(p, x, y) = actual_igs; pict_get_pgs(p, x, y) = 1; add_pixel_to_gs(p, x, y, actual_igs); -/* lastpixelwas_gs=actual_igs; */ + lastpixelwas_gs=actual_igs; } else { pict_get_pgs(p, x, y) = 0; - /* lastpixelwas_gs=0;*/ + lastpixelwas_gs=0; } } } @@ -2358,6 +2489,7 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 /* extract extremes from glare sources to extra glare source */ if (splithigh == 1 && lum_total_max>limit) { +/* fprintf(stderr, " split of glare source!\n"); */ r_split = max_angle / 2.0; for (i = 0; i <= i_max; i++) { @@ -2540,6 +2672,11 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 lum_backg = lum_backg_cos; } + if (non_cos_lb == 2) { + lum_backg = E_v / 3.1415927; + } + + /* file writing NOT here if (checkfile == 1) { pict_write(p, file_out); @@ -2591,12 +2728,21 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 muc_rvar_get_median(s_mask,lum_mask_median); muc_rvar_get_bounding_box(s_mask,bbox); /* PSGV only why masking of window is applied! */ - pgsv = get_pgsv(E_v, E_v_mask, omega_mask, lum_mask_av); + + + if (task_lum == 0 || lum_task == 0.0 ) { + fprintf(stderr, " warning: Task area not set or task luminance=0 ! pgsv cannot be calculated (set to -99)!!\n"); + pgsv = -99; + } else { + pgsv = get_pgsv(E_v, E_v_mask, omega_mask, lum_mask_av,lum_task,avlum); + } + + pgsv_con = get_pgsv_con(E_v, E_v_mask, omega_mask, lum_mask_av,avlum); pgsv_sat =get_pgsv_sat(E_v); if (detail_out == 1) { - printf ("masking:no_pixels,omega,av_lum,median_lum,std_lum,perc_75,perc_95,lum_min,lum_max,pgsv,pgsv_sat: %i %f %f %f %f %f %f %f %f %f %f\n",i_mask,omega_mask,lum_mask_av,lum_mask_median[0],sqrt(lum_mask_std[0]),per_75_mask,per_95_mask,bbox[0],bbox[1],pgsv,pgsv_sat ); + printf ("masking:no_pixels,omega,av_lum,median_lum,std_lum,perc_75,perc_95,lum_min,lum_max,pgsv_con,pgsv_sat,pgsv,Ev_mask: %i %f %f %f %f %f %f %f %f %f %f %f %f\n",i_mask,omega_mask,lum_mask_av,lum_mask_median[0],sqrt(lum_mask_std[0]),per_75_mask,per_95_mask,bbox[0],bbox[1],pgsv_con,pgsv_sat,pgsv,E_v_mask ); } @@ -2624,6 +2770,8 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 muc_rvar_add_sample(s_z1, lum_z1); omega_z1 += pict_get_omega(p, x, y); lum_z1_av += pict_get_omega(p, x, y)* lum_actual; + Ez1 += DOT(p->view.vdir, pict_get_cached_dir(p, x, y))* pict_get_omega(p, x, y)* lum_actual; + setglcolor(p,x,y,1,1 , 0.66, 0.01 ,0.33); /*check if separation gsn already exist */ @@ -2640,6 +2788,12 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 splitgs=(int)(pict_get_z1_gsn(p,act_gsn)); /* printf("splitgs%i \n",splitgs); */ split_pixel_from_gs(p, x, y, splitgs, uniform_gs, u_r, u_g , u_b); + /* move direct illuminance contribution into zone -value */ + delta_E=DOT(p->view.vdir, pict_get_cached_dir(p, x, y))* pict_get_omega(p, x, y)* luminance(pict_get_color(p, x, y)); + pict_get_Eglare(p,act_gsn ) = pict_get_Eglare(p,act_gsn ) - delta_E; + pict_get_Eglare(p,igs ) = pict_get_Eglare(p,igs ) + delta_E; + + } } /*zone2 */ @@ -2651,6 +2805,7 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 muc_rvar_add_sample(s_z2, lum_z2); omega_z2 += pict_get_omega(p, x, y); lum_z2_av += pict_get_omega(p, x, y)* lum_actual; + Ez2 += DOT(p->view.vdir, pict_get_cached_dir(p, x, y))* pict_get_omega(p, x, y)* lum_actual; setglcolor(p,x,y,1,1 , 0.65, 0.33 ,0.02); /* printf("zone 2 x y act_gsn pict_get_z1_gsn(p,act_gsn) pict_get_z2_gsn(p,act_gsn): %i %i %f 1:%f 2:%f \n",x,y,act_gsn,pict_get_z1_gsn(p,act_gsn),pict_get_z2_gsn(p,act_gsn)); */ if (act_gsn > 0){ @@ -2665,6 +2820,11 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 splitgs=(int)(pict_get_z2_gsn(p,act_gsn)); /* printf("splitgs %i \n",splitgs);*/ split_pixel_from_gs(p, x, y, splitgs, uniform_gs, u_r, u_g , u_b); + /* move direct illuminance contribution into zone -value */ + delta_E=DOT(p->view.vdir, pict_get_cached_dir(p, x, y))* pict_get_omega(p, x, y)* luminance(pict_get_color(p, x, y)); + pict_get_Eglare(p,act_gsn ) = pict_get_Eglare(p,act_gsn ) - delta_E; + pict_get_Eglare(p,igs ) = pict_get_Eglare(p,igs ) + delta_E; + } } @@ -2691,11 +2851,11 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 muc_rvar_get_bounding_box(s_z1,bbox_z1); if (detail_out == 1) { - printf ("zoning:z1_omega,z1_av_lum,z1_median_lum,z1_std_lum,z1_perc_75,z1_perc_95,z1_lum_min,z1_lum_max: %f %f %f %f %f %f %f %f\n",omega_z1,lum_z1_av,lum_z1_median[0],sqrt(lum_z1_std[0]),per_75_z1,per_95_z1,bbox_z1[0],bbox_z1[1] ); + printf ("zoning:z1_omega,z1_av_lum,z1_median_lum,z1_std_lum,z1_perc_75,z1_perc_95,z1_lum_min,z1_lum_max,Ez1: %f %f %f %f %f %f %f %f %f\n",omega_z1,lum_z1_av,lum_z1_median[0],sqrt(lum_z1_std[0]),per_75_z1,per_95_z1,bbox_z1[0],bbox_z1[1],Ez1 ); if (zones == 2 ) { - printf ("zoning:z2_omega,z2_av_lum,z2_median_lum,z2_std_lum,z2_perc_75,z2_perc_95,z2_lum_min,z2_lum_max: %f %f %f %f %f %f %f %f\n",omega_z2,lum_z2_av,lum_z2_median[0],sqrt(lum_z2_std[0]),per_75_z2,per_95_z2,bbox_z2[0],bbox_z2[1] ); + printf ("zoning:z2_omega,z2_av_lum,z2_median_lum,z2_std_lum,z2_perc_75,z2_perc_95,z2_lum_min,z2_lum_max,Ez1: %f %f %f %f %f %f %f %f %f\n",omega_z2,lum_z2_av,lum_z2_median[0],sqrt(lum_z2_std[0]),per_75_z2,per_95_z2,bbox_z2[0],bbox_z2[1],Ez2 ); } } } @@ -2708,9 +2868,9 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 } } no_glaresources=i; - +/*printf("%i",no_glaresources );*/ /* glare sources */ - if (detail_out == 1) { + if (detail_out == 1 && output != 3) { printf ("%i No pixels x-pos y-pos L_s Omega_s Posindx L_b L_t E_vert Edir Max_Lum Sigma xdir ydir zdir Eglare_cie Lveil_cie teta glare_zone\n", @@ -2756,8 +2916,8 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 } } +if ( output != 3) { - /* calculation of indicees */ /* check vertical illuminance range */ @@ -2770,10 +2930,11 @@ if (calcfast ==1 || search_pix <= 1.0 || calcfast == 2 dgp = get_dgp(p, E_v2, igs, a1, a2, a3, a4, a5, c1, c2, c3, posindex_2); /* low light correction */ + if (lowlight ==1) { if (E_v < 1000) { low_light_corr=1.0*exp(0.024*E_v-4)/(1+exp(0.024*E_v-4));} else {low_light_corr=1.0 ;} dgp =low_light_corr*dgp; - + } /* age correction */ if (age_corr == 1) { @@ -2886,8 +3047,274 @@ if (calcfast == 0) { printf("%f\n", dgp); } } +} +}else{ +/* only multiimagemode */ + + for (j = 0; j < num_images; j++) { + + +/* loop over temporal images */ + +pict_read(pcoeff,temp_image_name[j] ); + +/*printf ("num_img:%i x-size:%i xpos:%i y-size: %i ypos %i bigimg-xsize %i %i ",num_images,pict_get_xsize(pcoeff),x_temp_img[j],pict_get_ysize(pcoeff),y_temp_img[j],pict_get_xsize(p),pict_get_ysize(p)); +*/ + +/* copy luminance value into big image and remove glare sources*/ + for (x = 0; x < pict_get_xsize(pcoeff); x++) { + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x-1; + ymap=y_temp_img[j]+y-1; + if (xmap <0) { xmap=0;} + if (ymap <0) { ymap=0;} + + pict_get_color(p, xmap, ymap)[RED] = pict_get_color(pcoeff, x, y)[RED]; + pict_get_color(p, xmap, ymap)[GRN] = pict_get_color(pcoeff, x, y)[GRN]; + pict_get_color(p, xmap, ymap)[BLU] = pict_get_color(pcoeff, x, y)[BLU]; + pict_get_gsn(p, xmap, ymap) = 0; + pict_get_pgs(p, xmap, ymap) = 0; +}} + +actual_igs =0; + +/* first glare source scan: find primary glare sources */ + for (x = 0; x < pict_get_xsize(pcoeff); x++) { + lastpixelwas_gs=0; +/* lastpixelwas_peak=0; */ + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x; + ymap=y_temp_img[j]+y; + if (pict_get_hangle(p, xmap, ymap, p->view.vdir, p->view.vup, &ang)) { + if (pict_is_validpixel(p, xmap, ymap)) { + act_lum = luminance(pict_get_color(p, xmap, ymap)); + if (act_lum > lum_source) { + if (act_lum >lum_total_max) { + lum_total_max=act_lum; + } + + if (lastpixelwas_gs==0 || search_pix <= 1.0 ) { + actual_igs = find_near_pgs(p, xmap, ymap, max_angle, 0, igs, 1); + } + if (actual_igs == 0) { + igs = igs + 1; + pict_new_gli(p); + pict_get_Eglare(p,igs) = 0.0; +/* not necessary here pict_get_lum_min(p, igs) = HUGE_VAL; + pict_get_Eglare(p,igs) = 0.0; + pict_get_Dglare(p,igs) = 0.0; + pict_get_z1_gsn(p,igs) = 0; + pict_get_z2_gsn(p,igs) = 0; */ + actual_igs = igs; + + } + pict_get_gsn(p, xmap, ymap) = actual_igs; + pict_get_pgs(p, xmap, ymap) = 1; + add_pixel_to_gs(p, xmap, ymap, actual_igs); + lastpixelwas_gs=actual_igs; + + + + delta_E=DOT(p->view.vdir, pict_get_cached_dir(p, xmap, ymap))* pict_get_omega(p, xmap, ymap)* luminance(pict_get_color(p, xmap, ymap)); + pict_get_Eglare(p,actual_igs ) = pict_get_Eglare(p,actual_igs ) + delta_E; + + + + + } else { + pict_get_pgs(p, xmap, ymap) = 0; + lastpixelwas_gs=0; + } + } + } + } + } + + +/* here should be peak extraction */ +i_max=igs; + r_split = max_angle / 2.0; + for (i = 0; i <= i_max; i++) { + + if (pict_get_npix(p, i) > 0) { + l_max = pict_get_lum_max(p, i); + i_splitstart = igs + 1; + if (l_max >= limit) { + for (x = 0; x < pict_get_xsize(pcoeff); x++) + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x; + ymap=y_temp_img[j]+y; + + + if (pict_get_hangle + (p, xmap, ymap, p->view.vdir, p->view.vup, &ang)) + { + if (pict_is_validpixel(p, xmap, ymap) + && luminance(pict_get_color(p, xmap, ymap)) + >= limit + && pict_get_gsn(p, xmap, ymap) == i) { + if (i_splitstart == (igs + 1)) { + igs = igs + 1; + pict_new_gli(p); + pict_get_z1_gsn(p,igs) = 0; + pict_get_z2_gsn(p,igs) = 0; + + pict_get_Eglare(p,igs) = 0.0; + pict_get_Dglare(p,igs) = 0.0; + pict_get_lum_min(p, igs) = + 99999999999999.999; + i_split = igs; + } else { + i_split = + find_split(p, xmap, ymap, r_split, + i_splitstart, igs); + } + if (i_split == 0) { + igs = igs + 1; + pict_new_gli(p); + pict_get_z1_gsn(p,igs) = 0; + pict_get_z2_gsn(p,igs) = 0; + + pict_get_Eglare(p,igs) = 0.0; + pict_get_Dglare(p,igs) = 0.0; + pict_get_lum_min(p, igs) = + 99999999999999.999; + i_split = igs; + } + split_pixel_from_gs(p, xmap, ymap, i_split, uniform_gs, u_r, u_g , u_b); + + } + } + } + + } + change = 1; + while (change == 1) { + change = 0; + for (x = 0; x < pict_get_xsize(pcoeff); x++) + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x; + ymap=y_temp_img[j]+y; + before_igs = pict_get_gsn(p, xmap, ymap); + if (before_igs >= i_splitstart) { + if (pict_get_hangle + (p, xmap, ymap, p->view.vdir, p->view.vup, + &ang)) { + if (pict_is_validpixel(p, xmap, ymap) + && before_igs > 0) { + actual_igs = + find_near_pgs(p, xmap, ymap, + max_angle, + before_igs, igs, + i_splitstart); + if (!(actual_igs == before_igs)) { + change = 1; + } + if (before_igs > 0) { + actual_igs = + pict_get_gsn(p, xmap, ymap); + /* icol = + setglcolor(p, x, y, + actual_igs, uniform_gs, u_r, u_g , u_b);*/ + } + + } + } + } + + } + } + + + } + } + +/* end peak extraction */ + + +/* calculation of direct vertical illuminance for th multi-image-mode */ + + + for (x = 0; x < pict_get_xsize(pcoeff); x++) + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x; + ymap=y_temp_img[j]+y; + if (pict_get_hangle(p, xmap, ymap, p->view.vdir, p->view.vup, &ang)) { + if (pict_is_validpixel(p, xmap, ymap)) { + if (pict_get_gsn(p, xmap, ymap) > 0) { + actual_igs = pict_get_gsn(p, xmap, ymap); + delta_E=DOT(p->view.vdir, pict_get_cached_dir(p, xmap, ymap))* pict_get_omega(p, xmap, ymap)* luminance(pict_get_color(p, xmap, ymap)); + pict_get_Eglare(p,actual_igs ) = pict_get_Eglare(p,actual_igs ) + delta_E; + } + } + } + } + + + + + + + + + i = 0; + for (x = 0; x <= igs; x++) { + if (pict_get_npix(p, x) > 0) { + i = i + 1; + }} +no_glaresources=i; + +/* + +sprintf(file_out, "%s%i%s","ray2/img_",j,".hdr"); +pict_write(p, file_out); +*/ +printf("%i ",no_glaresources); + i = 0; + for (x = 0; x <= igs; x++) { + if (pict_get_npix(p, x) > 0) { + i = i + 1; + pict_get_sigma(p, pict_get_av_posx(p, x), pict_get_av_posy(p, x), p->view.vdir, p->view.vup, &sigma); + + x2=pict_get_av_posx(p, x); + y2=pict_get_av_posy(p, x); + printf("%f %.10f %f %f %f %f %f ", pict_get_av_lum(p, x), pict_get_av_omega(p, x), get_posindex(p, pict_get_av_posx(p, x), pict_get_av_posy(p, x), + posindex_2),pict_get_cached_dir(p, x2,y2)[0],pict_get_cached_dir(p, x2,y2)[1],pict_get_cached_dir(p, x2,y2)[2],pict_get_Eglare(p,x) ); + } +pict_get_npix(p, x)=0; +pict_get_av_lum(p, x)=0; +pict_get_av_posy(p, x)=0; +pict_get_av_posx(p, x)=0; +pict_get_av_omega(p, x)=0; + } +printf("\n"); + + +/* empty big image and remove glare sources*/ + for (x = 0; x < pict_get_xsize(pcoeff); x++) { + for (y = 0; y < pict_get_ysize(pcoeff); y++) { + xmap=x_temp_img[j]+x; + ymap=y_temp_img[j]+y; + pict_get_color(p, xmap, ymap)[RED] = 0; + pict_get_color(p, xmap, ymap)[GRN] = 0; + pict_get_color(p, xmap, ymap)[BLU] = 0; + pict_get_gsn(p, xmap, ymap) = 0; + pict_get_pgs(p, xmap, ymap) = 0; +}} +igs=0; + + + + + +} + +} + +/* end multi-image-mode */ + /*printf("lowlight=%f\n", low_light_corr); */ @@ -2921,33 +3348,15 @@ has to be re-written from scratch.... } - pict_free(p); - pict_free(pm); - muc_rvar_free(s_mask); - muc_rvar_free(s_band); - muc_rvar_free(s_z1); - muc_rvar_free(s_z2); - muc_rvar_free(s_noposweight); - muc_rvar_free(s_posweight); - muc_rvar_free(s_posweight2); - free(cline); + return EXIT_SUCCESS; + exit(0); userr: fprintf(stderr, "Usage: %s [-s][-d][-c picture][-t xpos ypos angle] [-T xpos ypos angle] [-b fact] [-r angle] [-y] [-Y lum] [-i Ev] [-I Ev ymax ymin] [-v] picfile\n", progname); - pict_free(p); - pict_free(pm); - muc_rvar_free(s_mask); - muc_rvar_free(s_band); - muc_rvar_free(s_z1); - muc_rvar_free(s_z2); - muc_rvar_free(s_noposweight); - muc_rvar_free(s_posweight); - muc_rvar_free(s_posweight2); - free(cline); - return 1; + exit(1); }
