--- ray/src/util/eplus_idf.h 2014/02/01 02:13:24 2.2 +++ ray/src/util/eplus_idf.h 2014/02/09 05:49:21 2.4 @@ -1,4 +1,4 @@ -/* RCSid $Id: eplus_idf.h,v 2.2 2014/02/01 02:13:24 greg Exp $ */ +/* RCSid $Id: eplus_idf.h,v 2.4 2014/02/09 05:49:21 greg Exp $ */ /* * eplus_idf.h * @@ -40,21 +40,27 @@ typedef struct { char *hrem; /* header remarks */ IDF_PARAMETER *pfirst; /* first parameter in file */ IDF_PARAMETER *plast; /* last parameter loaded */ - LUTAB ptab; /* parameter table */ + LUTAB ptab; /* parameter hash table */ } IDF_LOADED; -/* Create a new parameter with empty field list (comment optional) */ +/* Create a new parameter with empty field list (comment & prev optional) */ extern IDF_PARAMETER *idf_newparam(IDF_LOADED *idf, const char *pname, - const char *comm, - IDF_PARAMETER *prev); + const char *comm, IDF_PARAMETER *prev); /* Add a field to the given parameter and follow with the given text */ extern int idf_addfield(IDF_PARAMETER *param, const char *fval, const char *comm); -/* Delete the specified parameter from our IDF */ +/* Retrieve the indexed field from parameter (first field index is 1) */ +extern IDF_FIELD *idf_getfield(IDF_PARAMETER *param, int fn); + +/* Delete the specified parameter from the IDF */ extern int idf_delparam(IDF_LOADED *idf, IDF_PARAMETER *param); +/* Move the specified parameter to the given position in the IDF */ +extern int idf_movparam(IDF_LOADED *idf, IDF_PARAMETER *param, + IDF_PARAMETER *prev); + /* Get a named parameter list */ extern IDF_PARAMETER *idf_getparam(IDF_LOADED *idf, const char *pname); @@ -64,14 +70,19 @@ extern IDF_PARAMETER *idf_readparam(IDF_LOADED *idf, F /* Initialize an IDF struct */ extern IDF_LOADED *idf_create(const char *hdrcomm); +/* Add comment(s) to header */ +extern int idf_add2hdr(IDF_LOADED *idf, const char *hdrcomm); + /* Load an Input Data File */ extern IDF_LOADED *idf_load(const char *fname); /* Write a parameter and fields to an open file */ -int idf_writeparam(IDF_PARAMETER *param, FILE *fp); +int idf_writeparam(IDF_PARAMETER *param, FILE *fp, + int incl_comm); /* Write out an Input Data File */ -extern int idf_write(IDF_LOADED *idf, const char *fname); +extern int idf_write(IDF_LOADED *idf, const char *fname, + int incl_comm); /* Free a loaded IDF */ extern void idf_free(IDF_LOADED *idf);
