root/radiance/ray/src/util/eplus_idf.h
Revision: 2.2
Committed: Sat Feb 1 02:13:24 2014 UTC (11 years, 3 months ago) by greg
Made sure parameter names are case-insensitive in lookups
1 /* RCSid $Id: eplus_idf.h,v 2.1 2014/02/01 01:28:43 greg Exp $ */
2 /*
3 * eplus_idf.h
4 *
5 * EnergyPlus Input Data File i/o declarations
6 *
7 * Created by Greg Ward on 1/31/14.
8 */
9
10 #ifndef _RAD_EPLUS_IDF_H_
11 #define _RAD_EPLUS_IDF_H_
12
13 #include "lookup.h"
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 #define IDF_MAXLINE 512 /* maximum line length */
20 #define IDF_MAXARGL 104 /* maximum argument length */
21
22 /* Input Data File parameter argument list */
23 typedef struct s_idf_field {
24 struct s_idf_field *next; /* next in parameter list */
25 char *rem; /* string following argument */
26 char arg[2]; /* argument (extends struct) */
27 } IDF_FIELD;
28
29 /* Input Data File parameter */
30 typedef struct s_idf_parameter {
31 const char *pname; /* parameter name (type) */
32 struct s_idf_parameter *pnext; /* next parameter same type */
33 struct s_idf_parameter *dnext; /* next parameter in IDF */
34 IDF_FIELD *flist; /* field list */
35 char rem[1]; /* comment (extends struct) */
36 } IDF_PARAMETER;
37
38 /* Input Data File w/ dictionary */
39 typedef struct {
40 char *hrem; /* header remarks */
41 IDF_PARAMETER *pfirst; /* first parameter in file */
42 IDF_PARAMETER *plast; /* last parameter loaded */
43 LUTAB ptab; /* parameter table */
44 } IDF_LOADED;
45
46 /* Create a new parameter with empty field list (comment optional) */
47 extern IDF_PARAMETER *idf_newparam(IDF_LOADED *idf, const char *pname,
48 const char *comm,
49 IDF_PARAMETER *prev);
50
51 /* Add a field to the given parameter and follow with the given text */
52 extern int idf_addfield(IDF_PARAMETER *param, const char *fval,
53 const char *comm);
54
55 /* Delete the specified parameter from our IDF */
56 extern int idf_delparam(IDF_LOADED *idf, IDF_PARAMETER *param);
57
58 /* Get a named parameter list */
59 extern IDF_PARAMETER *idf_getparam(IDF_LOADED *idf, const char *pname);
60
61 /* Read a parameter and fields from an open file and add to end of list */
62 extern IDF_PARAMETER *idf_readparam(IDF_LOADED *idf, FILE *fp);
63
64 /* Initialize an IDF struct */
65 extern IDF_LOADED *idf_create(const char *hdrcomm);
66
67 /* Load an Input Data File */
68 extern IDF_LOADED *idf_load(const char *fname);
69
70 /* Write a parameter and fields to an open file */
71 int idf_writeparam(IDF_PARAMETER *param, FILE *fp);
72
73 /* Write out an Input Data File */
74 extern int idf_write(IDF_LOADED *idf, const char *fname);
75
76 /* Free a loaded IDF */
77 extern void idf_free(IDF_LOADED *idf);
78
79 #ifdef __cplusplus
80 }
81 #endif
82 #endif /* ! _RAD_EPLUS_IDF_H_ */
