root/radiance/ray/src/util/eplus_idf.h
Revision: 2.6
Committed: Mon Feb 10 04:51:26 2014 UTC (10 years, 3 months ago) by greg
Complete but untested implmentation of eplus_adduvf
1 /* RCSid $Id: eplus_idf.h,v 2.5 2014/02/09 22:19:30 greg Exp $ */
2 /*
3 * eplus_idf.h
4 *
5 * EnergyPlus Input Data File i/o declarations
6 *
7 * Created by Greg Ward on 1/31/14.
8 */
9
10 #ifndef _RAD_EPLUS_IDF_H_
11 #define _RAD_EPLUS_IDF_H_
12
13 #include "lookup.h"
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 #define IDF_MAXLINE 512 /* maximum line length */
20 #define IDF_MAXARGL 104 /* maximum argument length */
21
22 /* Input Data File parameter argument list */
23 typedef struct s_idf_field {
24 struct s_idf_field *next; /* next in parameter list */
25 char *rem; /* string following argument */
26 char val[2]; /* value (extends struct) */
27 } IDF_FIELD;
28
29 /* Input Data File parameter */
30 typedef struct s_idf_parameter {
31 const char *pname; /* parameter name (type) */
32 struct s_idf_parameter *pnext; /* next parameter same type */
33 struct s_idf_parameter *dnext; /* next parameter in IDF */
34 int nfield; /* field count */
35 IDF_FIELD *flist; /* field list */
36 char rem[1]; /* comment (extends struct) */
37 } IDF_PARAMETER;
38
39 /* Input Data File w/ dictionary */
40 typedef struct {
41 char *hrem; /* header remarks */
42 IDF_PARAMETER *pfirst; /* first parameter in file */
43 IDF_PARAMETER *plast; /* last parameter loaded */
44 LUTAB ptab; /* parameter hash table */
45 } IDF_LOADED;
46
47 /* Create a new parameter with empty field list (comment & prev optional) */
48 extern IDF_PARAMETER *idf_newparam(IDF_LOADED *idf, const char *pname,
49 const char *comm, IDF_PARAMETER *prev);
50
51 /* Add a field to the given parameter and follow with the given text */
52 extern int idf_addfield(IDF_PARAMETER *param, const char *fval,
53 const char *comm);
54
55 /* Retrieve the indexed field from parameter (first field index is 1) */
56 extern IDF_FIELD *idf_getfield(IDF_PARAMETER *param, int fn);
57
58 /* Delete the specified parameter from the IDF */
59 extern int idf_delparam(IDF_LOADED *idf, IDF_PARAMETER *param);
60
61 /* Move the specified parameter to the given position in the IDF */
62 extern int idf_movparam(IDF_LOADED *idf, IDF_PARAMETER *param,
63 IDF_PARAMETER *prev);
64
65 /* Get a named parameter list */
66 extern IDF_PARAMETER *idf_getparam(IDF_LOADED *idf, const char *pname);
67
68 /* Read a parameter and fields from an open file and add to end of list */
69 extern IDF_PARAMETER *idf_readparam(IDF_LOADED *idf, FILE *fp);
70
71 /* Initialize an IDF struct */
72 extern IDF_LOADED *idf_create(const char *hdrcomm);
73
74 /* Add comment(s) to header */
75 extern int idf_add2hdr(IDF_LOADED *idf, const char *hdrcomm);
76
77 /* Load an Input Data File */
78 extern IDF_LOADED *idf_load(const char *fname);
79
80 /* Write a parameter and fields to an open file */
81 int idf_writeparam(IDF_PARAMETER *param, FILE *fp,
82 int incl_comm);
83
84 /* Write out an Input Data File */
85 extern int idf_write(IDF_LOADED *idf, const char *fname,
86 int incl_comm);
87
88 /* Free a loaded IDF */
89 extern void idf_free(IDF_LOADED *idf);
90
91 #ifdef __cplusplus
92 }
93 #endif
94 #endif /* ! _RAD_EPLUS_IDF_H_ */
